LaCrosse / Wausau, WI - HDTV - Page 53 - AVS Forum | Home Theater Discussions And Reviews
post #1561 of 1571 Old 05-19-2015, 05:48 PM
hunmanik's Avatar
I was about to post that KQEG TV-23 in La Crosse has been off the air for several days.
Turns out it's for the best possible reason, as I just noticed the station posted this on their Facebook page the other day, May 14:
Our over the air signal (Channel 23) is off the air for the week as we are in the process of switching over to a digital transmitter.
You'll be able to continue to watch our programming on both Charter and CenturyLink during this process.
We hope to be up and running on Channel 23.1 by this time next week.
hunmanik is offline
post #1562 of 1571 Old 05-26-2015, 05:02 PM
old rat's Avatar
help.. I live in LaCrescent.. and I am about 16 to 18 miles due south of Channel 8's towers. I can get 19, 25, 10 with out any antenna hardly at all but I NEED TO get a CBS channel.. especially since the NFL now switches games to other networks.. I need an antenna and I have been looking at a MOHU as well with a booster.. I DO have a bluff IN my back yard.. and no.. I cannot get a tower over the top of it.. help me. please..
old rat is offline
post #1563 of 1571 Old 06-08-2015, 01:25 PM
old rat's Avatar
Wow I posted this a while ago.. I was really hoping for some response from guys who I feel are truly "in the know".. how about some help.. I really need to get channel 8 for the fall. .
old rat is offline
post #1564 of 1571 Old 06-08-2015, 02:24 PM
mattdp's Avatar
Quoted: 24 Post(s)
Post a TVFool.com report so we can see what kind of level you're working with. The situation is probably not as dire as you presume.
mattdp is offline
post #1565 of 1571 Old 06-08-2015, 06:00 PM
old rat's Avatar
old rat is offline
post #1566 of 1571 Old 06-09-2015, 03:38 AM
mattdp's Avatar
Quoted: 24 Post(s)
Here's a medium VHF-Hi antenna: http://www.amazon.com/BLV6F-CH7-13-A...racarro-Italy/
Point that straight north and combine it (via a splitter) with a small UHF antenna like this aimed at 223deg: http://www.amazon.com/Eagle-Aspen-EA...ectv-Approved/
mattdp is offline
post #1567 of 1571 Old 06-09-2015, 06:44 AM
old rat's Avatar
the links you posted .. I cannot get into.. amazon doesn't find them..
old rat is offline
post #1568 of 1571 Old 06-09-2015, 03:51 PM
mattdp's Avatar
Quoted: 24 Post(s)
Sorry about that. Trimmed the URL down a little too far.
http://www.amazon.com/BLV6F-CH7-13-A...dp/B002VM4GG4/
http://www.amazon.com/Eagle-Aspen-EA...dp/B000GIT002/
That's one surefire solution. There are a few different configurations that could work, including DIY antennas. Basically you are two miles away from the UHFs. They're stupid strong. WKBT is only 18 miles away but does take a bit hit because of the topography (if you click on WKBT in the listing, you'll see this page: http://www.tvfool.com/?option=com_wr...dALLTV%26n%3d5). That being said, it only needs a moderately sized VHF antenna. The one I prescribed is probably massive overkill. What antenna are you currently working with? Unfortunately a lot stuff is really only designed for VHF.
If you're a DIY kind of guy you could build a 2-bay VHF-Hi antenna like this (a 1 bay may even suffice) https://sites.google.com/site/maycre...tie-for-vhf-hi For UHF, a 2 or 4 bay version of this: http://uhfhdtvantenna.blogspot.com/
I wouldn't touch an amp or a preamp at those distances. Throw those two antennas in the attic (properly aimed) and if necessary put a reflector screen on the VHF-Hi - you could easily feed multiple sets.
mattdp is offline
post #1569 of 1571 Old 06-10-2015, 11:16 AM
old rat's Avatar
if you look at the diagram see the hills at the far right of the photo.. they are in blue and green.. that's where i live behind those hills..
old rat is offline
post #1570 of 1571 Old 07-01-2015, 05:21 PM
mvcg66b3r's Avatar
Quoted: 30 Post(s)
Liked: 1
WFXS Wausau goes dark; FOX moves to WZAW-LD
Wausau-Rhinelander, Wis. (DMA 134): Gray entered into an agreement with Davis Television LLC, to acquire certain non-license assets of WFXS, which had served as the market’s Fox affiliate. Earlier today, WFXS ceased operating. At that time, the parties closed the transaction, and Gray began broadcasting the program streams formerly transmitted by WFXS on Gray's digital low-power WZAW in Wausau. Gray also owns and operates full-power WSAW in Wausau, which serves as the market's CBS affiliate. Kalil & Co. was the exclusive broker for this transaction.
http://www.tvnewscheck.com/article/8...3-earlier-ones
At least they could have waited until after Sunday's Women's World Cup final.
Gray should add a simulcast of WZAW on WSAW-DT2 to cover the whole market. Also, where would WFXS go?
Anyway, here's how I'd do things in Wausau:
7.1 CBS (1080i)
7.2 FOX (720p) // WZAW-LD
7.3 MNT (480i) (move from 7.2)
55.1 FOX (720p) // WSAW-DT2
55.2 MeTV (480i)
55.3 Movies! (480i)
55.4 Heroes & Icons (480i) (move from 7.3)
One person's craziness is another person's reality. - Tim Burton
mvcg66b3r is online now
post #1571 of 1571 Unread Today, 10:24 AM
mvcg66b3r's Avatar
Quoted: 30 Post(s)
Liked: 1
From Northpine.com:
Gray TV CBS affiliate WSAW/7 (Wausau) has added FOX on channel 7.3, simulcasting low-power "FOX 55" (WZAW-LD/55.1 Wausau). Gray launched WZAW-LD at the beginning of the month to assume the programming and channel position of WFXS-DT/55.1 (Wittenberg), which went silent after Gray bought the rights to its programming. (FCC ownership caps prohibited Gray from buying WFXS outright, but LPTV stations are not subject to ownership caps.) Many viewers had complained that they could no longer receive FOX after 55.1 downgraded to 15kW, the maximum allowed for LPTV stations. FOX replaces Heroes & Icons TV on channel 7.3; WSAW continues to carry MyNetworkTV and other syndicated programming on 7.2, while WZAW-LD also carries Me-TV on 55.2 and Movies! on 55.3.
One Facebook poster says 7.3 is still in SD.
In my opinion I would much rather watch the Packers than hill street blues. I wish it was on 7-2 so it could be HD and widescreen, but this is better than nothing
https://www.facebook.com/WFXSFOX55
And this leaves Heroes & Icons without a home in Wausau.
