Sacramento, CA - SureWest - Page 33 - AVS Forum | Home Theater Discussions And Reviews
Old 11-17-2013, 07:57 PM
mgsports's Avatar
Yes they do but it's only ASIA and ZEETV. You have Applications channels in 9OO and KC area doesn't yet and other SD and HD Channels that KC will evently get.
mgsports is offline
Old 11-17-2013, 10:29 PM
HINOHI's Avatar
Is FUNimation Channel HD available with SureWest?
HINOHI is offline
Old 01-09-2014, 04:32 PM
macdawg's Avatar
Zeke, don't know if you are still following this thread, however I am considering switching over to Surewest from DirecTV and currently use W7 Mediacenter as my DVR program. Do you know if IP channel changing is possible with the Surewest mediaroom 2.0 set top boxes (or if not if there is another more reliable method than IR). I am also very intrigued by your post discussing bringing the IPTV signal right into mediacenter. I found a mythtv forum that discusses how to potentially do this, but have no idea how to do this for mediacenter under windows.
Also, does anyone know if you can get just a HD receiver without the DVR functionality and or the requirement to pay the DVR service? I'm going to be calling them soon to see what I can find out so far as the cost and availability of programming and receivers.
Any info you or anyone else could share would be appreciated.
macdawg is offline
Old 05-27-2014, 02:26 PM
carealtor's Avatar
Will a "Ethernet over Powerline adapter" work with Surewest? Thinking of putting a TV in the garage, but there is no Cat5 or coax installed. What about some kind of WiFi solution? Thanks.
carealtor is offline
Old 05-29-2014, 11:24 AM
GUERiLLAPUNK^MOB's Avatar
Do you have SureWest TV service already? Are the boxes you have right now ran with Ethernet? If so, you need a HomePNA adapter if you want to use coax, otherwise you would have to run Ethernet to the garage. Regarding Ethernet over Powerline, it might work, depending on the quality of the Romex and distance. It might not have enough bandwidth.
BMW E46 | Brembo | Technik | HRE | Toyo | Meguiar's | AC Schnitzer | Alpine | Alumapro | H&R| Porsche | ASA | MOMO | Rogue Engineering | Rennsport | Hamann | Supersprint
GUERiLLAPUNK^MOB is offline
Old 05-30-2014, 05:26 PM
carealtor's Avatar
Yes, I have Surewest TV service already. Yes, the boxes I have now are ran with Cat5. I already have a coax adapter that Surewest supplied, but I'm not using it right now.
Old 06-02-2014, 11:26 AM
Cucuy's Avatar
Quoted: 18 Post(s)
Does surewest run ethernet to install rooms? I was thinking about giving them a try
Cucuy is offline
Old 06-02-2014, 01:51 PM
carealtor's Avatar
From my experience, they will use existing Cat5 or Coax, whichever is available. I don't know what they would run from scratch, but whatever it is, it won't be pretty.
Old 06-03-2014, 07:51 AM
Adinn's Avatar
Is your Surewest ONT box mounted outside your garage? There are 6 LAN ports in the box. If one is free, you can plug in an ethernet cable and run it through the wall in your garage to plug into the set top box. I think I uploaded pics correctly.
Adinn is offline
Old 06-03-2014, 11:25 AM
Cucuy's Avatar
Quoted: 18 Post(s)
Interesting. Never checked this box. Thanks for the pics. My box is inside the garage so it would be a matter of just running the wires thru the attic and then down to the box. I was planning on getting 4 rooms wired with Ethernet cables then adding a switch but it looks like I may have 5 ports unused. Need to check tonight.
I am guessing using these wires may create network havoc if you are sharing and have "another" network already in place.
Cucuy is offline
Old 06-03-2014, 12:56 PM
Adinn's Avatar
Since your box is inside the garage, that will make it easier. Is your wiring setup going to be permanent or temporary? I still have lots of solid copper cat 6 cable.
I have set up a patch panel in a closet, so one cat 6 goes to a switch just for video and another goes to a router then to another switch for internet. I have one network.
I would only use one connection from the ONT for your internet network and the others for TV since video does not need a common switch, but a switch will work too if your house is wired.
Adinn is offline
Old 06-04-2014, 11:01 AM
Cucuy's Avatar
Quoted: 18 Post(s)
I am trying this to be permanent and I have no video services just internet/phone with Surewest. My plan is to have one network to avoid headaches. I was planning to to run a switch after my first current router and then distribute new wire to the new
rooms. I currently have a router with wifi after the ONT that distributes internet to two locations but that is not enough anymore. biggrin.gif One of those locations has another wifi router being used as a bridge only to extend wifi around the house but wifi does
not cut it sometimes.
Sorry about the confusion..
So ONT >> WIFI/ROUTER >> 1 PC
>> living room >> WIFI/BRIDGE >> Dish Hopper
>> Sling Box
>> Blu Ray Player
All of this is wired. Problem is I still have a SmartTV with Netflix and a PS4 in one room on WIFI with streaming ok most of the times, a PS3 in another room on WIFI, and my daughter room with a future streaming device on wifi. Lots of streaming!!biggrin.gif
If I were to do this again I would wire ethernet to every single room when I bought the house many years ago. But who would have known our connected devices were going to explode in usage...
Sorry is this is a little off-topic but there is not much talk in this section so not sure who cares. tongue.gif
GUERiLLAPUNK^MOB likes this.
Cucuy is offline
Old 06-05-2014, 11:31 AM
Adinn's Avatar
If you have a single story home, it would be pretty easy to run ethernet cable. I hired a hanyman to help me with my 2 story. I have ports in every room plus wifi.
Adinn is offline
