LaCrosse / Wausau, WI - HDTV - Page 54 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1591 of 1601 Old 06-29-2016, 05:17 PM
mattdp's Avatar
Quoted: 34 Post(s)
I think you referred to WEAU 13 as CBS in the original post. Hence the confusion. I'd just add another UHF antenna, as your big problem is how far off axis your channels are.
mattdp is offline
post #1592 of 1601 Old 07-01-2016, 05:35 AM
mtb54703's Avatar
Grr.... yes I did didn't I! NBC is to my SE and it's the one I'm having the most difficulty with. CBS due south with no reception problems using the CS5.
I'm curious - are there no USA manufacturers that do custom combiners?
mtb54703 is offline
post #1593 of 1601 Old 07-01-2016, 12:49 PM
mattdp's Avatar
Quoted: 34 Post(s)
Not that I know of. I would try two antennas into a backwards splitter first. Will most likely work fine - custom channel combiners were more necessary in the analog era where static multi-path was an issue.
mattdp is offline
post #1594 of 1601 Old 10-27-2016, 08:35 PM
hunmanik's Avatar
I don't know when it happened exactly, but I can report that WLAX 25.3 Laff and WLAX 25.4 Grit are now on the air.
hunmanik is offline
post #1595 of 1601 Old 10-29-2016, 02:11 PM
unclehonkey's Avatar
Quoted: 281 Post(s)
Liked: 60
end of August is when they launched on FOX25/48 but it was done uniquly
La Crosse-Eau Claire: In an unusual situation, Nexstar added four subchannels, but they are split between two stations serving different ends of the market. WLAX (La Crosse) is carrying Laff on 25.3 and Grit on 25.4, while WEUX (Chippewa Falls-Eau Claire) is carrying Escape on 48.3 and Bounce on 48.4. The stations simulcast FOX and Me-TV on their other channels.
DA1745 likes this.
unclehonkey is offline
post #1596 of 1601 Old 12-23-2016, 10:42 PM
tachmn's Avatar
Wpt4
Reception was wacky today for some reason, so I did a rescan to see if any distant stations were coming in that were whacking the closer stations.
Nothing showed up. But the rescan picked up WPT4 or 31-4 out of La Crosse. Nothing there but the text listing the six WPT stations.
16x9 SD.
So it looks like something is coming. Fixed amount of bits spread around even more thinly.
tachmn is offline
post #1597 of 1601 Old 12-24-2016, 08:15 AM
Jon Ellis's Avatar
A post from a WPT programming official on the Madison thread says the new channel will be PBS Kids starting in January.
Jon Ellis is offline
post #1598 of 1601 Old 01-16-2017, 05:38 PM
franktank232's Avatar
Its a 24 hour kids station. I have young children so i'm getting use out of it. I also use 24.2 out of Lansing (IPTV) for kids shows. 31.1 runs kids shows until 5;30 and then they switch over to news/adult progamming.
When they add a subchannel, does that degrade the signal to the other channels/??? So did 31.1 (which is HD) just get compressed more?
I'm just north of La Crosse but use 2 antennas (and a switch) to get channels out of Eau Claire (13/18) and IPTV (24) out of Iowa (along with 8,10,19,25,31).
franktank232 is offline
post #1599 of 1601 Old 01-16-2017, 06:24 PM
Jon Ellis's Avatar
It does mean there is less bandwidth for the other channels -- but compression technology has improved since the early days of digital TV. WPT says they have switched to different encoders that allow better picture quality.
post #1600 of 1601 Old 01-27-2017, 12:53 PM
Quoted: 281 Post(s)
Liked: 60
For the folks in the LaCrosse area
Did WKBT 8 add Ion recently?
Northpine mentions that both 8 and WISC3 in Madison added it. Ion site does confirm it
Great news – your local ION Television station, WKBT, is available over-the-air on channel 8.3
Can someone confirm?
post #1601 of 1601 Old 01-28-2017, 07:29 AM
hunmanik's Avatar
Yes, WKBT 8.3 Ion is on the air, thanks for the heads-up!
hunmanik is offline
