Does thread tracking by E-Mail work anymore? - AVS Forum | Home Theater Discussions And Reviews
Old 08-08-2001, 01:52 PM - Thread Starter
tji
tji's Avatar
Has anyone else had problems with the thread tracking feature of this forum?
About a month ago, the method for subscribing to a thread changed. Since that time, this feature has worked very poorly for me. Threads I am subscribed to are updated, but I never get an e-mail notification.
tji is offline
Old 08-08-2001, 02:21 PM
David Bott's Avatar
Liked: 45
I have no issue with the new method that went on-line and no reports of any issues at all.
Just so you know, I checked with Parker at Home Theaer Forum, they use the same method, and he also reports no issue from his users.
David Bott
It's A World Of Entertainment...Experience It!
AV Science/AVS Forum Admin
http://www.avscience.com
http://www.avsforum.com
The Nate Home Theater
David Bott
Founder - AVSForum
DISCLAIMER: All spelling and grammatical errors done on purpose for the proofreadingly challenged...:)
David Bott is offline
Old 08-08-2001, 02:24 PM
Ken Erickson's Avatar
I've used both the old method and the new one. As far as I can tell the new method works just fine. I'm tracking 5 threads at the moment with e-mail arriving for all of them.
Ken Erickson is offline
Old 08-08-2001, 03:34 PM
JohnRichmond's Avatar
No problem here either. Make sure you enter your email address correctly.
JohnR
JohnRichmond is offline
Old 08-08-2001, 06:21 PM - Thread Starter
tji
tji's Avatar
Thanks for the feedback.
Maybe there were some glitches early in the transition.. For one thread, I received a couple e-mails on updates, then it just stopped. For a couple other threads, I never got updates at all. And, yes.. I very carefully entered my correct e-mail address.
When I posted the first message this morning, I also signed up to track another thread, and this one appears to be working.
tji is offline
