Band Of Brothers In High Def - AVS Forum | Home Theater Discussions And Reviews
Old 09-08-2001, 09:28 AM - Thread Starter
Burke55's Avatar
I am having my High Def dish installed today. Anyone know
what time Band Of Brothers is being broadcast by HBO in High
Definition? I amn going to tape the standard version on one of my televisions. Is it being shown at the same time on 509?
Burke55 is offline
Old 09-08-2001, 10:56 PM
Ken Erickson's Avatar
Burke55,
DirecTV ch 509 is the same as 501 with exception that 501 is SD and 509 is HD. You can find out what HD programs are airing by going to www.HDTVGalaxy.com/board.html.
BTW, you should use the search feature; this topic has been posted on numerous threads in the HDTV Programming section already.
Ken Erickson is offline
