Chicago, IL - WOW - Page 31 - AVS Forum | Home Theater Discussions And Reviews
post #901 of 902 Old 01-10-2015, 11:12 AM
brucesprings's Avatar
One other thing, is there a way to purchase a third party box or receiver that would do the same thing or are you stuck renting from cable company?
brucesprings is offline
post #902 of 902 Old 01-12-2015, 01:21 PM
Mitch G's Avatar
Only the local channels are provided in HD in the clear - the 200-series channels that you see already.
To get cable channels like TNT or USA or Bravo etc in HD, you need a cable box.
Or a cable-card enabled TV or box.
I think for your purposes, just going with WOW's cable box will probably be the easiest option.
Mitch
Mitch G is offline
