Charlotte, NC - OTA - Page 326 - AVS | Home Theater Discussions And Reviews
 123Likes
post #9751 of 9766 Unread 04-27-2015, 12:13 PM
tylerSC's Avatar
Quoted: 359 Post(s)
Liked: 118
WMYT Channel 55 is apparently off the air as they upgrade their antenna. They hope to be back on the air Tuesday afternoon and hopefully their signal will be improved, although I think they will remain at a lower power level. But I always got a strong signal from 55 despite the lower power.
tylerSC is offline
post #9752 of 9766 Unread 04-27-2015, 06:38 PM
tylerSC's Avatar
Quoted: 359 Post(s)
Liked: 118
Spoke with WJZY/WMYT receptionist. They are definitely replacing the transmit antenna for Channel 55. Don't know if it will be positioned differently on the tower, but I guess it will still be side mounted. The old 46 analog antenna is still on top I think. Perhaps it will have a better pattern to reach problem areas around Hickory where there is interference from WHKY. Although 55 has a permit for a low power translator on Smith Mtn. to reach Catawba County. The new antenna should be up tomorrow afternoon. But meanwhile they still have 55 simulcast on 46.3.
tylerSC is offline
post #9753 of 9766 Unread 04-27-2015, 08:08 PM
tesla_engineer's Avatar
My guess would be, they are installing a new antenna that would be a antenna just like the one they have now.
It should be the same place on the tower, same gain, same pattern.
There is no construction permit, also there is a freeze on TV construction that changes coverage at this time.
Also the CP for Hickory is on Baker Mt, not Smith Mt.
Tom
tesla_engineer is offline
post #9754 of 9766 Unread 04-27-2015, 09:49 PM
blackcap93's Avatar
Quoted: 13 Post(s)
WMYT has been operating under special temporary authority at reduced power due to failure of some critical parts. No construction permit is required for any work to restore the station to normal licensed operation.
Link to STA authorization (you may need to append ".pdf" to the file name if you choose to save it):
http://licensing.fcc.gov/cgi-bin/pro...etter_id=56921
blackcap93 is offline
post #9755 of 9766 Unread 04-28-2015, 10:10 AM
eacalhoun's Avatar
Quoted: 23 Post(s)
I can probably kiss WYFF reception good-bye!
Eric Calhoun
"If it was simple, anyone could do it" - Roy Clark from Hee Haw
eacalhoun is offline
post #9756 of 9766 Unread 04-28-2015, 10:16 AM
I was aware of the STA. That was my point. It has to be built back just like it was. No height change, no power change, no pattern change, no gain in coverage.
Tom
post #9757 of 9766 Unread 04-28-2015, 11:39 AM
tylerSC's Avatar
Quoted: 359 Post(s)
Liked: 118
55 is back and a strong signal. Which I always find interesting as they are 225 kw power compared to WJZY and WBTV at 1000kw power. And the signal strength is basically the same with much less power. At my receiving location. WBTV is always 10 bars, WJZY and WMYT drop to 7 or 9 during the day and back to 10 at night.
tylerSC is offline
post #9758 of 9766 Unread 04-28-2015, 12:07 PM
My guess is the your "Signal Meter" is reading more quality, not level.
Many of the ones I have looked at are that way. I have seen locations that lower signal levels did better, because of less reflections.(multipath)
Tom
post #9759 of 9766 Unread 04-28-2015, 12:30 PM
LMckin's Avatar
Quoted: 57 Post(s)
I notice WJZY's Sub channels is off only the .1 channel is on.
LMckin is offline
post #9760 of 9766 Unread 04-28-2015, 12:58 PM
tylerSC's Avatar
Quoted: 359 Post(s)
Liked: 118
Rescan they are back now.
tylerSC is offline
post #9761 of 9766 Unread 04-28-2015, 01:00 PM
LMckin's Avatar
Quoted: 57 Post(s)
ok
LMckin is offline
post #9762 of 9766 Unread 04-30-2015, 08:38 PM
cpalmer2k's Avatar
Quoted: 69 Post(s)
I'm not sure if this is a promo plan or not, but right now TiVo is selling their Roamio OTA DVR's for $299 WITH Lifetime service included.
This unit is antenna only, but has four tuners... and the service, which is a huge deal. If you have reliable internet TiVo is the way to go, hands down.
The deal only shows using this URL: https://www.tivo.com/TLP4
cpalmer2k is online now
post #9763 of 9766 Unread 05-01-2015, 05:15 AM
OTA-DVR-guy's Avatar
Quoted: 84 Post(s)
My Sharp 70" smart TV will optionally connect to the internet, and has many of those same applications installed, but the internet is not required - you can choose to not use the internet features, and only use the over-the-air features. Could this Tivo work that way? I read your link, but can't tell.
OTA-DVR-guy is offline
post #9764 of 9766 Unread 05-01-2015, 05:42 AM
cpalmer2k's Avatar
Quoted: 69 Post(s)
You can choose not use any of the apps, but the TiVo will need to download the guide data via an internet connection (but the newer Channel Master DVR does the same, unless you want to rely on the 24 hours or so of PSIP data. Several posts on TiVo community and TiVo forums reference people using hotspots. It isn't "recommended", but most say it works. You might want to search for some more definite threads there first. One that I found is here
This apparently is the best of many "test" offers TiVo is considering, or offering for the Roamio OTA model. A TiVo community poster uncovered the link. They apparently aren't public, and are just going out in e-mails or might become public later on. I did order one of these myself last night, and can confirm that it checks out at $299 and says that it includes lifetime service.
Since moving my Roamio basic to our bedroom and adding a CableCard I've found I occasionally missed being able to record something from the Charlotte OTA stations. I wasn't willing to buy a full blown second TiVo with Lifetime service, but this was reasonable enough to fit the bill.
post #9765 of 9766 Unread 05-01-2015, 01:47 PM
tylerSC's Avatar
Quoted: 359 Post(s)
Liked: 118
That $299 promo is truly the best deal to date for an OTA DVR, especially a TiVo. The Channel Master DVR+ models are $249 and $399. So that TiVo deal is a happy medium worthy of consideration at this price point. Also, if you use a Gaffney zip code on the TiVo, you will get guide data for both Charlotte and Greenville-Spartanburg-Asheville markets, although Gaffney is officially GSP market. Which is good that TiVo goes by reception availability rather than DMA boundaries.
tylerSC is offline
post #9766 of 9766 Unread Today, 05:46 AM
blackcat6's Avatar
Quoted: 235 Post(s)
Liked: 59
Indeed. IMO, it's the best DVR out there. It's completely plug & play, with a well thought out universal remote control with real buttons (don't underestimate the importance of this) and excellent interface. And if you are willing to spend more, you can expand the storage and turn it into a whole house DVR.
blackcat6 is online now
