Palm Springs, CA - HDTV - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 270 Old 09-12-2007, 02:42 AM
mikeht's Avatar
Originally Posted by aBlueSky View Post
Wow, you are right down the road from me (I live in the Cove). I would like to know an answer to this question also.
Cheers!
Good luck! (you may want to wait for a cooler day)
Good thing I spent most the day inside hah. Have you tried pulling anything OTA? I got a bigger indoor antenna and now I get 3 crystal clear analog channels. Still have yet to get on the roof of the building.
mikeht is offline
post #92 of 270 Old 09-12-2007, 06:20 AM
aBlueSky's Avatar
I have never tried pulling any channels OTA. I look forward to hearing how it goes.
Cheers!
aBlueSky is offline
post #93 of 270 Old 10-03-2007, 12:07 PM
dennis1's Avatar
Well, Time Warner has finally added two new HD channels: ESPN2 and Golf Versus.
I hope that this relates to the implementation of switched-digital video, and that we'll soon be seeing lots of other HD channels appearing on our screens.
dennis1 is offline
post #94 of 270 Old 12-19-2007, 09:27 AM - Thread Starter
clapple's Avatar
Some time ago, there was a post that said our local CBS had applied for Ch. 27, for digital ota broadcasts. Anyone know the current status of that?
Red
clapple is offline
post #95 of 270 Old 12-20-2007, 02:01 AM
nllx's Avatar
Oh wow, I didn't know Palm Springs had a thread here! And right when I have a question.
I live in the Indio area and I'm looking for a quality antenna. I have some old antenna that only gets 65>* signal most of the time but I really want to enjoy OTA HDTV. I read about the 15-2187 from RadioShack that was posted here and it practically receives great reviews so would you guys recommend it?
Oh and does FOX (33-2) look odd like black bars on the side like it if was in SD and poor picture quality or is it just my old antenna?
nllx is offline
post #96 of 270 Old 12-20-2007, 07:08 AM - Thread Starter
clapple's Avatar
nllx
I live in the Sun City off Washington St. Don't know if Indio is too far away; but I do just fine with a Silver Sensor indoor ant. Might be worth a try?
Red
clapple is offline
post #97 of 270 Old 12-23-2007, 02:38 PM
DosUno's Avatar
Anyone got any info on directv offering locals in the CV? I recently had it installed and was about to put up an off-air antenna when the installer mentioned Directv is to be geeting locals channels starting Jan 16 2008.
DosUno is offline
post #98 of 270 Old 03-03-2008, 02:34 AM
gwise96557's Avatar
Due to my job at Kwajalein Atoll in the Marshell islands, I Get home to the valley once a year. This year I bought a Emerson TV (Wall mart special) for my Grand neice and her great grandma. Using a Amplified Rabbit ears (Variable Amplification control 1-5) and the distance from antenna web.org the Following stations were picked up (Amplifier at full power 5) was KVMD (150KW from 29 Palms-@ 55.9 Miles) Digital subchannels (KXLA and KJLA 31.1, 31.2, 31.3) (Channel 23). From Palm Springs KESQ (50KW channel 52 @ 31.7 miles) and Sub Channels KCWQ (2-3) KDFX (33.2) KESQ WX. Signal Strenghth levels were not available. But turning the antenna affected the picture quality of the Analog signals but the Digital did not appear affected by this. However when the amplifier control was lowered down to about 3 from 5 The pictures on the digital channels froze and dropped opf to no signal status. At my place several hundred feet away Trying a LG DVD (737 I believe as my notes are missing) recorder with an ATSC Tuner hooked to a Channel Master 4228 antenna with a low power distribution amp. I Received KESQ and Sub channels (Same distance for all stations as above) KMIR (12 KW @ 31.6 miles Channel 46) and the 29 Palms KVMD, KXLA, KJLA stations. I Will be back proably next year for or after the transition occurs and will be curious as more of the stations switch over until then I'll keep checking the sites as I have time
gwise96557 is offline
post #99 of 270 Old 03-05-2008, 12:26 PM
Weaselboy's Avatar
A neighbor of mine has DTV, and mentioned the locals are now up, but not in HD.
Weaselboy is offline
post #100 of 270 Old 03-18-2008, 09:44 AM
Johnny U's Avatar
My HD3250 box stopped working on Thursday morning (3/13/2008) after TWC ran a major update on their software/firmware. After a week of pulling my hair out, this is what I finally got from them:
At this present time, Time Warner Cable does not provide support for the USB, SATA, Firewire, HDMI, or DVI ports. Some of the ports on the digital boxes are active and can be used. Time Warner Cable can not help with the setup or installation of the following ports USB, SATA, Firewire, HDMI, or DVI ports; currently Time Warner Cable only support the setup and installation of composite, component, S-Video, and coax cable. If you have any questions feel free to contact your local Time Warner Office between hours of 8am to 8pm Monday through Saturday for Sales and Billing and Technical Support is open 24 hours a day / 7 days a week.
Thank you for contacting Time Warner Cable.
Johnny U is offline
post #101 of 270 Old 04-21-2008, 11:35 AM - Thread Starter
clapple's Avatar
This thread has been quiet, for over a year. Last I heard, Palm Springs channel 2 had applied for an OTA digital channel (27?). Anyone know the status of that; or when they might start OTA broadcasts?
Red
clapple is offline
post #102 of 270 Old 04-29-2008, 08:17 AM
PO BUG's Avatar
I don't think KPSP is any rush, until FEB 2009. Most viewers get Time Warner out here. The Palm Springs area has one of the highest percentage of cable viewers in the country. So they're probably just fine with their Time Warner HD channel for now.
Plus they're an "LP" (low powered tv station) like KDFX and KCWQ. The FCC didn't provide a Digital channel assingment back in the 90's for low powered stations. The difference here is that KESQ operates KDFX and KCWQ, so they placed those digital channels within their full powered KESQ digital signal.
KPSP is a "stand-alone", with no full powered option like KESQ or KMIR. So they either get their channel 27, which is unlikely, or wait until FEB 2009.
PO BUG is offline
post #103 of 270 Old 04-29-2008, 08:20 AM
PO BUG's Avatar
KESQ is now doing their news in 16:9 with some HD.
It may not be full HD yet, but it's a start, and better than a 4:3
PO BUG is offline
post #104 of 270 Old 04-29-2008, 11:12 AM - Thread Starter
clapple's Avatar
" KESQ is now doing their news in 16:9 with some HD. "
Let's hope that might prompt the other stations to upgrade their local broadcasts.
They all, except the CW, pass through the network HD programing; but none do any syndicated showsin HD.
Red
clapple is offline
post #105 of 270 Old 05-01-2008, 07:22 PM
tomanystraydogs's Avatar
Anyone know what HD channels TW in Palm Springs has?
I am not in that area so I can't check myself.
tia
Samsung Plasma TV FAQ - read it, learn it, live it.
tomanystraydogs is offline
post #106 of 270 Old 05-01-2008, 07:25 PM
aBlueSky's Avatar
tia
601 HD Movies on Demand
602 CBS HD (KPSP-2)
603 ABC HD (KESQ-3)
606 NBC HD (KMIR-6)
611 Fox HD (KDFX-11)
615 HD Theater
616 National Geographic HD
617 TNT HD
618 Versus/Golf HD
619 A&E High Definition
620 The History Channel HD
621 TBS in HD
622 HBO HD
625 Showtime HD
629 HD Special Events
630 MOJO
631 Universal HD
632 ESPN-HD
633 ESPN2 High Definition
634 HDNet
635 HDNET Movies
Cheers!
aBlueSky is offline
post #107 of 270 Old 05-01-2008, 07:52 PM
Thx Blue
They were looking for the WB and KCAL, odd they don't have them.
I get them here in Riverside.
post #108 of 270 Old 05-02-2008, 05:27 PM
Weaselboy's Avatar
It does look pretty good. I noticed a lot of the locally shot news footage is in HD as well.
The newscaster's makeup looks a little off though. They kinda look like corpses. Maybe they need to tweak their makeup technique for HD.
post #109 of 270 Old 05-05-2008, 07:20 AM
PO BUG's Avatar
To answer a question about KCAL:
KCAL is in the Los Angeles local TV market and Palm Springs is it's own local TV market.
So KCAL and Time Warner have to reach an agreement to carry HD, which most likely won't happen. KCAL doesn't get ratings or ad money from the Desert Cities because it's out of market. SO KCAL won't spend the money to push HD in the desert, that would be wasting $$.
However, I'm thinking if Time Warner wants to compete with Dish or DirectTV, they may work out a deal for HD. With the seperate television markets, sat tv providers can only show local stations within each market. So no KCAL at all on Dish or DirectTV in Palm Springs.
PO BUG is offline
post #110 of 270 Old 05-06-2008, 10:11 AM
N5XZS's Avatar
Quoted: 23 Post(s)
There is good news for Palm Springs TV Viewers that want to get LA local stations!!
Here's the link from the FCC <<a href="http://hraunfoss.fcc.gov/edocs_public/attachmatch/DA-08-1072A1.pdf" target="_blank">http://hraunfoss.fcc.gov/edocs_publi...-08-1072A1.pdf
I used to be in Palm Spring many years age to see my grandad and this areas is nice place to live.
I am from Albuquerque, NM now.
Hope you enjoy the good news!!!
5-6-08
"73's N5XZS"
From Timothy C. Johnson
Live Long and Prosper...
N5XZS is offline
post #111 of 270 Old 05-06-2008, 07:15 PM
iibbmm's Avatar
Wow, just found this thread.
I'll throw my hat in there as a Palm Springs resident. We just moved out to North Indio from Orange County, so we're new. We have Verizon FIOS tv and the HD package is crap. I'll probably be going with OTA in the near future.
iibbmm is offline
post #112 of 270 Old 05-08-2008, 11:13 AM
Eugene157's Avatar
Quoted: 231 Post(s)
Liked: 41
Are you saying that you have Fios TV in Indio? I live in Dell Web Shadow Hills and sure would like to have it.
Eugene
PS: CRAP= PQ?? number of channels etc???
Eugene157 is offline
post #113 of 270 Old 05-12-2008, 09:00 AM
iibbmm's Avatar
Eugene
We live in Terra Lago and have FIOS tv included in our HOA along with FIOS internet. The HD package is crap mostly because of channel choice, but I'm also not impressed with picture quality. I've heard that it varies from area to area, though.
I do have a relative in Bermuda Dunes who recently had Verizon run fiber to his house for internet/tv and he's very happy with the quality.
iibbmm is offline
post #114 of 270 Old 05-12-2008, 02:24 PM
Eugene157's Avatar
Quoted: 231 Post(s)
Liked: 41
Thanks for the reply. We recently had an offer from TW via our HOA, pretty good deal, app 75% here signed up for 5 years. The TW PQ, even for SD is awfull, lots of pixellation. HD is better but it takes 8 sec or so to change channels. So I am getting basic service and pay app $20 more than my neighbors while waiting for FIOS TV. Very happy with FIOS internet.
Eugene
post #115 of 270 Old 07-28-2008, 05:14 PM
PO BUG's Avatar
SEGUNDO, Calif., Jul 28, 2008 (BUSINESS WIRE) -- DIRECTV, Inc., the nation's leading satellite television service provider, continues to strengthen its HD presence with the addition of 44 new HD local channel markets. By the end of 2008, DIRECTV will provide local HD broadcast channels in 121 cities, representing more than 88 percent of U.S. TV households. DIRECTV will begin the rollout of the new HD local markets in August and continue through the end of the year. The new markets include:
-- Augusta, Ga. -- Harrisonburg, Va.
-- Bangor, Maine -- La Crosse-Eau Claire, Wis.
-- Baton Rouge, La. -- Little Rock-Pine Bluff, Ark.
-- Beaumont-Port Arthur, Texas -- Lincoln-Hastings, Neb.
-- Boise, Idaho -- Macon, Ga.
-- Burlington, Vt.-Plattsburgh, N.Y. -- Mobile AL-Pensacola, Fla.
-- Butte-Bozeman, Mont. -- Myrtle Beach-Florence, S.C.
-- Champaign-Springfield-Decatur, Ill. -- Norfolk-Newport News, Va.
-- Charleston, S.C. -- Palm Springs, Calif.
-- Chattanooga, Tenn. -- Peoria-Bloomington, Ill.
-- Colorado Springs-Pueblo, Colo. -- Richmond-Petersburg, Va.
-- Columbia-Jefferson City, Mo. -- Rockford, Ill.
-- Davenport, Iowa-Rock Island, Ill., -- Rochester, N.Y.
Moline, Ill.
-- Dayton, Ohio -- Savannah, Ga.
-- Des Moines-Ames, Iowa -- Sioux Falls, S.D.
-- Dothan, Ala. -- South Bend-Elkhart, Ind.
-- El Paso, Texas -- Springfield-Holyoke, Mass.
-- Evansville, Ind. -- Syracuse, N.Y.
-- Fort Smith, Ark. -- Tallahassee, Fla.
-- Fort Wayne, Ind. -- Toledo, Ohio
-- Greenville-New Bern-Washington, -- Traverse City-Cadillac,
N.C. Mich.
-- Harlingen-Brownsville, Texas -- Youngstown, Ohio
PO BUG is offline
post #116 of 270 Old 07-29-2008, 05:47 AM
bgooch's Avatar
Bob Barlow named top executive of Time Warner Cable's desert cities division
Staff
The Desert Sun
Bob Barlow, a former top executive of Time Warner Cable's desert cities division in California, has been named president of the company's San Diego division.
A 28-year cable industry veteran, Barlow will be responsible for broadband operations in the San Diego area, plus the Desert Cities division that includes the Coachella Valley, Banning and Yucca Valley areas. Just before his appointment to the San Diego post, Barlow had been president of the South Carolina division of Time Warner.
While in the desert, he led the integration of the Palm Springs and MediaOne Palm Desert cable systems into one operating unit. Barlow also worked on the merger of two separate cable companies into one unit as vice president and general manager of the Pinellas County, Fla., region.
Samsung 55” Class UHD HU8550 FXZA (8 bit panel) TV
Denon AVR-X4000
Synergy F-10 Premium Floor-standing & C-20 Center Speakers
TiVo Roamio Plus DVR
Sony Blu Ray BDP-S470
Samsung CY-SUC10SH1/ZA UHD Video Pack
bgooch is offline
post #117 of 270 Old 08-16-2008, 02:36 PM
stanruth's Avatar
Just installed AM 21 off the air tuner to Directv HD DVR 21
Works fine but only able to receive 4 stations
ABC over 15.1, NBC over 36.1. Prior to updating to new HD DVT, was able to receive Fox, but not now, 33.2 shows weather only.
Any suggestions. thanks
stanley
stanruth is offline
post #118 of 270 Old 09-04-2008, 03:34 PM
John McKee's Avatar
I found the following OTA stations in South Palm Springs 09.04.08
I’m using an EyeTV HDHomeRun Tuner with an inside antenna..
KMIR - DT 36-1 NBC
KUNA-DT 15-1 Spanish
KESQ - DT 42-1 ABC
KESQ-DT2 Weather
KDFX-DT 33-2 FOX
KCWQ-DT 2-3
John McKee is offline
post #119 of 270 Old 09-26-2008, 12:35 PM
Weaselboy's Avatar
Looks like Time Warner Desert Cities added following HD channels yesterday.
Discovery Channel HD
Animal Planet HD
CNN-HD
post #120 of 270 Old 09-28-2008, 04:19 AM
gwise96557's Avatar
For an interesting read on the over the air transition on the Palm Springs stations go to KESQ.com and check out the Bob's Blog portion on their web site. He explains that a lot of it depends on coordination with Mexico and what a challenge that it can be. An interesting note is that KVMD 29 palms wants to move to channel 50 and boost their power to 500 KW. I dont think that did their reshearch well or they would have noticed that MY 13 KPSE is on that channel and have applied quite some time ago for a Flashcut and power boost to 13 KW on that same channel. Will be interesting to see. Also KESQ will boost to 100 KW and KMIR is doing a 10 fold power increase to 120 KW. I hope that doesn't cause any over load issues on my Channel Master 4228 about 39 Miles away afert Feb 17th Now back to my grainy AFN low def TV pictures at Kwajalien
