Fort Smith, AR - HDTV - Page 100 - AVS Forum | Home Theater Discussions And Reviews
post #2971 of 3408 Old 10-23-2009, 06:15 PM
829
829's Avatar
I am picking up RTN now, 44.1. 88%.
829 is offline
post #2972 of 3408 Old 10-24-2009, 07:06 AM
arxaw's Avatar
Do you mean RTV?
Do you know the physical channel number?
arxaw is offline
post #2973 of 3408 Old 10-24-2009, 07:08 AM
Trip in VA's Avatar
Quoted: 786 Post(s)
Liked: 233
Send a message via AIM to Trip in VA
Should be 44. http://www.fcc.gov/fcc-bin/FMTV-serv...LD1150735.html
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
post #2974 of 3408 Old 10-24-2009, 07:54 AM
arxaw's Avatar
Trip, much appreciated.
Thankfully, it's too weak & too far away to interfere with KYTV 44.
arxaw is offline
post #2975 of 3408 Old 10-24-2009, 10:37 PM
arkeng's Avatar
RTV
Dang! Just a smidgen of a signal here in Greenwood, about 20%, and well within their coverage map. Wonder if they're transmitting at their full 15 kW?
arkeng is offline
post #2976 of 3408 Old 10-25-2009, 09:48 AM
829
829's Avatar
@arxaw: Yes, RTV. Sorry for the slight of hand.
@arkeng: I am not far from Greenwood and it is still coming in strong. I am in between The Links and Ben Geren and to the south of the air port, today I am at 80%. Are you still getting Tulsa channels? I am thinking of constructing a DBGH to pick some of those up.
829 is offline
post #2977 of 3408 Old 10-25-2009, 10:57 AM
aerotive's Avatar
Thanks for the info 4029 and arxaw. I have a private deck/patio but I'd have to use around a 30-ft pole to get it above the roof of my building, plus I'd have to somehow route it around other people's decks. I will have to live with 51.2 for Fox.
Even though KFSM is 2edge for me, I can pick that up just fine. Do you think if Fox upped their transmitter to 1000kW that'd put it in range? They're nine miles farther away than KFSM so it might still be out of range, or borderline.
aerotive is offline
post #2978 of 3408 Old 10-25-2009, 12:09 PM
arxaw's Avatar
It's the distance and the hills. Their choice of tower locations is not good for many NWA viewers. They're @ ~660kW and that's all their antenna setup can handle. So, no power increases are planned for KFTA.
BTW, KFSM is currently only at 550kW, not 1,000. They have applied to roughly double power to ~1,000kW ERP, but the project has been delayed until at least next year.
If you click the individual station's call letters on your TVFool results, you'll get a graph showing the number and relative size of hills between you & each station's tower. The TV transmitter tower is on the very far left and your house is on the very far right in the graph.
Reception strength is shown in spectrum colors, with white being the strongest and violet/pink being the weakest.
arxaw is offline
post #2979 of 3408 Old 10-25-2009, 06:29 PM
arkeng's Avatar
RTV
Originally Posted by 829 View Post
.... @arkeng: I am not far from Greenwood and it is still coming in strong. I am in between The Links and Ben Geren and to the south of the air port, today I am at 80%. Are you still getting Tulsa channels? I am thinking of constructing a DBGH to pick some of those up.
829, thanks for the heads up on RTV. You must have caught it right after they went on the air. I turned one of my antennas around toward channel 44's tower on Mt. Vista, now getting RTV on 44.1 at about 85%. Unfortunately though, twisting that antenna around about 35 degrees eliminated the Tulsa channels. I still get a couple of Tulsa UHF channels on the other antenna, but I rarely watch them any more anyway.
Good luck with the DBGH and the Tulsa stations. Let us know how it works out.
arkeng is offline
post #2980 of 3408 Old 11-02-2009, 07:05 PM
829
829's Avatar
This past week or so, I have been getting some bleed on OETA from KFSM and OETA becomes temporarily unavailable, anyone else seeing this?
829 is offline
post #2981 of 3408 Old 11-03-2009, 12:09 AM
arkeng's Avatar
829, are you talking about KOET-DT (3.1) from Eufaula or KOED-DT (11.1) from Tulsa, and what kind of interference are you seeing?
arkeng is offline
post #2982 of 3408 Old 11-03-2009, 03:22 PM
arxaw's Avatar
If you're in the Northern part of the DMA and can get KSPR out of Springfield, their local news/weather is now in HD.
It's a huge improvement over their old blurry analog studio.
arxaw is offline
post #2983 of 3408 Old 11-03-2009, 08:02 PM
829
829's Avatar
Yes, KOET 3.1. I get artifacts from KFSM on KOET and I have been loosing 3.1 regularly. This happens either reversing from 5.1 or advancing from 44.1.
No one has been in my attic to touch my antenna, but I guess it could be vibration from Jet's, it seems I remember the 188 practicing one night, but I do not remember if it was before or after I started having this issue.
829 is offline
post #2984 of 3408 Old 11-03-2009, 10:30 PM
arkeng's Avatar
Yes, KOET 3.1. I get artifacts from KFSM on KOET and I have been loosing 3.1 regularly...
That's interesting 829. I watch KOET occasionally, most recently Monday night I think, and didn't notice anything strange. What type of receiver(s) does it happen on? All receivers? If KOET is your weakest station, maybe some receiver overloading from KFSM? Is there an amplifier on your attic antenna?
arkeng is offline
post #2985 of 3408 Old 11-03-2009, 10:44 PM
arkeng's Avatar
I hope our locals find the funding and/or motivation soon for HD news and weather for us viewers here in the river valley. Before the transition I used to watch the Tulsa news and weather simply because it was in HD.
4029, anything you might be aware of?
arkeng is offline
post #2986 of 3408 Old 11-04-2009, 06:29 AM
829
829's Avatar
It is my weakest at around 70%. The antenna is powered.
829 is offline
post #2987 of 3408 Old 11-04-2009, 09:51 AM
arxaw's Avatar
I hope our locals find the funding and/or motivation soon for HD news and weather for us viewers here in the river valley...
I was initially surprised that KSPR went local HD, since it's a smaller market than LR (where even Wheel of Fortune is still in SD). But it made sense to go ahead and do HD, while they were consolidating and moving into a brand new studio in KYTV's building, owned by the same company. It would've been crazy not to. Digital automation also cuts costs by cutting back on the number of people used to run the station. According to the Springfield thread, with robotic studio cameras and other gadgetry, a news show that used to require 7 behind the scenes people to produce is now done with only 2.
I imagine for the most part, though, stations are in a holding pattern WRT upgrades. KFSM delayed their power increase until next year and their River Valley translator is on hold indefinitely.
arxaw is offline
post #2988 of 3408 Old 11-05-2009, 12:56 AM
arkeng's Avatar
829, lots of folks out there more qualified than I am, but sounds like a hardware issue to me. Don't know if there is a thread on the AVS forum or other for your particular receiver or not, might be someone there who's had the same problem. If you haven't already, a google search with your receiver number might turn up something.
arkeng is offline
post #2989 of 3408 Old 11-05-2009, 09:19 PM
4029engineering's Avatar
I only know about us and I've said it before. Hearst owns 27 stations. Their goal was to convert 3 a year. They have done 6. We are at the bottom of the list. 21/3=7 years. We would love to do it now. Now for even more bad news. The economic crunch caused Hearst to cancel any conversions next year.
4029engineering consists of several engineers who are HDTV viewers just like you. Anything said in this forum is their own opinion and not necessairly official KHBS/KHOG policy.
4029engineering is offline
post #2990 of 3408 Old 11-07-2009, 09:17 AM
Brian HD's Avatar
Getting pixels with sound hiccups every 8-10 seconds on 40/29. Both Dish and OTA signal.
The game is going to be a pain to watch.
UPDATE: It stopped once the game started - must have been the ESPN studio feed problem
Brian HD is offline
post #2991 of 3408 Old 11-07-2009, 06:52 PM
sethwell's Avatar
yeah, i'm sure not many people are really wanting to watch Craig or Donna in HD. Then again some may want to see Angelica or Melissa in HD. all in good fun.
sethwell is offline
post #2992 of 3408 Old 11-08-2009, 06:24 AM
arxaw's Avatar
Originally Posted by sethwell View Post
yeah, i'm sure not many people are really wanting to watch Craig or Donna in HD.... all in good fun.
Yeah, seeing Craig's bridge fall out of his mouth on camera was bad enough in Standard Def.
arxaw is offline
post #2993 of 3408 Old 11-09-2009, 11:43 AM
sethwell's Avatar
LOL, i must have missed that one. good clip.
sethwell is offline
post #2994 of 3408 Old 11-09-2009, 07:47 PM
arxaw's Avatar
Unfortunately, I saw it live.
Fortunately, it was in SD.
arxaw is offline
post #2995 of 3408 Old 11-12-2009, 02:15 PM
829
829's Avatar
Anyone else loose RTV last night?
829 is offline
post #2996 of 3408 Old 11-12-2009, 11:11 PM
arkeng's Avatar
Didn't watch it Wednesday night, but a pretty weak signal here right now, barely enough to lock.
arkeng is offline
post #2997 of 3408 Old 11-14-2009, 04:08 PM
arxaw's Avatar
Live from the White River (almost):
http://www.kfsm.com/news/kfsm-news-n...,1411223.story
arxaw is offline
post #2998 of 3408 Old 11-14-2009, 05:03 PM
829
829's Avatar
Someone getting a pink slip on that one.
829 is offline
post #2999 of 3408 Old 11-14-2009, 07:27 PM
arxaw's Avatar
In-depth coverage.
arxaw is offline
post #3000 of 3408 Old 11-15-2009, 02:50 PM
sethwell's Avatar
I guess they were trying to be "first" on the scene! glad they are all right though.
hmmm, a couple job postings on KFSM.com.
sethwell is offline
