Dallas, TX - HDTV - Page 218 - AVS Forum | Home Theater Discussions And Reviews
 68Likes
post #6511 of 8692 Old 02-09-2012, 07:08 AM
rakstr's Avatar
Quoted: 127 Post(s)
Liked: 64
Originally Posted by blueapplepaste View Post
It did help!! I'm not so much sure that the antenna is necessarily better than the mohu or CS2, but because of its low profile/size I was able to put it directly on a window sill so that was facing outwards. The CS2 and Mohu weren't really conducive to that, as I didn't want either of those those directly blocking the window (and the wife wasn't too keen on that either!).
Right now I have the wineguard facing east-northeast out of the window towards the building across the street from me. That building has a fairly unobstructed view, so I'm guessing I'm getting a good reflection or something off that building.
Needless to say, I'm getting FOX, NBC, ABC, CBS, and KERA (the ones I care about) nice and clear. Overall I have fewer channels, but I didn't really care about the Korean and Mexican channels, so doesn't bother me.
Signal strength is only ~60% for them all, but its holding there and the signal quality is great. So hopefully this will last and be the solution...
UNFORTUNATELY, as Dallas heats up, the humidity changes, ........., the reflection patterns are likely to change dramatically. You've got your plate full on this one but we all wish you the best of luck!!!!!!!
rakstr is offline
post #6512 of 8692 Old 02-09-2012, 08:27 AM
blueapplepaste's Avatar
Yeah, you're probably right, but for now I'm going to enjoy it!!
blueapplepaste is offline
post #6513 of 8692 Old 02-09-2012, 09:44 AM
K5ING's Avatar
*** snip ***
I'm not sure what kind of stations you're interested in, but we have several retro tv stations here too. HOT-TV (31.3), RTV (31.4), Antenna TV (33.2) and soon ME-TV (47.1?) all show stuff from the 50's and 60's. Highway Patrol, Sea Hunt, Bonanza, Burns & Allen, Jack Benny, McHale's Navy, Dick Van Dyke, etc., etc., etc. The ones on 31 are from a low power station in DeSoto, but I get them fine up here west of Denton. HOT-TV also shows on 26 and another station that slips my mind right now.
Far out in the uncharted backwaters of the unfashionable end of the south-western quadrant of the Greater Krum, TX  Metropolitan Area.
73, K5ING (Jeff)
K5ING is offline
post #6514 of 8692 Old 02-10-2012, 10:32 AM
JHBrandt's Avatar
Quoted: 1792 Post(s)
Liked: 860
Don't forget KFWD/52 also airs classic TV
Oh, and just in case one of these works better than the others, Hot-TV is also shown on KODF/26 and KATA/50.4. All three are low-power broadcasts from Cedar Hill, though. The OP probably doesn't get them reliably, due to having to receive the signals indirectly; but he probably does get KDAF/33 and KTXD/47 reasonably well (although he may have deleted 47 since right now it's just infomercials, religious, and Spanish-language programming).
I'll post back when Me-TV starts to remind everyone to rescan and/or add 47.1 back to their channel lineup.
JHBrandt is offline
post #6515 of 8692 Old 02-10-2012, 10:57 AM
JHBrandt's Avatar
Liked: 860
The big problem with hot weather is that a layer of hot air forms near any solid surface that faces the sun, which refracts signals arriving at a low angle (the mirage effect). Depending on what they're bouncing off of, this could make signals change throughout the day (and also evening as those surfaces cool down again), resulting in the dreaded "fading." Or he could be lucky and things won't be affected much. There's no way to know until it happens.
JHBrandt is offline
post #6516 of 8692 Old 02-10-2012, 12:23 PM
rakstr's Avatar
Quoted: 127 Post(s)
Liked: 64
Yes, I should have included Mr. Refraction as well
rakstr is offline
post #6517 of 8692 Old 02-13-2012, 08:56 AM
nukeboy67's Avatar
Quoted: 12 Post(s)
I have a 3020 too and love it, even though it's overkill for my location. I was looking at a 3018 at Fry's but thought, "the 3020 is only $10 more; why not?"
It'd be a good choice for HateNewNHL's granddad, except since he doesn't need VHF-Lo frequencies, I'd go with the smaller (thus easier to keep up in bad weather) 2020 instead. I edited my response above to include the 2020 as an option.
Since Dallas has hot days and very cold nights. (This winter is wacked out) My 3020 has been through it all and my other smaller antenna, the VU-90 shown it more than the 3020. 80 mph winds can move the dipoles back on the VU-90 and on 3020, I have more worries with that one than its dipoles moving back like for instance, when TS Hermine popped on through and gave us 12 straight hours of 60 mph winds. I was afraid of it blowing down with no guy wires. After that, we put up guy wires since it was high up.
Forecaster for Decatur, Texas Storm Team
nukeboy67 is offline
post #6518 of 8692 Old 02-23-2012, 10:29 AM
JHBrandt's Avatar
Liked: 860
Warm day today. (Groundhogs is so stupid) Everything still working OK for you?
JHBrandt is offline
post #6519 of 8692 Old 02-28-2012, 02:26 PM
Alan Curry's Avatar
Hi All,
I haven't posted in awhile. I moved recently and what a difference it makes just moving a few miles. Where as I could get a signal using rabbit ears in the attic, this location is a different beast. I know that I will need to mount an antenna on the roof. I just wanted to get the groups opinion on my tvfool plot. Note, that the ALG is set a 25 ft.
Alan
Alan Curry is offline
post #6520 of 8692 Old 02-28-2012, 06:09 PM
Dr L's Avatar
RabbitEars lists a 34-76. I can get 34-2 & 32-3 but my Vip222k doesn't show a -76. Does anyone see -76? I would expect if you have one CH34 you would get all, unless a model just doesn't work beyond -9? And why would they go to a -76 when -1 is empty?
Dr L is offline
post #6521 of 8692 Old 02-28-2012, 06:23 PM
Trip in VA's Avatar
Quoted: 857 Post(s)
Liked: 255
Send a message via AIM to Trip in VA
It's actually 34-768 but my site code doesn't handle display channels that long.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
post #6522 of 8692 Old 02-28-2012, 06:35 PM
ed_in_tx's Avatar
Quoted: 211 Post(s)
Liked: 89
- Trip
I think 34-768 "audio only" went away about a week ago or so. Have not been able to tune it in since.
ed_in_tx is offline
post #6523 of 8692 Old 02-28-2012, 07:29 PM
Trip in VA's Avatar
Quoted: 857 Post(s)
Liked: 255
It wasn't audio only, it was actually MPEG-4 HD video.
- Trip
N4MJC
RabbitEars
post #6524 of 8692 Old 02-28-2012, 07:42 PM
ed_in_tx's Avatar
Quoted: 211 Post(s)
Liked: 89
Everything I have that received 34.769 indicated Audio Only program. That's what I was going by.
ed_in_tx is offline
post #6525 of 8692 Old 02-28-2012, 08:17 PM
Trip in VA's Avatar
Quoted: 857 Post(s)
Liked: 255
Most TVs and tuners cannot decode MPEG-4, so that's not a surprise. You can see the MPEG-4 video noted in this TSReader data: http://www.rabbitears.info/screencap.../26957-0_0.htm
- Trip
N4MJC
RabbitEars
post #6526 of 8692 Old 03-02-2012, 09:47 AM
K5ING's Avatar
Just curious if ME-TV has signed on yet. I'm out of town right now and can't tell, but Neal Sabin told me a couple of weeks ago that March 1st was the sign in date. Should be on 47.1 if I'm not mistaken.
73, K5ING (Jeff)
K5ING is offline
post #6527 of 8692 Old 03-02-2012, 11:31 AM
JHBrandt's Avatar
Liked: 860
Still infomercials as of last night (3/1). I heard it's been pushed back to Monday (3/5) but I'll be checking throughout the weekend.
JHBrandt is offline
post #6528 of 8692 Old 03-05-2012, 11:19 PM
mp3trojan's Avatar
Did anyone notice the dropouts on KDFW HD D* LiL last night around midnight ? it was unwatchable. I am convinced that D* is pulling the signal off the air and being fed to D*. How am I convinced? I live out in the fringe areas and at night I have real diffuiculty getting 4, 8, 13, and 33. 8 and 13 being the worst. At the time of the dropouts I switched over to the OTA it was dropping out too. My antenna is the old school CM deep fringe antenna Don't know the model with a CM7777 preamp on a 40ft tower. My house sits on the tallest point on I-30 between Dallas and Little rock. When I'm up the tower, I can see into 3 counties. Hunt, Hopkins and Rains. I can see the Point TX cell tower, at night (if that counts).
COMCAST (Denver)
mp3trojan is offline
post #6529 of 8692 Old 03-06-2012, 12:14 AM
re_nelson's Avatar
Quoted: 27 Post(s)
KDFW was on their backup transmitter until around 4 AM. On occasion, they do so on Sunday mornings.
re_nelson is offline
post #6530 of 8692 Old 03-06-2012, 08:26 AM
K5ING's Avatar
Is anyone having trouble with Ch. 31 lately? I did a rescan yesterday and lost it all together on my main digital television. My other two, using converters, still showed it until I tried to do a rescan of one of them. That one now only shows 31.1 with a "no service" message.
The converter I left alone still has 31.4 (RTV) and will show a signal on 31.3, but says "no service". Signal strength is fairly good at around 70-73%. I usually don't have issues unless it falls below 60%.
After several hours of messing with it last night, I thought I'd check and see if anyone else was having problems with it too before pulling any more of my hair out.
73, K5ING (Jeff)
K5ING is offline
post #6531 of 8692 Old 03-06-2012, 10:27 AM
JHBrandt's Avatar
Liked: 860
*Sigh* Still infomercials as of Monday evening. Actually doesn't totally surprise me, but I wish they'd quit announcing dates before they're sure they can meet them.
Anyone heard a new ETA for Me-TV on KTXD/47?
JHBrandt is offline
post #6532 of 8692 Old 03-06-2012, 12:26 PM
K5ING's Avatar
I just heard from Neal Sabin of ME-TV, and he told me that the station here is experiencing some "internal equipment issues", and he has been told ME-TV should be on the air here tomorrow (Wed), but "as in the past, that may change".
BTW, all is right with Ch. 31 now. Just before noon, I went from getting 31.4 and no service on 31.3, to getting 31.3 and just black screen and buzzing from 31.4. At around noon, the signal went up and both 31.3 and 31.4 came in great, and scanned into my sets and converters.
I'm guessing they were doing repairs or maintenance on the transmitter.
73, K5ING (Jeff)
K5ING is offline
post #6533 of 8692 Old 03-11-2012, 11:33 AM
pdh0490's Avatar
i dont thank ktxd has any plains of going to metv they would be givieng up to much of a good thing they are makeing tons of money off of what they are doing right now thank about it ppl pay them to be on there ch why go to something where they are not paying
pdh0490 is offline
post #6534 of 8692 Old 03-16-2012, 02:03 PM
K5ING's Avatar
Good news everyone.... Sometime today, ME-TV signed onto Ch. 47.1 in Dallas. It wasn't on earlier today, but around 4pm I surfed over there and "The Rockford Files" playing with Me's logo in the corner of the screen. It looks like they finally solved their equipment problems.
73, K5ING (Jeff)
K5ING is offline
post #6535 of 8692 Old 03-16-2012, 02:18 PM
ed_in_tx's Avatar
Quoted: 211 Post(s)
Liked: 89
Well I can do without the obnoxious 'MeTV' bug. I have to commend AntennaTV for not contaminating the image. Hopefully KTXD will submit their program info so it will show up in the TVGOS.
ed_in_tx is offline
post #6536 of 8692 Old 03-16-2012, 02:26 PM
K5ING's Avatar
Are you getting a strange aspect ratio on 47? I'm watching "Rockford Files", and while it's not 4:3 like it should be, but it's not quite 16:9 either. It looks zoomed in (the tops of their heads look cut off). I've double checked the settings on my TV. Does it look that way to you too, or is it just me?
73, K5ING (Jeff)
K5ING is offline
post #6537 of 8692 Old 03-16-2012, 02:39 PM
ed_in_tx's Avatar
Quoted: 211 Post(s)
Liked: 89
I have narrow black bars on the sides, like an in-between ratio.
ed_in_tx is offline
post #6538 of 8692 Old 03-16-2012, 02:50 PM
pdh0490's Avatar
i have the black on both sides to i hope they fix it and as far as the metv bug i like it :-) am glad we got metv !!!
pdh0490 is offline
post #6539 of 8692 Old 03-16-2012, 06:35 PM
K5ING's Avatar
I just noticed...47.1 has the strange aspect ratio and is showing it's 1080i HD, however 47.4 is also showing MeTV, and has the proper 4:3 aspect ratio and 480i SD.
I was told that they are still dealing with issues at the local level.
73, K5ING (Jeff)
K5ING is offline
post #6540 of 8692 Old 03-16-2012, 07:49 PM
re_nelson's Avatar
Quoted: 27 Post(s)
There's some cropping on 47-1. Nevertheless, what I presume is a new exciter must be online. Their MER has never been better. It's an invariant >36.0 dB.
I never thought they'd go with general market programming like this. I hope it works out for London.
