is 480p considered HDTV quality or..... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-20-2001, 05:48 PM - Thread Starter
jdegraf's Avatar
is 1080i only considered HDTV quality
another or
Is 1920X1080 screen resolution considered HDTV and anything less not HDTV??
(look to be purchasing an XBox that does indeed to HDTV settings, so they say)
jdegraf is offline
post #2 of 6 Old 08-20-2001, 07:06 PM
Ken H's Avatar
HDTV (high definition) is currently defined as either 1080i or 720p. In the future we may also see 1080p.
480p is EDTV (enhanced definition), and 480i is SDTV (standard definition).
"Better living thru modern, expensive electronics devices"
tm
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #3 of 6 Old 08-21-2001, 05:48 PM
BarryO's Avatar
ATSC HD formats are 1080x1920 at 60i, 30p, 24p; and 720x1280 at 60p, 30p, & 24p.
Formats being broadcast OTA are 720/60p (ABC), and 1080/60i (CBS & NBC). 1080/24p seems to be a common production format for movies shot with HD-Cams.
You have a right to install OTA and dish antennas on property under your control.
See http://www.fcc.gov/csb/facts/otard.html
See http://www.fcc.gov/mb/facts/otard.html
BarryO is offline
post #4 of 6 Old 08-22-2001, 03:35 PM
Rebies's Avatar
I'm assuming this means 60 fps progressive or 30i would mean 30 frames per second interlaced..?
Rebies
_ __________________ _
"If I ever catch a fish and think of him as just another fish, it is that day that I will either sell my gear or simply give it away."
Rebies is offline
post #5 of 6 Old 08-22-2001, 04:22 PM
Frank's Avatar
I assume that 480P by definition has 4:2:0 chroma sampling.
If it had 4:4:4 sampling it would look very good indeed but I don't know if this is even a supported standard for MPEG II encoding.
Frank
Did IQ's suddenly drop sharply while I was away?
I enjoy 3D in spite of HDMI 1.4!
Full screen only 3D doesn't cut it!
Frank is offline
post #6 of 6 Old 08-23-2001, 04:01 PM
BarryO's Avatar
All the ATSC formats are 4:2:0. MPEG-2 does contain provisions for 4:2:2 profiles, which are used in some HD production formats.
60i means 60 fields (i.e., half-frames) per second, interlaced. 60p, 30p, 24p mean 60, 30, or 24 frames per second, progressive. 30p and 24p cannot be directly displayed on scanning or intermittant devices such as CRTs or film projectors, due to intolerable flicker, without doing frame multiplication or 3:2 pulldown first.
BarryO is offline
Closed Thread Local HDTV Info and Reception
