Phoenix, AZ - HDTV - Page 375 - AVS Forum
 2Likes
post #11221 of 11227 Old 12-13-2014, 01:45 PM
daidavel's Avatar
Originally Posted by kingpcgeek View Post
Lost in all of this recent guide mess was the fact that we now get Sundance HD. Too bad they didn't do this earlier, I'm sure I would have watched Rectify.
True, I was excited to see that ... they are supposed to air "Les Revenants" (The Returned) I heard ... I saw season 1 on Netflix on thought it was really good. I'll be watching Sundance a lot more now that I don't have to put up with the SD feed
daidavel is online now
post #11222 of 11227 Old 12-15-2014, 09:28 AM
Azlen's Avatar
Originally Posted by Bryan_CoxPHX View Post
ION is also messed up, it was moved from 17 and 1017 to 18 and 1018, but the guide data is still on 17 and 1017.
The HistoryHD feed was changed from East to Pacific
Tribune Media got Phoenix and Tucson mixed up
In Tucson HistoryHD is on channel 1036
http://www.cox.com/residential/tv/channel-lineup.cox
You will also notice 1099 got added as IONSPHD (ION Satellite Pacific feed), which was also intended for Tucson, since Tucson does not have a local ION affiliate.
I have submitted the corrections to both TiVo and Zap2It. Zap2It used to have a form for Line-Up issues, but took it down with the website redesign. I doubt they even look at the feedback emails.
http://www.tivo.com/lineup.html
They responded to my email on the subject this morning asking for my zip code so they could investigate it properly, so it looks like they are looking at the feedback mails. How long it will take to fix though is another story.
Azlen is offline
post #11223 of 11227 Unread Today, 08:17 AM
Azlen's Avatar
They fixed the History Channel mistake but the ION channel is still incorrect.
Azlen is offline
post #11224 of 11227 Unread Today, 08:50 AM
thebignewt's Avatar
Quoted: 144 Post(s)
Liked: 52
Howdy! I have CableOne in Prescott and a Motorola STB. I think it's upscaling all channels to 1080 because that's what shows on my TV screen every time. What I want is for the STB to send the TV the "native" resolution and let the Sammy TV upscale it. Any ideas how? Thanks in advance.
Samsung ES8000 65", Evo Kit installed, Yamaha AVR with Paradigm speakers, iMac, iPad, Apple TV and HTC One phone.
thebignewt is online now
post #11225 of 11227 Unread Today, 11:36 AM - Thread Starter
DoubleDAZ's Avatar
Quoted: 53 Post(s)
Liked: 71
Look in the menu somewhere to see if you can enable other formats. Sometimes you have to enable all those you want to use.
Cheers, Dave
DoubleDAZ is offline
post #11226 of 11227 Unread Today, 12:47 PM
daidavel's Avatar
Yup, that's what I'm seeing as well ... hopefully they are still working on it.
post #11227 of 11227 Unread Today, 01:30 PM
pbenjamin's Avatar
It depends upon the cable box. The older Scientific Atlanta DVR that I had for years had an option to pass through whatever it was. The newer Cisco boxes do not have this option. You have to choose a resolution and it upscales to that for everything.
Paul
pbenjamin is online now
