Fort Smith, AR - HDTV - Page 16 - AVS Forum | Home Theater Discussions And Reviews
post #451 of 3408 Old 07-27-2006, 09:45 AM
nj829's Avatar
I would assume that the cable channel would not change, as they are piping in the feed already. The over the air feed will only affect those who do not have cable and use an antenna to receive the signal. Fox is scheduled to start up on KFTA around 8/28, and should be HD, and will I assume be carried on cable as well. The 7/28 start for OTA is just for those of us that are antenna receiving HD vs. cable.
nj829 is offline
post #452 of 3408 Old 07-27-2006, 09:53 AM
arxaw's Avatar
Originally Posted by darupina View Post
And I'll assume that Fox on the new station will start around 8/28?
OTA, probably. On cable systems, probably, but maybe later.
But it could arrive sooner on cable than OTA, since you're paying Nexstar (indirectly, via your monthly cableco bill) to watch their programming.
arxaw is offline
post #453 of 3408 Old 07-27-2006, 09:49 PM
darupina's Avatar
thanks all.
darupina is offline
post #454 of 3408 Old 07-28-2006, 06:59 AM
dmix00's Avatar
Originally Posted by arxaw View Post
The actual (RF) broadcast channels will be:
KNWA-DT on channel 50
KFTA-DT on channel 27
It's up to the stations as to whether they will remap to their new digital or their old analog channel numbers. Example:
KNWA-DT (NBC) might be 51-1 or 50-1
KNWA-DT (FOX) might be 51-2 or 50-2
After analog goes dark, I think the FCC should make stations use their real RF channel numbers.
Thanks arxaw. So does this mean when KNWA starts OTA later today that we should look for anything in the range from 50.1 to 51.1 on our scan for new channels? Or will it be 50.1? (not 50 since that is the analog?).
dmix00 is offline
post #455 of 3408 Old 07-28-2006, 08:08 AM
nj829's Avatar
The analog is 51, digital is 50. I wouldn't be surprised if it is on 50-1 at first, and then later that channel disappears and a rescan shows it up on 51-1 just as the kinks get worked out.
If someone gets any updated info or sees it up and running, make sure to post where you are and signal strength!
nj829 is offline
post #456 of 3408 Old 07-28-2006, 08:41 AM
arxaw's Avatar
Yes. Look for 50-1 or 51-1.
arxaw is offline
post #457 of 3408 Old 07-28-2006, 02:43 PM
arxaw's Avatar
3:43pm and no KNWA-DT yet for me. Anyone else?
FWIW, I saw this on their web site:
Transmitter/Maintenance Engineer
( Date Posted: 6/14/2006 )
KNWA-TV has an opening for a full-time television broadcast transmitter/maintenance engineer. Successful candidate will have 5 years of solid work experience in the maintenance and repair of television broadcast transmitters, RF, and DTV systems. The candidate will be responsible for maintaining complete and accurate documentation for all equipment at the transmitter facility. This is a hands-on position that will require a thorough knowledge of UHF/HDTV transmitters. Duties will also include technical training on remote transmitter monitoring to the station operations staff, repair of ENG equipment, support for live newscasts, and outside broadcast remotes. A strong news background, the ability to lift a minimum of 25 lbs, and be willing to work nights, weekends, and holidays is desirable. Two year Associates degree or electronic certification program preferred. FCC General Class license and/or SBE certification preferred. Drivers license with satisfactory driving record mandatory. Final candidate will be asked to submit to a drug screen. Deadline: Open. Please send resume and salary requirements to: KNWA-TV; Attn: Chief Engineer; 15 S. Block, Suite 101; Fayetteville, AR 72701. No phone calls please. EOE."
arxaw is offline
post #458 of 3408 Old 07-28-2006, 03:14 PM
arkeng's Avatar
KFTA-DT 27-1 had their "Please Stand By" KNWA logo up for almost an hour this afternoon starting about 3:00 P.M., with intermittent short outages. Maybe just a coincidence that it happened today?
arkeng is offline
post #459 of 3408 Old 07-28-2006, 04:24 PM
arxaw's Avatar
Another Deathstar/KNWA deadline missed.
arxaw is offline
post #460 of 3408 Old 07-28-2006, 04:39 PM
Arkie's Avatar
maybe the rain today has caused a delay?
Arkie is offline
post #461 of 3408 Old 07-28-2006, 04:45 PM
arxaw's Avatar
surely their tower work is already completed. but then again, maybe not.
arxaw is offline
post #462 of 3408 Old 07-28-2006, 06:43 PM
arkeng's Avatar
KFTA-DT 27-1 OTA now has updated PSIP information to indicate that they are actually KFTA-DT, and their system time table now has the correct time. Tuesday they were KPOM-DT and their system time said it was May 30, 2001. So somebody is doing something. But their picture on 27-1 is still 720 x 480i and their signal strength here is the same as it was yesterday.
arkeng is offline
post #463 of 3408 Old 07-29-2006, 07:28 AM
nj829's Avatar
If their tower is the one going up on 540 just south of the new mall, there were 2 big crains working at it on Wednesday, so maybe they are a bit behind. is analog 51 on the air?
nj829 is offline
post #464 of 3408 Old 07-29-2006, 07:34 AM
arxaw's Avatar
Originally Posted by nj829 View Post
If their tower is the one going up on 540 just south of the new mall...
No.
KFTA-DT 27's tower is here:
KNWA-DT 50's tower is here:
arxaw is offline
post #465 of 3408 Old 07-29-2006, 08:16 AM
Theoliver's Avatar
I am picking up KFSM and KHOG OTA with a fixed antenna on my roof (Springdale, West of 540). KNWA's will be located in the opposite direction from me and I know from past experience that there's no way my antenna will pick it up since it's not faced in that direction. Should I get another antenna to face KNWA's way and then somehow feed them into the same line? Or is a multi-directional antenna my only choice?
Theoliver is offline
post #466 of 3408 Old 07-29-2006, 08:41 AM
arxaw's Avatar
I would wait until KNWA-DT gets on the air. You may be surprised, especially if you have one of the newer OTA tuners that works with the antenna in almost any direction. The DirecTV H20 receiver is a good example.
arxaw is offline
post #467 of 3408 Old 07-29-2006, 10:32 AM
nj829's Avatar
Well on another note, I did see a red KNWA work truck on hwy 112 this AM with several boxes in the back, could be a coincidence, and it's the weekend and there is nothing on anyway right now, so I am just stretching....
nj829 is offline
post #468 of 3408 Old 07-29-2006, 10:46 AM
Kimmie's Avatar
I'm just east of 540 in North Springdale and pick up KFSM and KHOG OTA well with a $100 pair of electric rabbit ear antenna hidden behind my tv wall unit.
Kimmie is offline
post #469 of 3408 Old 07-31-2006, 09:22 AM
Arkie's Avatar
Has KNWA made any announcement about how long the delay will be?
Arkie is offline
post #470 of 3408 Old 07-31-2006, 10:44 AM
arxaw's Avatar
I just called KNWA. The woman on the phone said they were still in the process of installing equipment and she had no idea when they would get on the air.
You might try calling or emailing them:
http://www.knwa.com/about.asp
arxaw is offline
post #471 of 3408 Old 08-01-2006, 02:36 PM
Arkie's Avatar
I sent them an email yesterday, but they have not replied yet. With NBC showing the Hall of Fame NFL game Sunday night in HD, I was hoping they would have their broadcast up and running in time.
Arkie is offline
post #472 of 3408 Old 08-01-2006, 06:48 PM
RhodeHog's Avatar
..receiving program information for KHOG. I have an antenna to receive the locals, and for some reason I can't get the program information for KHOG. It just says "digital service." Has anyone else encountered this? I've already spoken to the KHOG engineer, and he didn't know why, since he said that they were broadcasting fine.
RhodeHog is offline
post #473 of 3408 Old 08-01-2006, 08:36 PM
arxaw's Avatar
I assume you're talking about KHOG-DT 29-1 OTA.
Not sure about Dish, but on DirecTV, the guide info for OTA channels in your local market comes from DirecTV. They get their guide info from Tribune Media Services, which may also supply guide info for Dish, but I'm not sure. Anyway, KHOG-DT's program guide has been screwed up for a long time, at least in the mornings. It shows "SIGN OFF", instead of the correct program info. I've contacted KHOG, DirecTV and Tribune Media repeatedly, but nothing has ever been done about it. It's a tribune media problem.
http://www.tribunemediaentertainment...ctronic.shtml#
arxaw is offline
post #474 of 3408 Old 08-01-2006, 10:33 PM
wegaboy's Avatar
When PBS shows HD programming here in Fayetteville, the sound doesn't come on with it, just the video. Does anyone else have this problem? My TV has a built-in tuner so I'm getting it on channel 108.1.
wegaboy is offline
post #475 of 3408 Old 08-02-2006, 07:30 AM
arxaw's Avatar
Are you on cable? PBS-HD works great OTA. Try using an antenna and tune to OTA ch 13-1.
arxaw is offline
post #476 of 3408 Old 08-02-2006, 10:28 AM
Arkie's Avatar
Spoke to KNWA, didn't get the feeling they were going to be on anytime in the immediate future.
They said they had installation problems, and hoped it wouldnt be too long before they were broadcasting.....
Arkie is offline
post #477 of 3408 Old 08-02-2006, 01:14 PM
arxaw's Avatar
If anyone's interested, KNWA's phone number is:
479 571-5100
Let 'em know people have been waiting.... and waiting......and.....waiting....
arxaw is offline
post #478 of 3408 Old 08-02-2006, 01:41 PM
KeithAR2002's Avatar
You know, I dont even live up there, but that's just plain wrong. They've been advertising July 28 for the past two months.... all about promoting HD and crap... and now "not in the immediate future"? And they saying installation problems? Baloney. More like they are just too damn incompetent to run a television station.
HD OTA From Houston, TX
KPRC 2 (NBC-HD)
KUHT 8 (PBS-HD)
KHOU 11 (CBS-HD)
KTRK 13 (ABC-HD)
KTXH 20 (MNTV-HD)
KRIV 26 (FOX-HD)
KIAH 39 (CW-HD)
KeithAR2002 is offline
post #479 of 3408 Old 08-02-2006, 02:56 PM
WED0420's Avatar
This does NOT bode well for Nextar's takeover of the local FOX affiliate . . . .
But I must say that via Cox, the KNWA signal is much improved. I don't notice any AV synch issues and they've been exceedingly good at switching the picture over to HD when necessary.
WED0420 is offline
post #480 of 3408 Old 08-02-2006, 03:46 PM
wegaboy's Avatar
I'm on Cox cable and I pick up my local HD stations through my television's built-in tuner. I can get ABC (29.1), CBS (5.1), and NBC (108.2) in HD but PBS (108.1) is the only station that I have trouble with. Nothing comes up when I'm on ch 13.1.
wegaboy is offline
