Charlotte, NC - OTA - Page 285 - AVS Forum
 43Likes
post #8521 of 8547 Old 08-18-2014, 06:35 AM
blackcat6's Avatar
Quoted: 69 Post(s)
Liked: 42
Originally Posted by OTA-DVR-guy View Post
It's worth noting that a lot of regulations are put through without legislation, which takes congress out of the loop, and that would certainly include the FCC.
Congress took itself out of the loop. It delegated power to the FCC to control airwaves. Congress could vote tomorrow, if it wished, to abolish the FCC and take over direct control. Of course it won't because there is no need, or push, for it to do so.
blackcat6 is offline
post #8522 of 8547 Old 08-18-2014, 06:36 AM
OTA-DVR-guy's Avatar
Quoted: 36 Post(s)
Originally Posted by bdfox18doe View Post
I have the same HDHomerun Dual at home. Aside from the wall warts going bad, which they have been replacing free, a darn fine tuner. You should get free TSReader to use with it.
We have now switched microwave receivers & exciters at the transmitter. It seems to be better now.
A part of having everything redundant is finding which A or B item is bad.. Redundant encode chains..microwave transmitters and receivers, and exciters..and could be a combination of this A with that B. A broke is easy to fix, a bent not so much...
Hey Bob, I got a message from you that I was unfortunately unable to open. The captions are good now. But unfortunately the pixelating and freezing that others have spoken of, was still happening this morning quite a bit.
OTA-DVR-guy is offline
post #8523 of 8547 Old 08-18-2014, 06:45 AM
ejb1980's Avatar
Quoted: 28 Post(s)
Liked: 25
Originally Posted by A J View Post
I re-scanned my TV this morning and came across something I've never seen before. Two stations had the same virtual channel number (25.1) and the TV was able to handle that OK. I know that the real frequencies are different but wonder what kept my TVs tuner from getting confused.
My tuner sorted things out this way:
25.1 WOLO ABC, Columbia
25.1 WDMC Charlotte's low power bible thumper channel
25.2 WOLO (appears to be a duplicate of the primary 25.1 HD signal)
25.3 WOLO Weather
25.4 WOLO MeTV
I get this with WGSR and WRPX, although it's rare that WRPX comes in. It's pretty cool.
ejb1980 is offline
post #8524 of 8547 Old 08-18-2014, 08:33 AM
Theo1080's Avatar
I placed the ESCAPE Promo reel on at 11:30am Programming starts at 12 Noon. Program guide will start at 12 noon also.
Ted Hand, CPBE. 8VSB, DRB, AMD
I was there on July 23, 1996...First DTV broadcast in the US..WRAL-HD
Amateur Radio - W9SOC
Theo1080 is offline
post #8525 of 8547 Old 08-18-2014, 09:05 AM
blackcat6's Avatar
Quoted: 69 Post(s)
Liked: 42
Escape looks good here and I like the correct 16:9 full screen aspect ratio. Looks like a nice addition for CLT.
post #8526 of 8547 Old 08-18-2014, 10:25 AM
mcy919's Avatar
The program guide for Antenna TV has been working fine on 18.2 since launch, but 18.5 from Valdese is still showing "Antenna Tv August 15th!!". I hope that gets fixed soon because 18.5 comes in much better here.
mcy919 is offline
post #8527 of 8547 Old 08-18-2014, 11:09 AM
bdfox18doe's Avatar
Quoted: 60 Post(s)
Liked: 68
Ok, Should be more better now...
Bob
The views expressed here are my own and do not necessarily represent those of the FOX,ABC,CBS,or CW Networks,MeTv, my employer or its parent company. Nor my wife for that matter!
bdfox18doe is offline
post #8528 of 8547 Old 08-18-2014, 11:11 AM
mcy919's Avatar
It's working. Thank you!
mcy919 is offline
post #8529 of 8547 Old 08-18-2014, 01:00 PM
difuse's Avatar
64-3, and 64-11 both fine. Good job.
difuse is offline
post #8530 of 8547 Old 08-18-2014, 01:18 PM
A J
A J's Avatar
Quoted: 14 Post(s)
I was glad to see 64.3 Escape in 16:9 aspect ratio. However, Escape apparently has some widescreen movies in their library were were cropped to 4:3. The movie "Final Analysis" was originally 1.85:1 in theaters, perfect to display as-is on a 16:9 TV. Instead, what Escape aired was cropped (a.k.a. butchered) pan-and-scan 4:3. To make that worse, it was then stretched horizontally back to 16:9. Gad, Richard Gere and Kim Basinger looked short and fat!
Previews of many movies on Escape appear to be in correct 16:9 format, so hopefully "Final Analysis" was just an outlier.
A J is offline
post #8531 of 8547 Old 08-18-2014, 04:22 PM
blackcat6's Avatar
Quoted: 69 Post(s)
Liked: 42
I noticed after I posted, that unlike Movies! the aspect ratio on Escape isn't dynamic. Unfortunate that. Also getTV seems to have changed somewhat too. 16:9 is no longer shrunk down, but you have to manually adjust it back to 16:9 to get full screen.
post #8532 of 8547 Old 08-18-2014, 07:28 PM
veedon's Avatar
Quoted: 107 Post(s)
Liked: 47
AntennaTV released its new fall schedule. For early risers, the one-two combo of "Burns and Allen" at 5:00 a.m. and "Patty Duke" at 6:00 a.m. is going to be a nice accompaniment to the first several cups of morning coffee. Me-TV also released its new schedule today.
veedon is offline
post #8533 of 8547 Old Yesterday, 03:29 AM
blackcat6's Avatar
Quoted: 69 Post(s)
Liked: 42
I guess Patty Duke has moved from THIS to Antenna. Burns and Allen is pretty good, but like most shows on AntennaTV they have been constantly running it since they were on the air. Most of their programming changes are to move the same show to different time slot. Personal preference I guess. If you have seen neither, definitely worth watching.
I have been watching the classic Dr. Who on RetroTV. Some of those episodes have not been seen on broadcast TV since the 1960s, and never on American TV. A lot of the early episodes were lost for a long time as the BBC of the 1960s & 1970s had a bad habit of throwing out old film & video reels and reusing video tape to save money. Over the last 5 years or so, there have been efforts to restore old discovered episodes. This is what Retro is showing now. Retro is also showing One Step Beyond. It's pretty bad kinescoped material but I'm glad they are showing it anyway. Too bad there are only two stations in NC that carry Retro TV.
I'm also looking forward to Chips (yeah it's pretty much trash, but hasn't been on TV in a while), and more so The Man From U.N.C.L.E. It hasn't been re-run on TV, as far as I know, for many many years. Both will be on MeTV.
post #8534 of 8547 Old Yesterday, 05:57 AM
Quoted: 36 Post(s)
I was watching Archie and the Meathead last night on AntennaTV, and found that the captions are whacked out, with all of the same problems previously ascribed to the captions on MeTV. This is apparently a problem that WCCB has, because the captions were always fine when Antenna was on 46.2. But MeTV's captions were bad back then as well.
post #8535 of 8547 Old Yesterday, 06:51 AM
bdfox18doe's Avatar
Quoted: 60 Post(s)
Liked: 68
Like FOX Eng says..looks some shows on the AntTv feed may have bad captions. All the shows I have seen today have been good on my tv, I did see some yesterday that were bad.
Bob
post #8536 of 8547 Old Yesterday, 06:58 AM
A J
A J's Avatar
Quoted: 14 Post(s)
Saw a promo for "Black Sheep Squadron" coming in September, but I can't remember which channel. Glad to be able to see those bent wing Corsairs again, boring holes in the sky and blasting away at AT-6s painted as Zeke-lookalikes.
A J is offline
post #8537 of 8547 Old Yesterday, 07:56 AM
SpencerKarter85's Avatar
Quoted: 44 Post(s)
WOLO 25.1 is RF 8.
Also ThisTV and AntennaTV are owned by the same company as WGN America.
BTW, WBTV's parent company Raycom are in a possible dispute with DirecTV. Fortunately Senators Thune and soon-to-be-retiring Rockefeller introduced a new provision called local choice. http://www.americancable.org or http://www.americantelevisionalliance.org has the info.
Spencer Karter
R.I.P. Robin Williams (1951-2014)
SpencerKarter85 is offline
post #8538 of 8547 Old Yesterday, 10:47 AM
Quoted: 36 Post(s)
Hey Bob, is there any chance that when changes are made at the station to fix the freezing and pixelating issue described by some last week, that captions whack out, and accordingly when the captions are fixed, the pixelating starts again?
post #8539 of 8547 Old Yesterday, 10:48 AM
Quoted: 36 Post(s)
That's MeTV, Sunday night at 6:00 PM starting next month.
post #8540 of 8547 Old Yesterday, 11:32 AM
blackcat6's Avatar
Quoted: 69 Post(s)
Liked: 42
Ahh yeah. That is another show that I liked and haven't seen in a very long time.
MeTV is going to have some good stuff next month.
post #8541 of 8547 Old Yesterday, 12:24 PM
ejb1980's Avatar
Quoted: 28 Post(s)
Liked: 25
Originally Posted by SpencerKarter85 View Post
WOLO 25.1 is RF 8.
I am not seeing the connection between my post and Raycom...
ejb1980 is offline
post #8542 of 8547 Old Yesterday, 12:29 PM
Quoted: 44 Post(s)
I said WOLO is on RF 8 (25.1)
Spencer Karter
post #8543 of 8547 Old Yesterday, 12:33 PM
Quoted: 44 Post(s)
I apologize. Go to http://www.wbtv.com/story/26166833/m...tv-subscribers
Spencer Karter
post #8544 of 8547 Old Yesterday, 04:17 PM
blackcat6's Avatar
Quoted: 69 Post(s)
Liked: 42
More of what we have been talking about.
http://arstechnica.com/business/2014...ctrum-auction/
post #8545 of 8547 Old Yesterday, 04:56 PM
veedon's Avatar
Quoted: 107 Post(s)
Liked: 47
The main difference that I see between AntennaTV and MeTV is that MeTV shows more dramas (cop shows, westerns, some sci fi). AntennaTV is almost entirely comedy, except for the movies that it airs.
veedon is offline
post #8546 of 8547 Old Yesterday, 06:36 PM
tylerSC's Avatar
Quoted: 76 Post(s)
Liked: 89
I think WBTV is running a bit behind schedule with the launch of Grit TV on 3.3. I guess still coming soon.
tylerSC is offline
post #8547 of 8547 Old Yesterday, 08:56 PM
veedon's Avatar
Quoted: 107 Post(s)
Liked: 47
It's not really that anyone is taking Congress "out of the loop". Congress is a legislative body, not an executive agency or an "independent agency" like the FCC (subject to congressional oversight but somewhat more independent than many executive departments) . Congress can pass laws and set out requirements and guidelines, but you can't expect 100 senators and 435 representatives to do the day-to-day work of designing and conducting a spectrum auction.
My goodness, Congress has enough trouble just passing appropriations bills. The last thing we need is for senators and congresscritters to start deciding which frequencies should be allocated to which stations!
veedon is offline
User Tag List
