Charlotte, NC - OTA - Page 272 - AVS Forum | Home Theater Discussions And Reviews
 160Likes
Old 07-16-2014, 11:28 AM
Theo1080's Avatar
Quoted: 58 Post(s)
Liked: 34
Washington Redskins Football (Pre-Season) on WSOC-TV. COMCAST will deliver the feed in 16x9, HD to non-affiliated COMCAST stations this year. WSOC-TV will only cross-convert from 1080i to 720p, other than that it will be broadcast just as it is delivered to us.
bdfox18doe, cpalmer2k and ejb1980 like this.
Ted Hand, CPBE. 8VSB, DRB, AMD
I was there on July 23, 1996...First DTV broadcast in the US..WRAL-HD
Amateur Radio - W9SOC
Theo1080 is offline
Old 07-16-2014, 11:32 AM
Theo1080's Avatar
Quoted: 58 Post(s)
Liked: 34
WSOC-FM has an ERP of 100Kw, which is standard for a Class C - FM. It is not located on WSOC-TV tower. It is located on the former 36 tower on Hood Road.
bdfox18doe likes this.
Theo1080 is offline
Old 07-16-2014, 04:55 PM
bdfox18doe's Avatar
Quoted: 193 Post(s)
Liked: 102
Originally Posted by ybsane View Post
you can't compare signal transmission with a delta of 500mhz. FM is right above VHF Ch.6 and you understand the difference alone in the antenna differences of VHF Low to UHF, so in short you should have your answer.
Just shows how some here really know very little about some of the often off-topic subjects they continually comment on..things like transmit antenna patterns and power, signal propagation and curvature of the earth, etc, and The the fact that same tower being used has very little bearing on reception. Spending some time on Rabbitears would be a better usage of internet time for some. A lot can be learned from Trip's excellent trove of data.I use it constantly. Bravo Trip!
A J likes this.
Bob
The views expressed here are my own and do not necessarily represent those of ABC, CBS, CW, FOX, MeTv, or AntennaTv; my employer; or its parent company.
Nor my wife for that matter!
bdfox18doe is offline
Old 07-16-2014, 06:21 PM
tylerSC's Avatar
Quoted: 568 Post(s)
Liked: 137
As I said, I know UHF and FM are different. My point was simply that for some reason, I get surprisingly good reception of 103.7, in addition to the Gaston County radio signals which are more expected at my location.
tylerSC is offline
Old 07-16-2014, 07:16 PM
ejb1980's Avatar
Quoted: 62 Post(s)
Liked: 26
Excellent information. Thank you.
ejb1980 is offline
Old 07-17-2014, 07:50 AM
tesla_engineer's Avatar
Quoted: 27 Post(s)
Should stay off the TV site with FM info to start with. This site would do much better if it could stay on topic.
bdfox18doe and A J like this.
Tom
tesla_engineer is offline
Old 07-17-2014, 08:34 AM
Trip in VA's Avatar
Quoted: 387 Post(s)
Liked: 116
Send a message via AIM to Trip in VA Send a message via Yahoo to Trip in VA
Normally I'd magically appear sooner, but I've spent the last several days moving into the house I just bought. And reception is great!
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
Old 07-17-2014, 08:44 AM
Theo1080's Avatar
Quoted: 58 Post(s)
Liked: 34
Starting August 18th, WAXN 64.3 will start airing ESCAPE TV. It will be 16x9, 480i. Programing is targeted for woman 25-54. Its companion channel, GRIT TV is targeted for men 25-54 will air on another channel in Charlotte. I will let that station announce it. I can answer questions about ESCAPE TV if you have any. (edited 12:50pm...changed 4x3 to 16x9...feed from Escape TV is 1080i, WAXN will air at 480i)
A J likes this.
Theo1080 is offline
Old 07-17-2014, 09:44 AM
csmith's Avatar
Quoted: 39 Post(s)
Liked: 27
Starting August 18th, WAXN 64.3 will start airing ESCAPE TV. It will be 4x3, 480i. Programing is targeted for woman 25-54. Its companion channel, GRIT TV is targeted for men 25-54 will air on another channel in Charlotte. I will let that station announce it. I can answer questions about ESCAPE TV if you have any.
Found their websites:
http://www.escapetv.com/
http://www.grittv.com/
csmith is offline
Old 07-17-2014, 01:55 PM
tylerSC's Avatar
Quoted: 568 Post(s)
Liked: 137
Yes I have often researched his Rabbitears site as well as the FCC database. Very informative.
tylerSC is offline
Old 07-17-2014, 02:09 PM
A J
A J's Avatar
Quoted: 87 Post(s)
Liked: 27
Grit TV will be added on WBTV (I assume 3.3) sometime in August.
A J is offline
Old 07-17-2014, 02:15 PM
tylerSC's Avatar
Quoted: 568 Post(s)
Liked: 137
I hope they continue to do a good job preserving the video quality on the HD channel when they add these subchannels. I guess it is a bit of a balancing act, but supposedly now they have more advanced methods. But right now 64.1 and 64.2 look good when I see them. And the other station currently does a good job also, and I guess they will soon officially announce about the Grit TV. But a little research and you can find out what it is.
tylerSC is offline
Old 07-17-2014, 02:17 PM
tylerSC's Avatar
Quoted: 568 Post(s)
Liked: 137
That's what I learned as well. And hopefully they will continue to do a good job with the video quality on all the channels.
tylerSC is offline
Old 07-17-2014, 02:43 PM
SpencerKarter85's Avatar
Quoted: 102 Post(s)
Well WBTV 3 turned 65 years old this week! The first TV station in Charlotte, NC!
Spencer Karter
OTA Equipment: ChannelMaster 25' telescopic mast, 5' extra antenna mast, antenna rotor, AntennaCraft C490.
SpencerKarter85 is offline
Old 07-17-2014, 03:30 PM
blackcat6's Avatar
Quoted: 309 Post(s)
Liked: 68
I might be wrong, but I believe it was the first station in the Carolinas.
I remember my grandmother talking about getting a TV in 1949 or so and channel 3 was the only thing that could be picked up.
blackcat6 is offline
Old 07-17-2014, 04:22 PM
blackcat6's Avatar
Quoted: 309 Post(s)
Liked: 68
Interesting. I believe the official reason stated for WBTV getting rid of THIS (which I think was moved to 3.3 when Bounce was added) , was they needed the bandwidth for something else. i.e. The nonsense of broadcast TV on mobile phones or something like that.
I guess that didn't work out for them.
Old 07-17-2014, 06:05 PM
tylerSC's Avatar
Quoted: 568 Post(s)
Liked: 137
Yes WBTV was the first TV station in the Carolinas beginning in 1949. And one of the longest original CBS affiliates.
tylerSC is offline
Old 07-17-2014, 10:00 PM
ejb1980's Avatar
Quoted: 62 Post(s)
Liked: 26
Out of curiosity, what is the significance of the call letters of WBTV?
ejb1980 is offline
Old 07-18-2014, 12:24 AM
Quoted: 27 Post(s)
None at the start (Radio) WBT randomly assigned by Commerce Department when it moved to a licensed station from a experimental station. The "V" was added to the 3 letter call sign for TV. A Buick dealer that owned WBT in the 20's prior to CBS buying it in 1929 claimed WBT was Watch Buick Travel. Sorry about the radio reference, but you asked. At one time WBTV had this information on there web site. After the split of radio and TV I don't know if they still do.
eacalhoun likes this.
Tom
Old 07-18-2014, 02:19 AM
blackcat6's Avatar
Quoted: 309 Post(s)
Liked: 68
I was looking at archive.org's backup of WBTV and was surprised that in 1997, WBTV had the same anchor, chief weatherman, and sports director that it has today. (Cameron, Thomas, Little) I'd say that makes them the longest running news team in CLT. I'm not sure about the other two, but I'm pretty sure that Thomas was there in '94.
Edit: Cameron has been there since 1981! (how time flies)
In any case, if you want to read up on the history of WBTV, I suggest this from when the station was 50 years old. Funny that a lot of people at WBT didn't want to transfer to WBTV.
https://web.archive.org/web/20000815...om/wbtv-50.htm
ejb1980 likes this.
Old 07-18-2014, 03:52 AM
blackcat6's Avatar
Quoted: 309 Post(s)
Liked: 68
Speaking of that station. It's interesting that on their morning news, that WBTV hawks Bounce for a moment and they list all the ways you can get it, cable & web, but they neglect to say that it's available on broadcast 3.2 via an antenna.
Old 07-18-2014, 06:25 AM
A J
A J's Avatar
Quoted: 87 Post(s)
Liked: 27
Grit TV will be added on WBTV.
PBS transmits excellent HD on 58.1 plus two SD sub-channels with very good PQ. Why shouldn't WBTV be able to do the same thing? However, if two SD sub-channels would noticeably degrade CBS's HD primetime signal, then I'd give the second SD a big thumbs down.
A J is offline
Old 07-18-2014, 06:52 AM
blackcat6's Avatar
Quoted: 309 Post(s)
Liked: 68
WWAY in Wilmington transmits two HD channels and Retro TV and they all look good.
Old 07-18-2014, 01:02 PM
difuse's Avatar
Quoted: 67 Post(s)
WBTV was the 1st TV station in the Carolinas, beating out WFMY by a few weeks. However, for two years WBTV had only film and slide capability, and no network line connection. For what it is worth, WFMY had the first live local.and network programs.. For several years following, WBTV did surpass most stations in the country technically, being early employers of mobile remote and color transmission.
difuse is offline
Old 07-19-2014, 12:56 AM
Quoted: 102 Post(s)
Paul Cameron is a veteran in Charlotte broadcasting. Been there the same time when the late Mike Manhatton (who recently died from colon cancer last March) joined Savannah's WTOC (now WBTV's sister station) until Manhatton's colon cancer death earlier this year.
The late Mike Manhatton was WTOC's answer to Paul Cameron of WBTV.
Spencer Karter
Old 07-19-2014, 03:57 AM
blackcat6's Avatar
Quoted: 309 Post(s)
Liked: 68
.... Mike Manhatton (who recently died from colon cancer last March) joined Savannah's WTOC (now WBTV's sister station) until Manhatton's colon cancer death earlier this year. .....
Wow, only 56 when he passed. Poor fellow. It's one of those diseases that once you know you have it, it's already too late to do anything about it. I don't know if this applies to Mr. Manhatton or not, but anyone hitting 50 should get a colonoscopy.
Old 07-20-2014, 09:25 AM
Quoted: 102 Post(s)
I hope MeTV does a tribute to the late James Garner (he passed away yesterday at 86) by airing reruns of The Rockford Files on WCCB 18.3 in Charlotte, NC and WSPA 7.2 in my market of Greenville, SC. He was a great icon, but never be forgotten by fans.
Spencer Karter
Old 07-20-2014, 11:41 AM
rdgcss's Avatar
Quoted: 74 Post(s)
Liked: 32
+1
rdgcss is offline
Old 07-21-2014, 05:45 AM
A J
A J's Avatar
Quoted: 87 Post(s)
Liked: 27
I hope MeTV does a tribute to the late James Garner by airing reruns of The Rockford Files on WCCB 18.3 in Charlotte
WCCB 18.3 has already been showing episodes of Rockford, M-F from noon to 1:00PM, although I prefer to watch it uninterrupted on Netflix..
The James Garner series I'd like to see again is Maverick. Haven't seen that in years.
A J is offline
Old 07-21-2014, 05:55 AM
Trip in VA's Avatar
Quoted: 387 Post(s)
Liked: 116
My fiancee and I watched The Great Escape on DVD last night (it's my favorite movie and she'd never seen it). I also loved him in My Fellow Americans.
- Trip
N4MJC
RabbitEars
taboola here
