Analog vs. Digital Signal strength - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 06-08-2001, 09:06 PM - Thread Starter
Michael Mullis's Avatar
Well, step one of my 2 step local HD upgrade here in Baltimore, Maryland is complete. I installed my Terk TV 55 up on the roof, and as expected, the analog signals I get are pretty par for the course with what I am used too. Local NBC comes in decent, ABC and CBS fairly well (little ghosting but I expect that), Fox is crap.
So will this reflect the type of digital signal I'll get? Our DTV channels here start at 39, and run through the UHF line. I will have my 8Vsb tuner on Tuesday, but I was hoping for a little input on what to expect. Especially from anyone in the Baltimore area with a similar antenna.
Michael Mullis
Director of US Operations
Next Level Gaming
http://www.nlgaming.com
Michael Mullis is offline
post #2 of 9 Old 06-08-2001, 11:22 PM
dagman's Avatar
Terk 55? Do you have a wife that you have to please?
The big ugly antennas seem to give better performance. Give the Terk a try, but if you can't pull in the digital stations you want, you may want to switch to a better antenna.
dagman is offline
post #3 of 9 Old 06-09-2001, 05:22 AM - Thread Starter
LOL!! No, I unfortunately succumbed to the advertising on the back of the box. I bought the antenna before I joined this forum. I have no qualms about getting another antenna, I was just hoping I wouldn't have to.
Michael Mullis
Next Level Gaming
post #4 of 9 Old 06-09-2001, 06:20 AM
Bogney Baux's Avatar
I assume the good analog stations you mention are on the VHF channels. If so, they do not mean much as far as predicting your reception of the UHF digital stations.
A better test is how the analog UHF stations from similar transmitter locations are received. If they are received with a halfway decent picture, you should be able to receive the digital stations.
The analog Fox station you mention with the bad picture is probably UHF so you may have problems with digital reception. How do the other analog UHF stations come in?
Bogney Baux is offline
post #5 of 9 Old 06-11-2001, 06:54 AM
metamatt's Avatar
This may not work in your situation, I had tried a Terk 55 and an older Terk 50. Neither of them were at good as an indoor antenna that is now pulling in all the HDTV stations in Boston. It is a megawave MTV-1. You can only order at the following website or over phone.
http://www.megawave.com/mtv1.htm
Matt
metamatt is offline
post #6 of 9 Old 06-11-2001, 07:47 AM - Thread Starter
Well, I'm crossing my fingers. I still have about 20 days to find out if this works. My 8VSB tuner comes in tomorrow.
The kicker is that when I first saw this thing running at Best Buy, it was hooked up in the middle of the TV section, sitting on a stand, and it got every HD station perfectly.
Michael Mullis
Next Level Gaming
post #7 of 9 Old 06-11-2001, 11:05 AM - Thread Starter
I'd say mediocre to decent. But so far no antenna I have ever had has been able to pick up good UHF signals, which constitutes my analog FOX and WB stations.
Michael Mullis
Next Level Gaming
post #8 of 9 Old 06-11-2001, 06:23 PM
WOLVERNOLE's Avatar
Quoted: 16 Post(s)
Recommend a specific antennae for OTA UHF (HDTV) please...e.g. Winegard or Channel Master?
WOLVERNOLE is offline
post #9 of 9 Old 06-11-2001, 09:44 PM
Homer J's Avatar
The reception you are mentioning are all VHF channels, so they have no bearing on how your DTV channels will come in because they are UHF. How are your other analog UHF channels? That is a better indicator of how your reception will be.
Homer J is offline
Closed Thread Local HDTV Info and Reception
taboola here
