Columbus, GA - HDTV - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 130 Old 12-12-2013, 08:07 AM
tesla_engineer's Avatar
Quoted: 29 Post(s)
Originally Posted by voomvoom View Post
WLGA 66.1 (30 dtv)
now showing Antenna TV
instead of Weathernation HD
WLGA is now running Antenna TV on channel 66.1 and 66.2.
After the first of the year look for the start of local programming on 66.1 with the 66.2 remaining as Antenna TV.
Look for more on 66.3????
Also WLGA (RF30) is now running at permanent height on the Richland Tower at Cusseta, GA.
Receiving reports of reception at over 100 miles out from the transmitter.
Tom
tesla_engineer is offline
post #122 of 130 Old 12-12-2013, 08:41 AM
Trip in VA's Avatar
Quoted: 548 Post(s)
Liked: 145
Send a message via AIM to Trip in VA
Permanent height? Does that mean the STA height or the licensed height?
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
post #123 of 130 Old 12-12-2013, 11:23 AM
Quoted: 29 Post(s)
- Trip
This is the STA height.
Tom
post #124 of 130 Old 12-12-2013, 11:30 AM
Trip in VA's Avatar
Quoted: 548 Post(s)
Liked: 145
Should I assume an application to make the new height permanent will follow then? smile.gif
- Trip
N4MJC
RabbitEars
post #125 of 130 Old 12-12-2013, 12:10 PM
Quoted: 29 Post(s)
- Trip
Yes
Tom
post #126 of 130 Old 03-11-2014, 09:55 AM
GeorgiaPilot's Avatar
New to AVS - first post.
I am thinking about cutting the cord and going to OTA.
I am in North Columbus, is it even worth trying an indoor antenna, or should I jump right to the bigger investment in an outside model?
Any recommendations for either?
I may just go indoor for the shop TV and go big for the main one.
Thanks for any guidance!
GP
GeorgiaPilot is offline
post #127 of 130 Old 03-12-2014, 07:33 PM
Trip in VA's Avatar
Quoted: 548 Post(s)
Liked: 145
GeorgiaPilot,
You can certainly try an indoor antenna, but you'll get best results with an outdoor antenna, by far. You'll probably find that CBS, NBC and CW, FOX, and WLGA will be easiest. ABC and PBS will be your trouble spots. ABC is on VHF, and PBS is in Warm Springs.
Don't buy one of those plastic RCA-branded rectangles at the store. They're useless. My rule is that if it doesn't look like an antenna, it's probably not a good one. I like the Terk HDTVi (not the HDTVa) for an indoor antenna, if you want to try one.
- Trip
N4MJC
RabbitEars
post #128 of 130 Old 03-12-2014, 08:33 PM
Thanks Trip,
That is just the kind of info I was looking for.  What outdoor antenna would you rec?
post #129 of 130 Old 03-13-2014, 10:48 AM
Trip in VA's Avatar
Quoted: 548 Post(s)
Liked: 145
I was hoping someone more local to your area might chime in here, because while there's only really the one indoor antenna I like, outdoor antennas tend to vary with specific conditions. If you would, go to TVFool.com and post the link provided in bold print for your location (it masks your address) and if nobody else chimes in, I'll try to make you a recommendation.
- Trip
N4MJC
RabbitEars
post #130 of 130 Old 11-17-2016, 04:57 PM
jbrantley130's Avatar
Liked: 0
Originally Posted by GeorgiaPilot View Post
Thanks Trip,
I have a channel Master deep fringe advantage long range outdoor antenna. The one rated for 100 miles. I live about 20 miles north of Montgomery, AL and I'm getting channels in Columbus, GA 9, 38, 43, 54, 66). It works really well. Get a splitter and a preamp and you can use the one antenna for both of your TV's. Good luck.
Sent from my Pixel XL using Tapatalk
jbrantley130 is offline
