Detroit, MI - HDTV - Page 395 - AVS Forum | Home Theater Discussions And Reviews
 81Likes
post #11821 of 12489 Old 06-22-2014, 12:40 PM
Bozzmonster's Avatar
Quoted: 17 Post(s)
Originally Posted by itsthemultipath! View Post
They share the same tower. Wonder if they suffered a power outage because of the thunderstorms?
It is not unusual to see stations in other markets on humid summer nights. It's a phenomenon called "tropospheric refraction".
Good point. I think it was probably some sort of maintenance - they were back up later in the morning. No storms to think of - I live an easy bicycle ride away from the tower. I love the humid summer nights for the DXing opportunities.
Bozzmonster is offline
post #11822 of 12489 Old 06-25-2014, 08:44 PM
Northville Dave's Avatar
This may be a bit off topic but I hope someone can help. I've dropped Comcast TV for the summer and am using a media center pc connected to my Vizio 42" HDTV. Most of the time everything works great be every so often I get some really strange stuff.
(I usually run WMC on the PC for my recording and viewing needs but the strange stuff occurs with HDHomeRun Quick TV and MediaPortal as well.
I have an OTA antenna feeding a one to four powered amp with three of the outputs feeding ATSC tuners and the fourth properly terminated.
The strange stuff occurs most often when I have two of the tuners set to the same fairly weak channel, TVO 32 for example. I get a noise free picture on both the PC and the TV until I select the HDMI input the PC is connected to and the picture sync's.
Once this occurs the pic gets very noisy, even sometimes freezes on both the PC and the Vizio on even when using the "TV" input! Strange enough by itself, but the really strange part is that often the pic will return to noise free if I change my PC's desktop background to a less "busy" image or make the TV window on the PC full screen.
If I'm recording while this is going on the recording will be noisy also.
Will having two tuners tuned to the same channel diminish that channel's signal?
Anyone have any ideas what's going on here?
Dave
on Comcast Cable of Canton, MI
Northville Dave is offline
post #11823 of 12489 Old 06-26-2014, 01:41 AM
Super Moderator
DrDon's Avatar
Quoted: 1208 Post(s)
Liked: 2364
Got any clips of the noise? What's your graphics card and how much memory does it have? It SOUNDS like what happens when you overtax "integrated graphics." But I'd have to see it. However, if you're only experiencing that on weak stations, it kind of rules that out.
Try the same question over in HTPC. If you have a clip, include that.
Or blame it on the Canadians.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
post #11824 of 12489 Old 06-26-2014, 05:00 AM
ProjectSHO89's Avatar
Quoted: 279 Post(s)
Liked: 130
The short answer is "no, but".
I'd be suspicious of some weird combination that is causing RFI back to the antenna, or ingress into the cabling or amp. The elevated ingress noise is masking the desired, weak signal.
ProjectSHO89 is offline
post #11825 of 12489 Old 06-26-2014, 06:08 AM
Gary S's Avatar
Quoted: 25 Post(s)
They are down again this morning. They all have individual generators, so I don't think that they all would be affected by a power outage. I suspect maintenance at the top of the tower having people up there mandating shutting the transmitters off. Or are they adding another station to the area- that low power one that people have been mentioning?
Gary S is offline
post #11826 of 12489 Old 06-26-2014, 07:54 AM
Originally Posted by DrDon View Post
Got any clips of the noise? What's your graphics card and how much memory does it have?......
Probably I shouldn't have called it "noise", it's typical of dropouts and block errors associated with weak signals.
I'll try to post a clip tonight - both here and on HTPC.
I've ruled out the graphics card as the source since the noise also appears on the Vizio TV input which doesn't come from the graphics card and it also corrupts the recorded file of the program.
I'd love to blame it on the Canadians but it seems to occur on other channels at times, eh? (A few months ago you may recall I questioned the signal strength on 9 and 32, now I think the real problem seen then is what we're talking about here.)
Thanks for any and all replies.
Late breaking news! Seems I'll be so busy for the next two weeks I won't have time pursue this issue until the middle of July.
Dave
Last edited by Northville Dave; 06-26-2014 at 08:03 PM. Reason: Putting issue on hold.
post #11827 of 12489 Old 06-26-2014, 07:58 AM
yimitz's Avatar
Quoted: 30 Post(s)
Liked: 48
DPTV/WTVS has a note up on their web page: "SERVICE ALERT: Due to scheduled maintenance DPTV is off the air for part of our service area until approximately 11:00am." So I suspect you are right.
yimitz is offline
post #11828 of 12489 Old 06-26-2014, 08:36 AM
Gary S's Avatar
Quoted: 25 Post(s)
I'm just wondering why they are doing this work at 8 in the morning instead of overnight. Yes, I know it is lighter during the day, but that is a higher viewing time. I know they can and have done work during the night before.
Gary S is offline
post #11829 of 12489 Old 06-26-2014, 10:49 AM
Super Moderator
DrDon's Avatar
Liked: 2364
Forgot to ask while I was chatting with TV, today.
But if it's tower work, then everyone's going to backup antennas (if they have them) or greatly reduced power while the crew's on the stick. Can't do that at night. Again, don't know for sure.
DrDon is offline
post #11830 of 12489 Old 06-26-2014, 01:04 PM
Gary S's Avatar
Quoted: 25 Post(s)
Hi Doc, as I remember (and things could have changed), 20 and 56 don't have backup antennas. Don't remember about 62, but they probably do. Anyway, back in the day when 56's analog transmission line died, they were only allowed by the tower owner to work at the top at night to not take the other stations down during peak hours. I am not sure what is different now, except maybe that many of the channels have a fiber line to some cable companies and they view that as enough coverage. But as you know, not everyone gets their channels that way.
Gary S is offline
post #11831 of 12489 Old 06-26-2014, 01:11 PM
Super Moderator
DrDon's Avatar
Liked: 2364
Right you are. Pretty sure 62 has a backup. We all do. I'd ask, tomorrow, but I'm going to the wrong station for that (subtle plug for my "Live in the D" regular Friday appearance).
DrDon is offline
post #11832 of 12489 Old 06-26-2014, 01:58 PM
Gary S's Avatar
Quoted: 25 Post(s)
Smile
I guess inquiring minds just want to know why the stations have been shut down at least twice now.
Gary S is offline
post #11833 of 12489 Old 07-06-2014, 05:38 PM
Super Moderator
DrDon's Avatar
Liked: 2364
C'MON BRIGHTHOUSE
Came home from vacation to find my CableCARD devices de-authorized for MLB-EI. Happens first of every month. I always have to call twice, then someone finally fixes it. First of May, First of June, Middle of June and now. BUT... Today, I'm told that it's "company policy" not to support sports packages on CableCARD devices. Which, IIRC, is against FCC rules. But they "disagree."
This on a baseball season I've paid twice for. Last year's "Half-year-plus-next-year" price wasn't supported by Brighthouse, so I threw away $150. Paid again, this year and haven't been able to watch squat.
Sorry. Had to rant.
DrDon is offline
post #11834 of 12489 Old 07-07-2014, 06:40 AM
billmich's Avatar
Quoted: 261 Post(s)
Liked: 60
C'MON BRIGHTHOUSE
Sorry. Had to rant.
file a complaint with FCC
Sue for monetary damages...definitely "pain and suffering". Or threaten to and see if you can get a few months of Cable for free. I am sure you are a well connected guy
billmich is offline
post #11835 of 12489 Old 07-07-2014, 08:33 AM
yimitz's Avatar
Quoted: 30 Post(s)
Liked: 48
C'MON BRIGHTHOUSE
Sorry. Had to rant.
I suggest letting the BHN tech support person check this out. He's pretty good at getting odd stuff like this fixed.
https://secure.dslreports.com/forum/bhousedirect
yimitz is offline
post #11836 of 12489 Old 07-07-2014, 02:01 PM
Super Moderator
DrDon's Avatar
Liked: 2364
I'm ahead of you both. Complaint filed, BHNTechXpert contacted.
BHN left a voicemail late last night saying I'd be contacted today. But they always say that and it never happens.
FIVE techs and a week later and it's all back on with a bill credit. We'll see what happens first of August.
billmich likes this.
DrDon is offline
post #11837 of 12489 Old 07-22-2014, 09:39 AM
billmich's Avatar
Quoted: 261 Post(s)
Liked: 60
Such a quiet thread...so sad now.
Comcast will be adding a NEW HD channel. The SEC network when it launches in August
http://corporate.comcast.com/news-in...omcast-xfinity
They added a bunch of regional sports networks a couple of years ago, but not any recently. I am curious why they don't put ALL their Comcast sportsnets on the sports tier.
billmich is offline
post #11838 of 12489 Old 08-03-2014, 02:10 PM
Samk1's Avatar
Getting tired of Uverse with their picture quality. Does anyone have info for the Comcast direct sales reps that give you that awesome 2 year deal
Samk1 is offline
post #11839 of 12489 Old 08-04-2014, 03:52 AM
Yuss's Avatar
Quoted: 30 Post(s)
If you have WOW in the area, check them out as well. I switched from Comcast over a year ago. Very happy with their whole home DVR (6 HD channels). Their Internet has been less reliable, but not by much. 3 interruptions in service in the 16 months. The longest was a day. Even knowing that. I'd still switch.
I also love the way their digital boxes are DLNA compliant which lets me stream seamlessly from my main PC to any TV in the house.
I've been very satisfied with them.
Yuss is offline
post #11840 of 12489 Old 08-04-2014, 04:47 AM
oktoberrust11's Avatar
Quoted: 71 Post(s)
Liked: 38
What are you getting tired with regarding U-Verse PQ? Curious because I've had them for a little over a year and haven't noticed any degradation.
Xbox Live: oktober rust | Mii: 5207 2388 9861 4135 | Steam ID: detroit820 | Origin ID: oktoberrust11
oktoberrust11 is offline
post #11841 of 12489 Old 08-12-2014, 02:40 PM
billmich's Avatar
Quoted: 261 Post(s)
Liked: 60
anyone know what channel numbers the SEC network will be on Comcast....or Brighthouse?
I know the network launches on Thursday 8/14/14
billmich is offline
post #11842 of 12489 Old 08-14-2014, 08:11 AM
yimitz's Avatar
Quoted: 30 Post(s)
Liked: 48
Not sure about Comcast, but the Bright House channel numbers are 166 and 366 (SD and HD). Right now they're just showing a title card; I think the actual programming doesn't start until 6:00pm today.
Edit: The overflow channel is up too, channels 865/866 SD/HD.
yimitz is offline
post #11843 of 12489 Old 08-14-2014, 09:35 AM
lionsnob's Avatar
Comcast it looks like 700/1738 HD and 742 SD.
rreini likes this.
lionsnob is online now
post #11844 of 12489 Old 08-16-2014, 07:28 AM
Super Moderator
DrDon's Avatar
Liked: 2364
Can anyone tell me if BHN carried/is carrying the NFL RedZone preseason preview?
DrDon is offline
post #11845 of 12489 Old 08-28-2014, 10:32 AM - Thread Starter
rreini's Avatar
Quoted: 16 Post(s)
Comcast outage - scope?
Comcast service of all types has been out in my part of Westland since Tuesday evening (26th). I'm trying to determine how widespread it is, so who else is having problems?
Roger in DTW
rreini is offline
post #11846 of 12489 Old 08-28-2014, 11:19 AM
Gary S's Avatar
Quoted: 25 Post(s)
I know Brighthouse had Internet, VOD and phone issues starting overnight Tuesday night also. I don't know if it is fully resolved yet either.
Gary S is offline
post #11847 of 12489 Old 08-28-2014, 11:26 AM - Thread Starter
rreini's Avatar
Quoted: 16 Post(s)
Calling Comcast, I was told that a facility had flooded, don't know where. Estimated that service should be back by 6:30. We'll see...
Roger in DTW
rreini is offline
post #11848 of 12489 Old 08-28-2014, 11:44 AM
Gary S's Avatar
Quoted: 25 Post(s)
I think Brighthouse's issue was related to a nationwide Time-Warner Internet problem. Most of the people were back within a few hours, but some people still had issues last evening. I don't know if they still have problems today.
Gary S is offline
post #11849 of 12489 Old 08-28-2014, 01:02 PM - Thread Starter
rreini's Avatar
Quoted: 16 Post(s)
Everything was back as of 4 PM.
Roger in DTW
rreini is offline
post #11850 of 12489 Old 08-30-2014, 11:05 AM
Super Moderator
DrDon's Avatar
Liked: 2364
Just noticed Brighthouse is carrying Time Warner Sportsnet LA. I'm thrilled to know my cable dollar is going to help Time Warner defray the costs of an incredibly expensive regional sports deal I care nothing about.
Of course, TW negotiates for BHN, so the carriage isn't a surprise, though I'd have to think it's a bit of a waste in Detroit. Still, I'm sure they're happily counting Detroit subscribers when they're selling it to advertisers.
I do need to surf into the 600s more often. Finding all kinds of things I had no idea BHN was carrying. Serves me right for using paperless billing. I miss ALL the memos.
DrDon is offline
