AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Local HDTV Info and Reception (http://www.avsforum.com/forum/45-local-hdtv-info-reception/)
-   -   Chico, CA - HDTV (http://www.avsforum.com/forum/45-local-hdtv-info-reception/462140-chico-ca-hdtv.html)
cmassa 10-25-2004 01:21 PM
I am purchasing my first HDTV (Mits 52725). I am looking for information regarding the Chico/Redding, CA digital broadcasts. The local dealers are showing only Comcast digital cable. I am already a satellite subscriber and can't yet afford a HD satellite system at the same time as the TV. To get local stations on my satellite I would have to buy a new system as well. My wife isn't going for that yet.
According to Titan TV and antennaweb.org, our major networks are all broadcasting a digital signal with one (KRCR) broadcasting in HDTV. However, that signal is about 65 miles to the north in Redding. The remainder of the channels are within 20-30 miles towards the east.
Is anyone currently receiving OTA digital broadcasts in this area? Will I realistically be able receive the HDTV signal from Redding? I have looked at antennasdirect and figure I may need the DB8 unless someone has another recommendation.
This is a small market but hopefully we can get some discussion going.
Sacramento stations are a bit too far (probably about 90 miles)
Chris
cmassa 10-26-2004 10:25 PM
Sort of what I thought. Well, I guess I'll be the test case. I'll post results once I get the TV.
Chris
CPanther95 10-28-2004 07:22 AM
I've added this thread to the master list as the official Chico/Redding DMA discussion thread. It sounds stupid, but just continue to post your questions/observations and check back periodically. It normally takes a little bit of time, but eventually there should be a handful of local people to keep the discussion going.
I also changed it from exclusively OTA to all things HDTV in Chico/Redding - so if you know what the cable HD options are in the area, you might want to post that info. If the thread gets active enough, we can consider splittling it into separate OTA/Cable threads.
carl033 10-31-2004 01:44 PM
Chris
I've been receiving the Chico-Redding OTA digital channels for quite a few months now. My antenna is normally aimed at Sacramento and the Bay Area, but I'll swing it around tonight to see if any of the stations are indeed, transmitting HD. Any time I've looked at them in the past, they were just upconverting their analog channel to SD. I've heard they are not likely to go to full power to better cover their market until the FCC forces them to. This is understandable in such a small market, as it will cost them big bucks and produce a zero return on their investment.
My best channel from your area is Fox KCVU DT 20. Next is ABC KRCR DT 34, and finally CBS KHSL DT 43. I can tell PBS KIXE DT 18 is there, but it's very weak and will not lock up. I've never picked up NBC KNVN DT 36.
Carl
cmassa 11-24-2004 11:24 PM
I've gotten my Sony 55XS955 and hooked it up to my antenna (Terk tv50 - I know) which is in my attic. This the antenna I used for my old TV. I get digital FOX (KCVU), NBC (KNVN), and CBS (KHSL). ABC and PBS (KRCR and KIXE) come from Redding and I get no signal at all. Watching KHSL-DT is worse than the analog station. The digital channel is full of ghosting/double images. Fox and NBC are quite clear. One of these days, maybe after the holidays, I'll get a better antenna installed.
Chris
carl033 11-29-2004 11:18 AM
Chris
Hi Chris,
Because there are three transmit locations in your area, I recommend a high-gain directional antenna on a rotator. If roof-mounting is not an option, putting it in your attic will work, but not as well of course.
No rush on getting something up. As I said earlier, the local stations do not benefit economically from passing network HD programming through. They are on wuth low power, just to hold the DTV channel. However, they'll have to go to full power in a year or two; otherwise, they'll have to give up their digital channel assignment.
If you need to stick with an attic antenna, measure the turning radius available, and pick a UHF antenna that will spin around up there. A corner reflector or multi-bay bow-tie are the smallest. The larger yagi designs will require a four to six foot turning radius.
Carl
cmassa 11-29-2004 09:01 PM
I would like to stay away from installing a rotator. Once I upgrade my DirecTV to a multisatellite system, I'll pull the locals in from that but I'm saving for an HD Tivo system. How would a less directional antenna be, such as a DB4 or DB8 from Antennasdirect? I would like to get KRCR and PBS out of Redding but I think I'm too far (67 miles) without a tower. My VHF signals from them are somewhat weak currently with lots of snow. KHSL and KCVU (CBS and FOX) are only 14 miles away and KNVN (NBC) is 32 miles away. They are separated by about 90 degrees.
Chris
WilliamPC 01-09-2005 07:16 PM
I have D* HD and live in Redding, Ca. D* will not allow me any HD feeds. I have tried 5 different indoor antenna's will little luck. Ironically, the best results I got was with a cheap 10 year old non powered magnavox rabbit ear unit. I tried antennas from Terk, Zenith and Rat Shack. With the cheapo I was able to get ABC HD OTA occassionally but it cut in and out and was very frustrating, especially during MNF when the Rams were playing!
I am very frustrated because I layed out over $5k for gear and cannot get in the channels I want. Do I need to get an outdoor antenna?? I have a DirecTV mast mast still on my roof that was left when we moved our dish to a better location. What is the best outdoor antenna? I checked with antennaweb.org and these are the channels that are listed. Notice that FOX is not listed. The "local" Fox channel is over 56 miles away and they do not offer HD. Does this mean that there is no way I can get FOX HD in any way, shape or form? I read that since I get the local FOX thru D* I cannot get a waiver for FOX HD thru D* because of some new laws??? This doesnt seem fair since I cannot get it OTA anyway...?!?!?!
Sorry for the long post. Oh, my zip code is 96002. I also live in a area in town that is notorious for poor TV and Cell reception. Kinda like a black hole area.
Bill
carl033 01-10-2005 10:29 AM
Bill
D* plans to start adding HD locals by mid-year. However, they'll start with the biggest markets and work their way down to you. That may take a year or two.
There is hope for you sooner, however. The FCC is working on creating a "digital white area". This is where no OTA HD service is available, and does not depend on the availability of analog satellite-delivered locals. Other threads on this forum will keep us all informed on how this is developing.
Stay tuned,
Carl
WilliamPC 01-10-2005 02:51 PM
Stay tuned,
Carl
Thanks Carl,
Im looking to resolve this in the next week. Can someone point me in the right direction in terms of an outdoor antenna?? I am confused as to weather I need to make new cable runs or if I can tap into the existing DirecTV run and split it near the reciever?!?! Is this possible. I am really close to calling a local expert in to handle it even tho I usually am the DIY type. I just dont know enough about this stuff. My knowledge is in the Car Audio arena.
Also, do the clip on powered antennas work. I mean the ones that attach to the dish itself. I belive Terk makes them and I see that Terk isnt a favorable company in the Home Theater world.
Thanks for anyones help. I am desperate. Rams football looks terrible in SD. Its even worst knowing you have a Sammy DLP that give an awesome picture with HDTV sources......when you can get them!!!
ebolavirs 01-16-2005 12:02 PM
Is it just me or is KRCRDT 7.1 and 7.2 down now and has been for the last couple weeks? I suddenly quit receiving it after all the snow fell. I heard they have over 10 feet of snow on top of Shasta Bally where the broadcast from so hopefully thats the problem and not something with my equipment. Anyone else in the Redding/Chico area not receiving this channel?
cmassa 01-16-2005 05:48 PM
I wish I could even get KRCRDT in the first place in Chico. They are broadcasting with very low power and on the FCC site, Chico is entirely outside their service area for the digital channels. It would be nice to receive some kind of HD signal, but I haven't felt it worthwhile to even try getting a new antenna setup until their power output goes up. I can receive all the digital channels from Chico without problem but they are just converting their analog channels and broadcasting SD.
Chris
carl033 01-18-2005 10:26 PM
Chris
Yes, It's sad that the small market stations still can't justify full power or simply passing through the network HD signals. Just about every prime-time scripted show on the four major networks is now in HD.
I'll check DT34 in the morning and let you know if I see it here in Nevada City.
Unless this digital white area business becomes reality, the only hope of people in the hinterlands getting network HD anytime soon is to subscribe to either Bell ExpressVu or Star Choice. Bell offers the US networks in HD(including PBS) for $10 over and above their basic package but Star Choice includes it as part of their $28 basic collection of Canadian channels. There is nothing illegal about subscribing - you just need to provide them with a Canadian address.
Chas Hart 01-20-2005 04:30 PM
WilliamPC
I live in Redding (96001) and have DirecTV. I called DirecTV to receive the NBC and CBS HD network channels and they said the local stations in Chico would not sign a waiver but I was eligible to recieve FOX. I had a choice of New York or Los Angeles for $1.50 per month. Have been getting FOX HD for over a month now.
You can use the existing DirecTV line and split it at the receiver.
KRCRDT has been down for two weeks and still is.
Can anyone in Redding receive any HD channels from Chico?
Chas
cmassa 01-20-2005 04:39 PM
Chas,
Don't waste your time trying to receive HD from Chico because we don't have any channels broadcasting an HD signal. The stations (CBS, FOX, NBC) are just converting their analog signal to digital SD broadcast at very low power. You probably get a better picture over DirecTV than I do with the digital broadcast. I'm planning on upgrading my DirecTV service to receive the locals. I wonder if I could get FoxHD as well. When broadcasting, did KRCRDT broadcast a true HD signal?
Chris
carl033 01-20-2005 05:19 PM
Chas,
Chris
Supposedly yes, but I can't confirm it.
Chas Hart 01-20-2005 05:27 PM
Chris
Thanks for the Chico info.
KRCRDT has been broadcasting HD programming on 7.1 and SD on 7.2 for over a year now.
KIXEDT does broadcast HD on 9.1 and 9.2 at times and not always the same programs as on KIXE.
Chas
houselog442 01-30-2005 08:40 PM
I read on the tvradioworld website that your fox station there is broadcasting in hd (low power). Is that true or not?
cmassa 01-30-2005 10:02 PM
As far as I can tell, the Fox station is broadcasting a SD picture in 16:9. Everything is stretched out, very irritating to have to switch wide modes when I come across it. I have never seen anything but 480i material on that station. I guess I can hope for the Super Bowl to be in HD but I won't hold my breath.
Chris
Lance1701 01-31-2005 10:17 AM
I have to agree with you about the fox station, is not in HD. I live in Redding and it took me sometime before I could even get it, I had to try different antennas and placement, and when I did finally get it, I have seen nothing but SD TV since, not any better than the regular channel. So the only channel thats working right now is PBS KIXE, which has limited programing. Hope fully KRCR will be fixed soon. Someone at the station said it froze when we had the snow storm about a month ago, and they still have not fix it.
Lance
Chas Hart 02-01-2005 06:10 PM
KRCRDT is broadcasting again as of today.
Chas
cmassa 02-06-2005 05:04 PM
Well, I'm sitting here watching the Super Bowl in SD. However, Fox30 has changed the display mode on the digital channel. I am unabel to zoom in to fill the screen. If I want to zoom I have to change to the analog channel. My television shows the signal as 480i, 16:9. The picture is 4:3.
There are people in other threads complaining about the quality of Fox HDTV compared to other networks. I would be happy to get even one network in HDTV. Oh well.
Has anyone been able to recieve Sacramento digital stations from Chico? I know its a stretch.
Chris
cmassa 02-19-2005 10:24 PM
I hooked up a new DirecTV HD-Tivo unit yesterday. I am still using a Terk TV-50 in my attic. Tonight I was able to pull in PBS in HD from Redding. The signal kept dropping out but would occasionally show for 10-15 seconds uninterrupted. KRCR wouldn't lock at all but does at least show on the signal strength meter. I think I might have to experiment with a better antenna. The tuner in the HD-Tivo must lock better on weaker signals than the TV. I doubt that I would be able to get ABC (KRCR) though.
Chris
cmassa 03-02-2005 10:35 PM
I have reliably received a signal from both PBS (KIXE) and ABC (KRCR) from Chico. Those stations are 67 miles away at low power (<26kW) Both locked solidly tonight showing HD. I bought an AntennasDirect DB4. I haven't put it in a permanent location yet, its currently propped up next to the TV, sitting on the floor of my living room. Signal strength was solidly in the 60's on my HR10-250. Interestingly, I can receive all of our digital stations without redirecting the antenna even though some are 90 degrees apart. My next move will be to install it in the attic and try it out. If I rotate towards the southwest I am even able to pick up KFTY-DT out of Santa Rosa which is 88 miles away.
Chris
carl033 03-03-2005 10:22 AM
Chris
Good job, Chris. I'm assuming that you can't (or don't want to) mount the antenna on your roof. Reception from all directions will of course be better from up there.
Something to look forward to, however. All DTV stations must attempt to replicate their analog service area by a certain date. This usually means coming up to full power (1 megawatt). Most Sacramento stations are already at or near full power now. But none of the Chico-Redding channels have done so because of the cost. I'm not sure of the date, but they will be "forced to" increase power or lose exclusivity of their service area.
As far as actually transmitting HDTV, that's another matter, however. There is no timetable to force HDTV transmissions. They can run four or five channels of 480p and not incur the wrath of the FCC. Your best bet to "coax" KHSL, KNVN and KCVU to carry network HDTV programming is to make a stink on the editorial pages. Only KRCR and KIXE have taken the plunge, so get as many of your friends as you can to turn up the heat on the other three stations.
Good luck,
Carl
cmassa 03-03-2005 10:36 AM
I may try to mount it on the roof. This antenna is not that visible and my wife has given approval. I'm not going to be installing a rotator though. It would be extremely difficult to run the control wire to the living room. Once I get it up on the roof I'll try aiming at Sacramento. I doubt I'll get much at 110 miles. Even though I can now get ABC, I don't watch it much except Monday Night Football. I like the PBS-HD channel a lot though.
Chris
carl033 03-03-2005 11:07 AM
Chris
Hi Chris,
I've seen some RG-6 cable bundled with a multi-conductor rotator cable. So if some of the Sacrameto channels are "useable", you may want to reconsider.
Carl
cmassa 03-03-2005 11:13 AM
Running ANY new wiring to the living room is difficult. I am using diplexors right now because I can't get another coax line in without A LOT of work. But I'll think about it if I can get signals from Sac.
Chris
isacariah 07-24-2005 01:36 PM
Chris
Hey guys,
Recently got an HDTV in Chico and came across this discussion. Chris, just wanted to know if that DB4 antenna has been working out well for you and how your reception has been lately. Were you able to pick up the channels in Sacramento? Would like to be able to get some of the HD channels and just wondering what antenna and what source will be the best. Thanks for any info!
Isaac
cmassa 07-24-2005 06:32 PM
I'm not using my antenna much lately but I can get KRCR-DT and KIXE-DT reliably with the DB4. I'm on the far north side of Chico though. The antenna is mounted about 8 ft above the ground on a pole next to the house. I have not tried Sacramento much although I think it is just too far. I have DirecTV and have gotten HD waivers from ABC, NBC, CBS, and Fox in Chico. I get the LA networks in HD over the satellite now. I never got around to mounting the antenna on the roof once I had HD networks from Directv.
Chris
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
