Screen Size to viewing distance - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-07-2001, 07:07 AM - Thread Starter
Dan S's Avatar
I know this has been asked alot, but here goes again what size RPTV should I get for say 14 ft viewing distance, what is the formula for size to distance? Thank you for your help!
Dan S is offline
post #2 of 3 Old 09-07-2001, 09:11 PM
Larry Hutchinson's Avatar
Assuming you are talking about 16:9 HDTV , the optimal viewing distance is generally considered to be about 3.3 screen heights.
So, if you are 14 feet away, that gives a height of 51 inches. As it happens, the diagonal of a 16:9 set is very close to twice the height, so you would need a 102 inch set !!!
But since HDTV sets and broadcasts are less than optimal at the current time, a somewhat smaller set would be ok.
STOP DVI/HDCP; Boycott JVC
Larry Hutchinson is offline
post #3 of 3 Old 09-07-2001, 09:57 PM
jedipoteat's Avatar
I doubt there is a RPTV made that is going to be too big for that distance. If I were you I'd probably get a 65" 16x9, maybe even bigger if you can find (and afford) it.
jedipoteat is offline
Closed Thread Local HDTV Info and Reception
