Norfolk, VA - OTA - Page 223 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #6661 of 6766 Old 05-07-2014, 07:03 AM
Digitude's Avatar
Has anyone here tried one of those ClearTV antennas? (as seen on TV) I live on the north side of VB and have never had much luck with indoor antennas. I have a guest bedroom with no cable drop and thought I might try this. Not sure if it is new technology or just another "rabbit ears".
Digitude is offline
post #6662 of 6766 Old 05-07-2014, 08:56 AM
ADTech's Avatar
Quoted: 121 Post(s)
Liked: 65
They're inexpensively made UHF-only antennas. The Chinese manufacturer (Qiaohua) was courting us a few years back (before they signed up Solid Signal and MCM Electronics) and their rep bragged that they made the antennas for that company. She even said there was nothing special about the technology.
We had some poor soul who had bought four of them (with amplifiers) return them to us by accident. We forwarded them back to the US-based reseller for the customer.
Tech support for Antennas Direct
ADTech is offline
post #6663 of 6766 Old 05-07-2014, 09:08 AM
Digitude's Avatar
Thanks. I'll pass.
Digitude is offline
post #6664 of 6766 Old 06-08-2014, 05:53 PM
2pugsinapod's Avatar
I am trying to figure out which antenna to purchase. Here's a little background on my situation first.
I'm in Norfolk, VA, pretty much in the middle of the city. My house has aluminum siding. There's an old style antenna that has been attached to a chimney since before I bought the house 10 years ago. A cable is draped across the lower roof which is tin. The entire west side of the house is shaded by very tall pine trees. Shorter trees are on the other three sides. My house is multi-story. One section is two stories with a full story attic. Another section is only one floor. That section has a chimney. That chimney is on the western side. There is another chimney that extends from a second story roof. This chimney is very close to oak and pine trees. I do not have a chimney that goes through the very top roof.
The TV is on an interior wall of the house, the only place it can go. My current set up uses a long co-ax cable from the TV to the antenna.
I currently have a RCA indoor antenna, ANT112F. It is sitting in a northern window, vinyl. The window is across the room from the TV, and it's the only window in the room. It was doing ok, except that the window is where the cats want to be. One of the rabbit ears broke. Because I'm frugal, I taped it back together.
The dropped signal drives me bonkers. Almost to the point of going back to cable. It never drops during commercials, just during the intense scenes of a show! The signal did drop some before the break, but it seems so much worse now.
So, what am I looking for? I need an antenna that is less likely to drop the signal, even during a breeze or storm. If it's a window unit, a non rabbit ear that won't tangle a kitty. Would the old antenna still work? Or does it go bad? Forgive my ignorance on this. I didn't realize that co-ax cables could go bad, but I had one that just stopped working. I'm guessing that the old antenna is at least 20 years old. I'm assuming that the cable would have to be replaced. I haven't been on the roof to inspect it, but is that something I could do or would I need a professional?
If I do need an exterior antenna, is that something I could do (or have help with)? It appears to be attached with metal to the brick chimney. From there, I would rather run the cable down the chimney and wall of the house to go through the floor. That's how the commercial cable is run.
I've been reading about interior antennas, but the descriptions all say something about interference from metal exteriors. Does the fact that the antenna is in the window somewhat alleviate that issue? Would a Leaf or a Monoprice HDA 3700 work better? Or just let it go and find a professional?
Also, I don't want to invest lots of money because I'll be moving in a year or two.
If you've made it this far, thank you in advance for any and all advice.
2pugsinapod is offline
post #6665 of 6766 Old 06-08-2014, 11:58 PM
KC4JGC's Avatar
2pugs,
Before doing anything else, have you tried connecting the cable from the outside antenna to see if you need to purchase anything? Yes, cable can go bad; I would try the existing cable first before buying a replacement.
Second, is that outside antenna vhf and uhf? If it is, you should be in business as long as there no damage to the antenna (no missing elements and no corrosion at the feedpoint) and is pointed in the correct direction. All the local TV transmitters, with the exception of WSKY are due west in the Driver section of Suffolk. All local full power TV stations -- except WVEC 13 and WTPC 21 (rf channels 13 and 7 respectively) -- are transmitting on uhf, despite what the virtual channels on your set may say. If your antenna is vhf only, you may have trouble with uhf.
Trees can be a problem with digital TV; how much depends on each situation. One thing for sure is that aluminum siding and tin roof will not do you any favors as far as hanging an a full size antenna in an attic. Indoor "rabbit ear" antennae are compromises.
When I was living in Norfolk (near Tidewater @ E. Little Creek), I used a small uhf antenna on a mast strapped to a chimney about 25 above the ground. Feedline was 50' of Cox issue RG 59 cable. I had no trouble with all local full power stations in normal conditions. I had some trouble with WVEC during heavy storms, something that didn't happen when their digital was still on ch 41! I could even receive WSKY (after they finally transitioned from rf ch 4 to rf ch 9) except when heavy rains were in the area. On good days I could even watch low power WGBS 7 (rf ch 11) in Portsmouth.
In a nutshell, YES, use that outside antenna if you can!! You may need to go up there to change height/azimuth for optimum viewing; if both antenna and cable are in good condition, you won't need to spend a red cent!
One other thing, once you connect your TV to that outside antenna and verify all is in working order, be sure to have your TV run a scan through the channels to make sure you're receiving all you can. You can stop your scan once it reaches ch 52 (WGNT 27 is physically on the highest channel available, ch 51).
Hope that helps,
Steve
Steve KC4JGC
KC4JGC is offline
post #6666 of 6766 Old 06-09-2014, 06:36 AM
starrin's Avatar
Originally Posted by KC4JGC View Post
2pugs,
Have to agree with Steve. I installed an outside antenna on the house when I first moved in in 1973. There was no cable at my location in V.B. Though I'm on cable now, if I need to shift to the antenna (storms/power outages - no cable) I can still get about 20 channels. Have changed nothing in that installation.
starrin
starrin is offline
post #6667 of 6766 Old 06-10-2014, 04:55 PM
Steve and Starrin, thank you for your responses. I'll have to do some homework to identify what kind of antenna it is. I'll also need to figure out where the cable goes once it disappears into the house. I would like to move the cable though. It goes from the correct side (where the tv is) to the other side of the house. I'm guessing I would need 75-100 feet of cable to reach the tv, if I left it as is. If I see that the cable and can be unscrewed like a regular co-ax cable, I will just replace it so I can get it where I want it to be.
I'll have to get on the roof and look at it more closely. The straps that attach it to the chimney are rusty. If there is rust on the antenna, it isn't visible from the ground. The end with all the spikes is pointed northwest.
Another question. Is there any significant loss in strength if I have to connect two cables together in order to meet the length? I have a longer cable now, but I'm not sure what "strength" it is. I know that exterior extension cords are rated. Steve mentioned a numbered cable. Is that similar to extension cords? I'm guessing that the optimum choice is one cable of a higher strength. However, if that's not an option, how bad would it be to connect two of different strengths and lengths?
post #6668 of 6766 Old 06-23-2014, 11:43 PM
dtv_junkie87's Avatar
Quoted: 40 Post(s)
Liked: 25
WTVZ to get getTV on a subchannel soon:
http://www.tvtechnology.com/news/008...tations/271009
dtv_junkie87
dtv_junkie87 is offline
post #6669 of 6766 Old 06-30-2014, 06:17 PM
Originally Posted by 2pugsinapod View Post
<p>Steve and Starrin, thank you for your responses. I'll have to do some homework to identify what kind of antenna it is. I'll also need to figure out where the cable goes once it disappears into the house. I would like to move the cable though. It goes from the correct side (where the tv is) to the other side of the house. I'm guessing I would need 75-100 feet of cable to reach the tv, if I left it as is. If I see that the cable and can be unscrewed like a regular co-ax cable, I will just replace it so I can get it where I want it to be. </p>
<p>I'll have to get on the roof and look at it more closely. The straps that attach it to the chimney are rusty. If there is rust on the antenna, it isn't visible from the ground. The end with all the spikes is pointed northwest. </p>
<p> </p>
<p>Another question. Is there any significant loss in strength if I have to connect two cables together in order to meet the length? I have a longer cable now, but I'm not sure what "strength" it is. I know that exterior extension cords are rated. Steve mentioned a numbered cable. Is that similar to extension cords? I'm guessing that the optimum choice is one cable of a higher strength. However, if that's not an option, how bad would it be to connect two of different strengths and lengths?</p>
After a scare with a stepladder inside the house, I'll be leaving the outside antenna to someone else. Some of the brackets are completely separated from the brick chimney. Also, where the cable goes into the house, five other cables also go in. I can't figure out which one goes where.
Any advice on a reputable company to check out whether the existing antenna works and rewiring it? I prefer to hire local instead of corporate when I can.
post #6670 of 6766 Old 07-03-2014, 09:36 PM
KC4JGC's Avatar
Any reputable electrician should be able to help you. Be prepared to dig deep! At least $40/hr.
Steve KC4JGC
KC4JGC is offline
post #6671 of 6766 Old 07-08-2014, 05:19 AM
kes601's Avatar
Quoted: 20 Post(s)
Anybody notice auto blips on WTKR-HD on Monday night? I didn't check OTA but on FiOS it was happening during programming and commercials so I am assuming it was a station issue and not a national issue. I noticed it both on a surround sound setup and a regular tv setup.
kes601 is offline
post #6672 of 6766 Old 07-23-2014, 01:26 PM
KC4JGC's Avatar
Any update on your progress?
Steve KC4JGC
KC4JGC is offline
post #6673 of 6766 Old 07-23-2014, 07:56 PM
Steve KC4JGC,
I have not even attempted anything yet. My senior pug was diagnosed with cancer and recently had surgery. All my focus (and extra money) has gone for her care. She's recovering now, so maybe in August, I can redirect my energy toward the antenna.
I work with electricians so I'll start with them for recommendations, I think. I hadn't even thought to go with an electrician first.
Thank you!
post #6674 of 6766 Old 07-31-2014, 07:05 PM
zpf
zpf's Avatar
dtv_junkie87
Yeah, comes in about as good as Me and AntennaTV for me. I'm in the Salem Lakes area.
zpf is offline
post #6675 of 6766 Old 07-31-2014, 07:19 PM
zpf
zpf's Avatar
I have a basic Epson projector that plays DVDs and has various types of inputs, including RCA. I would like to hook it up for OTA, but I'm not sure what additional equipment I'd need. I'm assuming I'd need a tuner and an antenna. Am I right? If so, can anyone recommend a tuner for this purpose?
zpf is offline
post #6676 of 6766 Old 09-16-2014, 03:23 PM
levets's Avatar
Quoted: 17 Post(s)
I'm in Suffolk, right across the Chesapeake city line near the "TV Towers" (re-transmitters I think? Used to say WVEC-13 IIRC years ago) that have been there for decades. Was considering an indoor OTA - I didn't realize things like the the Leaf or Curve were so inexpensive - even the 50 versions of those are not too pricey - if they work. TV Fool says I should get everything I do on Satellite and maybe a couple more (probably the things like the shopping or church channels I don't care about though...). Can I expect much from a Leaf or Curve (I just like the "designer" aspect of the Curve) in my area? Seems like with such a large metro there should be plenty of signal, though it would be cool to get something that maybe DirectTV doesn't have (I get ABC. NBC. CBS, WGN, WTVZ, PBS and WVBT locally, as well as PBS and WSKY from NC, and Ion from the DirectTV box).
levets is offline
post #6677 of 6766 Old 10-26-2014, 11:53 AM
STVA1's Avatar
I've noticed that college and NFL football games on both Fox and CBS seem to have issues with surround sound all the sudden, i.e. all sounds are coming from all 5 channels. Is it just me? Normally the center speaker has the announcers and the surrounds have crowd noise.
Surround sound is working fine on my Xbox though, and my receiver indicates it should be working on TV, which makes me think the stations started to do something wrong?
*EDIT* I figured it out, it was a setting on my AVR. No idea how it got changed to that setting.
STVA1 is offline
post #6678 of 6766 Old 01-28-2015, 07:53 AM
KC4JGC's Avatar
THIS on WTKR 3.2! Also JN on 13.2
I don't know if I missed an announcement or maybe WTKR is testing; I did a rescan on my truck TV Monday night to find that WTKR was showing THIS on channel 3.2! I've been waiting for some station in this market to carry the classic movie network that's carried on just about every neighboring market from Baltimore to Greensboro.
Was this a quiet launch? There's no mention of THIS on WTKR's web site. THIS web site doesn't acknowledge an affiliate in the area.
Also, I noted WVEC no longer carries Live Well on 13.2; been replaced by Justice Network; a check on their web site says it was launched on Jan 20. http://www.13newsnow.com/story/life/...work/22116805/
Steve KC4JGC
KC4JGC is offline
post #6679 of 6766 Old 01-28-2015, 09:00 AM
VARTV's Avatar
Quoted: 65 Post(s)
Liked: 26
thistv has been on 3-2 almost two months. Justice replaced LWN on the 20th at 6 p.m. (national sign-on). The pull was to be pulled on LWN but I think it's still running on some stations around the country (ABC O&O's?)...
Robert F Corbin
VARTV.com | Virginia Media News & Information
email: editor@VARTV.com
facebook: facebook.com/VARTV
twitter: twitter.com/VARTV
linkedin: linkedin.com/in/VARTV
google+: plus.google.com
pinterest: pinterest.com/VARTV
VARTV is offline
post #6680 of 6766 Old 01-28-2015, 09:29 AM
KC4JGC's Avatar
Smile
Thanks, Bob for the quick response. It must have been a very quiet launch at WTKR, especially since there's no mention on either their or thistv site.
Steve KC4JGC
KC4JGC is offline
post #6681 of 6766 Old 01-28-2015, 10:26 AM
VARTV's Avatar
Quoted: 65 Post(s)
Liked: 26
Yep... Zero promotion. Justice, on the other hand, was getting promoted on WVEC's main channel...
Robert F Corbin
VARTV is offline
post #6682 of 6766 Old 01-28-2015, 04:22 PM
levets's Avatar
Quoted: 17 Post(s)
I actually hadn't noticed the LWN but I had actually taken it off a favorites list before the 20th so...
Yeah, This TV has been on I think since I bought that antenna, looks like around Sept 16th.
If they only carried - I think it's RTV - there's some station locally that carries it but the other signals around me are so strong that they mask it and it's beyond my effort to try to get it.
Steve
levets is offline
post #6683 of 6766 Old 01-28-2015, 04:37 PM
VARTV's Avatar
Quoted: 65 Post(s)
Liked: 26
Steve
WGBS/7 (digital 11) carries it. Are you close to Norfolk / Portsmouth?
Robert F Corbin
VARTV is offline
post #6684 of 6766 Old 01-28-2015, 06:07 PM
levets's Avatar
Quoted: 17 Post(s)
I can't get it (without some supression and other antenna antics based on info in another thread). I live near the "TV Towers" at the chesapeake/suffolk line and I think the signal from them is so close that they block out anything else farther away (what I was told in the other thread).
levets is offline
post #6685 of 6766 Old 02-25-2015, 07:02 PM
Skeletor's Avatar
I posted this in another thread but I figure the local guys might be able to help me more.
None of the simple indoor options I tried worked. I've bought and returned about 5 antennae from WalMart. I think my location not near a window and the interference from the TV and metal on the stand are causing my problem. My option now is to try to use an old cable line run in the attic from behind my TV to an attic mount antenna. I was thinking of getting this one since it's at WalMart and it's fairly inexpensive.
http://www.walmart.com/ip/GE-Attic-M...tenna/20976617
Again, here are my TVFool results
http://www.tvfool.com/?option=com_wr...f1f03ed69eda32
I should be good with this one, right?
Also, this may be dumb, but can you split the signal coming to from antenna? I have one TV in the den and one in the bedroom. Or should I just get a small indoor one for the bedroom?
Skeletor is offline
post #6686 of 6766 Old 04-23-2015, 05:29 AM
Trip in VA's Avatar
Quoted: 545 Post(s)
Liked: 145
Send a message via AIM to Trip in VA
WJGN-CD 38 is now on the air, evidently without PSIP. Anyone seeing it?
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
post #6687 of 6766 Old 04-23-2015, 07:57 AM
VARTV's Avatar
Quoted: 65 Post(s)
Liked: 26
- Trip
Yep! I thought they were an affiliate of FamilyNet, not NRB Network. Eventually they might run multiple streams...
Robert F Corbin
VARTV is offline
post #6688 of 6766 Old 04-26-2015, 07:09 AM
Skeletor's Avatar
Has anyone else had a problem with WTKR? I did a channel scan and it seems to be on frequency 40 and 18. 18 has no picture and 40 has a picture with no show info.
Skeletor is offline
post #6689 of 6766 Old 05-07-2015, 12:24 PM
JimG19's Avatar
Yes.
I use a tivo hd and had this issue as you describe. I notified tivo and zap2it of the issue and it was resolved for me about a week ago. You might want to try another channel scan and hopefully it will be fixed for you as well.
Jim
JimG19 is offline
post #6690 of 6766 Old 05-12-2015, 06:33 AM
sepepper's Avatar
Thumbs up Success with Tablo OTA DVR
I'm in Norfolk VA, I have fairly good (but not perfect) clearance to the southwest, towards the Driver, VA antenna farm area where most of the local stations have their OTA TV towers. I recently ordered and set up a Tablo OTA DVR (2 tuner) which is a high VHF/UHF HDTV tuner and DVR that is viewed via LAN on app devices including Roku, Android. It connects via ethernet to my home LAN and has USB connectors for external hard drives for recording storage. Compared to the Silicon Dust HD Homerun tuners I was using (networked but only successfully viewed through Windows Media Center in my setup), it runs a whole lot better with regard to scanning for channels, and streaming the video signals. I was experiencing a lot of "broken streaming" on the HD Homerun/WMC setup, where it would seem as if someone was remotely toggling the play/pause button. I am running Cox internet premier level service, so bandwidth is not an issue-- the HD Homerun/WMC simply had severe performance issues. I am also using 2 amplified Mohu leaf antennas diplexed together, & located in separate areas (den & kitchen windows) which both face in same SW direction that I require. I am getting 26 channels, including Me TV on 13.3, Get TV on 33.2, and Grit TV on 33.3, the best classic rerun & movie channels, IMHO. All of the channels that the Tablo successfully scanned range from a 3 to 5 out of 5 on their signal quality-- and has perfect streaming & viewing quality with no broken/frozen streaming annoyance. I discovered that the Tablo requires a subscription service (monthly, yearly, or lifetime is offered) for receiving the EPG data on it for the onscreen TV guide & recording scheduler, but all of the alternate brands of these kinds of DVRs (Tivo etc) require similar purchasing schemes. I am very pleased with the performance & features of the Tablo, and I now have a clear path to my ultimate goal of cancelling the $100+ monthly TV cable fee from Cox!
Last edited by sepepper; 05-12-2015 at 06:38 AM. Reason: I needed to add another comment
sepepper is offline
