Minneapolis, MN - OTA - Page 79 - AVS Forum
 4Likes
post #2341 of 2354 Old 10-23-2014, 03:33 PM
unclehonkey's Avatar
Quoted: 18 Post(s)
I'm curious if Comcast may actually have a better HD version of KSTP, maybe they get their signal from fiber
yes they get their feeds via fibre
unclehonkey is offline
post #2342 of 2354 Old 10-23-2014, 04:58 PM
jjeff's Avatar
Quoted: 144 Post(s)
Liked: 90
But I thought I read somewhere(not sure if it was our market) that some stations feed the fiber the same signal as would go to the transmitter. If this was the case cable would suffer the same as OTA.
I don't have cable but if someone did and also had OTA it would be interesting to compare the filesize(or bitrate if you could read it realtime) for say a 1hr ABC HD program. I know OTA a 1hr KSTP HD program is less than a standard DVD, under 4gb, which is way too small for decent HD. Compare this to WCCO where a 1hr HD program is over 6gbs.
Whoa, just checked WFTC(Fox9.1) and they are even worse than KSTP, coming in at a paltry 3.6 gb for a 1hr program! I don't watch much on FOX and what I do isn't probably too demanding but I've never seen the issues on FOX9.1 as I do on KSTP. Wonder if FOX has a better or newer encoder....
jjeff is offline
post #2343 of 2354 Old 10-23-2014, 05:24 PM
primetimeguy's Avatar
Quoted: 130 Post(s)
Liked: 139
I'm with you, I think no matter how they receive it (fiber vs OTA) I think the odds of having a different feed are slim. Would be nice for someone to compare.
As for FOX, yep, the pretty much suck too for PQ. Locally here I would put NBC at the top, say 9/10. CBS gets an 8 FOX a 5.5 and ABC a 3. KSTP is the worst excuse for an HD channel I have seen anywhere. And our FOX NFL broadcasts are terrible too. Other than NFL on FOX it's a good thing I don't watch either channel.
primetimeguy is online now
post #2344 of 2354 Old 10-23-2014, 06:20 PM
mattdp's Avatar
Quoted: 14 Post(s)
Are there even mobile DTV capable receivers on the market? I've never seen any. Seems like one of those pre-smart-phone-and-4G-LTE-everywhere ideas that sounded good at the time (like HD Radio on AM).
mattdp is offline
post #2345 of 2354 Old 10-23-2014, 06:51 PM
Trip in VA's Avatar
Quoted: 82 Post(s)
Liked: 64
Send a message via AIM to Trip in VA Send a message via Yahoo to Trip in VA
Very few, but they are out there. You really have to go looking to find them.
I remember someone here doing a comparison some months ago and it was clear that the fiber feed was much better since they weren't feeding the Mobile piece of the transport stream to the cable company.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
post #2346 of 2354 Old 10-24-2014, 06:22 AM
jjeff's Avatar
Quoted: 144 Post(s)
Liked: 90
- Trip
That might explain why more people aren't complaining about KSTP's picture quality as most people probably watch it on cable or satellite(which may be the same feed as cable).
Kind of a switch from the early days of HDTV when OTA was generally considered better PQ than compressed satellite or cable.
jjeff is offline
post #2347 of 2354 Old 10-24-2014, 07:45 AM
Trip in VA's Avatar
Quoted: 82 Post(s)
Liked: 64
It's still generally true that OTA is better than the fiber feed, or at least equivalent. I think KSTP just does a totally separate signal path for the fiber feed because of the huge amount of compression they're having to do to accommodate the Mobile DTV.
- Trip
N4MJC
RabbitEars
post #2348 of 2354 Old 10-24-2014, 09:24 AM
Quoted: 18 Post(s)
Rabitears says 3.3 so its close
I mainly watch it via 9.9 which doesn't seem to have the issues as 9.1 does
post #2349 of 2354 Old 10-24-2014, 02:53 PM
John21's Avatar
I have Comcast and KSTP is definitely a better picture on cable than on the OTA signal.
John21 is offline
post #2350 of 2354 Old 10-24-2014, 07:48 PM
jjeff's Avatar
Quoted: 144 Post(s)
Liked: 90
Thanks for your observations, that might make sense then why more people aren't complaining.
When they first added 9.9 I made a couple test recordings and both channels were identical in size for a 1hr program, so I figured it was a wash. I think people speculated that even though 9.9 could have more bandwidth, FOX may have been sending the same bitrate program to both channels. I'll have to do more testing, problem is I watch such little FOX and what I do isn't really demanding material. Now if they aired things like live event shows, especially ones with lots of strobes, it would be easy to spot a bitstarved picture.
jjeff is offline
post #2351 of 2354 Old 10-25-2014, 03:46 PM
edjones34's Avatar
I've noticed that people comment on the picture quality of KSTP. They mention how the mobile channels are taking away a lot of bandwidth. What I am wondering is how much bandwidth the feed sent from ABC has? I ask this because I've noticed that the ABC Owned-and-Operated stations have two subchannels of the LiveWell network, one in HD one in SD, so in those markets the main ABC channel has about the same bandwidth as what KSTP's does.
edjones34 is offline
post #2352 of 2354 Old 10-26-2014, 03:58 PM
Quoted: 18 Post(s)
per rabbitears.info
KSTP uses between 7.7-8.7Mbps for ABC
LiveWell uses 1.55-2.25
Mobile takes up 7.34
Now if we look at a ABC O&O
WABC NY uses a variable bitrate but they max out at 13.5
KABC LA uses up to 14.0
KGO San Fran is up to 12.5
In comparison to other Hubbard ABC's in the state
WDIO Duluth 13.3
KAAL Austin 12.5
KSAX Alexandria (satellite of KSTP) 11.45 (KSAX and KRWF Redwood Falls has ABC on -1, a SD feed of 45 on -2 and MeTv on -3)
post #2353 of 2354 Old 10-26-2014, 07:20 PM
jjeff's Avatar
Quoted: 144 Post(s)
Liked: 90
Originally Posted by edjones34 View Post
... I've noticed that the ABC Owned-and-Operated stations have two subchannels of the LiveWell network, one in HD one in SD, so in those markets the main ABC channel has about the same bandwidth as what KSTP's does.
And when the station has Livewell in HD, such as some other ABC markets, the picture quality is also quite poor. I've read posts from someone in the PHI market, where the ABC affiliate has Livewell in HD and they're always complaining about how easily the picture macroblocks with any motion, like KSTP(OTA anyway).
jjeff is offline
post #2354 of 2354 Old 10-27-2014, 06:08 AM
Quoted: 130 Post(s)
Liked: 139
The bitrate is already so low that the picture is so soft and blurry it makes it harder to see the macroblocking.
This station is a joke.
User Tag List
