Baton Rouge, LA - HDTV - Page 19 - AVS Forum | Home Theater Discussions And Reviews
post #541 of 3018 Old 01-27-2006, 06:50 AM
digiblur's Avatar
Quoted: 18 Post(s)
Originally Posted by ronismonis View Post
I have a Samsung HL-R5067W. I rescanned for channels and now have picked up the local CBS, ABC, PBS, & NBC channels. I guess it does have a built in digital tuner however it still doesnt get FOX (whihc should be 44-1, right?)
WGMB is on channel 99-15 or 99.15, depending on the set. See if you can manually type it in. I just checked the QAM TS and sure enough the PSIP is missing, the PSIP is NOT missing via OTA. Also WBRL HD is also on channel 98-18 or 98.18.
Where do you live? If you still can't get Fox via QAM you can probably pick them up OTA via a cheap antenna due to their smokin' signal.
digiblur is offline
post #542 of 3018 Old 02-04-2006, 03:30 PM
Ben Hardy's Avatar
Quoted: 14 Post(s)
Liked: 25
Hi,
I live in Metairie, about 2 miles south of MSY. I've always had a "rock steady" signal from WBRZ with my CM 4228. Today, just to insure that I won't loose the Super Bowl tomorrow (with a gang of folks coming over), I added the CM 7775 UHF amp. We raised the antenna back up (about 30 ft. from the ground). 33.1, 44.1 and 27.1 are clear and steady, but WBRZ is GONE! Now I'm aware that 13.1 is VHF, but could this UHF amp be that discriminating? Is there any problem with WBRZ today?
Any help will be deeply appreciated,
Ben
Ben Hardy is offline
post #543 of 3018 Old 02-04-2006, 08:41 PM
Professor Bobo's Avatar
Ben,
No problem with WBRZ that I can see. Twice I've seen the CM 7775 block WBRZ. I had the same thing happen to me when I tried the 7775 with my 4228. Once I switched to the 7777 WBRZ became my strongest signal.
Hope this helps.
Is this working? Testing? Hello? Can they really read my words? Hello?
Professor Bobo is offline
post #544 of 3018 Old 02-05-2006, 09:01 AM
Ben Hardy's Avatar
Quoted: 14 Post(s)
Liked: 25
Sunday 9:55 AM
Professor,
Thank you so much! I removed the CM 7775, and once again we're receiving WBRZ in all it's soon-to-be SUPER BOWL glory!
You kind reply really saved my Super Bowl Party. Next time you're in New Orleans, I owe you dinner.
Ben
post #545 of 3018 Old 02-05-2006, 11:48 AM
digiblur's Avatar
Quoted: 18 Post(s)
13 is actually a VHF channel. I bet that UHF amp was blocking the VHF band.
digiblur is offline
post #546 of 3018 Old 02-05-2006, 01:04 PM
ronismonis's Avatar
2 days ago i lost wbrz! im using a set with a builtin digital tuner so i dont have an antenna, but any advice as to why i lost the signal i still have all my other HD channels working alright just WBRZ gone which is obviously the most important as its Super bowl Sunday! thanks
ronismonis is offline
post #547 of 3018 Old 02-05-2006, 03:27 PM
ronismonis's Avatar
helppp.. not wanting to spam here i just wanna watch the super bowl in HD!! Ideas as to why i lost WBRZ? ive got a HD DLP 50" samsung with COX basic cable and im picking up 4 other HD channels. just lost WBRZ and the ABC station (2-1 and 9-1) the other day. been tryin to get em back. Thanks
post #548 of 3018 Old 02-05-2006, 10:28 PM
digiblur's Avatar
Quoted: 18 Post(s)
If I remember right they are in the 100's and 101's when they aren't mapping correctly.
digiblur is offline
post #549 of 3018 Old 02-07-2006, 06:48 PM
raouliii's Avatar
As of yesterday, I'm receiving a main and two subchannels of OTA WGMB-DT. 44.1 (WGMB-DT), 44.2 (WBRL-TV) and now 27.5 (East). The subchannel with the "East" short name has the same content as the main with the short name "WGMB-DT". Anyone else seeing this, or do I maybe have a receiver problem? I have rescanned a number of times with the same result.
BTW, WLPB-DT still shows a main and two subchannels of 27.1, 27.3, and 27.5.
raouliii
Those who would give up essential liberty to purchase a little temporary safety, deserve neither liberty nor safety. - Benjamin Franklin
raouliii is offline
post #550 of 3018 Old 02-08-2006, 09:04 AM
carwashguy's Avatar
raouliii
Im getting a signal of 93% on 44.1 but no video or audio. I'm also receiving two 27-5 one is WGMB-DT and the other is WLPB. I have rescanned many times also. Im guessing their PSIP is messed up again.
carwashguy is offline
post #551 of 3018 Old 02-08-2006, 12:01 PM
phitz's Avatar
Yes, I am getting a 27-5 'east' that shows fox44 programing Also getting 44-1 and 44-2 (fox44 and wb 21)
phitz is offline
post #552 of 3018 Old 02-08-2006, 01:08 PM
carwashguy's Avatar
Can I catch WBXH UPN OTA in Denham Springs? Im tired of watching the JP basketball games, I would rather watch golf. I cant catch WWL any more. I wish they would show it on 9.2 for the 3 hour broadcast instead of news repeats.
post #553 of 3018 Old 02-09-2006, 12:50 PM
carwashguy's Avatar
Does anyone know the current Cox HD lineup and if they have added or plan on adding ESPN2HD? Also has Cox picked up ESPN U and The NFL Network yet?
post #554 of 3018 Old 02-09-2006, 10:57 PM
byrde's Avatar
Cox has not added any of the networks listed. The most recent HD channel is the MHD (MTV). I hope they add NFL Network in HD and ESPN2HD before the start of next football season. I will continue to email them until they do.
byrde is offline
post #555 of 3018 Old 02-12-2006, 01:18 PM
Ben Hardy's Avatar
Quoted: 14 Post(s)
Liked: 25
Originally Posted by Professor Bobo View Post
Ben,
Hope this helps.
Sunday, Feb.12th
I just installed the CM7777 and the signal from WBRZ is solid, just as you described. The only problem I have is my Sammy 165 crashes when I tune to 44.1
The RatShack STB I have in the bedroom, however, receives this channel without incident.
Thanks again for your help.
Ben
post #556 of 3018 Old 02-15-2006, 07:10 PM
digiblur's Avatar
Quoted: 18 Post(s)
Any American Idol fans in the house? We've got plenty in this household! They make sure they are sitting down 10 minutes before each episode!
I think the guys controlling the SD / HD feed switch are having fun toying with 'em during commercials. It seems every commercial the colors drop to a smeared look and the sound drops to 2 channel audio. The entire room lets out an "awwww!!!", then they all perk back up when the show comes back on in 16:9 with 5.1. It's actually kind of entertaining! Except the past 2 or 3 episodes after the last commercial break it stays in SD. You ought to hear the F words echoing in the room and FOX sure isn't one of them. I told them "feed gods" have it in for them because they know they are going to watch the last 5-10 minutes even if it's in SD. I know the show is kinda of boring but someone needs to stop falling asleep at the wheel during the last commercial break.
digiblur is offline
post #557 of 3018 Old 02-16-2006, 11:20 AM
carwashguy's Avatar
I have been noticing that too. They also do that on 24.
post #558 of 3018 Old 02-17-2006, 08:27 AM
j-bo's Avatar
Could it be, that maybe some of the commercials are paying for their ads to be in HD?
I noticed all the Budweiser commercials for the Olympics are in HD. Just a thought.
<<<<<< addicted to the "IDOL" too!
The Truth IS out there!
j-bo is offline
post #559 of 3018 Old 02-17-2006, 12:40 PM
digiblur's Avatar
Quoted: 18 Post(s)
I hope they got their money back because they are changing to SD to show 'em.
digiblur is offline
post #560 of 3018 Old 02-18-2006, 05:09 PM
sbmanuel's Avatar
I recently moved from Lafayette to Houston and FOX26 here is doing the same thing with SD at the end of Idol. It's pretty frustrating. One nice thing about H-Town is all of the DTVs are in the same direction. My HDTVi gets all channels without touching it. Wish it was the same for Lafayette.
sbmanuel is offline
post #561 of 3018 Old 02-21-2006, 08:00 AM
j-bo's Avatar
Did I miss some announcement that PBS was doing work on their antenna? I have and have not had any signal since Saturday.
j-bo is offline
post #562 of 3018 Old 02-21-2006, 06:05 PM
jbradj's Avatar
I am not receiving any video or audio on the WGMB Fox 44-1 HD station on Directv. Is anyone else having this problem???
jbradj is offline
post #563 of 3018 Old 02-21-2006, 06:39 PM
digiblur's Avatar
Quoted: 18 Post(s)
PBS HD and FOX HD via OTA still cooking loud and clear over here.
digiblur is offline
post #564 of 3018 Old 02-22-2006, 07:34 AM
j-bo's Avatar
Wow..... Hmm... Geeeez....
What to do.... I did a rescan again, and no PBS. I went to the signal meter, and no signal for PBS. But it did pick up 27-5 FOX "EAST".
Strange. Weird. Unbelievable. Whack.
More tinkering this evening.
j-bo is offline
post #565 of 3018 Old 02-22-2006, 11:20 AM
carwashguy's Avatar
when I'm unable to catch 44.1 wgmbdt, it usually pops in at 27.5 east
post #566 of 3018 Old 02-22-2006, 03:16 PM
j-bo's Avatar
I have no problem with FOX at all, nor NBC, nor ABC.
Never ever had a problemo with PBS until last Saturday.
Be goin home soon. Will have to see
j-bo is offline
post #567 of 3018 Old 02-22-2006, 08:24 PM
digiblur's Avatar
Quoted: 18 Post(s)
LPB looks fine but WGMB doesn't
digiblur is offline
post #568 of 3018 Old 02-22-2006, 08:30 PM
jbradj's Avatar
I am getting a 100% signal OTA for 44-1, but no picture or video. I need to get this corrected ASAP for Nascar. Any suggestions out there? Thanks
jbradj is offline
post #569 of 3018 Old 02-22-2006, 09:25 PM
digiblur's Avatar
Quoted: 18 Post(s)
It's being mapped to 27.5. Do you have this one?
digiblur is offline
post #570 of 3018 Old 02-23-2006, 06:47 AM
j-bo's Avatar
Welp.... tinkered and tinkered. Looked and kadoodled. Did hard reboot on my hd stb. No luck for moi. Turned antenna 360degrees, and then a full on triple axle, double toe loop and still nadda.
NO PBS signal for me.
FOX is 100%.
Weird man, just weird.
j-bo is offline
