Detroit, MI - HDTV - Page 398 - AVS | Home Theater Discussions And Reviews
 3Likes
post #11911 of 11930 Old 01-06-2015, 02:01 PM
billmich's Avatar
Quoted: 101 Post(s)
Liked: 37
I have a true HD OTA question/plead for help to the group
I have a Panasonic plasma (TC-P65VT50) and A while back I hooked up a small powered indoor antenna and was able to watch all the Detroit area OTA HD channels and sub-channels. A couple of weeks ago I decided to scan around again and I could not get anything for WJBK (FOX) . The signal strength was only like 30% and pixellation. So I decided to get my antenna out on the 'preferred location' and do a scan. Everything has scanned in well EXCEPT WJBK.(Which failed to register AT ALL)
The 'issue' that I am having is that even when I am trying to manually add the station, I run into a conundrum.
If I wish to add WKBD , I can manually add channel 14 and viola, i have it added...BUT
With WJBK's actual channel number being channel 7. When I try to punch anything in to channel 7, I get WXYZ (PSIP their actual channel of 45 to virtual channel 7)
1) Is WJBK running OTA a lower power than a few months ago? ( I am by Joy and Newburgh, certainly close enough by their tower I would surmise)
2) Any idea of how to get around this "channel 7" issue that I am having?
3) I may actually have to get a LONG RG-6 cable and do a new scan with the antenna right by a window in my place (apartment) that faces north (and a little east).
Any assistance and information is greatly appreciated
billmich is offline
post #11912 of 11930 Old 01-06-2015, 02:18 PM - Thread Starter
rreini's Avatar
The indoor antenna is VHF/UHF, correct? If it is UHF only, then that can explain difficulties in receiving WJBK. I haven't noticed any major issues receiving 'JBK with my setup in recent months.
I have a feeling that your Panasonic tuner can't disable PSIP, so there may be no way to tell it to use actual channel numbers (my old DTC-100 could do that, but I'm sure I don't have it anymore).
Roger in DTW
rreini is offline
post #11913 of 11930 Old 01-06-2015, 02:26 PM
Super Moderator
DrDon's Avatar
Quoted: 148 Post(s)
Liked: 318
I don't recall the model of the television, but the last time I saw this come up, I believe the suggestion was to delete WXYZ, then the TV will "find" WJBK when you manually tune 7, then you go back and re-add WXYZ using the actual channel.
If you can't individually delete, then do a rescan with no antenna attached (which will erase everything) and start manually adding stuff. I'd start with WJBK only until you get the antenna positioned right for it, THEN see about adding all the others.
Though, in all honesty, you need to make sure you have a combo antenna before you do anything.
How long ago was "a while back?" Before analog cutoff?
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
post #11914 of 11930 Old 01-06-2015, 02:43 PM
billmich's Avatar
Quoted: 101 Post(s)
Liked: 37
LMAO...a while back was in August; thanks for the heads up about a blank scan.
My antenna is a UHF/VHF combo antenna, amplified and all
billmich is offline
post #11915 of 11930 Old 01-06-2015, 03:45 PM
yimitz's Avatar
Not sure how much this helps with your #1 . I live near you (just north of Joy, about half-way between Newburgh and Wayne Roads). On the small TV here in my office (connected to rabbit ears sitting on top of my computer desk), I haven't seen any difference in WJBK's signal strength lately. The TV has only a 4-bar signal strength indicator, and it's normally in the 4 position, every now and then dropping to 3. No pixellation at all. So I don't think they've done anything to their signal.
yimitz is online now
post #11916 of 11930 Old 01-06-2015, 03:47 PM
Super Moderator
DrDon's Avatar
Quoted: 148 Post(s)
Liked: 318
August? You had leaves to attenuate reflected signals (Multipath). My advice is to toss that antenna and put something in the attic or the roof. But that's me.
DrDon is offline
post #11917 of 11930 Old 01-07-2015, 06:23 AM
billmich's Avatar
Quoted: 101 Post(s)
Liked: 37
I am in an apartment, no attic or roof access for me; but last night I did a re-scan and everything is working great now
billmich is offline
post #11918 of 11930 Old 01-24-2015, 05:23 AM
Tom899's Avatar
Quoted: 48 Post(s)
Antenna and Tuner for Brownstown in Attic
Hello, I live in Brownstown between West Rd and Vanhorn Rd, and between Arsenal Rd and Inkster Rd. It's the DelWebb community named Bridgewater.
Is this location ok for Detroit area HD with attic antenna?
I have a single story home wood construction with vinyl siding, asphalt shingles, and no foil backed insulation, it's blown in.
I would like to install an antenna in the attic, recommendations please!
Also, stand alone Tuner recommendations, don't need to record, just looking for high quality.
-Tom
Tom899 is online now
post #11919 of 11930 Old 01-24-2015, 06:05 AM
pcpopcorn's Avatar
I live in Clarkston so we may be about the same distance from the sources.
I dont have an attic antenna but I put this on my Pool house and it is small and works very well.You may be able to use it in your attic.Read the reviews on Amazon,
Winegard FL6550A FlatWave Air Outdoor HDTV Antenna
pcpopcorn is offline
post #11920 of 11930 Old 01-24-2015, 10:04 AM
Super Moderator
DrDon's Avatar
Quoted: 148 Post(s)
Liked: 318
Here's your TVFool plot. http://www.tvfool.com/?option=com_wr...2c15cdfdb6ee2b
Got a lot of big planes coming and going not too far from you. Could be an issue for an omni-directional antenna. So could Toledo's signals.
I'd start with a small combo such as the RCA ANT751 pointed due north and see how that works for you.
DrDon is offline
post #11921 of 11930 Old 01-24-2015, 11:19 PM
Tom899's Avatar
Quoted: 48 Post(s)
Got a lot of big planes coming and going not to far from you. Could be an issue for an omni-directional antenna. So could Toledo's signals.
Thanks, I ordered one of these today. The planes are actually a good 5-10 miles west of me. I rarely see any above.
Looking forward to hooking it up. I have a projector and large screen. The Comcast compressed signal is not too bad but looking for better and hope this is it.
-Tom
post #11922 of 11930 Old 01-24-2015, 11:20 PM
Tom899's Avatar
Quoted: 48 Post(s)
-Tom
post #11923 of 11930 Old 01-25-2015, 11:24 AM
Jeremy W's Avatar
Unless something has changed recently, Comcast does not add any compression to the local channels. What you get from them is the same as OTA.
Jeremy W is offline
post #11924 of 11930 Old 01-25-2015, 07:12 PM
Tom899's Avatar
Quoted: 48 Post(s)
I read an article by a Comcast representative that they try not to compress more than 2 to 1 where as some other company's do 3 to 1. They run on a 875mhz system and there is only so much bandwidth for all the channels. It's not bad but he says it is there. If they did not compress they would have to drop channels. Again, I'm only quoting and reading. Try a Google search for Comcast and compression. I would actually like to be proven wrong. Also, I suppose different parts of the country do different things.
-Tom
post #11925 of 11930 Old 01-25-2015, 07:50 PM
Jeremy W's Avatar
2:1 isn't adding additional compression, because a QAM channel can fit exactly two 19Mbps ATSC channels. Which was my point, and what they do for local channels. For national channels, most of them are 3:1.
Jeremy W is offline
post #11926 of 11930 Old Yesterday, 04:19 AM
Tom899's Avatar
Quoted: 48 Post(s)
With this in mind, do you think the quality of the cable channel is exactly the same as OTA? I'll be installing my OTA setup today. I live in a new community with an excellent Comcast signal. On my Pioneer Elite 60" Plasma I think it looks really good. On my 134" projection setup it looks good but I see a few issues that I think might be attributed to 2:1. I will be able to do a direct comparison today or tomorrow. Thanks for explaining and commenting. The whole antenna setup is relatively inexpensive so it will be a good experiment.
-Tom
post #11927 of 11930 Old Yesterday, 06:11 PM
Jeremy W's Avatar
Yes.
Jeremy W is offline
post #11928 of 11930 Old Today, 05:51 AM
Tom899's Avatar
Quoted: 48 Post(s)
Ok, I have my OTA antenna up and running through an OTA TiVo Roamio.
I have a very good Comcast cable signal and picture looks very good, especially on my Pioneer 60" Kuro Plasma.
On my Sony VPLHW40ES projector and Carada 134" Brilliant White screen it also looks good, but you start to see imperfections at this size, not bad, but if you are a hobbyist you start to wonder if it could be improved.
This brings me to wondering if OTA HD would improve this at all. I did a lot of reading on the forums for weeks on this subject. What I continually found is it would improve. I read a lot of reviews and comments stating cable company's sometimes apply compression to there signals to fit more channels in there allocated bandwidth. Jeremy says this is not so, so I respect that statement because I have no first hand proof if the Detroit area Comcast does this or not. I will take Jeremy's word for it until I get proof either way. So, at any rate I thought I would try an antenna.
On my 60" Plasma I could really see no difference (the picture was near perfect either way)
On my 134" projector I could see some slight difference. It cleaned it up and is now approaching the Plasma (All processing off, no sharpening etc...)
Now, whether Comcast cable has some slight degradation through the cable coming from Comcast, splitters, amplifiers, compression, or whatever reason?
The bottom line is, if you want a pristine signal, I think OTA HD might be best. Of coarse your millage may vary! I think it could go either way for each case.
Thanks for everyone's comments and replies. I wouldn't have tried OTA if it wasn't for the forums.
-Tom
post #11929 of 11930 Old Today, 10:26 AM
Super Moderator
DrDon's Avatar
Quoted: 148 Post(s)
Liked: 318
Tom.
First, anything Jeremy W has to say about Comcast is pretty much gospel and we'll leave it at that.
Second: It's impossible to make a determination over which is better since you're probably using two different tuning circuitries (unless your projector has its own QAM and ATSC tuners). Also, digital television is 1s and 0s, so splitters and amps don't degrade the PQ. It's all or nothing. If the signal degrades enough that the ones and zeroes are affected beyond the point the data correction can't fix it, the picture goes away either entirely or in huge blocks. It's not a matter of it looking a "little bit better" or worse.
Unless a compression scheme is employed, the programming stream that hits your cable tuner should be the same as the one that got fed into the transmitter at the television station. However, looking at one stream decoded by a Motorola cable box and the same thing decoded by a TV's internal ATSC tuner can have slight differences. But it's impossible to know if that came from the cable system or the different tuners. Heck, two cable boxes - same make and model - can
Third: "Their" is a plural possessive pronoun: They have their ducks in a row.
"There" is a location. "Put the ball over there."
Had to tease ya
billmich likes this.
DrDon is offline
post #11930 of 11930 Unread Today, 05:25 PM
Tom899's Avatar
Quoted: 48 Post(s)
Thanks for the reply and good information! Yes, I understand it's probably equipment variences more than not. It's probably just better to say, with my equipment OTA is slightly better. Thanks to you and Jerry for helping me out.
Yes, I missed the their, ha-ha
