Charlotte, NC - OTA - Page 119 - AVS Forum | Home Theater Discussions And Reviews
 225Likes
post #3541 of 10942 Old 07-08-2011, 03:54 PM
ybsane's Avatar
Quoted: 99 Post(s)
Liked: 35
Originally Posted by Theo1080 View Post
WSOC and WAXN are at reduced power and have been off and on all week...Yesterday was usually as the JIM Pole was in the UP position in an attempt to lift the new WAXN antenna, however the storm came up and they were not able to lower the JIM Pole for the night. Both station were at reduced power during the overnight. Hopefully the WAXN antenna will go up today and the reduced power times will be behind us. Thank you for your patients.
Ted, it is a Gin Pole, not Jim...
http://www.tower-technologies.com/GinPole.htm
rob
All Comments made are my own and not of my employer.
ybsane is offline
post #3542 of 10942 Old 07-08-2011, 04:05 PM
bdfox18doe's Avatar
Quoted: 241 Post(s)
Liked: 135
rob
Ted will probably need some Gin by the time he's finished...
Bob
The views expressed here are my own and do not necessarily represent those of ABC, CBS, CW, FOX, MeTv, or AntennaTv; my employer; or its parent company.
Nor my wife for that matter!
bdfox18doe is offline
post #3543 of 10942 Old 07-08-2011, 06:45 PM
Theo1080's Avatar
Quoted: 99 Post(s)
Liked: 44
My tower, my antenna.....I call it what I want......
Ted Hand, CPBE. 8VSB, DRB, AMD
I was there on July 23, 1996...First DTV broadcast in the US..WRAL-HD
Amateur Radio - W9SOC
Theo1080 is offline
post #3544 of 10942 Old 07-08-2011, 06:51 PM
stevohdftmill's Avatar
Did they get the antenna up before the storms today? I guess the bigger question is did the guys get down the elevator before the storms hit?
stevohdftmill is offline
post #3545 of 10942 Old 07-09-2011, 04:19 AM
hamstang's Avatar
Quoted: 24 Post(s)
rob
Then there's guy wires and guide wires also......
hamstang is offline
post #3546 of 10942 Old 07-10-2011, 10:12 AM
evan237's Avatar
Quoted: 20 Post(s)
both WSOC and WAXN went back to full power at 1602, Friday, 7/8/11....they will go back to reduced power tomorrow (7/9/11) for appox 6 hours.
Ted, can you provide any updates on WSOC and WAXN? I am just curious to know whether the work is completed or if it is still ongoing. Appreciate it.
evan237 is offline
post #3547 of 10942 Old 07-10-2011, 07:52 PM
tylerSC's Avatar
Quoted: 798 Post(s)
Liked: 180
WSOC and WAXN appear to be back at full power Sun night as I am getting 10 bars on 9.1 and 3-5 on 64.1. Looks like I may now be able to see 64.1 more often at night with their new antenna and more power.
tylerSC is offline
post #3548 of 10942 Old 07-10-2011, 10:12 PM
tylerSC's Avatar
Quoted: 798 Post(s)
Liked: 180
By midnight, WAXN ranged from 6-10 bars and WSOC remained a solid 10. WCCB is at 8-10. Seems like their work may be done as I am now seeing good overnight reception. Although I will lose these channels by 10am, they usually return by 7:30pm. The Dallas signals remain solid all day, ranging from 8-10 lead by WBTV. Sometimes lose WCNC due to overnight weather conditions.
tylerSC is offline
post #3549 of 10942 Old 07-11-2011, 08:11 AM
Theo1080's Avatar
Quoted: 99 Post(s)
Liked: 44
Structure issues will require WSOC and WAXN to go to reduced power doing the daylight hours on July 12th, (Tuesday)..Depending on the outcome of these repairs, more reduced power days maybe needed. At the end of all work, WAXN-TV will increase to 150Kw, DA, Horiz polar....109Kw, DA, Vertical polar.
Theo1080 is offline
post #3550 of 10942 Old 07-11-2011, 12:11 PM
Theo1080's Avatar
Quoted: 99 Post(s)
Liked: 44
Crowder's Mt. translator has lost a RF PA module and is at 75% power...Harris is overnighting a new module.
Theo1080 is offline
post #3551 of 10942 Old 07-13-2011, 02:24 PM
Theo1080's Avatar
Quoted: 99 Post(s)
Liked: 44
WAXN is now on its new antenna, at new power level and new vertical polarization.....any signal reports from SC or West of Charlotte are welcome.
Thank you....
Crowder's Mt translator is back at 100% as of 9:02am this morning (Wednesday)
Theo1080 is offline
post #3552 of 10942 Old 07-13-2011, 02:29 PM
bdfox18doe's Avatar
Quoted: 241 Post(s)
Liked: 135
Does it have MH pids to test with Ted? I'm in Montgomery now so can't check.
Bob
post #3553 of 10942 Old 07-13-2011, 02:42 PM
Theo1080's Avatar
Quoted: 99 Post(s)
Liked: 44
Yes, MH/H is there...I will start testing in August to see if MH/H improves with the 30% V-Pole...
Theo1080 is offline
post #3554 of 10942 Old 07-13-2011, 09:08 PM
evan237's Avatar
Quoted: 20 Post(s)
Has anyone had any problems with WSOC tonight (Wed night) after 1130pm? This station was acting very eractic on me. The signal meter was first in the high 90s, then it dropped as low at 38% when the picture dropped out completely. Then back again between the 50's, 60's, 80% and back down again to 40%. All of this in the space of a few minutes apart.
With my long range antenna and amplier, I normally get a good (consistent signal) on RF34 WSOC during the day and night. However, tonight was very much the exception.
Note: I don't expect a consistent signal on RF50 for WAXN. But, again, this is was not expected on main WSOC since it operates at higher power and there seems to be no bad weather in the area.
evan237 is offline
post #3555 of 10942 Old 07-14-2011, 12:03 AM
tylerSC's Avatar
Quoted: 798 Post(s)
Liked: 180
Had some drop out issues with WSOC and WCCB last night but I believe it was due to weather conditions and storms in Clt area. And I am just beyond their coverage area, but I often do see WSOC overnight. WAXN is also appearing now, but not as strong as WSOC. But I seldom saw it before the antenna/power upgrade, so that does seem to be an improvement.
tylerSC is offline
post #3556 of 10942 Old 07-14-2011, 05:29 AM
A J
A J's Avatar
Quoted: 130 Post(s)
Liked: 41
AntennaTV's website has updated their map to include WJZY, with a pop-up note saying, "early August".
AJ
A J is offline
post #3557 of 10942 Old 07-14-2011, 09:51 AM
rls976's Avatar
Regarding WCCB (ch 27): Down here in North Charleston I received it at up to 24 dB (signal-to-noise ratio) last night. This summer I have been receiving WCCB at least seven nights per month, once at more than 28 dB. I got WBTV (ch 23) last night also, 19 to 20dB. It is not possible to get WSOC (ch 34), WJZY (ch 47) or WAXN (ch 50) here because there are stations in Charleston on those channels. WCNC (ch 22) never comes in here either, at least partially due to WJCL (ch 22) in Savannah, which I can see most nights.
rls976 is offline
post #3558 of 10942 Old 07-14-2011, 08:27 PM
evan237's Avatar
Quoted: 20 Post(s)
That's impressive, especially with your ability to get WCCB up to 24 db and seven nights per month.
evan237 is offline
post #3559 of 10942 Old 07-14-2011, 08:38 PM
evan237's Avatar
Quoted: 20 Post(s)
I guess there must've been some bad storms in the CLT area last night b/c my coverage was no where near what I am used to. I've been gone all day and evening. Right now, main WSOC on RF34 is up to 97% on the signal meter.
The only weird thing now is WAXN. As we know, RF50 does not put out a lot of signal to the east and north.....particuarly now with the directional antenna to the west and south. However, I am getting 'some' signal on that while nothing at all from RF36 CH 64-7 out of China Grove.
Does anyone know if there's a problem with WAXN out of China Grove? I always get this signal, except for the last two days evenings in a row. I haven't been home during the day to check it but I assume it's been out the whole time (at least for me up here).
evan237 is offline
post #3560 of 10942 Old 07-15-2011, 11:57 AM
rls976's Avatar
I am using a Winegard 7698 antenna, 42 ft above sea level (30 ft above the ground). The UHF section of it is enhanced: I extended the end of the boom and added five UHF director elements from the 8084 antenna I was replacing. And it is grounded: It helps that the junk signals received by the coaxial shielding are dumped to earth ground, rather than being allowed to bleed through to the center conductor and reduce my signal-to-noise ratio. Nevertheless, I doubt that I will get quite such stellar reception results once summer atmospheric conditions have ended.
rls976 is offline
post #3561 of 10942 Old 07-15-2011, 04:50 PM
Bordershy's Avatar
Thank you....
64.5 @ 10 bars & 64.1 is 2-10 bars,very inconsistent. This is in Northern Spartanburg county.
Bordershy is offline
post #3562 of 10942 Old 07-15-2011, 05:03 PM
Bordershy's Avatar
Mad respect for your DX skills regarding WCCB. I'm 76ml away & daytime is a bit iffy but night time is solid. You must be 175ml away! Love to see a pix of your setup. Are you using a military grade preamp?
post #3563 of 10942 Old 07-16-2011, 12:30 PM
evan237's Avatar
Quoted: 20 Post(s)
Ted,
Can you provide any updates on RF36 WAXN out of China Grove? I have not seen the signal off this translator in several days. Is there an outage? Thank you for any feedback.
evan237 is offline
post #3564 of 10942 Old 07-18-2011, 01:55 PM
rls976's Avatar
To Bordershy:
Channel Master 7778 pre-amplifier, fed into RG6 Quad-Shield cable. I provide the antenna setup and God provides the atmospheric conditions. Last night I watched the 11pm news on WBTV, then a few minutes of a program about Lake Mead on WCNC's subchannel. Distance to WBTV's 2,000-ft tall tower: 181 miles.
What is amazing is that, with the antenna aimed at Gaston County, the tuner of my Sony TV was detecting something on channel 11, though the signal was not strong enough to view. I verified that WTOC-11 in Savannah was not coming in strongly enough to be what I was getting. Surely it could not have been WTVI!
rls976 is offline
post #3565 of 10942 Old 07-18-2011, 02:57 PM
Theo1080's Avatar
Quoted: 99 Post(s)
Liked: 44
WAXNTV1, China Grove is operating at full power.
Theo1080 is offline
post #3566 of 10942 Old 07-18-2011, 05:18 PM
evan237's Avatar
Quoted: 20 Post(s)
This is a strange situation. When I pull up my signal strength meter, I am (currently) getting about 87% on RF36 WAXN from China Grove. However, I get no picture at all on RF36. The screen is completely black with some brief flashes of light (not pixelations--just occasional flashes of light on a black screen). It has now been this way for about 5 days while no other channels have been affected.
As the crow flies, my house is 38 miles from this translator in China Grove. I have always gotten a picture on RF36 (day and night) from the time my antennas were installed a half a year ago. I did a re-scan of my channels but it didn't make any difference. Also, both of my TVs (on separate antennas) are behaving in this same manner concerning RF36. Let me know if you have any thoughts on this. Appreciate it.
evan237 is offline
post #3567 of 10942 Old 07-18-2011, 10:05 PM
Country_Boy's Avatar
That was strange. Last night, I picked up WAXN on channel 64.1 perfectly.
Today: Nothing.
What is the wattage for this station now?
I still can't pick up WMYT. I get it a few minutes a month. I suppose a bird flies into the signal path on occasion and bounces it my way.
What watts is WMYT tossing out there?
Country_Boy is offline
post #3568 of 10942 Old 07-18-2011, 10:39 PM
Trip in VA's Avatar
Quoted: 800 Post(s)
Liked: 239
Send a message via AIM to Trip in VA
150 kW, but directional. Toward Hickory, looks to be roughly 110 kW, give or take.
225 kW, omni directional.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
post #3569 of 10942 Old 07-19-2011, 05:54 AM
Theo1080's Avatar
Quoted: 99 Post(s)
Liked: 44
WAXN now has a directional pattern, with the main lobe at 215 degrees True of the tower site. The null is back toward WFMY-TV tower site in Greensboro, as we must now protect Channel 51. The 41 dbu line is pushed out about 5 miles to the SW and pulled in about the same to the NE. That is why WAXNTV1, China Grove was granted, to fill in the null. All work in completed. With the exception of a tower inspection on Wednesday by KPFF, which will reduce power for an hour or two...All power levels are at 100%.
Theo1080 is offline
post #3570 of 10942 Old 07-19-2011, 05:59 AM
Theo1080's Avatar
Quoted: 99 Post(s)
Liked: 44
I will drive up to China Grove today and check on it. The remote control says 100% power, but we can not pick it up because of WYFF.
Theo1080 is offline
