Houston, TX - OTA - Page 208 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #6211 of 6239 Old 11-05-2016, 01:01 PM
sbombs's Avatar
ANTOP V/UHF-272 antenna for Bay City, Tx (77414) Opinions?
Spec sheet claims 10dB VHF and 14dB UHF, which seems okay for thirty bucks. Any opinions or experience with this antenna? I'm open to suggestions. Bay City is about ~60Mi from Missouri City where the transmission towers are located. Not too worried about getting the Victoria stations.
Also thinking about a Holland LA-520 In-Line Amplifier 50-2150MHz, 20dB Gain, but I can't find a power supply for it. Is there a favorite amplifier around here for rural TV reception?
I'll be distributing to three end points in the home. None of the cable runs will be more than 100ft.
TV Fool: http://www.tvfool.com/?option=com_wr...dfaf7d529914d2
Antenna spec sheet: http://www.parts-express.com/pedocs/...272-manual.pdf
-- Corner bass traps? Where would I put my K-Horns?
sbombs is offline
post #6212 of 6239 Old 11-06-2016, 10:35 AM
rcbtaw's Avatar
Kingwood, Texas: To Combine or not to Combine?
http://www.tvfool.com/?option=com_wr...5134e64591db1e
I recently combined a Stellar Labs 60" VHF antenna with my Channel Master 4221 UHF antenna to finally solidify my VHF reception. I'm 40 miles away from the towers in the Houston area and both antennas are mounted in my attic. I receive all channels at over 90% strength.
I have friend that wants to cut the D* cord who wants help installing an antenna for OTA reception. We live in the same general area. My question is if there is a good antenna that will receive both VHF and UHF signals that can be mounted in an attic or do I need to recommend combining two antennas like my set up? Thoughts?
Robert Christian Barger
rcbtaw is offline
post #6213 of 6239 Old 11-06-2016, 10:48 AM
rabbit73's Avatar
Quoted: 436 Post(s)
Liked: 176
Please post the tvfool report for his location, as the sticky says.
NOTE: Put YOUR LOCATION in the TITLE of ALL antenna threads & TVFOOL info in 1st post
You can do it here:
http://www.tvfool.com/index.php?opti...pper&Itemid=29
Small changes in location can make a big difference in the signals.
The signal strength in an attic is difficult to predict. A metal roof, aluminum thermal barrier, aluminum siding, and stucco wire mesh will block TV signals, as will trees and other buildings. It becomes an exercise in trial and error.
If you can not measure it, you can not improve it.
Lord Kelvin, 1883
www.megalithia.com/elect/aerialsite/dttpoorman.html
rabbit73 is offline
post #6214 of 6239 Old 11-06-2016, 11:03 AM
rabbit73's Avatar
Quoted: 436 Post(s)
Liked: 176
It would have been helpful if you had at least posted your report. Does it look something like this?
http://www.tvfool.com/?option=com_wr...dfaf8b42e5de49
What channels are most important to him?
Any trees or buildings in the signal path?
He can do it your way or use a combo antenna for VHF and UHF.
Lord Kelvin, 1883
rabbit73 is offline
post #6215 of 6239 Old 11-06-2016, 11:10 AM
rabbit73's Avatar
Quoted: 436 Post(s)
Liked: 176
Thank you for the report link that I see in you first post. Is that for you or him?
Lord Kelvin, 1883
rabbit73 is offline
post #6216 of 6239 Old 11-06-2016, 11:13 AM
rcbtaw's Avatar
I added the tv report link to the first post. My question isn't about what channels he will receive. I guess I am asking for a recommendation for an attic mounted VHF/UHF antenna that will do the same job as my combined set up.
rcbtaw is offline
post #6217 of 6239 Old 11-06-2016, 11:16 AM
rcbtaw's Avatar
The report is for my location but we live very close to one another. I don't know his address but it's the same zip code.
rcbtaw is offline
post #6218 of 6239 Old 11-06-2016, 11:30 AM
rabbit73's Avatar
Quoted: 436 Post(s)
Liked: 176
IF his attic has similar construction and IF the signals are the same in his area and IF the trees are the same, then this combo antenna will be about as good as your two antenna system:
Winegard HD7694P
and this larger one will have a little more gain:
Winegard HD7698P
Good enough?
Lord Kelvin, 1883
rabbit73 is offline
post #6219 of 6239 Old 11-06-2016, 11:42 AM
rcbtaw's Avatar
Thanks. Does anyone out there have experience with these products?
rcbtaw is offline
post #6220 of 6239 Old 11-06-2016, 11:55 AM
rabbit73's Avatar
Quoted: 436 Post(s)
Liked: 176
Robert:
I started experimenting with antennas when I was 8 years old; I'm now 83. I have been giving antenna advice on four forums for 8 years, and have built many ham and TV antennas. If I have given you bad advice I'm certain the other regulars will shoot me down.
I welcome their input.
I had to drag the information out of you to give you accurate advice in spite of what the sticky stated was required of you.
Your friend still has to try it out in his attic. We don't give a guarantee because every reception location is unique.
Lord Kelvin, 1883
rabbit73 is offline
post #6221 of 6239 Old 11-06-2016, 12:03 PM
rcbtaw's Avatar
rcbtaw is offline
post #6222 of 6239 Old 11-06-2016, 12:31 PM
Calaveras's Avatar
Quoted: 1151 Post(s)
Liked: 260
The TV Fool report isn't just about what channels you can receive but what it will take to receive them. In your case the HD7694P should be plenty good enough for the job barring any of the issues rabbit73 has mentioned.
I recently put up an HD7698P with preamp for a neighbor who has as miserable a TV Fool report as I do and he receives all the local stations with no unusual issues. Separate antennas are not required.
http://www.tvfool.com/?option=com_wr...b97dd0d97ac6e0
The local stations are the ones between 271 and 273 degrees. Your stations are on the order of 30-50 dB stronger.
Calaveras is offline
post #6223 of 6239 Old 11-06-2016, 01:48 PM
Super Moderator
DrDon's Avatar
Quoted: 963 Post(s)
Liked: 1952
Moved to Houston thread: >>> Antenna help: Please start with your city's thread in the LOCAL RECEPTION sec 1st
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is online now
post #6224 of 6239 Old 11-06-2016, 05:23 PM
rabbit73's Avatar
Quoted: 436 Post(s)
Liked: 176
How did you combine your two antennas, with a splitter in reverse or a UVSJ?
Lord Kelvin, 1883
rabbit73 is offline
post #6225 of 6239 Old 11-06-2016, 07:36 PM
rcbtaw's Avatar
I used this which I assumed is a UVSJ:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
rcbtaw is offline
post #6226 of 6239 Old 11-07-2016, 08:00 AM
rabbit73's Avatar
Quoted: 436 Post(s)
Liked: 176
Thank you for answering my question. I wanted to be certain that I gave you an accurate answer about a combo antenna equivalent to your combined separate antennas.
The MCM 33-2230 combiner IS described as a UVSJ, but there have been reports of problems with it. Maybe those users just had a defective unit, or didn't connect it properly. There is a part of the description that bothers me; it is either an error or is a design fault:
Insertion loss: 3.5dB
A UVSJ should have an insertion loss of less than 1 dB; usually about 0.5 dB.
I ordered 4 Stellar Labs coax jumpers that were described as equal to gold Monster cable jumpers for 1/4 the price. The quality was so bad, I couldn't even use them because the hex nuts were frozen.
If you suspect trouble with the MCM combiner, I suggest you substitute another brand of UVSJ.
Most UHF/VHF combo antennas have an integrated UVSJ that uses shorting stubs to block any UHF signals from the VHF section, but Winegard uses a combiner and balun in a plastic housing.
The RCA ANT751 uses shorting stubs:
This is the combiner used by Winegard:
How To Troubleshoot a Winegard Antenna Cartridge Housing
Name:	RCA ANT751stubsRev2.jpg
Lord Kelvin, 1883
rabbit73 is offline
post #6227 of 6239 Old 11-10-2016, 04:44 AM
rcbtaw's Avatar
Anybody else experience audio drops during Arrow and Frequency on 39 last night? Issue ended for me when 39 switched to its local news.
rcbtaw is offline
post #6228 of 6239 Old 12-26-2016, 12:25 PM
BPTTV's Avatar
Quoted: 27 Post(s)
Originally Posted by kevinbf View Post
I have a weekend house on Lake Livingston, about 83 miles from the towers in SW Houston. We decided we weren't getting our money's worth with cable and satellite since we weren't there enough and didn't watch TV a lot even when we were. I have always wondered whether an antenna would even be possible at that distance. Not knowing much about antennas at the time, I researched long range antennas with good reviews on Amazon and bought something called the Marathon Distance Amplified HDTV Antenna.
(Sorry can't post links yet, so no TVFool link)
Not expecting much because of the distance, I mounted the antenna on the eave of the second story of the house (about 25 ft. AGL) and was surprised to get a pretty solid signal on all of the major stations (2, 8, 11, 13, 20, 26, 39) and a many others, over 100 channels in all- most of which I'm not interested in. The reception is strong most of the time but occasionally blanks out or disappears for a period of time. (The house is lakefront if it makes a difference btw)
Since then I've been doing quite a bit of research on antennas and learned about multipath interference, which I'm assuming is the cause for the reception issues at times. I've read in the forum that a 2edge signal path will never get completely solid reception because of multipath.
Is there any reason to beat my head against the wall by trying different antenna/amplifier combos or should I just live with the occasional lapses in reception and be glad I'm getting anything at all?
Thanks in advance for your advice.
Kevin F.
At Livingston, you can go for a CM7777 amp at the antenna and that should clear up any dropouts; personally I like the RS VU45- or VU90 or CM 3016/3017 models....also the higher the better on the antenna...I usually recommend 30 ft as a min...anything higher is great
BPTTV is offline
post #6229 of 6239 Old 01-15-2017, 01:19 PM
rcbtaw's Avatar
Anybody out there in Houston area getting signal drops on FOX 26? Noticed it yesterday during the playoff game. It's worse today. No other UHF channel experiencing any signal drops (2, 20, 39).
rcbtaw is offline
post #6230 of 6239 Old 01-15-2017, 02:21 PM
GadgetJunkies's Avatar
Yes, I just installed my setup yesterday and was wondering if it was me. I have the AD Clearstream 2V mounted on my roof with a 5' extension and a PCT-MA2-4P Amp. All other channels are great but Fox is bad. I'm in Fulshear, so about 30 miles from the towers but my antenna shouldn't be the issue. I'm getting mid 60's on the signal meter.
SAMSUNG SAM-UN75JU 75" 4K Ultra High Definition TV
POLK Audio Vanishing RT Series in-wall 6.5" 2 way
PLK V60 POLK AUDIO 6.5" in-ceiling
Polk DSWPRO 660wi 12-inch High Performance Subwoofer /400 WATTS
Onkyo TX-SR607
GadgetJunkies is offline
post #6231 of 6239 Old 01-15-2017, 02:27 PM
rcbtaw's Avatar
I have always received 26 at 95-100%. Don't know what is up.
rcbtaw is offline
post #6232 of 6239 Old 01-22-2017, 07:33 PM
rcbtaw's Avatar
One week later still intermittent break ups on Fox 26. No other problems on other UHF channels.
rcbtaw is offline
post #6233 of 6239 Old 01-22-2017, 07:36 PM
lohertz's Avatar
I didn't see anything, but I wasn't watching very intensely.
lohertz is online now
post #6234 of 6239 Old 01-24-2017, 04:23 AM
rcbtaw's Avatar
All my reception on all channels down this morning. starting to think problem is on my end.
rcbtaw is offline
post #6235 of 6239 Old 02-05-2017, 05:21 PM
rcbtaw's Avatar
Moved my UHF antenna to a different spot in my attic because of the constant Fox 26 signal drops. Finally got my reception back to 95-100%. I find it funny that the only UHF channel that was affected when I moved the UHF antenna when I combined it with a VHF antenna was 26. The whole process has taught me that if I am having reception issues, it's probably on my end.
rcbtaw is offline
post #6236 of 6239 Old 02-18-2017, 01:02 PM
newsman's Avatar
It usually starts at home (or wherever the antenna is placed). Before the Super Bowl, Fox 26 engineers were making sure they were operating at 100%. Didn't need any issues on the most watched event of the year for them.
newsman is offline
post #6237 of 6239 Old 04-04-2017, 08:21 AM
brg606's Avatar
I set up my antenna a couple weeks ago and reception of the Houston locals has been fine until this morning. They are all weak, especially the vhf channels 8, 11, & 13. Anybody else?
Update...all channels coming in strong again. For some reason this morning from 8:00-10:30 or so all the vhf channels were very weak.
brg606 is offline
post #6238 of 6239 Old 04-04-2017, 06:58 PM
rcbtaw's Avatar
I had the same problem from when my wife turned on the tube at 6am. Tonight all back to normal.A
rcbtaw is offline
post #6239 of 6239 Old Today, 06:49 AM
lohertz's Avatar
There was a lot of vhf interference yesterday. Not sure of the cause, but some FM stations were having reception difficulty on my morning drive in.
