Wood on bit rates...cable...1080i vs. 720p...more - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 06-23-2001, 07:03 AM - Thread Starter
John Mason's Avatar
Quoted: 76 Post(s)
Liked: 112
There's a fascinating Greg Rogers interview of Lee Wood in July's "Widescreen Review." Forum member Wood is director of engineering at CBS affiliate KOIN-TV in Portland, Ore. For his moderated HDTV news forum, one learns, he daily scourers the Internet starting at 5 a.m.
Among the many tidbits about current HDTV broadcasting that caught my attention:
  • KOIN varies the bit rate of HDTV broadcasts depending on the content. (A 6-MHz HDTV signal can carry up to 19.3 million bits per second.) Typical evening broadcasts at KOIN are delivered at 11 Mbps, Wood said, where the MPEG-2 encoding might cause motion artifacting only during action scenes. CBS's Super Bowl got about 15 Mbps to minimize artifacting, and basketball used all 19.3 Mbps.
  • KOIN delivers a standard-definition digital channel in a 4:3 format simultaneously with a 16:9 HDTV program (for those with 4:3 screens who don't like letterboxing.) SDTV channels get 4 Mbps.
  • Unused bits in a 19.3 Mbps channel are being experimentally used to broadcast data (1-3 Mbps as the bit rate varies with MPEG-2 encoding). Otherwise, unused bits become 'null packets' or blank spaces.
  • 1080i vs. 720p is a tradeoff between detail and motion, Wood notes, indicating 1080i can put three times the pixels on screens. Outside of fast-moving sports, the detail is what catches the eye.
  • "Satellite delivery of local HDTV stations isn't going to happen anytime soon," he notes, urging cable operators to bundle programming such as HBO with local HD as an advantage.
  • The HDTV rollout and the availability of set-top boxes was slowed by the arguments over modulation schemes (8-VSB vs. COFDM), he said. He estimated only about 66,000 in the U.S. can watch HDTV due to limited STB availability.
    --John
STOP DVI/HDCP AND DFAST
[This message has been edited by John Mason (edited 06-23-2001).]
John Mason is offline
Closed Thread Local HDTV Info and Reception
