Dallas, TX - HDTV - Page 291 - AVS Forum | Home Theater Discussions And Reviews
 68Likes
post #8701 of 8707 Old 10-21-2017, 03:50 PM
ed_in_tx's Avatar
Quoted: 212 Post(s)
Liked: 89
KVFW 38, back to "0". So much for that!
ed_in_tx is offline
post #8702 of 8707 Old 10-21-2017, 04:35 PM
schultdw's Avatar
Quoted: 35 Post(s)
It must be something local as the signal strength is unchanged here and I can see Dr. Who. The Pertwee incarnation anyway.
schultdw is online now
post #8703 of 8707 Old 10-22-2017, 07:46 AM
schultdw's Avatar
Quoted: 35 Post(s)
I added overrides and it helped three stations including RF38 (KVFW) but not RF10.
https://rabbitears.info/tvdx/signal_...tuner0/KVFW-LD
The dropouts are a problem on the server side. Perhaps overload of the database engine.
post #8704 of 8707 Old 10-22-2017, 10:21 AM
JHBrandt's Avatar
Quoted: 1803 Post(s)
Liked: 863
Excellent! Since you have custom code, I assume you had to modify it.
Out of curiosity, which approach did the trick: forcing the call letters into virtual program 1, or adding the "reporter-callsign" tag?
I've been noticing those in my own data for the past couple of weeks. They come and go. At least now I know it's not just me.
I mentioned them to Trip because I was worried my tuner was going out. He told me the site was looking at possibly revamping the server-side software. Hopefully they can come up with an approach that solves that issue.
JHBrandt is offline
post #8705 of 8707 Old 10-22-2017, 11:13 AM
schultdw's Avatar
Quoted: 35 Post(s)
Originally Posted by JHBrandt View Post
Out of curiosity, which approach the trick: forcing the call letters into virtual program 1, or adding the "reporter-callsign" tag?
Special tag.
post #8706 of 8707 Old 10-22-2017, 06:24 PM
JHBrandt's Avatar
Liked: 863
Special tag.
OK, great. So for those with the "stock" script, the command-line override should work.
Turns out the Windows version has the same command-line override. I just installed overrides for KWDA, KODF, KJJM, KVFW, and KLEG and they're working. As you noted, trying to override RF 10 doesn't work, probably because the server cross-checks the channel/call sign pairs against a database that still lists KHPK on RF 28.
If you see a green or yellow number in the rightmost column, that station is watchable at my home, but a few such stations aren't identified by their call letters at the link above. (I think Trip may have a fix for this, though, since Bob's scan does somehow manage to identify those stations.)
Originally Posted by Trip in VA View Post
Bob is running the Linux build and custom modified his code to identify those stations at least some of the time. I do not have those modifications.
- Trip
Good news if this comes up again: both the Linux Perl script and the Windows executable support a command-line option to deal with this issue. The syntax is:
-o 10,KHPK,21,KWDA, etc.
JHBrandt is offline
post #8707 of 8707 Old Yesterday, 06:07 AM
ed_in_tx's Avatar
Quoted: 212 Post(s)
Liked: 89
You may be right on the local interference. Whatever is causing it, wipes out the signal down to 0-52-55-0 which isn't good enough to get a lock. Maybe Rent a Center has a spectrum analyzer I can rent..
ed_in_tx is offline
