Dallas, TX - HDTV - Page 289 - AVS Forum | Home Theater Discussions And Reviews
 66Likes
post #8641 of 8646 Old Yesterday, 05:30 PM
schultdw's Avatar
Quoted: 29 Post(s)
Originally Posted by ed_in_tx View Post
No reason the LG should be that way unless it has a defective VHF tuner section.
This assumes that it has separate VHF and UHF tuners. Tuner chip sets tend to be all in one affairs these days.
Signal loss in coax cable depends on frequency so there is less loss at VHF frequencies, making it more likely that you could overload the RF front end. There are a number of ways to test that idea. I keep some attenuators around for just this purpose. Just as easy is to connect a really bad antenna, like a 3 foot wire, to the input.
I just tried that here and WFAA came in fine.
schultdw is offline
post #8642 of 8646 Old Yesterday, 05:49 PM
ed_in_tx's Avatar
Quoted: 207 Post(s)
Liked: 88
Yep they don't make'em like they used to. The few integrated tuner chips I have looked at will probably have some sort of VHF low-VHF high-UHF band filtering.
For example if something was defective between pins 32 and 33 the VHF High tracking filter circuit ...
ed_in_tx is offline
post #8643 of 8646 Old Yesterday, 08:14 PM
Liked: 0
Thanks guys. I'll report back tomorrow. The amp is separate, so I'll disconnect in the morning. I'm also tempted to go to a nearby big box and see if they can get WFAA digital. If they can't, it would indicate a failure with these units. If they can receive on their set, my tuner is bad.
How do I post tvfool? Do I post a screen shot, or post a link?
Thanks again!
texski is offline
post #8644 of 8646 Old Yesterday, 08:24 PM
JHBrandt's Avatar
Quoted: 1719 Post(s)
Liked: 847
Thanks again!
Either one will work but the link is easier. Once you bring up your TVFool.com report, the link should be right there on the page in bold, ready to copy and paste. Here's mine, for instance: http://www.tvfool.com/?option=com_wr...e6a4c6b638ccf8
That hex string on the end encodes your address, so you can share a TVFool report for your exact location without revealing it to the world.
texski likes this.
JHBrandt is offline
post #8645 of 8646 Old Today, 09:14 AM
ed_in_tx's Avatar
Quoted: 207 Post(s)
Liked: 88
Did you happen to notice if the LG added 28.x and 52.x channels? They transmit on VHF high like Ch 8.1.
ed_in_tx is offline
post #8646 of 8646 Old Today, 02:32 PM
JHBrandt's Avatar
Liked: 847
He mentioned "DTV 9;" I took that to mean it didn't add 52.x:
Just a couple of days ago I bought this OLED and was hoping you all might be able to shed some light. I hooked this up to my attic antenna and this LG will not auto tune or manually recognize 8.1, 8.2, 8.3 or dtv 9.
... unless maybe he was looking for some 9.x channels?
JHBrandt is offline
