Question about HDTV size - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-14-2001, 08:13 PM - Thread Starter
Decoder's Avatar
I will be buying a HDTV in the next 2 months and don't know what size would be right. The sofa will be 7 feet away from the TV. Which size would be optima? 61, 55, 51.
Decoder is offline
post #2 of 4 Old 08-14-2001, 08:51 PM
bdenman's Avatar
Depends in part on what you watch the most. Here is one rule of thumb I have seen discussed in the forums, its about right for us and it might work for you:
HD 3.3 x Picture Height (PH)
DVD 5 x PH
NTSC 7 x PH
My RP widescreen 55" Picture Height is about 27" so the recommended viewing distances are approximated being:
HD 7.5'
DVD 11'
NTSC 15:75'
I sit about 11-12' for most things and find it fine and I can move closer for HD if necessary. NTSC is a bit ragged but its not too bad. Good luck.
Bruce
[This message has been edited by bdenman (edited 08-14-2001).]
Bruce
Latest Summary on COLUMBIA SC HDTV can be found here.
bdenman is offline
post #3 of 4 Old 08-15-2001, 07:07 PM
Bill's Avatar
Quoted: 88 Post(s)
Liked: 54
Get a 16x9 and the side barred 4x3 NTSC image will be the right size for the distance also. I'd say about a 50" 16x9. I think Toshiba is coming out with one.
[This message has been edited by Bill (edited 08-15-2001).]
Bill is offline
post #4 of 4 Old 08-17-2001, 11:15 AM
Kipp Jones's Avatar
Move the couch back and get a larger tv. Even if you have to knock a hole in the wall or put on an addition!
Kipp
IS THAT A REMOTE CONTROL IN YOUR POCKET OR ARE YOU JUST HAPPY TO SEE HDTV?
Kipp
Are you boozen & cruisin the AVS? Join us here ---> http://www.avsforum.com/avs-vb/showt...8&page=1&pp=60 good times! www.illinoiscarry.org www.nra.org
Kipp Jones is offline
Closed Thread Local HDTV Info and Reception
