Tulsa, OK - HDTV - Page 31 - AVS Forum | Home Theater Discussions And Reviews
post #901 of 921 Old 01-16-2016, 08:10 PM
Super Moderator
DrDon's Avatar
Quoted: 1044 Post(s)
Liked: 2066
Threads merged. Coweta's a short shot from Bixby, so any combo pointed in that direction will accomplish your goals. Unless you have some desire to get all the other indies from the various other directions, that is.
Moved to Tulsa thread.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is online now
post #902 of 921 Old 01-17-2016, 03:53 PM
shinerburke's Avatar
Thank you. I think I'm going to try the antenna suggested by Calaveras and see how it does.
I was thinking of getting something like the Channel Master Metrotenna 40, but I am afraid it wouldn't be able to pick up the CW and ION channels which I watch quite a bit since they are not located on the Coweta towers.
shinerburke is offline
post #903 of 921 Old 07-14-2016, 02:40 PM
Quoted: 22 Post(s)
Liked: 0
Moving to Tulsa from the country
I need antenna recommendations please!
http://www.tvfool.com/?option=com_wr...e2cb311466d85c
AntheaH is offline
post #904 of 921 Old 08-18-2016, 03:56 PM
Quoted: 22 Post(s)
Liked: 0
I cannot access Channel 8 at all, which is very strange?
AntheaH is offline
post #905 of 921 Old 08-19-2016, 09:58 AM
truckmann's Avatar
Not strange at all really. A lot of people have problems with Channel 8. I think some of the smaller antenna don't pick up the frequency it uses. What antenna are you using?
truckmann is online now
post #906 of 921 Old 08-19-2016, 03:29 PM
Quoted: 22 Post(s)
Liked: 0
Leaf
Another forum user suggested I could use just a set top antenna so I grabbed the Leaf HD which has horrible reception. I had to use a signal booster. Granted, I'm in a brick house so I gather that will cause some issues.
I hope to grab my outdoor antenna this weekend and see if that resolves the issue - I was curious as to what other issues there may be as I cannot pick up Channel 35 either. Plus PBS did not come in at all until I used the signal booster.
AntheaH is offline
post #907 of 921 Old 08-19-2016, 03:52 PM
truckmann's Avatar
An outdoor antenna should work much better for you. I'm in Mannford and get all the channels with a big directional antenna. 35 is spotty but it's in a different direction than most of the other channels and I suspect it's a lower output signal. You shouldn't have any problems with 11 though. Those come in great for me. I'm not sure what it is about 8 but I've heard a few times where the small indoor antenna won't pick it up.
post #908 of 921 Old 08-23-2016, 11:38 AM
Quoted: 22 Post(s)
Liked: 0
I can't pull in Channel 11 at all without the signal booster.
AntheaH is offline
post #909 of 921 Old 08-29-2016, 02:14 PM
Quoted: 22 Post(s)
Liked: 0
I have my outdoor antenna hooked up and I still can't pull in Channel 8.
Any suggestions?
My tvfool listing
AntheaH is offline
post #910 of 921 Old 08-29-2016, 02:52 PM
truckmann's Avatar
Any suggestions?
My tvfool listing
What antenna do you have? Did you re-scan the channels?
post #911 of 921 Old 08-29-2016, 02:57 PM
Quoted: 22 Post(s)
Liked: 0
Yes
RCA Compact Outdoor Yagi HDTV Antenna
Model Number: ANT751R
AntheaH is offline
post #912 of 921 Old 08-29-2016, 05:10 PM
truckmann's Avatar
Sorry I don't have any good ideas. Looks like that antenna should be good. I just checked and I'm getting good signal on channel 8.1 out here in Mannford. The only thing I can think of is something is ether interfering or blocking the signal where you're at.
post #913 of 921 Old 08-30-2016, 11:21 AM
Quoted: 22 Post(s)
Liked: 0
Would a directional antenna be better? One that rotates to catch the signals?
I'm wondering which direction is best for me to orientate the antenna in, if there is any difference?
As you can see by my previous location, I just pointed it at the direction of Channels 11 and 8 and got all the channels I wanted.
http://www.tvfool.com/?option=com_wr...e2cb245ea9c38b
I'm not sure which direction to point the antenna in now :/
AntheaH is offline
post #914 of 921 Old 08-30-2016, 12:45 PM
truckmann's Avatar
Just so I'm on the same page, when you say Channel 8 are you referencing the real channel or the virtual channel? It can be little confusing since ABC is channel 8.1 but the real channel from tvfool list it as 10. I'm assuming you mean ABC channel 8, but just want to make sure.
The antenna type you have is pretty directional. I would try aiming your antenna at about 107-115 degrees and see what comes in. A lot of the channels are still really close to the same direction so it might be pretty good. If you have it aimed to catch most of them. The ones I would suspect might be weak would be 19.1, 35.1 and 44.1 since they are at different angles and farther away.
If you still can't get channel 8.1 you probably will need a bigger antenna. According to this site http://www.channelmaster.com/Antenna...tion-a/134.htm 8.1 is one of the weaker channels for your area. If you are able to aim to get it and then can't get the others I mentioned you might get by with an omni-directional antenna like the CM3000HD. Otherwise you might need a roof mounted directional with a rotator to get them all.
post #915 of 921 Old 02-21-2017, 10:54 AM
osu1991's Avatar
Quoted: 127 Post(s)
Liked: 85
Sinclair has squeezed another channel onto KTUL. 8.4 is now the TBD network that Sinclair owns. Not really interested in the channel. If they insist on another subchannel, hopefully they change it to their other new network Charge!, when it launches in a couple weeks.
http://tbd.com/
osu1991 is online now
post #916 of 921 Old Today, 08:43 AM
truckmann's Avatar
Sometime in the last few months I have lost a bunch of channels. I'm only getting 2,8 and 11 now. Anyone else having any problems?
Sent from my Nexus 6P using Tapatalk
post #917 of 921 Old Today, 12:58 PM
Super Moderator
DrDon's Avatar
Liked: 2066
You're only getting the stations on VHF, then. Might post a link to your TVFool.com results, tell us what kind of antenna you're using, what all is in the line and so forth. (Your address will only show to you with the TVFool link. Use a link, not an image). And please use call letters as channel numbers can be confusing. Don't know if you're talking actual or virtual, though I'm assuming from your list you mean virtual. KJRH, KTUL and KOED are all transmitting on VHF (8, 10 and 11 respectively) KOTV is 45 and so on. https://www.rabbitears.info/market.p...arket&mktid=74
DrDon is online now
post #918 of 921 Old Today, 01:15 PM
truckmann's Avatar
Yes I was referring to the virtual channels. I had a lightning strike a few months ago maybe that killed the UHF circuit in my antenna. I have a Winegard HD 7080P antenna.
Oh and here's my tvfool link.
http://www.tvfool.com/?option=com_wr...e6a4784fdd54cb
post #919 of 921 Old Today, 01:46 PM
truckmann's Avatar
Assuming my antenna is damaged do you think this antenna would be good for my location?
http://a.co/2zw1vh1
or should I step up to the bigger one?
http://a.co/4IwETMV
or any other suggestions.
post #920 of 921 Old Today, 01:52 PM
Super Moderator
DrDon's Avatar
Liked: 2066
Mannford. You can get KRMG on your dental fillings. Lovely area.
Gee. Lightning in Oklahoma.. THAT rarely happens
I'm going to assume the weather didn't spin your antenna and that it still points toward Coweta.
Something's cooked or loose. If you have any pre-amps or combiners, check those. Otherwise, walk back the cabling looking for damage or corroded connections. Better still, if nothing else seems amiss, replace the whole cable run.
Unless portions of your antenna are melted, I'd suspect something else. VHF is more likely to find its way through corroded connections, fried joiners and so forth. The higher the frequency, the less it takes to foul it.
DrDon is online now
post #921 of 921 Old Today, 02:15 PM
truckmann's Avatar
I'll look through it all good. My pre-amp is in the attic and it is also my splitter to send the signal to 2 different tv's. I have another splitter outside that sends signals to another building when I decide to hook it up. The amp seemed fine. The power light is on and I didn't gain anything when I switched it out for another one I have. Didn't see any noticeable damage to the antenna and it's still pointed where it's always been.
