Minneapolis, MN - OTA - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 88Likes
post #61 of 3166 Old 01-19-2005, 09:58 AM
Marzo's Avatar
I recently upgraded to HD through D* (H10 box) and an OTA antenna. I receive strong signals on all the OTA channels except ABC (5-1, 5-2). Signal strength varies wildly and I usually can't get a signal. Is there something about channel 5's feed that causes more problems than the others?
Marzo is offline
post #62 of 3166 Old 01-19-2005, 12:35 PM
dmcgovern's Avatar
It really depends how far you are from Shoreview and what type of antenna you're using. More info needed brother Marzo.
D
dmcgovern is offline
post #63 of 3166 Old 01-19-2005, 12:49 PM
Syzygy's Avatar
Me too, Marzo. UHF channel 50 is very hard for a lot of people to receive. In the summer it was the leaves causing multipath interference. In the winter it's the thermal inversion layers. Right now I'm watching KSTP's analog feed via D* and hoping that sometime this year we'll be able to get the local HD feeds from the new Spaceway satellites. (New PVR box required, though.)
DirecTV & Dish HD Channel Spreadsheet
DirecTV & Dish HD Channels Listed by Package
Frank  TiVangelist since Aug 1999, HD since Dec 2002, DirecTV since Aug 2004, DECA/MRV since Nov 2010
Syzygy is offline
post #64 of 3166 Old 01-19-2005, 12:58 PM
dmcgovern's Avatar
Yeah, I'm probably not the best qualified for current local OTA issues... I've got Charter HD w/dvr and only use my OTA receiver to get kstp-dt and haven't even done that since the last MNF game :-)
D
post #65 of 3166 Old 01-20-2005, 05:23 PM
Steve Kuester's Avatar
Quoted: 108 Post(s)
Liked: 148
Anyone have audio synch issues with KSTP's HD channel (5-1)? I upgraded to HD with Directv a couple weeks ago, and I've noticed this problem while watching the last 2 episodes of "Lost." The box is Directv's new receiver - model number H10. (The box is not the problem though, as the NBC and CBS local HD channels are fine)
I can switch to the regular channel 5 and everything is synched up, but I then switch back to 5-1 and audio is noticeably out of synch with the video.
I don't believe is a signal strength or dropout issue as I live in New Brighton and can see the Shoreview towers from my house. The setup guide in my receiver shows the antenna signal strength for my local channels is anywhere from 86-100%
Anyone else?
I turn the sharpness on my TV all the way up, because that's how I like my picture... real sharp.
Steve Kuester is offline
post #66 of 3166 Old 01-24-2005, 06:40 PM
MojoJuice's Avatar
Anyone else having issues with the Fox 9 feed? I'm watching 24 and the logo on the bottom right is only showing Fox 9, the bottom half of the logo with KMSP doesn't show.
MojoJuice is offline
post #67 of 3166 Old 01-25-2005, 06:22 AM
Fast351's Avatar
Quoted: 12 Post(s)
Yeah that logo is probably offscreen for most people.
As far as the feed goes, it was perfect for me last night.
-Mike
Fast351 is offline
post #68 of 3166 Old 01-25-2005, 07:41 AM
MojoJuice's Avatar
Thanks Mike, everything else was ok just couldn't figure out why the logo was so low.
post #69 of 3166 Old 01-28-2005, 04:58 AM
ShiningBengal's Avatar
Originally posted by atye
I live in Menomonie, Wi, about 60 miles from MSP. I'll be getting my new set in the next few days. I'm hoping to attempt reception out of the cities instead of Eau Claire, Wi, which is about 30 miles. What type of antenna setup would you recommend?
I would suggest the largest yagi-style UHF only antenna you can find. I mounted a Radio Shack 15-2160 on my brother's house in Northfield, MN, which is about 40 miles directly south of the Shoreview antenna farm. It gets flawless reception on all the MSP channels, and surprisingly the St. Cloud channels as well, even though they are considerable off axis.
It is rated for 75 miles over "open terrain." You might try it and return it if it doesn't work. The main thing is get a highly directional antenna, preferably a yagi style.
Ignore them, m'dear: They're beneath your dignity.
ShiningBengal is offline
post #70 of 3166 Old 01-28-2005, 05:16 AM
post #71 of 3166 Old 02-02-2005, 06:56 PM
swenjj's Avatar
why has the last couple smallvilles not been in HD? it letterboxes it in my tv for some reason, on the top and the bottom and sides, instead of a full hd signal filling the screen, has WB cheaped out or something?
swenjj is offline
post #72 of 3166 Old 02-08-2005, 05:44 AM
reeferaddict's Avatar
Anyone having problems with WCCO (4-1) in the last week or two. I get all the local digital Twin City stations and have for the last year. In the last week 4-1 won't lock in, all the other channels pull in perfectly.
The signal appears moderately strong but it just wont lock in and pull in the picture. If I pull up the program info screen it briefly pulls up the description of what is playing but then blanks out as if it loses the info.
I have a Samsung SIR-T165 that has worked flawlessly till now.
I live in Rogers, MN and reception hasn't been an issue in the past.
reeferaddict is offline
post #73 of 3166 Old 02-08-2005, 05:42 PM
swenjj's Avatar
did you rescan? that worked for my 23-1 channel problem, for the missing channel,
now i just get no sound from 23, my friend has the same missing sound so it is their problem
swenjj is offline
post #74 of 3166 Old 02-09-2005, 06:36 PM
swenjj's Avatar
well tonight i watched smallville on 23 again, and the voice didnt match the picture, is this something that is going to be a problem long term for digital tv? alll the other stations worked fine
swenjj is offline
post #75 of 3166 Old 02-09-2005, 07:04 PM
greghoffman's Avatar
I was surprised I hadn't seen this more often. I had the exact same thing happen - SIR-T165 and all - but the problem seems to have fixed itself about a week/week-and-a-half ago. My problem sort of coincided with the length of time that I had snow on my roof. I've got an antenna in the attic - I just assumed that the snow was causing the signal to be blocked just enough so that I couldn't receive it anymore.
I had never had a problem receiving 4-1 before, and that was the only channel that I lost completely, although 9-1 was sort of blocky/intermittent for a few days.
I'm in Apple Valley, with a Radio Shack double-bowtie antenna in the attic, and, like you, I hadn't had any trouble receiving anything before, at least not for the past nine months or so.
Greg.
greghoffman is offline
post #76 of 3166 Old 02-10-2005, 12:53 PM - Thread Starter
sregener's Avatar
No UHF antenna really works for 75 miles over "open terrain." They do over water, though. Take any Radio Shack mileage estimate and divide by 2 and you have a more realistic number.
Once you're 60 miles from the transmitter, the earth itself gets in the way of the signal. Beyond that, you either need a very tall antenna (broadcasting/receiving) or a lot of luck to get reliable reception without doing everything right.
One of the best antennas I've found is the 91XG from AntennasDirect. You can read my review here:
http://www.geocities.com/figbert/ant...irect91xg.html
Still, at 60 miles, he's going to need a lot of elevation to get a good signal.
sregener is offline
post #77 of 3166 Old 03-01-2005, 10:52 PM
Runch Machine's Avatar
Quoted: 30 Post(s)
All Samsung SIR-T165 owners should check out the following link to a software upgrade.
http://product.samsung.com/stb_upgrade/
WCCO had turned on the broadcast flag for a few days by mistake. The software that shipped with the SIR-T165 can't handle this flag. Samsung will send you a serial cable and CD rom and instructions so you can upgrade the software yourself using a Windows based computer and a serial port.
WCCO turned off the broadcast flag after a few days. That's why the problem went away. It had nothing to do with snow. If you don't update your software and stations start using the broadcast flag, your Samsung will not work.
Runch Machine is offline
post #78 of 3166 Old 03-21-2005, 01:14 PM
mdfuller's Avatar
Hi gang...I have a TV5 Terk antenna (I know most people will say Terk sucks and I agree). I also have a SS 2000. For the most part all the stations are at 100% locked on my Samsung HD receiver. Watching the NCAA games in HD on WCCO-DT almost made me throw my shoe through the TV. There were consistent dropouts every minute or so. I constantly checked my signal strength and it was pegged at 100%. I tried the SS antenna and it did the same thing. So I guess I am wondering why I am getting any dropouts when my signal meter stays pegged at 100% all day long. It seems the other channels are better (not to bash any particular channels). I live in Roberts, WI (54023). About 28 miles from the towers.
mdfuller is offline
post #79 of 3166 Old 03-24-2005, 09:12 AM
andreej's Avatar
hey mdfuller,
I am just up the road about 5 miles N of Roberts. I have an LG 4200a tuner and a roof mounted radio shack antenna. I receive all the MSP stations with no drop-outs or any other problems. LG's reception scale doesn't show an actual % but most of my stations are at about 60%. I think that number is purely subjective though - every manufacturers scales are different.
"Wooden Airplanes - Finally they found a use for all those trees instead of just standing around like a bunch of jerks" - Homer Simpson
andreej is offline
post #80 of 3166 Old 03-24-2005, 10:28 AM
mdfuller's Avatar
Sounds good. We might be the only two people in Roberts with HD
I think I might try a roof antenna this summer...if I put an antenna on the roof though (new house) and it doesn't fix my problem my wife might leave me.
mdfuller is offline
post #81 of 3166 Old 03-24-2005, 04:49 PM
mdfuller's Avatar
So far 4-1 is coming in great for me during the Illinois - Milwaukee game. Go Panthers!
mdfuller is offline
post #82 of 3166 Old 04-05-2005, 06:48 AM
jpetersohn's Avatar
Just wanted to report that I can receive all but PAX with strong signals using an RS 15-1880 antenna sitting on a north wall shelf in the garage, in Rosemount, MN. For some (undetermined) reason I was unable to get anything with any antenna I tried inside the attic of the garage.
jpetersohn is offline
post #83 of 3166 Old 04-10-2005, 01:03 PM
hjw
hjw's Avatar
The Masters is looking great on WCCO-DT as I watch this afternoon!
Last year there were some problems. I really appreciate the excellent performance this year!!!
hjw is offline
post #84 of 3166 Old 04-19-2005, 10:22 AM
tman_ndsu08's Avatar
I've noticed that a few of you guys say that all of the stations come off of one tower in Shoreview.
If if you ever drive through Shoreview on 694, you can clearly see what looks like 3 towers right next to each other.
Maybe all the stations are on one of the three, but I don't see why.
Perhaps that's part of the problem some of you are having.
tman_ndsu08 is offline
post #85 of 3166 Old 04-19-2005, 12:12 PM
Syzygy's Avatar
From a post by Runch Machine on the HDTV Twin Cities forum...
All channels except for 41 are broadcast from a set of side-by-side towers in Shoreview. 4, 5, 11 and 45 come from one pair of towers. 2, 9, 17, 23 and 29 come from a third tower about a mile away from the first pair of towers.
Syzygy is offline
post #86 of 3166 Old 09-06-2005, 02:01 PM
vreath's Avatar
Does a person need an HD antenna to HD quality reception? Or does a strong UHF antenna accomplish the same result?
vreath is offline
post #87 of 3166 Old 09-06-2005, 02:27 PM
Fast351's Avatar
Quoted: 12 Post(s)
Nope, no "special" antenna needed. Any decent quality UHF will do it. (I personally use a Radio Shack U-75 and it works great at 22 miles from the antenna farm).
Fast351 is offline
post #88 of 3166 Old 09-12-2005, 03:54 PM
Fezmid's Avatar
Quoted: 26 Post(s)
Hi all! I'm new to the HD game - just got the HD-TiVo today. Unfortunately, I can't seem to get any OTA channels. I'm in Hudson, WI (~20 miles from the towers, according to Antenna Web).
I have the Winegard MetroStar Amplified MS-2VRD antenna (looks like a small picnic table on top of my DirecTV dish). This setup worked fine last year when I had a regular DirecTV HD receiver. Unfortunatley, I realized I couldn't live without DVR, so sold the receiver until I could afford the TiVo version.
Just had the HD-TiVo installed today, and I can't get the OTA channels... However, sometimes if I don't plug the cable into the RF input all the way, I DO get a signal... Strange, no?
I tried buying an attenuator (due to talk on TiVoCommunity.com), but it still doesn't seem to work...
Any thoughts? I'm willing to buy another antenna if it'll help, but I don't want to go on the roof, and I don't have a ladder even if I wanted to...
Oh, and this receiver is in the basement, so I don't think rabbit ears would work well, although if they had RCA or F connectors, I could put them in another room and then connect them to my central wiring closet (I have multiple home runs of rg6 in every room)...
So much for watching Monday Night Football tonight
CW
Fezmid is offline
post #89 of 3166 Old 09-13-2005, 02:58 PM
Fezmid's Avatar
Quoted: 26 Post(s)
As an update, DirecTV is willing to credit my account $75 to cover the cost of another antenna plus installation. Any ideas on where to go to hire someone to install it on the roof? Along the same lines, any recommendations (hopefully from someone in Hudson....)? I need to start researching this myself, but if someone else already has a solution that works...
CW
Fezmid is offline
post #90 of 3166 Old 11-07-2005, 08:46 AM
kevinjanet's Avatar
Will a PRE-AMP help?
I recently purchased a wine gard square shooter for use with MYHD computer card.
I get constant audio & video drop outs and pixelation on all (5-1 is worst) of the HD channels. (Antenna is on the roof peak but there are several trees in the neighbors yard that are higher) I am less than 5 miles north
from the Shoreview Towers that supply all the HD channels in the area. Some people have told me that if you're that close a pre amp won't do much for you. Any ideas on what model of preamp I should buy Or should I just give it up and blame the tree branches?
kevinjanet is offline
