Charlotte, NC - OTA - Page 318 - AVS | Home Theater Discussions And Reviews
 106Likes
post #9511 of 9540 Old 03-01-2015, 08:08 AM
Liked: 0
Originally Posted by blackcat6 View Post
You don't have direct LOS to WCNC at 16 ft. height and all the stations from that farm are on the low side. i.e. You are picking up a refracted signal.
That explains why I get better recption with cloudy weather. WCNC is coming in fine this morning, I guess the signal is bouncing off the clouds.
I'll take a look at the antenna suggestions you guys have made and see if I can get an outside one up.
davebmck is online now
post #9512 of 9540 Old 03-01-2015, 09:04 AM
tylerSC's Avatar
Quoted: 319 Post(s)
Liked: 115
Originally Posted by 4:3 Toshiba View Post
Just who all broadcasts from the Dallas tower farm?
Does this forum cover weather radio signal reception for weather radios?
I have a fairly new Midland WR-120 weather radio, and I have seen times when I got no alert in spite of warnings scrolling across the TV. I've ruled out incorrect radio settings. My reception signal comes from Spencer Mountain.
WBTV-3, WCNC-36, WJZY-46, and WMYT-55 all broadcast from tall towers in Dallas. Only WBTV has a top mounted stick antenna which is more omnidirectional. The others are side mounted panels which may have nulls in certain areas. Also, several radio signals are broadcast from these towers also, including 107.9, 105.3, 95.1, and 96.1. 105.3 used to be a popular local station in Gaffney, SC before it was "relocated" to Charlotte in a controversial move that still angers SC listeners to this day. And WSOC/WAXN has a translator from Crowder's Mtn. for 9 and 64.
tylerSC is online now
post #9513 of 9540 Old 03-01-2015, 12:47 PM
4:3 Toshiba's Avatar
Quoted: 49 Post(s)
WAGI was hugely popular in this area before the hispanics took it over. Why did the original owners sell the station?
Same thing happened to stations like WKMT. WLTC in Gastonia was a popular station, but it shut down altogether if I'm not mistaken. Most local low-power stations were bought by talk radio. Nothing against that format, but I do miss the local programs.
4:3 Toshiba is offline
post #9514 of 9540 Old 03-01-2015, 02:36 PM
realoldman's Avatar
Quoted: 23 Post(s)
I wish 9, 14, and 18 and 64 were there.
realoldman is offline
post #9515 of 9540 Old 03-01-2015, 03:31 PM
tylerSC's Avatar
Quoted: 319 Post(s)
Liked: 115
9 and 64 have the translator on Crowder's Mtn. but it is much lower power.
post #9516 of 9540 Old 03-01-2015, 03:35 PM
tylerSC's Avatar
Quoted: 319 Post(s)
Liked: 115
I believe the original owner of WAGI passed away and it was sold. The new owners decided it was more lucrative to be a Charlotte station rather than a local Gaffney or Greenville-Spartanburg station. It is now owned by Radio One and is an oldies R&B station.
post #9517 of 9540 Old 03-01-2015, 03:38 PM
tylerSC's Avatar
Quoted: 319 Post(s)
Liked: 115
Look like WBTV has made an adjustment and Grit TV is now full screen. Similar to WLOS. But still not the same as before, but better than the recent change.
post #9518 of 9540 Old 03-01-2015, 07:05 PM
realoldman's Avatar
Quoted: 23 Post(s)
To low power to reach WNC but WBTV-3, WCNC-36, WJZY-46, and WMYT-55 all reach.
Can not get 13 or 40 here and 62 is weak.
post #9519 of 9540 Old 03-02-2015, 03:09 AM
blackcat6's Avatar
Quoted: 216 Post(s)
Liked: 58
It is a lot better. The weird distortion that was on Grit & Escape is now gone from Grit. The only issue now that I see is that Grit is transmitting a lot of 16:9 programs where it's now supposed to be 4:3. So they get shrunk down to fit that format. The 4:3 stuff looks pretty good now.
At least the 16:9 stuff can be fixed by a simple zoom now.
blackcat6 is offline
post #9520 of 9540 Old 03-02-2015, 06:57 AM
A J
A J's Avatar
Quoted: 35 Post(s)
Thanks for the info. Sounds like Grit will be worth watching again. I'll add 3.3 back to the channel lineup on my TV and DVR.
A J is offline
post #9521 of 9540 Old 03-02-2015, 11:01 AM
Quoted: 49 Post(s)
I think the signal is greater towards the west. From the east, I can see the tower (5 miles away) from my porch, but picking up the signal is a hit or a miss depending on atmospheric conditions.
post #9522 of 9540 Old 03-02-2015, 11:43 AM
eacalhoun's Avatar
I am a huge weather junkie and own multiple wx radios - I'm old school and it's more reliable than weather apps. And don't be offended by my helps here - in other words I don't want to come across as a smarty. I just want to make sure all the bases are covered. Plus, given your comment about "incorrect radio settings" I will assume you've read the user manual, etc.
First, in what county do you live? This is important because you could live in a county not served by the Spencer Mountain transmitter, thus any tone alerts they transmit (tones which trigger your radio) would not apply to your location. I say this because there are 3 different NOAA weather radio stations that serve the Charlotte Metro and county combinations vary a bit for each one.
Secondly, this COULD ultimately be your issue. Not every TV weather scroll you see would meet the severity criteria for the National Weather Service to transmit a tone alert. For winter weather events, Winter Storm Warnings (not Watches) are "toned". Winter Weather Advisories are NOT toned, either. Ice Storm Warnings would also likely be toned. Generally, any weather event that's a threat to life/property is "toned". And while lightning is certainly a threat, there are no such warnings and thus are not toned - the sound of thunder is your warning here.
The Greenville-Spartanburg National Weather Service has a weather radio webpage that may provide some help http://www.weather.gov/gsp/nwr
You can also verify some alarm functionality, by way of the weekly tone alert test transmitted each Wednesday between 11am-Noon. Given the newness of your radio, I doubt it audibly alarms for the weekly test - however it does log it and it will show on the radio's LCD display. This display does hold "tone alert" history - maybe up to 30 events - and you should be able to "scroll" back through the history and see its tone alerts. You should find how to display this history in the user manual.
Hope you get the radio to working - please reply back with your results!
Eric Calhoun
"If it was simple, anyone could do it" - Roy Clark from Hee Haw
eacalhoun is offline
post #9523 of 9540 Old 03-03-2015, 07:59 AM
Theo1080's Avatar
Quoted: 36 Post(s)
Liked: 27
Antenna Pattern for Crowder's Mt.
Name:	crowdersmtn pattern.png
Ted Hand, CPBE. 8VSB, DRB, AMD
I was there on July 23, 1996...First DTV broadcast in the US..WRAL-HD
Amateur Radio - W9SOC
Theo1080 is offline
post #9524 of 9540 Old 03-03-2015, 03:13 PM
mmehtas's Avatar
Liked: 0
Need help again!
Some of you were kind enough to help me choose an antenna, etc. As I posted earlier, I did get the antenna and amp installed in the attic. For various reasons, I just got around to canceling cable TV this week.
I have two tv's - one upstairs and one downstairs. Both tv's are fed from a wiring closet downstairs. I replaced the input going into the powered splitter in the wiring closet with the antenna input. Move my old Series 3 Tivo upstairs and everything works great upstairs. Ordered a new TIVO Roamio for the downstairs TV, and although the channel scan says it found many channels (225!!), i could not get a single channel showing up. Every single one had zero signal strength. Assuming that there might be a problem with the new Roamio, I brought the old Series 3 Tivo downstairs and hooked it up. No channels!!
I am at a loss. Cable TV was working fine, so by replacing the input in the closet with the antenna, with no changes to the output cables, the signal must be getting to the Tivo downstairs. It does work upstairs, therefore the antenna as input is definitely working.
Is there any possibility that the signal is over amplified? There is an amp in the attic, and the powered amp/splitter in the closet. The upstairs TV does have a much longer run since the cable has to go back upstairs, and there are a couple of joins in that route. I am not even sure if there is such a thing as over amplified - wouldn't the channel strength show something if that was the case? And, wouldn't I get at least one channel showing?
I would sincerely appreciate any thoughts or suggestions. The wiring from the closet to the downstairs tv is obviously through the walls, and I cannot imagine something happening to it just from my disconnecting the coax from the Digital Tuning Adapter and hooking it directly into the Tivo Roamio.
Originally Posted by mmehtas View Post
Thanks! I was planning on putting the power supply in the attic. And, I will try it with/without the distribution amp. Probably won't get to routing it through the wiring closet until I am happy with the tuning.
I did put the preamp in the circuit (still just attached to the upstairs TV), and did not overload any signals. It's a bit of a pain having to go up and down the attic stairs, make a change to the antenna position, search for channels, etc. Wish I had a smaller tv I could take into the attic.
So far, I am not finding much difference no matter what. There are a couple of channels (WCWG-DT & WFMY-DT) about 82 miles away and at 50 degrees that are sensitive to the right bay position. The left bay does not seem to make much of a difference whether I have it parallel to the main bay or at 90 degrees off (except for one channel). I can also get WYCW-DT (at 99 miles away) at 287 degrees but was losing a few closer channels, and it was coming in pixelated so gave up on that.
There are 46 sub-channels that are rock solid and don't seem to be at all sensitive to moving the bays around within reason (including the one VHF channel). I am going to do some more trial and error, and may end up just being happy with the 46 to 50 channels. Then it will be time to get the routing correct to the two tv's.
mmehtas is offline
post #9525 of 9540 Old 03-03-2015, 04:01 PM
Liked: 0
OK, I picked up an HBU55 at Radio Shack yesterday and I'm going to try to get it up this week. I have a question about grounding though. My antenna will be placed roughly in the middle of the house and the cable will come in through a wall close buy the antenna. There's not really any place close by to run the ground to. How critical is this, and can I run a ground wire in with the cable and just connect to one of the wiring ground wires?
post #9526 of 9540 Old 03-03-2015, 04:25 PM
tylerSC's Avatar
Quoted: 319 Post(s)
Liked: 115
It may not be necessary to ground an antenna in the attic, but I am not sure about that.
post #9527 of 9540 Old 03-03-2015, 04:30 PM
tylerSC's Avatar
Quoted: 319 Post(s)
Liked: 115
I think previous poster mmehtas has an issue with the amplifier or the junction box. Try replacing the amp with just a regular splitter, and try putting a preamp closer to the antenna.
post #9528 of 9540 Old 03-03-2015, 05:30 PM
mmehtas's Avatar
Liked: 0
Thanks! The preamp is in the attic, very close to the antenna. The amplifier/splitter in the wiring closet has been working fine all this time, and the upstairs TV is getting a great signal, so I don't think that is the issue.
In the meantime, since the cable company does not actually disconnect the cable TV until tomorrow, I replaced the input to the amp/splitter in the closet back to the cable TV. Now I am getting all the basic cable channels (already returned the Digital Tuning Adapter and Cablecard) on the downstairs TV, verifying that there is nothing wrong with the cable from the closet to the downstairs TV.
This means that the downstairs TV is not getting a proper signal, and this is puzzling. The TV upstairs works fine, and the cable from the closet to the upstairs is much longer. The downstairs TV is barely 20 feet away. I have no idea why the signal would be too weak here, but not so upstairs. I also tried hooking the cable from the antenna directly to the cable in the closet that is routed to the downstairs TV (bypassing the amp/splitter in the closet). No change in signal, and still not getting any channels to show.
Not sure what to do now. Any suggestions would be much apprecated.
mmehtas is offline
post #9529 of 9540 Old 03-03-2015, 05:52 PM
mmehtas's Avatar
Liked: 0
The only difference with the downstairs TV setup is that the Tivo is hooked into a AV receiver then to the TV. However, since the cable goes first into the Tivo, it should make no difference.
So, we have cable from closet to upstairs - works great with Tivo/TV setup. Cable from closet to downstairs Tivo/TV setup - no picture and signal stength is 0 ("no digital signal"). Somehow the signal is is getting degraded, but I don't see how since there is a preamp next to the antenna, and a high quality amplifier/splitter in the wiring closet. That should be plenty of amplification.
mmehtas is offline
post #9530 of 9540 Old 03-03-2015, 06:11 PM
mmehtas's Avatar
Liked: 0
I might have hit on the problem.
Looks like the cables are mislabeled. What was marked as the "Family Room TV" coming out of the amp/splitter was not so - discovered that accidentally by disconnecting it and the TV still showing the cable signal.
It appears as though the input cable coming to the closet was split into two - one going into the amp/splitter, and the other to the downstairs TV. So, when i switched the input to the amp/splitter to the antenna, the upstairs TV got an antenna signal, but the downstairs tv did not. I am reconfiguring and should know in an hour if that solves it. I will post an update if that is not the case.
Thanks for reading and helping.
mmehtas is offline
post #9531 of 9540 Old 03-03-2015, 06:52 PM
Liked: 0
The antenna will be mounted outside on a mast.
post #9532 of 9540 Old 03-03-2015, 06:52 PM
Quoted: 49 Post(s)
I live northeast of the pattern, so I can see why 9.5 and 64.5 are a hit or miss.
Do these map sections represent miles?
post #9533 of 9540 Old Yesterday, 06:46 AM
Theo1080's Avatar
Quoted: 36 Post(s)
Liked: 27
No, they do not. Mileage in coverage is based on A) Power Input to the Antenna and B) Height Above Average Terrain (HAAT) of the Antenna. The drawing only shows the shape and relative power of the pattern. The shape of the pattern would be the same if it was fed with 1 watt or 1000 watts.
Theo1080 is offline
post #9534 of 9540 Old Yesterday, 09:54 AM
Liked: 0
I was reading some reviews on the HBU55 antenna I bought and ran across these comments from one reviewer:
"There are too many VHF driven elements. The length of them need to be shortened. From the boom measure out 10" on each VHF element with tin snips cut the rest. By cutting the VHF elements to 10" you are making this antenna Bi-directional it will receive equal or nearly from the back side by using the UHF Corner reflector elements because they are longer."
Does this sound valid? If its true, it would be convenient as I have Columbia to the south and would like to pick that up. Anyway if it's true, which are the VHF elements, the horizontal ones at the rear of the boom?
post #9535 of 9540 Old Yesterday, 01:23 PM
tylerSC's Avatar
Quoted: 319 Post(s)
Liked: 115
The UHF elements are the shorter one in front of the corner reflector. The longer horizontal elements are for high VHF and could be a bit more bidirectional than the UHF. HBU55 is a good antenna.
post #9536 of 9540 Old Yesterday, 07:28 PM
SethH's Avatar
Issue with Channel 9 - WSOC
I've been having issues with WSOCTV recently. The sound cuts out and I feel like we miss 1 out of every 5 words. When I pull up my signal meter on my tv it is typically registering in the 85%-90% range even as this is happening. Im not sure if the drops in signal are so brief they don't register on the meter or if there's some other issue at play here. I have not noticed this on any other channels.
Any thoughts?
SethH is offline
post #9537 of 9540 Old Today, 10:44 AM
blackcat6's Avatar
Quoted: 216 Post(s)
Liked: 58
Originally Posted by SethH View Post
I've been having issues with WSOCTV recently. The sound cuts out and I feel like we miss 1 out of every 5 words. When I pull up my signal meter on my tv it is typically registering in the 85%-90% range even as this is happening. Im not sure if the drops in signal are so brief they don't register on the meter or if there's some other issue at play here. I have not noticed this on any other channels. Any thoughts?
Assuming that WSOC isn't having any issues, then...
Most TV signal meters will give you signal strength, but not signal quality which is the more important measurement. You can have a strong signal but if the signal quality is bad then picture drops. On the other hand, you can have a weak signal but if the signal quality is good, then you can receive it.
What you describe sounds like you are getting hit by multipath. Generally this means you need to work on your antenna. i.e. better pointing/location, or a different model. Indoor/attic mounted antennas are more prone to the problem.
post #9538 of 9540 Old Today, 11:13 AM
tylerSC's Avatar
Quoted: 319 Post(s)
Liked: 115
Any thoughts?
Sounds like signal is too strong causing overload or multipath, which can cause dropouts. Try reaiming antenna, perhaps slightly away from WSOC direction. Or add attenuater and remove amp if used.
post #9539 of 9540 Old Today, 06:21 PM
Quoted: 49 Post(s)
Gaston County. I'm not sure if I can pick up any other station.
Yes, I found that out not long after I installed the radio.
Eric Thomas of WBTV sent me the following info a while back...
Good question! The criteria for a ‘severe’ thunderstorm is very specific: The storm, by their determination, must be capable of producing one inch hail and/or winds in excess of 59 mph - in other words, damaging weather. The NWS issues many Specials for storms that are strong but don’t meet the severe threshold. So they do issue statements about the storms, but not actual warnings.
As you pointed out, many apps are now capable of flagging those Specials and alerting the end user. But because they are not considered ‘severe’, the NWS does not sound the alarm on the weather radio. I suppose if they did sound the alarm every Special Weather Statement, your alarm would be going off all summer long and you’d probably throw the radio out the window.
Again, I’m not defending their practice, everyone has a valid opinion about how to most effectively warn people about impending weather and finding the balance between issuing timely statements without over-warning the public about every garden variety storm.
I hope that helps!
Eric
post #9540 of 9540 Old Today, 06:41 PM
Quoted: 49 Post(s)
I have all audible alarms turned off, but we do get text messages and flashing lights. We never saw the weekly test information yesterday, but it may have displayed without our knowledge. However, there are no stored events, so I can't say for sure if the test results were displayed or not.
Last week, I saw a flashing red warning light and a snow warning text message to boot, but an hour or so later, the red warning light turned itself off, and there was no more text message either. A quick check of the web, TV, and radio indicated that the warning was still intact. Why would the weather radio dismiss a current warning? This is not the first time this has happened. The Spencer Mountain broadcast signal comes in loud & clear from where we live.
The user manual is somewhat disappointing. For example, there is no documentation about how to delete unwanted SAME codes for multiple counties, but a Midland rep instructed me how to do it. Why would the manual leave out such info?
