Minneapolis, MN - OTA - Page 102 - AVS Forum | Home Theater Discussions And Reviews
 31Likes
post #3031 of 3059 Old 01-14-2017, 12:38 PM
Jim1348's Avatar
Quoted: 117 Post(s)
Originally Posted by unclehonkey View Post
by the way Tivo FINALLY has guide listings. It only took 3 weeks from the day I sent in the ticket to Tivo
And mine still shows "Title not available". Do I somehow need to force it to do an update?
Jim1348 is online now
post #3032 of 3059 Old 01-14-2017, 12:42 PM
unclehonkey's Avatar
Quoted: 286 Post(s)
Liked: 60
yeah do a force update. Mine updated this morning (I think it ran around 9:30 this morning). Gave me a message of channel update. Added KBMD-LD7
unclehonkey is online now
post #3033 of 3059 Old 01-14-2017, 12:45 PM
Quoted: 286 Post(s)
Liked: 60
Which brings up some other questions. I am doing what isn't recommended, specifically using an outdoor antenna inside the attic area above my attached garage. With that in mind, do any certain antennas work out better than others inside?
An outdoor antenna inside will give better results than a indoor antenna indoors While its not the best option (you lose up to 50% of signal depending on what type of roof, shingles, etc) for some folks its the only option
I had my outdoor antenna (HBU33 then 2 separate ones) in my walk in closet in my apartment for 3 years.
Since two of our ATSC channels are still VHF, both 9 & 11, I have to be mindful of that.
If it aint broke (as in the reception is fine) why bother monkeying with it? Unless you have some other reason. From someone who like to tinker I found out once I got optimal reception across the board (all the full power stations maxed out and the LP's especially 43 to the best it will be) I left it now.
Also, are any certain amplifiers better than others? I assume that there are some that are better than others, but how do I determine what would be the best choices for me?
I use an old (discontinued) Radio Shack one mainly because of the 2 outputs. I also have used an RCA one available at Fleet Farm, Menards, etc and that has worked well too. It has 2 inputs so if you want you can use separate antennas but will accept a combo (VHF/UHF) fine. One drawback for me? Only one output
http://www.rcaantennas.net/search/?sku=TVPRAMP1R
runs about $25 bucks at FF, Menards, Lowes, WalMart etc
I have seen some antennas that allow them to be pointed in two different directions. I am tempted to try one of the Xtreme Signal HDTV HDB8X antennas.
http://www.solidsignal.com/pview.asp...source=inhouse
not worth it IMO. I have one (well part of one....1/2 got damaged in a storm). Anywho I bought one to try and aim one panel at Mpls and one at St Cloud (for 41) and as soon as you start moving the panels so they are at 2 different directions the signal quality went to pot. Both panels aimed the same way it worked great but trying 2 different markets only works really if they are 25-30 miles away
Also, has anybody here tried combining two antennas? I seem to recall reading that it is tricky. I don't recall what needs to be done to effectively combine the inputs of two different antennas.
yup done that too. When 43 came online and they had power issues I would combine my XG91 clone (from Solid Signal) and my existing HBU33 together. I used a splitter backwards. The cable lengths MUST BE THE EXACT SAME LENGTH or it wont work. It really didnt give me the results I wanted. If I recall the antennas have to be the same model, aimed the same way and be a specific distance apart. Honestly the only reason someone would do that would be if you lived way outside the coverage area or needed the extra oomph to get a signal due to blockage (mountains, etc)
post #3034 of 3059 Old 01-14-2017, 12:51 PM
Quoted: 286 Post(s)
Liked: 60
Oh and yeah I am a hoarder of TV antennas Currently stored in various spots around the apartment
-HBU33 (mounted outside)
-1/2 of the SS 8 bay that you linked to
-Eagle Aspen 2 bay UHF only
-AntennaCraft V5-7-13 VHF only antenna
-part of AntennaCraft V5-7-13 (only has 3 of 5 elements...2 got damaged in storm...or moving...something like that)
-AntennaCraft C490 in the box (12 1/2 foot long VHF Low/Hi/UHF). Got it from Radio Shack when they went out of business....think I paid like $5 for it
-Winegard HBU44 (12 foot VHF HI/UHF)...Got from another Radio Shack same time...paid like $3 for that one
post #3035 of 3059 Old 01-14-2017, 02:50 PM
Jim1348's Avatar
Quoted: 117 Post(s)
With the announcement at CES 2017 of the Mohu Wireless HD antenna, is this something that would interest you? I think that it might be handy for some people to be able to place their antenna somewhere that receives OTA signals well and then send that content to devices around their home. Although this appears to be designed for indoor use, via wifi, I might also be interest in a version designed for outdoor use and also having the ability to connect via Ethernet (CAT 5).
https://www.engadget.com/2017/01/04/...utting-simple/
post #3036 of 3059 Unread 02-02-2017, 10:48 PM
Quoted: 286 Post(s)
Liked: 60
March 1st "Chuck Norris TV" errr Grit is leaving. Being replaced with the new Sinclair/MGM station "Charge!"
http://thecw23.com/features/charge-tv
Charge! is the all-new network television home for action & adventure content from MGM's library. This includes movies such as the Rocky & James Bond franchises.
This channel will be available over-the-air on 23.3 and on Comcast cable channel 211 in St. Paul and channel 253 in Minneapolis as of March 1, 2017
worachj likes this.
post #3037 of 3059 Unread 02-02-2017, 11:13 PM
robrob10's Avatar
Quoted: 36 Post(s)
It also looks like TBD-TV is replacing GET on 23.4 on March 1st. So there will be 2 new diginets on WUCW. So it looks like GRIT and GET will be gone from the Twins Cities OTA market, starting March 1st.
worachj likes this.
robrob10 is online now
post #3038 of 3059 Unread 02-03-2017, 10:42 AM
Quoted: 286 Post(s)
Liked: 60
Personally I would prefer American Sports Network instead of TBD
post #3039 of 3059 Unread 02-03-2017, 06:50 PM
Quoted: 147 Post(s)
Liked: 106
TBD TV seems stupid and shallow... What is it, youtube for people without the Internet? Really???
RTPVid is online now
post #3040 of 3059 Unread 02-03-2017, 09:47 PM
Jim1348's Avatar
Quoted: 117 Post(s)
HDCP In The Minneapolis-Saint Paul DMA
What content is HDCP protected in the Minneapolis Saint Paul DMA?
post #3041 of 3059 Unread 02-03-2017, 10:52 PM
Quoted: 286 Post(s)
Liked: 60
sounds like it
post #3042 of 3059 Unread 02-04-2017, 01:41 AM
jjeff's Avatar
Quoted: 695 Post(s)
Liked: 246
Nothing OTA AFAIK, don't know AFA pay TV as I don't have it.
jjeff is online now
post #3043 of 3059 Unread 02-04-2017, 08:46 AM
Quoted: 286 Post(s)
Liked: 60
depends on the provider...nothing OTA is
post #3044 of 3059 Unread 02-04-2017, 05:15 PM
Jim1348's Avatar
Quoted: 117 Post(s)
That is good to know. The reason I ask is because I am considering another Slingbox. It looks like both the Slingbox 500 and the Slingbox M2 are available. For the life of me, I can't really tell why the Slingbox 500 is $200 more than the Slingbox M2. It doesn't look to me like it really offers much more.
post #3045 of 3059 Unread 02-15-2017, 08:59 PM
Quoted: 286 Post(s)
Liked: 60
looks like 2/28 6AM is when Charge (23-3) and TBD (23-4) arrive in MSP (per zap2it)
post #3046 of 3059 Unread 02-16-2017, 06:42 AM
jjeff's Avatar
Quoted: 695 Post(s)
Liked: 246
Now lets see how long it takes Tivo to update things
jjeff is online now
post #3047 of 3059 Unread 02-17-2017, 10:04 AM
Quoted: 286 Post(s)
Liked: 60
since its just a guide change hopefully WUCW sends the info
edit: zap2it already shows the changeover. Rovi/tvguide does not (but then again they still dont have the Bemidji State hockey games next weekend in the guide yet either)
post #3048 of 3059 Unread 02-17-2017, 05:02 PM
Jim1348's Avatar
Quoted: 117 Post(s)
This could be an Uncle Honkey question, but certainly all are welcome to reply. Knowing what you know now, based on the experience you have in the Minneapolis Saint Paul DMA, what antenna(s) would you buy today? I guess one of the important things is that we are mostly RF UHF channels, plus RF 9 & 11, which are VHF. I am most interested in antennas designed for outside use, but certainly some use external antennas inside. I have one in the attic area above my attached garage.
post #3049 of 3059 Unread 02-17-2017, 05:58 PM
jjeff's Avatar
Quoted: 695 Post(s)
Liked: 246
I have this antenna in my attic and it works well not only on UHF but VHF high.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
jjeff is online now
post #3050 of 3059 Unread 02-18-2017, 03:57 PM
Jon Ellis's Avatar
It's also important to remember that more stations may be moving to VHF as part of the spectrum auction. It won't be publicly announced which stations are moving until April.
Jon Ellis is offline
post #3051 of 3059 Unread 02-18-2017, 09:30 PM
Jim1348's Avatar
Quoted: 117 Post(s)
That is a great point. Thank you for pointing that out. If I recall correctly, VHF High is preferred over VHF Low or it least it was in the past. Also, I seem to recall that adjacent channels were typically not assigned next to one another in the same market, BUT that was NTSC. Now, with ATSC, I think we have some adjacent channels.
post #3052 of 3059 Unread Yesterday, 09:33 AM
Quoted: 286 Post(s)
Liked: 60
As long as the stations tower are within 14 miles of each other you can have adjacent stations assigned.
That is why we have 31(Daystar),32(WCCO),33(3ABN),34(KTCA),35(KSTP) assigned in Mpls. 32,34 and 35 are on the Shoreview towers. 31 & 33 are on the IDS building.
Thats why we have 22 (WUCW) and 23 (KTCI) next to each other too.
Also the only way someone is going to VHF is if they PAID to be moved. If none of the Mpls stations paid to move to VHF we will still have only 2 full powered stations on VHF (9 & 11). Now low powered ones can move if they get displaced.
post #3053 of 3059 Unread Yesterday, 11:14 AM
steve1971's Avatar
Quoted: 499 Post(s)
Liked: 435
Just a heads up for you 4K guy's waiting on Comcast to have 4K channel's. 4K from Comcast has been scratched this year, maybe next year. They had a 4K app on Samsung tv's but due to the very low interest in the app it's been closed. I guess Comcast dont trust the 4K format at this point to go forward with channel's so they are going to wait until next year to see where the tech is at. No big loss for me since I have zero interest in the format anyway. But for those that do and are waiting on Comcast for 4K your gonna have to wait until next year it seem's.
steve1971 is offline
post #3054 of 3059 Unread Yesterday, 03:09 PM
Quoted: 286 Post(s)
Liked: 60
Speaking of 4K I see RCA is in the "gimmick game" again with their antennas.
Was at Fleet Farm and saw new "4K ready" RCA outdoor antennas. Funny thing is the older stock is the identical model yet they dont tout "4K ready"
post #3055 of 3059 Unread Yesterday, 04:21 PM
Jim1348's Avatar
Quoted: 117 Post(s)
Was at Fleet Farm and saw new "4K ready" RCA outdoor antennas. Funny thing is the older stock is the identical model yet they don't tout "4K ready"
I remember some places doing that with the analog to digital transition. They announced "digital antenna"!
post #3056 of 3059 Unread Yesterday, 06:04 PM
Runch Machine's Avatar
Quoted: 28 Post(s)
Directv has a full time 4K channel and a 4K events channel. I'm also a DIRECTV dealer so contact me if you have questions or need pricing. SatNet Direct LLC, Jeff, 612-741-8476.
Runch Machine is offline
post #3057 of 3059 Unread Today, 05:55 PM
Quoted: 286 Post(s)
Liked: 60
yup I remember that. Or saying you need a "HD antenna"
post #3058 of 3059 Unread Today, 07:23 PM
Quoted: 147 Post(s)
Liked: 106
It hasn't gone away: http://www.cleartvkey.com
post #3059 of 3059 Unread Today, 07:24 PM
Quoted: 286 Post(s)
Liked: 60
hmmm wonder what DTVAmerica is going to add next?
Noticed tonight that The Country Network (TCN) moved from KMBD-LD7 (43-7) to KJNK-DT5 (25-5). 25-5 use to be 24/7 paid programs
43-7 is just a black screen but still shows up on a scan.
Both GetTV and Grit do have contracts with DTVAmerica so it is possible that when one of them gets dropped next Monday off WUCW (for Charge! and TBD) it could be picked up. I have no clue but its possible
