Fort Smith, AR - HDTV - Page 17 - AVS Forum | Home Theater Discussions And Reviews
post #481 of 3408 Old 08-02-2006, 03:23 PM
arxaw's Avatar
13-1 is the OVER THE AIR (OTA) channel. You need to connect an antenna to your TV and do a scan for OTA digital channels. See the setup menu in your TV.
arxaw is offline
post #482 of 3408 Old 08-03-2006, 05:13 PM
EricJ's Avatar
There is an interesting letter from Nexstar to the FCC up on the arkansastvnews
blogspot com site
From this, it looks like KNWA is trying to be on OTA DTV by Sept 1st and
KFTA is labeled with a September 2006 start.
"Nexstar, the parent company of KARK/Little Rock and KTAL/Shreveport, is asking the FCC to grant them an extension in the deadline to up the power for some of its station's DTV signal. KTAL is one of those stations. Nexstar says can't afford to make the needed upgrades at the moment. "
They are claiming it will cost 48 million to upgrade all of its stations to DTV.
http://svartifoss2.fcc.gov/prod/cdbs...ibit_id=415284
EricJ is offline
post #483 of 3408 Old 08-03-2006, 06:55 PM
arxaw's Avatar
They wrote a nearly identical letter to the FCC, begging for a time extension for KOLR-DT, up in Springfield.
View it here.
arxaw is offline
post #484 of 3408 Old 08-04-2006, 12:46 PM
Arkie's Avatar
KNWA has an updated letter from their GM on their website. Promises HD soon, no date set though this time......
http://www.knwa.com/hdtv.pdf
Arkie is offline
post #485 of 3408 Old 08-04-2006, 02:24 PM
arxaw's Avatar
KNWA idiot:..."we are happy to announce that this [hd] has now become a reality...."
They need to do a reality check.
They obviously don't give a sh*t about their OTA viewers or they would've had this station up & running a long time ago.
arxaw is offline
post #486 of 3408 Old 08-06-2006, 03:49 PM
hevnbnd's Avatar
I am in Bella Vista. Anyone getting any HD OTA channels their? Also what satelite are the locals on from dish in this area. Thanks
hevnbnd is offline
post #487 of 3408 Old 08-07-2006, 05:20 AM
arxaw's Avatar
Depending on elevation, you should be able to get ABC, CBS, PBS OTA from Fayetteville/Ft Smith area stations. NBC & FOX should be on the air by this fall.
The antenna/preamp below works very well in this area for those channels:
Channel Master CM 4228 antenna
Channel Master CM 7777 preamp
Go to http://www.antennaweb.org for a rough estimate of channels you may be able to get. Enter your complete address for a more accurate estimate. UNcheck the "send me info" boxes, so they won't send you emails, etc.
arxaw is offline
post #488 of 3408 Old 08-08-2006, 07:31 PM
dmix00's Avatar
Just heard from KNWA's VP:
Hi Dwight,
July 28 was the target. We have had numerous vendors that
did not meet their delivery dates, which is something we
can't do anything about. I will not release a new launch
date until we have cycled the new facility and am sure
it's ready to go, which I hope will be within the next 2
weeks. I will update the website as soon as I am ready to
commit. We're building our new Fox HD facility at the
same time. You can appreciate the scope of the project.
Great things are worth waiting for! I appreciate your
e-mail.
Have a wonderful evening.
Blake Russell
VP/GM
I followed up his email and asked if Fox HD will have some shows broadcast in 720p or just 480p. Hope to hear from him soon so we can know if we are getting HD (instead of SD, as was rumored earlier) on Fox as well. Will post when I hear more.
dmix00 is offline
post #489 of 3408 Old 08-09-2006, 08:08 AM
Arkie's Avatar
I got a similar email last night. It also said 2 weeks for the switch to be flipped.....
Arkie is offline
post #490 of 3408 Old 08-09-2006, 09:35 AM
arxaw's Avatar
Originally Posted by dmix00 View Post
...I followed up his email and asked if Fox HD will have some shows broadcast in 720p or just 480p....
All FOX network HD programming is 720p.
In all likelihood:
FOX on KFTA-DT 27-1 will be 720p.
NBC on KFTA-DT 27-2 will be 480i.
NBC on KNWA-DT 50-1 will be 1080i.
FOX on KNWA-DT 50-2 will be 480i.
KFTA-DT's 2 channels will probably look better than KNWA-DT's, since 720p needs less bandwidth than 1080i.
arxaw is offline
post #491 of 3408 Old 08-09-2006, 07:25 PM
dmix00's Avatar
In all likelihood:
Interesting. Why would they bother broadcasting the 480i signals when we are already supposed to get the 720p and 1080i signals?
dmix00 is offline
post #492 of 3408 Old 08-09-2006, 07:38 PM
arxaw's Avatar
They're doing it to reach more viewers with both fox & nbc, because the transmitters for KFTA and KNWA are in different locations. KNWA doesn't reach all of KFTA's coverage area and vice-versa.
KFTA-DT ch 27
KNWA-DT ch 50:
arxaw is offline
post #493 of 3408 Old 08-09-2006, 08:58 PM
dmix00's Avatar
I see, so depending on where you live you may or may not get the HD signal over the air. Do you expect to get both signals in HD (720p, 1080i)? Or only one of them in HD and the other in SD (480i)? (since you live further out)
dmix00 is offline
post #494 of 3408 Old 08-10-2006, 07:27 AM
arxaw's Avatar
I have no problem getting analog KFTA 24 because I'm on a hill. But I doubt I'll be able to get KFTA-DT 27 because of interference from another channel 27 (KSFX analog) in Springfield, MO, which I get very clearly on an analog TV.
After KSFX shuts down analog ch 27 in '09, I shouldn't have any problem getting KFTA-DT. Until then, I'll just watch FOX-HD on DirecTV, channel 88 - WNYW out of New York.
arxaw is offline
post #495 of 3408 Old 08-10-2006, 07:44 AM
dmix00's Avatar
Yes, on Ch. 27. As I understand it, bare with me... we'll
have 720p.
Blake
So this confirms 720p for the new FOX station, which means we finally will see 24 in HD come January (or house, Prison Break, football). Surely they will have it up by then! So instead of watching NFL on FOX with the worst transmission quality of all time, it will finally be watchable!
dmix00 is offline
post #496 of 3408 Old 08-10-2006, 09:15 AM
arxaw's Avatar
If you're within the blue lines of the maps above, you should be able to get FOX in 720p & NBC in 1080i.
Unless of course, you have a giant hill in the way.
arxaw is offline
post #497 of 3408 Old 08-10-2006, 11:27 AM
BelmontATO's Avatar
Check out this exchange between KNWA and myself...
Yes, you are correct.
Blake
On Wed, 9 Aug 2006 08:17:37 -0500 "Mark" wrote:
Excellent news!
I am hearing August 28 for a soft target date for FOX to go HD on Cox Cable. Is that accurate?
Thank you for getting back with me. I really appreciate
your help!
Mark
----- Original Message ----- From:
To: "Mark"
Sent: Tuesday, August 08, 2006 8:52 PM
Subject: Re: What does KFTA mean for Fort Smith?
Hi Mark,
Cox will have both Fox (708) and NBC (715) in HD. Cox will continue to have KNWA and the new Fox will replace the existing Fox on Channel 12. Cox will move us to Channel 8 in the fall. KNWA's over the air HD should reach into the River Valley. KFTA (Fox) will broadcast KNWA on Digital 27-2 over the air. The new Fox will in fact, be fantastic. I hope I have answered your questions, if not, let me know.
Blake
On Fri, 30 Jun 2006 10:45:30 -0500
"Mark" wrote:
Instead of trying to sort through all of the confusion online, I thought I would just come straight to the source. Once the new Fox affiliate goes live, will the Fort Smith area still receive KNWA NBC as well as the new KFTA FOX station? Also, will they both be available in High Definition from Cox? Finally, do you have an approximate broadcast date for the new FOX affiliate?
Speaking for everyone here, we are thrilled about the prospect of getting a new FOX affiliate. The broadcast quality on the one we have now is so bad that I often times will not watch that channel at all.
Thank you so much for your time!
Mark
BelmontATO is offline
post #498 of 3408 Old 08-10-2006, 11:52 AM
Kimmie's Avatar
I wonder if Aug 28th if soft date for Fox HD to be OTA as well?
Kimmie is offline
post #499 of 3408 Old 08-10-2006, 12:11 PM
darupina's Avatar
Belmont, thanks for that info!
darupina is offline
post #500 of 3408 Old 08-10-2006, 01:11 PM
arxaw's Avatar
If it's like the July 28th date for KNWA-DT OTA, don't hold your breath.
arxaw is offline
post #501 of 3408 Old 08-11-2006, 08:30 AM
arxaw's Avatar
I noticed that KPBI-CA 46 has an application in for a LP digital station on channel 44.
What's on KPBI (I can't get it OTA)? Is it still fox or what?
arxaw is offline
post #502 of 3408 Old 08-11-2006, 02:06 PM
arxaw's Avatar
Anyone else having pixelization problems today with KHOG-DT OTA?
They seem to have lingering problems after any rain storm comes along....
arxaw is offline
post #503 of 3408 Old 08-11-2006, 05:12 PM
arkeng's Avatar
Good info on the new channel. Thanks. As of now, KPBI 46 is still announcing as Fox 46 and has the Fox logo on their picture.
arkeng is offline
post #504 of 3408 Old 08-12-2006, 09:13 PM
tgpurye's Avatar
Does anyone if Digital KNWA and KFTA will be broadcasting in 5-1 sound?
tgpurye is offline
post #505 of 3408 Old 08-13-2006, 06:04 PM
WED0420's Avatar
Via Cox, I'm currently getting 5.1 on KNWA.
Not sure what OTA will be.
WED0420 is offline
post #506 of 3408 Old 08-13-2006, 08:38 PM
arxaw's Avatar
Originally Posted by WED0420 View Post
... Not sure what OTA will be.
[LOL] And at the rate KNWA's digital OTA install is going, we may never find out.
arxaw is offline
post #507 of 3408 Old 08-14-2006, 09:32 AM
Arkie's Avatar
I was picking up a digital stream on channel 50 last night. I had a signal strength of 94, but no picture or channel ID......
Arkie is offline
post #508 of 3408 Old 08-14-2006, 12:11 PM
arkeng's Avatar
In case you missed it...
From KNWA's website, posted today:
Channel 51 Off Air
KNWA-TV is currently in the process of moving its over-the-air analog transmission facility (Channel 51)to a new location. The result of this move will enable us to
reach viewers that live in certain low lying areas that may have had trouble receiving us in the past. This only affects our over the air viewers in Northwest Arkansas.
We expect this move will take approximately 3 days. We appreciate your patience and apologize for the inconvenience.
arkeng is offline
post #509 of 3408 Old 08-14-2006, 03:00 PM
Arkie's Avatar
My HD TiVo is still picking up a very strong digital signal on channel 50. Is anyone else seeing this?
I get no picture, and the channel identification is not received by the TiVo either. Perhaps they are testing their equipment?
Arkie is offline
post #510 of 3408 Old 08-14-2006, 04:13 PM
dmix00's Avatar
I was scanning for the new channel yesterday, and noticed that it had stopped on channel 50 (which means it was picking up something), then when the scan completed it did not tune to 50. So something was there, just not a full signal yet.
dmix00 is offline
