Minneapolis, MN - OTA - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 31Likes
Old 08-18-2009, 10:03 AM
koko5000's Avatar
Originally Posted by Trip in VA View Post
So has WFTC moved?
- Trip
the dishpaldvr said that it "automatically added 29-1 and 29-2" this morning. I saw that 29-1 was working and did not dig any further. It looks fine for that channel but i didnt go into settings and verify any change
koko5000 is offline
Old 08-18-2009, 10:29 AM
gjvrieze's Avatar
So has WFTC moved?
- Trip
Ya.
Not great results for me though. 29 seems to be even weaker at my place then 21 was. Which I cannot believe given that the 29 antenna is 150ish feet higher on the KMSP tower then the 21 antenna... I will send you the TSreader output tonight, when it locks again (seems to lock at nights ok, just like DT-21 did)
KD0MOF
All opinions expressed (unless otherwise noted) are the poster's only and NOT that of the poster's employers.
gjvrieze is offline
Old 08-18-2009, 11:02 AM
Trip in VA's Avatar
Quoted: 552 Post(s)
Liked: 147
Send a message via AIM to Trip in VA
Alright, thanks.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
Old 08-18-2009, 12:05 PM
gjvrieze's Avatar
Alright, thanks.
- Trip
I sent in an email to KMSP/WFTC engineering to verify that DT-29 is at a full 1MW. (I cannot imagine that they would have wanted to switch if it could not run 1MW from the get go, but does not hurt to check.)
KD0MOF
gjvrieze is offline
Old 08-18-2009, 12:55 PM
w0en's Avatar
So has WFTC moved?
- Trip
Yes, this morning , they shut down UHF 21 right before midnight and a couple minutes later they were up and running on UHF 29. Signal quality meter on Insignia CECB looks identical at 42 miles south, before and after.
w0en is offline
Old 08-18-2009, 12:58 PM
w0en's Avatar
Originally Posted by gjvrieze View Post
I sent in an email to KMSP/WFTC engineering to verify that DT-29 is at a full 1MW. (I cannot imagine that they would have wanted to switch if it could not run 1MW from the get got, but does not hurt to check.)
I'm wondering about their antenna on 21, IIRC they were using CP on analog, I'll assume that is the antenna they went back to.
w0en is offline
Old 08-18-2009, 01:01 PM
gjvrieze's Avatar
Yes, they were planning to reuse the analog antenna for DT-29. (as I read in their fillings with the FCC)
KD0MOF
gjvrieze is offline
Old 08-19-2009, 08:46 AM
makellogg's Avatar
Thanks for the information - I've sent off a request to KARE to increase their power for those of us in the outstate area. KARE has no translators in our area and we can't receive any other NBC stations (Fargo, Duluth too far away)
makellogg is offline
Old 08-19-2009, 08:15 PM
Jon Ellis's Avatar
KTCI has received the construction permit for channel 23. They'll be upgrading from 50kW on channel 16 to 375kW on channel 23, but that still won't match the 662kW of KTCA on channel 34. It should be larger than their old analog channel 17 signal, though (I think that was 300kW).
Jon Ellis is offline
Old 08-19-2009, 11:12 PM
Doc Sief's Avatar
Location: Eagan, MN, southern suburb of St. Paul, 16mi from TV Towers
The engineers at KTCI/KTCA must just hate me! Last week I had to re-scan our Downstairs RCA DTA800B box as we are no longer able to pick up Ch. 41, and every thing went fine. Today I had promised by kids I would re-scan for Ch 29, and when I did, my RCA box locks up at 20% AGAIN just like the last time they screwed around (this would be real Ch16, Virtual 2.3 & 2.4). Of course I have double rescanned to no avail, other converter boxes have no issue. Something to do with their PSIP. My problem is I am going to have a bunch of family complaining that this is happening again. Hope someone will light a fire in KTCI/KTCA to fix this again
Doc Sief is offline
Old 08-21-2009, 10:22 PM
Doc Sief's Avatar
Originally Posted by Doc Sief View Post
The engineers at KTCA must just hate me! Last week I had to re-scan our Downstairs RCA DTA800B box as we are no longer able to pick up Ch. 41, and every thing went fine. Today I had promised by kids I would re-scan for Ch 29, and when I did, my RCA box locks up at 20% AGAIN just like the last time they screwed around (this would be real Ch16, Virtual 2.3 & 2.4). Of course I have double rescanned to no avail, other converter boxes have no issue. Something to do with their PSIP. My problem is I am going to have a bunch of family complaining that this is happening again. Hope someone will light a fire in KTCA to fix this again
KTCI/KTCA fixed the problem, able to re-scan and pick up 2-3 & 2-4.
Doc Sief is offline
Old 08-22-2009, 07:05 AM
gjvrieze's Avatar
Remember that it is KTCI that runs UpdateTV on two "subs" after 2.3/4 and KTCA (2.1/2) It may not be TPT's fault, but the fault of UpdateTV, maybe they have an update in the system that simply does not work well on your CECB...
KD0MOF
gjvrieze is offline
Old 08-22-2009, 07:33 AM
kedirekin's Avatar
Two subs after 2.3/4? Is that the 2.7 and 2.8 that I see on my TV? I've wondered what those were about and where they came from. They're always black and silent when I tune to them.
kedirekin is offline
Old 08-22-2009, 03:43 PM
gjvrieze's Avatar
More then likely, these are artifacts of UpdateTV. Trip told me a while back, that he has been told that UpdateTV requires 2Mbps of bandwidth, but has yet to see it pushing that down in TSreader data.
KD0MOF
gjvrieze is offline
Old 08-23-2009, 08:51 AM
Anode's Avatar
Quoted: 30 Post(s)
did KMSP(9) and KARE(11) do anything to their signal in the last week or so ? These two channels have just vanished all of a sudden for me. I have rescanned several times. But it just seems like they abruptly reduced power ? or something else might be going on ?
Anode is offline
Old 08-23-2009, 09:07 AM
Jim1348's Avatar
Quoted: 114 Post(s)
What is your ZIP code? What antenna and receivers(s) are you using?
You may want to do the double scan. Disconnect your antenna, scan, re-connect, scan again, and see what you get. That should add the "new" 29s and possibly other stuff depending on how long it has been since you updated.
Jim1348 is offline
Old 08-23-2009, 10:37 AM
Anode's Avatar
Quoted: 30 Post(s)
this is my tvfool - http://www.tvfool.com/?option=com_wr...23c51e4509464d
I am using a CM7000 and rabbit ears converted to dipole sitting on top of the set. The 'dipole' has been trimmed to 12-13"(each side) for optimum performance across all channels. All channels were coming in great. Ch9 and 11 were the weakest but certainly usable, until their disappearing act a few days ago.
Ok, I did the scan like you said and it picked up Ch11(kare) but still no Ch9(kmsp).
Anode is offline
Old 08-23-2009, 05:34 PM
Doc Sief's Avatar
You certainly should be able to pick up KMSP 9 if you can get KARE11! Maybe your dipole needs to be moved slightly, with the polarization that they have been using, moving the dipole a foot or 6inches might make all the difference. Granted the effect is worse with UHF but even VHF has issues. The other possibility could be the appearance of some new electronic noise. In my case, one of my kids fans and my wife's aluminum blinds kill KMSP9. While lightning kills KARE11 (boy I wish they would go to 30kW like KMSP!).
Good luck!
Doc Sief is offline
Old 09-10-2009, 07:17 PM
srtguy's Avatar
You should grab either
Winegard HD-1080 (for indoor) and should get the VHFs with good signal strength.
My HD 1080 is slightly better than a DB2 for UHF, gets ZERO high VHF (FOX 9 and KARE 11) in northern Anoka County (St. Francis) 26 miles from the antennas.
srtguy is offline
Old 09-11-2009, 08:23 AM
gjvrieze's Avatar
Can you post your TV Fool results?
I actually just installed one these a couple weekends ago. It was for an uncle and he was 15miles from our local VHF-HI station, KTTC and it peaked the signal meter. This is an outdoor install about 18ft off the ground.
KD0MOF
gjvrieze is offline
Old 09-11-2009, 09:13 AM
srtguy's Avatar
http://www.tvfool.com/?option=com_wr...8ecd9fdf93bbc4
Indoor install, in a window with no trees in view. Did the double rescan etc. The frustrating thing is, I had all the channels coming in great on the DB2 until June 12 when KARE and KMSP left their temporary UHF for VHF. I am hesitant to buy a preamp because I feel this will only give me an amplified no signal.
Can't get either station with rabbit ears at work in Anoka either, distance is 17 miles.
srtguy is offline
Old 09-11-2009, 09:23 AM
gjvrieze's Avatar
Yes, a preamp is a very bad idea, as it will VERY likely overload off of KQQL-FM (107.9) which is just a few miles from you running 96kW ERP.
Have you tried the antenna outdoors yet? Maybe set it up on a ladder or something like that for testing, just to see if you can get signal outside.
What tuner are you using?
KD0MOF
gjvrieze is offline
Old 09-11-2009, 10:04 AM
srtguy's Avatar
Have you tried the antenna outdoors yet? Maybe set it up on a ladder or something like that for testing, just to see if you can get signal outside. What tuner are you using?
Tried it outside on a 12' ladder. No VHF. Tuner is a Sanyo HDTV.
srtguy is offline
Old 09-11-2009, 10:11 AM
gjvrieze's Avatar
Very odd. It should work well with signals at the predicted levels that you have. I really wonder if it could still be FM overload from KQQL-FM. (less likely without an amp, but not impossible)
One of the engineers on this forum, posted a while back that he could his stations signal right under the broadcast tower with a short piece of wire as the antenna in analog, but in digital it would not work, so he hooked an FM trap in line and wall-ah, nice strong signal.
KD0MOF
gjvrieze is offline
Old 09-11-2009, 10:19 AM
srtguy's Avatar
Hmmm...I can see that tower from my house, but it is more straight south and my signals are coming from the SE...perhaps I need a FM trap...
srtguy is offline
Old 09-11-2009, 10:53 AM
gjvrieze's Avatar
At the distance you are from KQQL-FM, it prolly does not matter where you in terms of direction of antenna, also most of the time when you receive a signal for which the antenna is not resonant, the aim of the antenna will be much different then the frequency for which it was designed. (often the boom will be the actually receiving element for the lower bands like this)
I would prolly try the FM trap. Unfortunately, if doesn't work, you may simply need a bit more gain to get a lock.
KD0MOF
gjvrieze is offline
Old 09-15-2009, 11:29 AM
srtguy's Avatar
It seems the problem was the tuner in my 3 year old JUNK Sanyo HDTV
Now getting VHF 9 & 11 indoors at 26 miles unamplified. Not a very strong signal, but oddly enough, high VHF doesn't seem to pixelate like UHF does with a weak signal.
I might try the Winegard 269 if I have reception problems during snowstorms etc.
srtguy is offline
Old 09-15-2009, 11:46 AM
ProjectSHO89's Avatar
Quoted: 211 Post(s)
Liked: 110
Hah! Wait until you have a thunderstorm with 50 miles.....
ProjectSHO89 is offline
Old 09-15-2009, 11:58 AM
gjvrieze's Avatar
I would not try the HDP-269 unless you get a separate FM trap, as the HDP-269 does not have a built FM trap. The trap should be ahead of the preamp up at the antenna, to help keep it from overloading off of the FM.
KD0MOF
gjvrieze is offline
Old 09-15-2009, 12:57 PM
srtguy's Avatar
That bad huh? Here is what KMSP emailed me:
VHF is our final channel. VHF is a more robust signal during storms and is less affected by impulse noise issues.
srtguy is offline
