Milwaukee, WI - HDTV - Page 9 - AVS Forum | Home Theater Discussions And Reviews
post #241 of 416 Old 06-12-2009, 11:30 AM
lgodave's Avatar
Thing(s) I'll miss with the Analog switch is the loss of 87.7 FM (Channel 6 Analog) after today...
Not that it is "common" but I remember using radios with "TV" band functions... to bad there aren't Radio Converter boxes (or are there?) to allow for "mobile" audio access to local TV signals.
I've got a Sony Portable TV that could do the job but I'd have to plug a converter box into it... (Not very portable)
Of coarse now that the day has arrived maybe there will some a market for portable Radios with "Digital" TV bands...
lgodave is offline
post #242 of 416 Old 06-12-2009, 11:33 AM
Jon Ellis's Avatar
You will still be able to hear 87.7 through June 26, but it will only be the feed telling you to convert to digital TV.
Jon Ellis is offline
post #243 of 416 Old 06-12-2009, 03:36 PM
lgodave's Avatar
Not sure how many "non-DTV converts" will hear it (who actually "surfs/seeks" their FM dial much these days?)... but 87.7 FM might "get out the word"... rather nicely for those that don't watch OTA or Broadcast or TV in general (basically those people still under a rock somewhere)...
lgodave is offline
post #244 of 416 Old 06-12-2009, 07:20 PM
Satch Man's Avatar
Quoted: 66 Post(s)
Liked: 75
Shimmering of Picture on TWC-Milwaukee
My picture is clear and sharp, but today I notice a lot of shimmering on BOTH SD/HD stations with "crawler information" at the bottom of the screen. Moving words, containing sports or news information will shimmer across the screen. On stations without news or information crawlers the problem is less frequent. However, there was occasional shimmering of the picture during an episode of Friends on both TBS and TBS HD. This may relate to the digital transition. Anybody else have this issue? Either with or without TWC?
Jack
Cisco 9865HDC DVR with TWC Navigator Guide
Metro-Milwaukee Wisconsin
Satch Man is offline
post #245 of 416 Old 06-13-2009, 02:31 AM
Satch Man's Avatar
Quoted: 66 Post(s)
Liked: 75
Jack
Problem solved with box reboot.
Jack
post #246 of 416 Old 06-13-2009, 12:17 PM
Flak's Avatar
I was getting all my local HD channels before the switch. Since the switch was officially yesterday I did a rescan and have lost channel 18 entirely. It doesn't get picked up in the scan and I can't manually force it as the tv notices ZERO signal.
Any ideas?
Flak is offline
post #247 of 416 Old 06-13-2009, 01:38 PM
jimboy's Avatar
Any ideas?
18-1 moved from RF channel 61 to RF channel 18 on June 12th at 9am. Some people have been having problems because their tv or converter box already have 18-1 established (from channel 61) and it refuses to do anything when it scans digital channel 18 (now 18-1).
Where do you live?
What make/model of tv is it?
What are you using for an antenna?
Have you tried a factory reset (if available in the menu)?
jimboy is offline
post #248 of 416 Old 06-13-2009, 03:37 PM
Flak's Avatar
Where do you live? West Bend
What make/model of tv is it? Samsung HL61A750
What are you using for an antenna? Eagle Aspen + amplifier because of the length of the cable run.
Flak is offline
post #249 of 416 Old 06-13-2009, 04:26 PM
jimboy's Avatar
Charter cable picks us up in West Bend and they indicated that the signal on 18 is fairly strong. What are you getting for signal on 30-1, 24-1. & 4-1 (RF channels 22, 25, 28)?
jimboy is offline
post #250 of 416 Old 06-13-2009, 06:03 PM
gjvrieze's Avatar
Try unhook the antenna from the converter box, then run a complete scan, then hook the antenna back up and run another full scan, and please post back about what that does for you!
KD0MOF
All opinions expressed (unless otherwise noted) are the poster's only and NOT that of the poster's employers.
gjvrieze is offline
post #251 of 416 Old 06-13-2009, 07:08 PM
Flak's Avatar
I don't use a converter box. Trying the antenna at different locations through out the house now.
Flak is offline
post #252 of 416 Old 06-13-2009, 07:10 PM
jimboy's Avatar
Flak...I would try the scan without the antenna first as gjvrieze suggests.
Otherwise, from your manual......
The “Resets all settings to the default values” message appears.
This appears when you press and hold the EXIT button for a while. The product settings are reset to the factory defaults.
Not sure if this would wipe the channels as well (probably not).
Or....try calling Samsung
Digital TVs : 1-800-SAMSUNG(726-7864)
Mon - Sun : 9am - Midnight (EST)
jimboy is offline
post #253 of 416 Old 06-13-2009, 07:11 PM
gjvrieze's Avatar
Opps, but you could do the same with the tv and its' tuner...
KD0MOF
gjvrieze is offline
post #254 of 416 Old 06-13-2009, 07:15 PM
jimboy's Avatar
What are your signal readings for 30-1, 4-1, and 24-1?
I don't suspect it's an antenna issue.
jimboy is offline
post #255 of 416 Old 06-13-2009, 07:25 PM
Flak's Avatar
4-1 no matter where I put the antenna always shows at least 4bars out of 10 for signal str.
24-1 varies by location from 2bars (and break up) to 8bars but it is always picked up by the scan
30-1 I never got until this last location I tried with the antenna... and it comes in at 7bars
18-1 I finally got as well in this last location with 8bars.
So I think I'm getting all my channels now, including what seems to be two CBS and both showing the same shows... 5-1 and 58-1.
The location all this works at though shocks me. It was at the highest point in the house mounted in a window facing the general direction of the towers. Now it is on the 1st floor of the house mounted low in a window kind of in the general direction of the towers (as good as I could get it right now).
Flak is offline
post #256 of 416 Old 06-13-2009, 07:37 PM
jimboy's Avatar
OK...so it is an antenna issue. Based on your signal readings.
Outside and as high as possible is always better.
What I'm currently using
http://www.warrenelectronics.com/antennas/4228HD.htm
Haven't tried this one yet but other engineers claim this works well.
DigiTenna, LLC Oostburg, WI.
http://www.skywalker.com/itemdisplay.aspx?item=228606
or
http://www.skywalker.com/itemdisplay.aspx?item=228697
Make sure your antenna is grounded properly so you don't get shocked again...
jimboy is offline
post #257 of 416 Old 06-13-2009, 08:01 PM
Flak's Avatar
Shocks me as in surprises. Since it's lower then the original location, didn't think it would work better at all. Maybe it has something to do with the fact that all the trees are full foliage now and the location it is in now has less obstruction even though it's lower giving me better signal str.
Flak is offline
post #258 of 416 Old 06-13-2009, 08:12 PM
jimboy's Avatar
I was trying to make a funny with the shocks.
Any idea what the model number of the antenna is? Curious as to what you are using.
jimboy is offline
post #259 of 416 Old 06-13-2009, 08:24 PM
Flak's Avatar
Eagle Aspen
I thought that after I posted, lol. That is the antenna I am using, a DB2 clone.
Flak is offline
post #260 of 416 Old 06-14-2009, 10:20 AM
Mr.G's Avatar
Quoted: 766 Post(s)
Liked: 441
I've got the Time Warner HD package out of Milwaukee. Last night I picked up channel 513 (Cinemax HD) for the first time. Is this a trial promotion or a HD channel addition to the package?
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
post #261 of 416 Old 06-14-2009, 11:37 AM
gjvrieze's Avatar
Eagle Aspen
How far out from the tower are you on WMVS, and do you get WMLW-LD on RF channel 13, PSIP remapped to 41-1.
KD0MOF
gjvrieze is offline
post #262 of 416 Old 06-14-2009, 02:52 PM
perpetual98's Avatar
Quoted: 89 Post(s)
Liked: 50
My HDHomerun picked up 4.3 after the switch, but my HTPC didn't grab it in a scan. Anyone know what that channel is?
perpetual98 is offline
post #263 of 416 Old 06-14-2009, 03:58 PM
lgodave's Avatar
Last time I checked it was still showing "Test bars".
I've had issues with a weak signal or intermittent one... causing a converter box (DTVPal) to "miss" some of the channels... It actually was Channel 4... Instead of 3 sub-channels(services) it only found one (4.1?). A rescan after the signal came back gave me all three...
You might try another scan after the signal is stronger maybe?
lgodave is offline
post #264 of 416 Old 06-14-2009, 08:13 PM
Satch Man's Avatar
Quoted: 66 Post(s)
Liked: 75
All Cinemax and Cinemax On-Demand channels are doing a four day promotional run in most TWC divisions. The same with HBO and HBO on Demand channels. The promotion began on Friday, and is supposed to run through Monday. (June 12-June 15, 2009.)
Jack
post #265 of 416 Old 06-14-2009, 09:02 PM
Flak's Avatar
I get channel 41 but scan does not pick up 41-1 in the antenna's current location. And according to the dtv site I am 27miles from the WMVS towers.
Flak is offline
post #266 of 416 Old 06-15-2009, 02:28 PM
Mr.G's Avatar
Quoted: 766 Post(s)
Liked: 441
Jack
Wishful thinking on my part - thanks for the reply.
Mr.G is offline
post #267 of 416 Old 06-26-2009, 07:01 AM
jlachowin's Avatar
Eagle Aspen
Such a good price on that, thanks for the link! I got that antenna, 500ft of SCP RG6 Quad Shield cable (pull box) and a RCA 1x3 splitter for $59 shipped. Insane deal.
jlachowin is offline
post #268 of 416 Old 06-26-2009, 07:12 AM
gjvrieze's Avatar
I DXed WMTJ this morning and saw first hand 4-3. Does anyone know what they are planning for the sub or why it is there? (they do not do Update TV or anything else, that could cause "weird" subs to show up)
KD0MOF
gjvrieze is offline
post #269 of 416 Old 06-26-2009, 09:23 AM
caledonia1's Avatar
Wishful thinking on my part - thanks for the reply. [IMG]http://www.*****************/trafficreport/img/3721/k08t1221bbuq/gdsmile.gif[/IMG]
That reply was also helpful to me too.
caledonia1 is offline
post #270 of 416 Old 06-26-2009, 10:24 AM
dwright944's Avatar
I don't know for sure, but I'm guessing they will be adding Universal Sports like WMAQ in Chicago.
dwright944 is offline
