Dallas, TX - HDTV - Page 255 - AVS | Home Theater Discussions And Reviews
 15Likes
post #7621 of 7633 Old 01-20-2015, 07:48 PM
PlnOTA's Avatar
Pulling in K31GL fine here in Plano. Same signal as usual, give or take a few percent.
PlnOTA is offline
post #7622 of 7633 Old 01-20-2015, 08:57 PM
JHBrandt's Avatar
Quoted: 331 Post(s)
Liked: 235
Whatever it was, K31GL seems to be straightened out and working OK now.
Although I'll repeat this once again, in case anyone reading is in a position to do something about it: with all the simulcasts among channels 26, 28, 31, and 50, why can't we get a simulcast of Retro TV on another station so we have a backup when things like this happen?
Whoops-by the way, I just checked 26.2 and Soul of the South is off the air, replaced by color bars! What up?
JHBrandt is online now
post #7623 of 7633 Old 01-21-2015, 03:18 PM
Liked: 0
Update: Yes K31GL finaly came back for me last night. But I had to do a scan about 3 times before I was able to grab it. Thanks to all that replied to my original post!
Norman Fisher is offline
post #7624 of 7633 Old 01-29-2015, 10:17 PM
Liked: 0
Hi Gents,
New to the forum read some great reviews. I need some help with antenna recommendation or suggestions to receive channels from the DFW Cedar Hill antenna farm. Open to any combination, single, yagi, bowtie, large, or small antennas. I plan on mounting the antenna(s) outdoors. Coaxial cable length will be approximately 75 - 100ft long.
Attached is my TVFool report.
Thank You for your assistance and any response.
BowtieYagi is online now
post #7625 of 7633 Old Yesterday, 07:27 AM
ed_in_tx's Avatar
Quoted: 55 Post(s)
Liked: 65
At a distance of 80-90 miles or so, you are likely going to have problems with any big antenna. Maybe nukeboy has a suggestion, since he's in Decatur. I was going to suggest Antennacraft's biggest longest range HD1850, but on UHF doubt that would even do it.
ed_in_tx is offline
post #7626 of 7633 Old Yesterday, 09:03 AM
bglf83's Avatar
Liked: 0
It's a little over 60 miles to Cedar Hill from my house in Anna Tx, I get all the channels fine with a Winegard Hd7698p and a Boost xt preamp.
Do you have any kind of antenna now?
Might try a similar antenna with a channel master cm777, but you are 5 to 10 miles farther out than me.
--- I take it back, I pulled the Tv fool report for my house and the DFW broadcasts are alot higher levels at my house than yours are. Distance is similar but all my stations are LOS.
bglf83 is online now
post #7627 of 7633 Old Yesterday, 11:36 AM
crackedscreen's Avatar
Originally Posted by BowtieYagi View Post
Hi Gents,
For CBS and NBC, it looks like you'll have better luck aiming for Wichita Falls. Do you specifically want stations from DFW?
crackedscreen is offline
post #7628 of 7633 Old Yesterday, 01:39 PM
JHBrandt's Avatar
Quoted: 331 Post(s)
Liked: 235
I see; Alvord is about halfway between Cedar Hill and Wichita Falls. There are more stations in the DFW direction, but it's going to take a big antenna. Does CM still sell the CM3671? It's huge and expensive but probably your best bet. Winegard's HD7698 might also do it, but not with as much margin of error.
Might see if you can get higher than 25 feet too.
BTW, it looks like @bglf83 's spell checker mangled "Winegard"
post #7629 of 7633 Unread Yesterday, 10:24 PM
Liked: 0
@ed-in-tx.
I was thinking to aim for the Cedar Hillsantenna farm at about 61-70 miles. Ilike the recommendation of biggest and longest Antennacraft’s HD1850. Thanks
@ Bglf83.
Glad you gave me a distance point ofreference and type of antenna – Winegard HD7698P and preamp. Good to hear you receive all channels.
Yes, aCM-4228HD (8 Bay) However, just arrived and I think it was dead onarrival. It looks like it could havebeen a used or return item – box arrived open, holes in it, bent top deflector,missing 2 hardware bolts, and partially assembled. I tried to scan for channels on two differentTV tuners, with 4 different length coax cables and received zero channels. Maybe I should have received something. I don’t know the condition of thisantenna. The balun could be defective?
Good point, our distance is about the same,but I may not be line of sight as you are.
@crackedscreen
I would prefer the DFW channels overWichita; more channels and a little closer.
@JHBrandt.
Good question about the CM3671Crossfire and yes its huge. Did somesearch’n and they might have it.
Gents, givenyour response, experience, and recommendations; did some searching of them and belowis list of 4 Gi-Normous Huge antennas with some specifications. What doyou think about them? Do I need or can I receive VHF -Lo? Looking forward to your thoughts. Thanks
Channel Master 3671 Crossfire
Receptionrange:
61 Active Elements
UHF - 60Mile, VHF/FM - 100 Miles ,
Dimensions: 173” Boom x 110 x 35.4 in.
Weight: 17 lbs
Winegard HD8200U Platinum
69 ActiveElements: 34 VHF & 35UHF
UHF – 60+miles; VHF – 100 miles
Gain - 14. 2dBi
•Gain:Average: 2-6 ch: 5.9dB / 7-13 ch: 11.5dB / 14-69 ch: 13.3dB
Dimensions –168.25” Boom x 110”Wide X 33” Height
Weight: 16 lbs
Winegard HD7698P
Active Elements: 64
•Less Windloading
•EstimatedRange: 70 miles VHF & 60 miles UHF
•*Note: Thisantenna can receive stations 2-6 in most areas due to the fact they aregenerally broadcast on higher unused UHF or VHF frequency numbers in the area.Our techs can verify this with your zip code information
•UHFElements: 35
•VHFElements: 29
•BoomLength: 168.25"
•MaximumWidth: 53.5"
•VerticalHeight: 33"
AntennaCraft HD1850
•ExtremeDeep Fringe UHF/VHF/FM TV Antenna
•84 ActiveElectronic Elements
•180"Boom Length
•Max Width:112"
•VerticalHeight: 38"
•TurningRadius: 102"
•UHF Range:60+ Miles (Ch. 14 - 69)
•VHF LowRange: 100+ Miles (Ch. 2 - 6)
•VHF HighRange: 100+ Miles (Ch. 7 - 13)
post #7630 of 7633 Unread Today, 10:07 AM
ed_in_tx's Avatar
Quoted: 55 Post(s)
Liked: 65
@ed-in-tx.
If that's the distance probably any of the above would work. I had Google Maps using their scale, measuring the distance between Alvord and Cedar Hill. Looked more like 80-90 miles. Height is what you need. You know what the elevation above sea level is there at your location?
I had better luck with Antennacraft's UHF design, a folded dipole driven element that I think their big daddy antenna has too, hard to see in the pics online. Vs. a new Winegard I bought to replace it, of similar specs and size, which had a good 10-15 count less signal received than the old Antennacraft which was simply outperforming the Winegard. So out with the new, in with the old! I'm about 26-27 miles from Cedar Hill and I have lots of ground clutter between here and there.
ed_in_tx is offline
post #7631 of 7633 Unread Today, 12:11 PM
JHBrandt's Avatar
Quoted: 331 Post(s)
Liked: 235
Looks like the Antennacraft is in a league of its own. 84 active elements?!? Also the longest at 15 feet
The Winegard HD7698P is narrower due to the lack of VHF-Lo elements. Cedar Hill doesn't have any VHF-Lo TV stations, so it would probably work OK for now; but that may change after 2016 when the FCC is expected to chop another 17 UHF channels or so off the TV band. (VHF-Lo may be the only place left for LPTV.) You may also want an antenna with VHF-Lo elements for FM radio.
Make sure you get a good low-noise preamp too. I've had good luck with a Winegard Boost! preamp, but at your distance you may do better with a Kitztech KT-200 (although that's not built for outdoors).
post #7632 of 7633 Unread Today, 05:31 PM
Liked: 0
I see nowthat you used Google Maps for measuring distance. Checked some elevations above sea level:
Alvord - 879ft,
Decatur - 1,100ft
Cedar Hills -830 ft
TV stationsfrom this hill - most around 480 meters(1,500ft) tall.
Glad youexplained your experience with the Antennacraft and Winegard’s performancechararcteristics.
I’m not sureI completely understand the difference in folded dipole driven elements VSother types of elements? Can you sharethe model # of the AntennaCraft and Winegard you compared?
post #7633 of 7633 Unread Today, 05:49 PM
Liked: 0
Yep, theAntennacraft is the big Kahuna. I likethe fact that the Winegard HD7698P is narrower due to the lack of VHF-Loelements. Good point about “Cedar Hilldoesn't have any VHF-Lo TV stations, so it would probably work OK for now; butthat may change after 2016 when the FCC is expected to chop another 17 UHFchannels or so off the TV band.” For VHF-LO,if there are not any channels available, then I may not need it. But, if there was an off chance to receive VHF-Lofrom an unknown source or help with gain in the other bands.
Would the antenna with VHF-Lo elements for FMradio be displayed/heard on the TV?
Updated someof the characteristics of the discussed antennas:
Receptionrange: UHF - 60 Mile, VHF/FM - 100 Miles ,
61 ActiveElements ( made from aircraft-grade aluminum)
Gain: VHF-lo 5.6 db / VHF-hi 10.9 db / UHF 10db
Weight: 17 lbs
69 ActiveElements: 34 VHF & 35 UHF
Gain - 14. 2dBi
•Gain Average: 2-6 ch: 5.9dB / 7-13 ch: 11.5dB / 14-69 ch: 13.3dB
*Front-to-backRatio: 14dB(CH2) / 20dB(CH4-13) / 18dB(CH14) / 20dB(CH32-50)
Weight: 15lbs
Winegard HD7698P
*Hassuperior polar plots
•ActiveElements: 64
•Less Windloading
•UHF – 35elements •VHF – 29 elements
*Gain VHF -12.6 dB / UHF - 14.2 dB
•BoomLength: 168.25" x •Width: 53.5" x Height: 33"
AntennaCraft HD1850
•180"Boom Length
•Max Width:112"
•VHF Low:100+ Miles (Ch. 2 - 6)
•VHF High:100+ Miles (Ch. 7 - 13)
* Gain - VHFLow 6.2 dB / VHF High: 10.7 dB / UHF: 10 dB
● Front-to-Back Ratio - VHF Low: 20.2 dB/ VHF High: 17.3 dB / UHF: 13.7 dB
Weight: 16lbs
AntennaCraft (HD1800)
•L 180"W 112" H 38"
•69Electronic Elements
•OutputImpedance: 300 Ohms
•Mileage VHFLow: 100+ Miles VHF High: 100 Miles UHF: 60+ Miles
•Gain - VHFLow 6.2 dB / VHF High: 9.4 dB / UHF:10.0 dB
•Front-to-BackRatio - VHF Low: 20.2 dB / VHF High: 17.3 dB / UHF: 13.7 dB
Weight: 15lbs
