Detroit, MI - HDTV - Page 369 - AVS Forum | Home Theater Discussions And Reviews
 77Likes
post #11041 of 12452 Old 03-16-2012, 03:25 PM
dsscpu's Avatar
I noticed this as well. Its too bad, I liked the way it was...
dsscpu is offline
post #11042 of 12452 Old 03-17-2012, 09:25 AM
Super Moderator
DrDon's Avatar
Quoted: 895 Post(s)
Liked: 1763
A lot of us did, too. But it wasn't sticking where it counted.
On the bright side, we get to skip the subchannel stuff. For now, at least.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is online now
post #11043 of 12452 Old 03-17-2012, 10:29 AM
dsscpu's Avatar
Agreed, re: subs except I wouldn't mind getting a 'First Weather' sub that had radar + hourly forecasts... or any other weather based station amongst the Detroit/Windsor OTA's...
dsscpu is offline
post #11044 of 12452 Old 03-17-2012, 10:52 AM
Super Moderator
DrDon's Avatar
Quoted: 895 Post(s)
Liked: 1763
I've heard from different stations that the proliferation of smartphone and computer weather apps, plus the unlikeliness of cable carriage makes the money and effort to program one a nonstarter. As always, that could change. Heck, I've got a TV that grabs that from the internet and both my cable and DSS boxes have instant weather, too. My Windows Phone has the best radar app I've ever seen. And it's frighteningly fast to load and display. Zoom, move, motion.. all with fingertip access. You'd have to wait for a weather sub to cycle through to the view you wanted.
DrDon is online now
post #11045 of 12452 Old 03-18-2012, 10:15 AM
00firebird's Avatar
my face when ctrl+f, 1080p. zero results.
when are we gonna start getting 1080p?
00firebird is offline
post #11046 of 12452 Old 03-18-2012, 11:31 AM
Ken H's Avatar
You already have it from BD and select pay providers.
From linear TV channels? Probably never, because they will most likely evolve to higher resolutions (see the 4K topic in the HDTV Programming Forum: http://www.avsforum.com/avs-vb/showthread.php?t=1400304 ) as opposed to putting more infrastructure into existing standards.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #11047 of 12452 Old 03-18-2012, 04:31 PM
Ken H's Avatar
PGA Golf today on NBC WDIV-DT. Dolby Digital is screwed up again; no feed for center & l/r surrounds.
Ken H is offline
post #11048 of 12452 Old 03-18-2012, 06:35 PM
MWmetalhead's Avatar
I actually begged 'em to consider a lower virtual channel number so we'd be nested closer to the other network stations. Legal shot that down as there really wasn't an easy choice that wouldn't have drawn objections from an adjacent market. And a lot of cable systems have 'em all nested pretty close, anyway. So, CBS62 it is.
Definitely makes sense.
"CBS 6" would've been perfect, but I suspect the folks at WLNS in Lansing might not be too happy about that. (WLNS has a large viewership in Livingston County.)
The only VHF channel number not used for branding or PSIP in either Detroit, Windsor, Flint / Saginaw, Toledo, and Lansing is "3." However, "3" would be so radically different from "62" that using it would probably be a terrible idea!
So, in the final analysis, I'm cool with CBS 62.
MWmetalhead is offline
post #11049 of 12452 Old 03-18-2012, 06:38 PM
Trip in VA's Avatar
Quoted: 563 Post(s)
Liked: 150
Send a message via AIM to Trip in VA
What would have been wrong with 14? Co-owned WKBD uses it as their RF channel.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
post #11050 of 12452 Old 03-18-2012, 06:46 PM
Super Moderator
DrDon's Avatar
Quoted: 895 Post(s)
Liked: 1763
Trip.. 14 is where they are on some cable systems. Plus, it's still at the high end (of cable net affiliate placement). So, 14 gets them nothing.
3 is out of the question since no cable system would put them there due to all of the converters that use 3 as an output. I don't know about Comcast, but every other cable system I've lived with used 3 as a billboard or some other useless access channel. Granted, nobody's ON 3, so ingress from the outside isn't an issue, but I'm guessing in-house interference was the primary reason 3 was never on the list. Moot now as they're sticking with 62.
DrDon is online now
post #11051 of 12452 Old 03-18-2012, 07:13 PM
Ken H's Avatar
Re: TV Ontario - TVO Digital Channel 32
TVO has been on the digital air since last September, when the Canadian digital transition occurred. They broadcast from the same tower as the CBC affiliate CBET, located in McGregor, ON. Here is a coverage map from our friend Trip at RabbitEars.info: http://www.rabbitears.info/contour.php?appid=1283753
As you can see, many Detroit area viewers can receive TVO with the same antennas they currently use for Detroit stations.
For the TVO stations located West of Toronto, they use a 'digital daisy chain' from the main OTA transmitter in Toronto. Any OTA disruption between Toronto heading West causes the HD go away and the system drops back to SD. SD is distributed by satellite (plans are for satellite HD distribution at some point when the money is available) so it's not subject to the same OTA disruption. The other TVO stations Windsor HD is dependent on are Chatham, London, and Kitchener.
They have been experiencing some problems with this system and for the time being they have dropped to SD, and also do not have PSIP. It should take 2-3 weeks to test the proposed fix and if it works, fine, if not it will take longer to correct the problem.
Having seen TVO HD, I can tell you:
1) It's really good 1080i, because they have no subchannels.
2) They offer a wide variety of programming, with many programs not available from other sources in our area. This includes the famous Saturday Night At The Movies series with exclusive films and commentary from industry insiders.
Ken H is offline
post #11052 of 12452 Old 03-21-2012, 06:09 AM
Ken H's Avatar
Originally Posted by DrDon View Post
The HD buildout was completed here about a month or so ago. The changes I spoke of - largely cosmetic - Begin this Thursday. It's stuff the other O&Os are already doing. No biggie.
I happened to flip to WKBD-DT this morning and was stopped by the sheer HD goodness of 'First Forecast Mornings'. I didn't hear much of what they were saying because the video was so good...
Ken H is offline
post #11053 of 12452 Old 03-21-2012, 10:09 PM
Ken H's Avatar
The Tonight Show on NBC WDIV-DT. Dolby Digital is screwed up again; no feed for center & l/r surrounds.
Ken H is offline
post #11054 of 12452 Old 03-22-2012, 01:06 PM
Ken H's Avatar
WMYD-DT channel virtual 20, real UHF 21, is off the air, at least for now. Not sure when it started.
Ken H is offline
post #11055 of 12452 Old 03-22-2012, 01:29 PM
dsscpu's Avatar
Before they went off-air, I noticed that their PSIP was messed up and while it was remapping to 20, there was no IPG info.
dsscpu is offline
post #11056 of 12452 Old 03-22-2012, 04:29 PM
dsscpu's Avatar
Technical issues knock Detroit's WMYD off the air this afternoon
MyNetworkTV WMYD-TV Ch. 20 Detroit has been off the air for at least the past 90 minutes as of 4:30 p.m. The outage does not appear to be affecting the other TV stations (WWJ-TV Ch. 62, WTVS-TV Ch. 56, WUDT-CA Ch. 23) that also broadcast from the same tower. The outage affects both Ch. 20.1 and Ch. 20.2. At least some cable providers are also affected- Comcast is displaying blue 'technical difficulty screens for Ch 20.1, both SD and HD, and Ch. 20.2.
http://www.michiguide.com/archives20...mar-22-20.html
dsscpu is offline
post #11057 of 12452 Old 03-22-2012, 04:59 PM
Super Moderator
DrDon's Avatar
Quoted: 895 Post(s)
Liked: 1763
It's been down since around 2. That's the last time I ran a scan and 20 fell out of my list. Also about the same time as the first report on Facebook.
Strangely, there's no official mention on their website or Facebook page. Unless I missed it.
DrDon is online now
post #11058 of 12452 Old 03-22-2012, 06:28 PM
Jeremy W's Avatar
Quoted: 14 Post(s)
Still down as of right now. Must be pretty serious.
Jeremy W is offline
post #11059 of 12452 Old 03-23-2012, 05:47 AM
billmich's Avatar
Quoted: 258 Post(s)
Liked: 60
What does the CA stand for in WUDT-CA?
billmich is offline
post #11060 of 12452 Old 03-23-2012, 05:51 AM
Super Moderator
DrDon's Avatar
Quoted: 895 Post(s)
Liked: 1763
"Class A." Sort of a low power station that gets RF protection wheras LPs are on their own.
DrDon is online now
post #11061 of 12452 Old 03-23-2012, 08:33 AM
Ken H's Avatar
Not sure when they got back, but WMYD-DT is up and appears to be running like normal again. I hope we hear what happened.
Ken H is offline
post #11062 of 12452 Old 03-24-2012, 12:34 AM
Jeremy W's Avatar
Quoted: 14 Post(s)
A poster on another site emailed the station's GM and received this reply:
Thanks for your email.
Our power supply was unstable yesterday and we had to power down our
transmitter to avoid damaging it. This forced us to go off the air while
we fixed the problem. I am happy to say that the problem is fixed and
you can enjoy watching TV20 again.
Thank you for watching our station, we always like to hear from our
viewers.
David Bangura
President/ General Manager
MyTV20 Detroit
Source: http://www.mibuzzboard.com/phpBB3/vi...427306#p427306
Jeremy W is offline
post #11063 of 12452 Old 03-24-2012, 11:18 PM
Ken H's Avatar
Thx.
Ken H is offline
post #11064 of 12452 Old 03-25-2012, 11:49 AM
Net313's Avatar
No redundancy? I would think they should have two full exciter/transmitter/power supplies, but it is Granite, too.
Net313 is offline
post #11065 of 12452 Old 03-25-2012, 11:53 AM
Super Moderator
DrDon's Avatar
Quoted: 895 Post(s)
Liked: 1763
Given the outlay to move from analog to digital, I imagine a lot of smaller stations are rolling the dice until they can work yet another transmitter into the budget.
DrDon is online now
post #11066 of 12452 Old 03-25-2012, 02:23 PM
Ken H's Avatar
Ken H is offline
post #11067 of 12452 Old 03-27-2012, 02:08 PM
redwings1914's Avatar
Substantial HD additions and lineup shuffling very simular to what is seen at http://www.mycharterchannels.com/ will be coming to Charter customers in Michigan this summer.
redwings1914 is offline
post #11068 of 12452 Old 03-27-2012, 02:17 PM
Ken H's Avatar
Good deal. It looks like most Charter areas will have access to over 50 HD channels. This will be helpful for the Lineup topic in the HDTV Programming Forum.
Ken H is offline
post #11069 of 12452 Old 03-27-2012, 03:19 PM
Super Moderator
DrDon's Avatar
Quoted: 895 Post(s)
Liked: 1763
5:18 and WDIV just went south on BHN. Analog and Digital ....for about three minutes.
IOW, it just came back as I was typing this.
NVM, move along. Nothing to see here. Of course, now I have to re-scan to get WDIV digital back. SIGH
DrDon is online now
post #11070 of 12452 Old 03-27-2012, 08:25 PM
dsscpu's Avatar
Has anyone contacted WPXD as of late to find out what the hold up is with going to RF 50?
dsscpu is offline
