Detroit, MI - HDTV - Page 416 - AVS Forum | Home Theater Discussions And Reviews
 78Likes
post #12451 of 12471 Old 02-09-2017, 12:38 PM
Super Moderator
DrDon's Avatar
Quoted: 916 Post(s)
Liked: 1852
Originally Posted by skatingrocker17 View Post
I always wondered why WWJ doesn't broadcast from that tower considering their studio is right beside it. But WKBD and WPXD do.
You have to put the transmitter where the FCC will LET you put the transmitter. A mile here, a mile there and suddenly, you're an interference problem for some other station. If I sound a bit jaded, I am. Relocating WYCD's transmitter to 11 mile would solve so many signal issues, but there's only a tiny triangle where the FCC will allow us to hang it and the 11 mile tower is a mile and a half too far south. Trip could probably tell you in an instant who'd be affected if WWJ-TV moved the transmitter to 11 mile. Looking at his spreadsheet, I'm guessing Lima, OH. Grand Rapids also has a 44. So, moving WWJ south and west could impact both of those. I dunno. It may be that 8 mile simply provides better coverage to all areas than 11 mile does.
Even if the FCC has no issue, there's a big "why bother" factor. Signal's fine, most places. Expense wouldn't be much different except for the gasoline used by the engineering department. IIRC, WWJ's backup IS on the 11-mile tower. And there's a huge advantage in having a separately-located backup. In fact, CBS has put together a central FM backup site on WDZH's tower. Most of the stations could only run temporarily and there may be other maximum power and HAAT restrictions. Having your backup on the same tower isn't much good if that tower comes down.
I always thought it'd be smart to put the whole CBS operation there on 11 mile instead of leasing the huge radio plant on American Drive. Without a news department, you can fire a cannon through half of WWJ and not hit anything. There's room for everybody on property CBS owns. Nope. From a bookeeping/tax standpoint, it's apparently better the way they're doing it. That, or they've always known they were going to spin off radio and having TV and having radio in the same house with TV would have possibly meant moving radio back out, again.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is online now
post #12452 of 12471 Old 02-09-2017, 03:03 PM
Trip in VA's Avatar
Quoted: 601 Post(s)
Liked: 165
Send a message via AIM to Trip in VA
To add to what DrDon is saying (and because he invoked my name), often stations are pretty well boxed-in at their present locations. Yes, a station can move to another tower, but it may require a drop in power, or a directional antenna, or something else unsavory that would make you as a station engineer wonder if it's really worthwhile.
FM is particularly messy in my eye, doing everything by distance and contour calculations. FM stations can move even if they're boxed in like DrDon says, but as soon as you move out of the "distance protected" space, suddenly you have to do a contour analysis (I forget if the appropriate rule is 73.207 or 73.215 off-hand; pre-1964 short-spaced stations I think are 73.213) and start coming up with screwy directional patterns and other ways of managing things.
In TV you actually do a path-loss type analysis where signal is plotted to individual sample points. (I would know; the software for that is my day job at the FCC.) So you wind up having to deal with antenna patterns no matter what, which is a bit of a double-edged sword. On the one hand, it often means that small moves don't matter very much, because generally the path to each sample point isn't very different. On the other hand, and this is especially true in rougher terrain, it also means that tiny moves can create big changes if those moves change the path a lot because of line-of-sight differences.
But the bigger thing that's better in TV is that you can agree to accept interference as predicted by those analyses, something which I don't think FM can do. If you have stations who are willing to negotiate, it means often there's more latitude to move around as a result.
... I think I started rambling.
In any event, the repacking may result in stations realigning where they're transmitting from. The FCC is encouraging stations to share facilities to reduce the cost of the repack, so if it turns out that moving WWJ and WKBD to a common antenna at the WWJ studio is cheaper, it may very well happen. We won't know for certain what is happening for some time to come, though.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
post #12453 of 12471 Old 03-07-2017, 03:52 PM
Andrew K's Avatar
Quoted: 702 Post(s)
Liked: 117
I contacted WTVS, and I was told that they'd move from channel 43 to channel 20 in the repacking.
Andrew K is online now
post #12454 of 12471 Old 03-07-2017, 11:25 PM
Bozzmonster's Avatar
Quoted: 16 Post(s)
Interesting... which means WHNE (also on RF 20) will either go dark or be pushed somewhere else.
Bozzmonster is offline
post #12455 of 12471 Old 03-09-2017, 09:13 AM
billmich's Avatar
Quoted: 259 Post(s)
Liked: 60
where is the wycd tower?
how can the 11 mile tower be too far "south" if the current tower is on 8 mile?
typo?
billmich is offline
post #12456 of 12471 Old 03-09-2017, 01:53 PM
Super Moderator
DrDon's Avatar
Quoted: 916 Post(s)
Liked: 1852
Greater Media studio site.
DrDon is online now
post #12457 of 12471 Old 03-11-2017, 06:35 PM
itsthemultipath!'s Avatar
Quoted: 16 Post(s)
It's interesting to try to speculate about the future of WXYZ.
It had been announced that Scripps had not participated in the spectrum auction, yet no channel reassignment has been stated for WXYZ, who cannot stay on channel 41.
I plotted out the assignments for the stations in the Detroit market and other markets close enough to represent a conflict with the Detroit Market.
no station is shown moving to 14, which is being vacated by WKBD moving to 34. WCMH is 14 in Columbus, but WKBD coexisted with it.
What is interesting is that WHIO Dayton is on 41 going to 33, and WKBN Youngstown also on 41 going to 33. Since WHIO and WKBN had been sharing channel 41 with WXYZ, I wonder if WXYZ could land there, too. It would seem to work with other Detroit stations, as it would produce a "four-card straight" on channels 31, 32, 33 and 34.
I guess Scripps could put both 7.1 and 20.1 on WMYD's transmitter, but I don't want to lose Laff, Escape and Bounce.
itsthemultipath! is online now
post #12458 of 12471 Old 03-12-2017, 05:39 AM
Andrew K's Avatar
Quoted: 702 Post(s)
Liked: 117
Based on what we know so far, if WXYZ is to remain on UHF, the only channels still available for it to move to are 14 and 36.
FYI... WKBN is not going to 33. WFMJ is going to 33. And interestingly, WXYZ cannot be co-channel with WFMJ according to the repack checker... https://www.rabbitears.info/repackch...ch6=&ch7=&ch8=
post #12459 of 12471 Old 03-12-2017, 10:19 AM
Quoted: 16 Post(s)
Yeah, I discovered that mistake a few hours after I posted it (WKBN).
I suspect that some assignments forbidden by "A few hundred yards" might get waived through.
Then again, would WXYZ on 33 pass that repack checker if it were to be moved to the WKBD candleabra (It's a little further westward)?
post #12460 of 12471 Old 03-12-2017, 12:47 PM
Trip in VA's Avatar
Quoted: 601 Post(s)
Liked: 165
What you see in the Repack Checker on RabbitEars is what was used for the repack. There were no waivers to what you see there. The channel assignment system took those as hard limitations.
- Trip
Andrew K likes this.
N4MJC
RabbitEars
post #12461 of 12471 Old 03-12-2017, 12:53 PM
Quoted: 16 Post(s)
So is WXYZ going dark? (I had thought that Scripps had auctioned nothing).
post #12462 of 12471 Old 03-12-2017, 12:57 PM
Trip in VA's Avatar
Quoted: 601 Post(s)
Liked: 165
Nope. Their channel has not yet been announced.
- Trip
N4MJC
RabbitEars
post #12463 of 12471 Old 03-12-2017, 01:02 PM
Quoted: 16 Post(s)
Bigger question:
What about Canada. Will there be new channels for CICO32, CFTV, and others?
post #12464 of 12471 Old 03-12-2017, 02:14 PM
mvcg66b3r's Avatar
Quoted: 104 Post(s)
Bigger question:
And what about CKCO's analog stick at Sarnia (RF42)?
James Calvin Woods - Son of Verta Jane Holland
mvcg66b3r is online now
post #12465 of 12471 Old 03-12-2017, 03:28 PM
Trip in VA's Avatar
Quoted: 601 Post(s)
Liked: 165
Canada's stations will all receive new assignments, either on a current channel or a newly assigned channel.
- Trip
N4MJC
RabbitEars
post #12466 of 12471 Old 03-12-2017, 03:41 PM
mvcg66b3r's Avatar
Quoted: 104 Post(s)
- Trip
And those Canadian stations still in analog, will they now be forced to go digital?
post #12467 of 12471 Old 03-12-2017, 05:00 PM
Trip in VA's Avatar
Quoted: 601 Post(s)
Liked: 165
They will be required to move to new channels. Those channels were assigned on the assumption they were converting to digital, but there's nothing strictly requiring them to convert when they move, as far as I know.
- Trip
N4MJC
RabbitEars
post #12468 of 12471 Old Yesterday, 10:20 AM
Andrew K's Avatar
Quoted: 702 Post(s)
Liked: 117
WXYZ is moving to channel 25. I wonder how that's possible with WUPW being adjacent on 26.
post #12469 of 12471 Old Yesterday, 11:24 AM
Quoted: 16 Post(s)
I've heard very little about Canada in this process. I don't even know if Canada will stop using Band V for television. Would a powerful DTV transmitter (e.g., Channel 51 at Alvinston, ON) cause chaos stateside if a strong tropo opening were going (I would assume so).
Even the relatively weak mobile service transmitters on the Wisconsin and Illinois shorelines wreak havoc on phone users along the Lake Michigan shoreline in Upper Michigan on a warm humid day (our phones would show five bars and Central time, but we couldn't place a call, because the GPS figures carried by our handsets would cause our connection to be denied.)
Meanwhile, I could watch Willis Tower DTV 300+ mile path on a handheld set with an unfurled jumbo paper clip for an antenna!
post #12470 of 12471 Old Today, 11:56 AM
Quoted: 16 Post(s)
I was checking one of the other threads in the forum, this case Minneapolis, MN, and found the below link that lists some of the assignments. Of course, this isn't official but great for speculation!
http://www.nab.org/repacking/clearinghouse.asp
post #12471 of 12471 Old Today, 02:51 PM
Super Moderator
DrDon's Avatar
Quoted: 916 Post(s)
Liked: 1852
Thanks for that.
DrDon is online now
