Charlotte, NC - OTA - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 233Likes
post #631 of 10985 Old 10-17-2005, 05:03 AM
CPanther95's Avatar
Quoted: 72 Post(s)
Liked: 94
Threads merged.
Tipper, see the post just before yours.
CPanther95 is offline
post #632 of 10985 Old 10-17-2005, 07:32 PM
CPanther95's Avatar
Quoted: 72 Post(s)
Liked: 94
Looks like WSOC is getting a little better at the hard switch to SD at the end of primetime. They used to switch with about 5 minutes left every night, now it is normally about 2-3 seconds before the end of the show. Not sure how they made the improvement, yet still jump the gun by just a few seconds
Only exception to this "improvement" was Sunday (IIRC) where they switched to SD with about 10 minutes left in the show.
post #633 of 10985 Old 10-24-2005, 04:26 PM
sharpe's Avatar
Is anyone having a problem with Channel 9? I lost it last night but have all the other stations. I'm located in Cornelius and use a 4 bay antenna in the attic.
sharpe is offline
post #634 of 10985 Old 10-25-2005, 10:19 AM
CPanther95's Avatar
Quoted: 72 Post(s)
Liked: 94
Been strong for me.
post #635 of 10985 Old 10-25-2005, 11:15 AM
jerry birdwell's Avatar
The four-bay you describe probably is a UHF only antenna, and Channel 9 is VHF. Usually the 4 bay UHF does a fair job picking up VHF, but you may need to couple it with a small VHF antenna to ensure stability for Ch 9.
JB - Asheville
jerry birdwell is offline
post #636 of 10985 Old 10-25-2005, 04:08 PM - Thread Starter
sengsational's Avatar
I think he's talking about UHF 34 which is "Channel 9" in name only. The only VHF digital we have in Charlotte is VHF 11 (aka "Channel 42").
--Dale--
sengsational is offline
post #637 of 10985 Old 10-25-2005, 04:31 PM
sharpe's Avatar
Sorry about the confusion. 34 dropped to 20% on the HD-TiVo Sunday night and into Monday, but it seems to be back now. Go figure.
sharpe is offline
post #638 of 10985 Old 10-29-2005, 10:33 PM
jtbell's Avatar
I'm curious... why did WSOC decide to keep their digital signal on channel 34 and give up ch 9 after the analog shutdown, instead of moving the digital signal to ch 9 and giving up ch 34? I've read often that the high-VHF channels (7-13) are generally considered "prime territory" because they propagate better than UHF channels, with less power, and are less affected than the low-VHF channels by impulse noise.
jtbell is offline
post #639 of 10985 Old 11-01-2005, 07:02 PM - Thread Starter
I thought that the FCC was going to hand the VHF spectrum to cell phone companies.
post #640 of 10985 Old 11-01-2005, 09:08 PM
jtbell's Avatar
Nope, it's the highest UHF channels (52-69) that are going to be auctioned off. All the channels in the range 7-13 will be used for DTV by stations within range of my antenna after the analog shutoff:
7 - WSPA (Greenville CBS)
8 - WOLO (Columbia ABC)
9 - WNTV (Greenville ETV)
10 - WIS (Columbia NBC)
11 - WTVI (Charlotte ETV) (OK, I probably won't be able to get this one, except when a blue moon is up )
12 - WRDW (Augusta CBS)
13 - WLOS (Asheville ABC)
Of these, 8 and 9 are currently in use for DTV. WOLO comes in very nicely at 67 miles, even with a wall of trees behind my house in the line of sight. WNTV is mediocre, but that's probably because it doesn't have much power and I'm getting interference from WSOC's analog signal.
jtbell is offline
post #641 of 10985 Old 11-02-2005, 06:01 AM
beakerlene's Avatar
I just moved to Mooresville, NC, just north of Charlotte, zip 28117. So far I have been able to get most DTV channels, NBC, CBS, ABC and usually FOX. UPN and WB come in most of the time too. I'm using a basic powered rabbit ears antenna which provides a signal usually around 70% for the strong channels. On channels like Fox 1018, I will occasionally get "skips" in the programming due to the signal dropping out. I'm planning to upgrade my antenna to a medium directional attic mount antenna. I would appreciate any suggestions or references for an appropriate antenna. Being in Mooresville, I'm about 20-25 miles away from most broadcasts. The directions vary between 164 degs for ABC (9.1) and 236 degs for NBC (36.1). So I need something that will cover about 72 degs from 20-25 miles away.
beakerlene is offline
post #642 of 10985 Old 11-02-2005, 06:24 AM
CPanther95's Avatar
Quoted: 72 Post(s)
Liked: 94
beaker:
First thing I'd do is get a Radio Shack double-bowtie set top antenna for about $15. It will blow away just about any "amplified" rabbit ear type (w/ UHF disc) antenna - no matter how many times the manufacturer stamps "HDTV" on the box. IIRC, I have about an 80 degree spread and 19-23 miles to both towers and I picked up all signals strong without having to rotate the RS-DB antenna.
Attic antennas are tricky and your particular home and location will introduce fairly unique variables - a lot of it is trial and error. I put a CM4228 in my Dad's attic in Fort Mill and it works for the Charlotte stations, but margin of error is 1 or 2 degrees. If a mouse farts up in the attic, I have to readjust the positioning because he'll lose one tower or the other.(once or twice a year). About a mile away, I put a CM4221 outside on a mast, and I get Columbia and Greenville stations also - so an attic is a huge hindrance.
post #643 of 10985 Old 11-02-2005, 07:13 AM
beakerlene's Avatar
CPanther95,
Thanks for your quick response. The RadioShack in Cornelius has the item in stock. Will the signal be strong enough without being powered, or do I need to use an amp/preamp. I do have my HD tuner connected to an amplified splitter. My second concern is that I use my current antenna for VHF and FM also. If I use the double bowtie antenna for my UHF signal could I "combine" (not the technical word) that signal with the VHF and FM signals from my current antenna. If so, would the UHF signal from my current antenna interfere with the bowtie antenna?
post #644 of 10985 Old 11-02-2005, 07:53 AM
bdfox18doe's Avatar
Quoted: 242 Post(s)
Liked: 141
Originally Posted by CPanther95 View Post
If a mouse farts up in the attic, .
I'd hat eto be up there when that happens!!
Bob
The views expressed here are my own and do not necessarily represent those of ABC, CBS, CW, FOX, MeTv, or AntennaTv; my employer; or its parent company.
Nor my wife for that matter!
bdfox18doe is offline
post #645 of 10985 Old 11-02-2005, 07:57 AM
CPanther95's Avatar
Quoted: 72 Post(s)
Liked: 94
No amp or pre-amp. I worked my way all the way up the RS line of indoor antennas and none performed better (in fact, not nearly as good) than the $5 antenna I had laying around in my attic. They actually discontinued it a few years ago, but a "black" market of sorts sprung up on eBay and these cheap antennas were going from $10 to $25 each. They reluctantly started offering them again and bumped the price to $15 since it was now an "HDTV" antenna.
Not sure how you are using the VHF antenna, is it for PBS digital, or just for analog stations? If you're most concerned with the primary 6 HD networks in Charlotte, there'd be no reason to combine the antennas, all are on UHF frequencies. Run the UHF antenna to your HD tuner, and run the VHF antenna to an analog input and the FM input of your receiver.
If you explain the need for VHF better, it might make it more clear.
post #646 of 10985 Old 11-02-2005, 08:22 AM
beakerlene's Avatar
The VHF signal is primarily for the analog stations that either don't have a digital station, or where I don't receive a sufficient signal for the digital station. Hopefully the second issue will no longer be a problem with the new antenna. If all the local Charlotte channels broadcast in digital too, I suppose I technically won't need VHF. If I want the digital PBS do I need a VHF signal? I could take your suggestion and run the FM and analog tuners to a separate antenna. I had hoped to have everything (UHF, VHF, FM) coming from one (or multiple) source on one cable in the attic so I didn't have to have any antennas visible near the TV or receiver. I do have a few workarounds, including your suggestion if this is not possible. Thanks again!
post #647 of 10985 Old 11-02-2005, 10:51 AM
CPanther95's Avatar
Quoted: 72 Post(s)
Liked: 94
If you go with a set top antenna for UHF, you will still have only one cable coming into your system. It's worth a try for $15.
post #648 of 10985 Old 11-02-2005, 05:24 PM - Thread Starter
Just put that idea right out of your mind because it won't work like you expect; 1+1 usually equals about .5 in this arena. If you have other devices that need other signals, just give them their own antenna and be done with it.
--Dale--
post #649 of 10985 Old 11-02-2005, 07:12 PM
bdfox18doe's Avatar
Quoted: 242 Post(s)
Liked: 141
Originally Posted by sengsational View Post
Just put that idea right out of your mind because it won't work like you expect; --Dale--
Dale's correct..however, if you use exactly the same length cables for the two antennas, it "MIGHT" work, you'd just have to try it.. sometimes, it will, a lot of times, it won't...
I'm not exactly a PBS fan..don't get me started about having 3 PBS dinosaurs..er, stations..here in our area.... so I could care less about WTVI since it is on a great VHF channel but woefully underpowered....However, WUNG gives me all I need for PBS..and they're easily received! (great job, Wayne !!)
Bob
post #650 of 10985 Old 11-03-2005, 10:03 AM
beakerlene's Avatar
I purchased a UHF double-bowtie antenna yesterday from Radio Shack and hooked it up. The new antenna was intended to replace my existing amplified UHF/VHF rabbit ears, RCA ANT200B with UHF loop. The change was negligible and probably had more to do with orientation than the antenna. Some channels got slightly better, others slightly worse. I can't pick up either PBS stations with either antenna. I am able to pick up ABC, CBS, FOX and NCB with both antennas 90% of the time. The rationale for seeking a new antenna is to prevent occasional skips in the broadcasts from signal drop outs. It appears I'm just as well off with my old UHF loop. I would appreciate any comments or suggestions to help increase my signal strength. Right now I can't receive WB or PBS, which doesn't make sense to me if they have the same range and orientation of neighboring stations. Maybe it's the broadcast strength. Thanks!
WSOC-DT 9.1 ABC 165 24.1 34 71-79% 68-73%
WUNG-DT 58.1 PBS 142 22.1 44 21-58% 0-21%
WJZY-DT 46.1 UPN 231 21.1 47 28-67% 56-61%
..WB-DT 55.1 WB 231 21.7 39 21-30% 0%
WCNC-DT 36.1 NBC 231 23.1 22 74-84% 71-75%
WBTV-DT 3.1 CBS 235 22.9 23 65-75% 72-78%
WCCB-DT 18.1 FOX 166 23.6 27 62-71% 71-74%
WAXN-DT 64.1 IND 165 24.1 50 18-26% 0%
WTVI-DT 42.1 PBS 159 23.2 11 0% 0%
post #651 of 10985 Old 11-03-2005, 04:58 PM - Thread Starter
You can go to the fcc site http://www.fcc.gov/fcc-bin/audio/tvq.html and look at the power they are licensed for (may not be using it all). Bob, didn't you say that you had good experience with a Square Shooter with a wide spread between towers?
--Dale--
post #652 of 10985 Old 11-03-2005, 05:02 PM
bdfox18doe's Avatar
Quoted: 242 Post(s)
Liked: 141
Bob, didn't you say that you had good experience with a Square Shooter with a wide spread between towers?--Dale--
Yes, I get all local stations perfectly with the square shooter.. I'm on the Matthews end of Mint Hill..
Just got a Sony DHG-HDD250.. A very nice HD-DVR!
Bob
post #653 of 10985 Old 11-04-2005, 06:28 AM
beakerlene's Avatar
Thanks for the tips. I just did a couple quick google searches on the Winegard SS-1000 SquareShooter. It looks very promising. Are there any local retailers that provide it, or do I have to purchase it online? I'd like to be able to try it out and return it if it doesn't do the trick. Thanks!
post #654 of 10985 Old 11-04-2005, 08:00 AM
WallyBR's Avatar
Hey beaker, I'm in Cornelius so I'm in a similar situation to you. The first antennaes I tried were the Channelmaster Stealthtenna and then the CM 3016 that I bought at the local Lowe's. I installed them in my attic and tried to shoot the difference between the 2 tower clusters - they are 90 degrees apart for me. The 3016 got good reception, but it was too directional - it couldn't pick up both clusters at once.
I pondered the SquareShooter, but didn't want to drop a hundred bucks. Like you say, it's not available locally. I ended up getting the antennasdirect DB-4. It does a good job for me. The CM 4228 that is popular here is a similar design.
Hope this input is helpful.
WallyBR is offline
post #655 of 10985 Old 11-04-2005, 08:21 AM
CPanther95's Avatar
Quoted: 72 Post(s)
Liked: 94
The CM4221 is a closer match to the DB-4 (4-Bay). I went with it because it is less directional than the big 8-Bay 4228. In fact, when I point almost due south for Columbia stations, the rear of the 4221 is efficient enough to pick up both Charlotte towers. I can rotate the 4221 at least 20 or 30 degrees either way and still pick up both towers when pointing in between the Charlotte towers.
I went with the 4228 for my Dad because it is an attic installation, stronger but more directional (at least that's the reports from AVS'ers) - it must be positioned exactly to get both towers - never tried the 4221 in an attic or the 4228 outside, so TIFWIW.
post #656 of 10985 Old 11-04-2005, 08:33 AM
beakerlene's Avatar
Hey Wally, thanks for your response. That was helpful. I actually tried a the Stealthenna too before I joined this forum and was dispointed with the results. Both your suggestions look promising. I'm assuming neither of those are available locally either? I found the SquareShooter online for $79. I'm wondering if it's worth the extra money. The DB-4 is marketed as the strongest multi-directional antenna which is apealing to me since I have broadcast location with about 80 deg separation. I'm wondering how directional the Square Shooter is?
post #657 of 10985 Old 11-07-2005, 05:41 AM
beakerlene's Avatar
Again, thanks for all the responses. I've been looking to purchase one of the medium UHF antenna (e.g., DB-4, CM4221) and the various online retailers recommend purchasing a preamp with the antenna. Do I need a preamp with the antenna and if so, can anyone recommend a good one? For example, Antenna's Direct matches up the "PA16 Low noise UHF Pre-amp" with the DB-4.
post #658 of 10985 Old 11-07-2005, 08:14 AM
WallyBR's Avatar
beaker,
I am not using a preamp. From some reading I did here and elsewhere, it didn't sound like it would do me any good. I can't recall the reasoning though.
I don't know what kind of return poicy antennasdirect has, but I'd recommend the company highly. When my antenna came in, the box was damaged and the antenna was bent in the corner. I called to let them know and they apologized and immediately FedEx'd a replacement. Since the antenna bay was aluminum, I just bent it back into shape and still use the original bent one to this day. I sold the replacement on audiogon - if I still had it I'd offer it to you!
Good luck.
WallyBR is offline
post #659 of 10985 Old 11-07-2005, 08:44 AM
CPanther95's Avatar
Quoted: 72 Post(s)
Liked: 94
I use a CM7775 (UHF only) pre-amp ... would have got the CM7777 if I knew I'd be picking up Columbia stations.
post #660 of 10985 Old 11-15-2005, 01:39 PM
jeff1257's Avatar
Go with the 4221 and save the money. The screen on the back allows it to have more forward gain than the DB-4. I would try without the preamp first. If you need one, I would look at the Wiengard AP-4700. The 19db is better suited for this area. I still have to cut 6dbs out of mine. Anything stronger can cause problems. I have a 4228 roof mounted off of Sardis Rd. Everything is 90 and over with my Dish 942. Great reciever. Also get WSPA-Spartanburg, WFMY-Greensboro and the best PBS-WNSC-Rock Hill. They have HD programming 24 hours a day. Unlike 42 and 58 that dont even come on till 7:00 and 8:00 at night.
jeff1257 is offline
