Houston, TX - OTA - Page 206 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #6151 of 6168 Old 10-11-2014, 04:43 PM
BPTTV's Avatar
Quoted: 17 Post(s)
Why in the attic?? Federal law allows you to put up an outside antenna.....screw the HOA......
BTW the FCC issued 3rd NPRM on the LPTV/translator issue....read it and get your comments in on this farce ASAP...
http://transition.fcc.gov/Daily_Rele...C-14-151A1.pdf
BPTTV is offline
post #6152 of 6168 Old 12-19-2014, 05:25 PM
kwg
kwg's Avatar
New subchannel:
34.3
www.revntv.com
kwg is offline
post #6153 of 6168 Old 01-31-2015, 05:48 PM
brg606's Avatar
channel 8 and channel 11 problems
channel 8 (PBS) and channel 11 (CBS) have been having problems for me lately. they usually come in very clear. usually signal strength around 75-80, now about 45 and signal breakups. all other major channels are working fine. anyone else having problems with these?
brg606 is offline
post #6154 of 6168 Old 01-31-2015, 06:39 PM
astrohip's Avatar
No, i record a lot of OTA CBS (Ch 11), with no problems.
astrohip is offline
post #6155 of 6168 Old 01-31-2015, 06:51 PM
brg606's Avatar
thanks for the fast feedback. do you have any idea what could be causing this? another vhf, channel 13 comes in perfect. channel 2, 26, 39, and 57 perfect as well. I have a rca ant751r with rca preamp mounted outside. just started having problems with 8 & 11 a few days ago.
brg606 is offline
post #6156 of 6168 Old 02-01-2015, 06:43 AM
astrohip's Avatar
No idea. I think ch11 and ch13 even come from the same antenna farm, which makes it unlikely they would have different reception quality. Sorry, no ideas....
astrohip is offline
post #6157 of 6168 Old 02-01-2015, 07:23 AM
newsman's Avatar
I have not had any problems either.
newsman is offline
post #6158 of 6168 Old 02-01-2015, 12:55 PM
brg606's Avatar
i figued it out....damnedest thing. I have my antenna set up in my mancave/shed. I recently bought a 10w led spotlight to shine on my Texans flag. For some reason when I turn on the light it puts off some interference than ONLY affects channels 8 & 11. my signal strength goes from about 80 to about 40 immediately when I plug the light in. I don't understand it.
brg606 is offline
post #6159 of 6168 Old 02-01-2015, 01:53 PM
bobchase's Avatar
LED lights use switching power supplies to power the LEDs that often radiate frequencies that interfere with other electronics. They are supposed to be FCC certified *not* to radiate but then there is the real universe that we have to live in...
Happy Trails,
Bob
We are experiencing some Technical Difficulties.
Please standby while we reboot our TV station...
bobchase is offline
post #6160 of 6168 Old 02-02-2015, 05:54 AM
ggmorton's Avatar
On a side note. I see channel 11 has a new sub channel. 11-3.
Justice Network
http://deadline.com/2014/11/justice-...tt-1201280309/
http://www.thewrap.com/nbc-nat-geo-a...stice-network/
ggmorton is offline
post #6161 of 6168 Old 03-31-2015, 09:31 AM
Liked: 1
Marriage law dictates if yo wife says it don't go there then it don't go there.. This applies to all your masts lol
Lane Meyer is offline
post #6162 of 6168 Old 06-23-2015, 01:34 PM
Liked: 0
Hello fellow Houstonians,
I was wondering if any of you could recommend a VHF-HI & UHF TV antenna?
Here are the TV Fool results: tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d82305e53bb957 a
I tried the Channel Master 4228HD inside and in the attic with marginal results so I am willing to mount something on the roof of a two story house.
cuttingmycordss is online now
post #6163 of 6168 Old 06-23-2015, 01:36 PM
Liked: 0
something happened with the above link. Here it is again tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d82305e53bb957 a
post #6164 of 6168 Old 06-23-2015, 02:13 PM
Liked: 0
Sorry....you'll need to remove the space before the "a"
post #6165 of 6168 Old 06-25-2015, 08:03 AM
newsman's Avatar
I'm very happy with this antenna. I pick up stations from Victoria as well.
http://www.mcmelectronics.com/produc...-2440-/30-2440
newsman is offline
post #6166 of 6168 Old 07-08-2015, 06:45 AM
cube799's Avatar
What's wrong with KXLN and KTFH, They're broadcasting in 4:3 instead of 16:9. I Checked 45-1, 45-2, and 67-1, and they're in 4:3.
cube799 is online now
post #6167 of 6168 Old 07-10-2015, 06:48 AM
cube799's Avatar
Never mind it turns out that the TV was in the wrong aspect ratio. I fixed it.
post #6168 of 6168 Old Today, 08:01 AM
Liked: 0
Went with this one...http://www.amazon.com/Winegard-HD769.../dp/B001DFTGR4 . Works great!
