CANADA: Toronto, ON - HDTV - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 1191 Old 12-31-2004, 08:01 PM
rob50312's Avatar
Rabid nbc comes in fine for me in N/W mississauga but their signal is weeker then the rest.Their at half power and have a lower tower.they will go to full power in april.Try to get your antenna up higher
rob50312 is offline
post #92 of 1191 Old 12-31-2004, 08:17 PM
Rabid's Avatar
It's already on a 8 foot mast on top of the roof, but it is only one of those omni-directional (amplified flying saucer). Any more antennas will have to wait for the summer before I go up there........LOL
Rabid
(also in NW mississsauge - derry/407)
Rabid is offline
post #93 of 1191 Old 01-01-2005, 09:01 AM
rob50312's Avatar
Rabid I would suggest you install a channel master or winegard uhf only antenna with pre-amp in spring then you will receive nbc
rob50312 is offline
post #94 of 1191 Old 01-01-2005, 11:26 AM
Rabid's Avatar
That would probably work - but we'll see if nbc going to full power will fix the problem. Not that fond of roofs, jumping out of planes is ok, at least you havea chute. LOL
Rabid is offline
post #95 of 1191 Old 01-02-2005, 06:12 AM
videobruce's Avatar
Quoted: 608 Post(s)
Liked: 247
Those "amplified flying saucer" antennas need to be launched................
Or should I say they are out to lunch.
Free, abundant OTA television separates this country from many others. ATSC1 has only been in force since 2009. The wireless industry has enough spectrum. Enough of 'planned obsolesce'.
videobruce is offline
post #96 of 1191 Old 01-02-2005, 06:46 AM
BLT
BLT's Avatar
channel master 4228 with preamp works fine here for me and I,m 60 miles from the towers
BLT is offline
post #97 of 1191 Old 01-02-2005, 02:35 PM
intrac's Avatar
On the Buffalo thread, there is a mention that WGRZ has been playing with their PSIP and that these have to be finalized by Feb. 05. They mention that you should delete the channels and do a rescan.
Don't know if this will help.
The preamp might be a problem in Toronto. It may cause overloading on the Toronto channels.
intrac is offline
post #98 of 1191 Old 01-02-2005, 06:32 PM - Thread Starter
3mar67's Avatar
I was thinking of buying the US Digital receiver for my brother for his birthday. Does it pick up digital cable as well?
CSI is on CBS, so you'll pick it up on 4.1, 23.1 or 39.5 (all WIVB)
66.1 is Toronto-1, so far pretty useless...
I'm in east Mississauga -- NBC comes in for me..I've got an antennasdirect DB8 mounted outside.
Where is the nearest Wal Mart in Buffalo or Niagara Falls?
Did they have more in stock where you got yours?
3mar67 is offline
post #99 of 1191 Old 01-03-2005, 10:59 AM
Rabid's Avatar
I picked it up at the Walmart on Niagara Blvd close to the Blvd Mall, I beleive that it is in Amherst. So far I like it very much. Looking forward to watching CSI tonite.
The only trouble so far is the signal from ch. 29 - I don't think they've been broadcasting the HD signal lately. Can anyone confirm this???
Rabid
Rabid is offline
post #100 of 1191 Old 01-03-2005, 12:34 PM
intrac's Avatar
Remember that WUTV 29, comes in on 14 DT.
intrac is offline
post #101 of 1191 Old 01-03-2005, 11:03 PM
mdamberger's Avatar
Originally posted by videobruce
Rabid; if you are able to get 39 (4) & 38 (7) you should get 33 (2)! I prefer to use the ACTUAL channel number instead of using the analog equivalent since in a few years that will be history anyway (hopefully). Easier to get use to it now! You use it for the Toronto stations, why not use it for the US also!
You might have noticed recently that all the US stations are no longer promoting or specifically mentioning their digital channel position as they had been. Such as the station ID or promo with the channel listed at the bottom. As in WIVB 4 TV / WIVB 39 DT, now only showing WIVB 4 TV/DT. The FCC now wants only mention of the primary channel with channel mapping to their primary from the digital. Along with this they require at least 3 days of program information transmitted, the guide info. Feb 05 being the date to be in compliance.
There is also an option to have mapping from the analog station to the digital for STB's in the vertical interval info. So if you're STB has an analog tuner and can tune in the analog but does not know the digital equivalent the info is imbedded in the signal to tell the STB what channel to tune in to for the digital signal. So then the guide can also be available for the analog broadcast. Most broadcasters probably won't implement this option since analog will go away, why make the expense. There is also a closed captioning requirement for the digital version to be available; most have been simply passing along the line 21 caption, allowing an analog TV to decode it. Much like digital satellite does, but this will be part of the data stream, and allows the STB to give you options of color, text type and size etc.. Only the digital STB can decode this and display it, not the analog TV's decoder chip. But in all likely hood, both will be available and be identical.
mdamberger is offline
post #102 of 1191 Old 01-04-2005, 05:32 AM
videobruce's Avatar
Quoted: 608 Post(s)
Liked: 247
The FCC can & would f*** up a wet dream! Just another stupid move on their part. Never had any use for the FCC as far back as when I knew what the letters stood for.
Especially back in the 70's with the great 'CB' debacle when many US manufactures went under because of their stupidity!.
Remember, all those FCC commissioners are lawyers appointed by the President. Do I have to say more?
post #103 of 1191 Old 01-04-2005, 10:23 AM
mdamberger's Avatar
You are right about the lawyer thing. They also ruined HAM radio with incentive licensing. Resulting in many many manufactures going away, with only a few left and mostly Japanese manufactures. (Japan never did incentive licensing, and HAM radio stayed strong) But I believe the ARRL was the primary sponsor of this. There are also some ITU requirements that have to be meet, but mostly the ARRL's dumb idea.
post #104 of 1191 Old 01-04-2005, 01:12 PM
nambi's Avatar
I got an 8spK for my 6000 Expressvu, (located in Woodbridge). I wasn't sure on the UHF antenna to purchase but I bought an HD set top antenna to test out the 8spk and see what I might get.
I managed to get only 2 channels using the search fucntion on the receiver, City TV (53) and Toronto 1 (66) but to my surprise they quality wasn't as good as I was searching for.
I have a 60 " DLP Samsung and when the receiver was previously hooked up to BEV HD the HD (true HD Widescreen) looked great!!. I was hoping for something similar, I compared my 2 DTV OTA to my Sat picture and they looked EXACTLY The same, meaning digital but not HD, is this what I should have expected??
I am going to return the set top antenna to Radio Shack and probably go with the DB8 but I wanted to see if It would be worth the troubles.
Also I was hoping to see these in 16:9 but they were not. Do any OTA HD broadcast in 16:9?
Thanks for any answers.
nambi is offline
post #105 of 1191 Old 01-04-2005, 04:58 PM
rob50312's Avatar
The US networks have hdtv widescreen on most primetime shows and some sport events.8 to 11pm only.City-tv has the occational hdtv material .
rob50312 is offline
post #106 of 1191 Old 01-04-2005, 08:48 PM
Daniel Tonks's Avatar
Quoted: 308 Post(s)
Liked: 125
Toronto1 and CityTV are primarily mediocre upconverted SD. For City, wait for an episode of Smallville or Enterprise to see what HDTV looks like. They also show a lot of HD movies; go to their site and look in the bottom left corner for a HDTV link listing what they have in HD. Toronto1 doesn't do much at all in HD, I think some football.
Daniel Tonks is offline
post #107 of 1191 Old 01-05-2005, 12:18 PM
nambi's Avatar
Does anyone here use OTAHD and lives in Woodbridge I would like a recommendation on what they used to get signal and how many digial channels they received.
nambi is offline
post #108 of 1191 Old 01-05-2005, 01:22 PM
FrostMann's Avatar
I came accross this thread and found it really interesting. I have a HD tv and have never seen HD on it and I've had it for 2 1/2 years. I find it hard to believe you can get HD over the air waves. Does it really look like when you see it in the Future Shop? I measured on the map and I'm 78 miles accross the lake to Buffalo and Rochester, their exactly the same distance. Is this too far?and 45 miles to hart of TO. ?.Does Rochester even have HD channels?Thanks for the info.
FrostMann is offline
post #109 of 1191 Old 01-05-2005, 01:26 PM
dsspredator's Avatar
http://www.rochesterhdtv.com/portal.php
http://www.avsforum.com/avs-vb/showt...&pagenumber=68
dsspredator is offline
post #110 of 1191 Old 01-05-2005, 02:46 PM
Rabid's Avatar
Frostman - believe it or not - it looks better than Future Shop. Amazing
Rabid
Rabid is offline
post #111 of 1191 Old 01-05-2005, 03:18 PM
rob50312's Avatar
Yes Rochester has hd channels.Only pbs is at their full power.The other networks are at low power.If you can receive analog signals with indoor uhf antenna then you can receive the hd channels.
rob50312 is offline
post #112 of 1191 Old 01-05-2005, 05:59 PM
daredevil23's Avatar
http://www.avsforum.com/avs-vb/showt...postid=3081198
Just in case anyone wants to do some back reading.
Married Men Live Longer Than Single Men, But Married Men Are More Willing To Die.
All Rights Reserved.
daredevil23 is offline
post #113 of 1191 Old 01-06-2005, 08:26 PM
FrostMann's Avatar
With my rabit ears,thats all I have right now. I get Fox 29 which I think is Buffalo.Is this a HD channel?I get it good enough to watch with a little snow. Would this be a good enough signal?I'm sure with a good antenna I could get it perfect.But it would be nice to know before I by a HD receiver. I'm just trying to figure this stuff out Thanks guys.
post #114 of 1191 Old 01-06-2005, 08:56 PM
FrostMann's Avatar
I just read on one of the forums that just because you can get the analoge channel doesn't mean you will get it in HD?is this true
post #115 of 1191 Old 01-06-2005, 09:11 PM
FrostMann's Avatar
Another thing I was wondering is why some people say14.1 is Fox. I get it on 29 on my TV?Is the digital channel 14? Thanks
post #116 of 1191 Old 01-07-2005, 06:20 AM
htnut99's Avatar
FrostMann,
I'm new here to the forum and like you trying to educate myself on OTA signals.
I think that the Fox you are pulling in on channel 29 is the analog channel. To address your previous question, yes, just because you can receive the analog signal of a channel, does not mean you will be able to pull in the digital version.
Hope that helps.
htnut99
htnut99 is offline
post #117 of 1191 Old 01-07-2005, 06:42 AM
FrostMann's Avatar
Thx Htnut. I was wondering If anyone here has had any luck with buffalo or Rochester from East Toronto. I'm in the Bowmanville area. About 78 miles directly accross the lake to Buffalo or Rochester,there the same distance. I read that Fox in Rochester will be going full power this month?will this be posible from my area,Thanks alot
post #118 of 1191 Old 01-07-2005, 09:21 AM
intrac's Avatar
From Bowmanville you should be able to get a good shot at Buffalo -- directly across the lake for you.
You may even get Rochester -- but remember, the HD channels are the major networks, and they are the same in Buffalo as in Rochester.
ABC, NBC, CBS, FOX, UPN, WB and PBS are all running in Buffalo. Not all are at full power. FOX, UPN and PBS are the closest -- on Grand Island.
The others are S.E. of buffalo.
intrac is offline
post #119 of 1191 Old 01-07-2005, 12:48 PM
FrostMann's Avatar
So If I wanted Fox from buffalo what antenna would I get if thats all I wanted?75miles across the lake?
post #120 of 1191 Old 01-07-2005, 12:57 PM
intrac's Avatar
With your location in Bowmanville, you would aim straight south, and all the Buffalo stations are almost in a straight line for you.
I like the ChannelMaster 4228. It works well for 75 miles. There are others too. This antenna would likely give you some gain off the side which is probably enough for the Toronto HDs. (when most come on, right now there are only 2 (CITY & Toronto1).
intrac is offline
