Philadelphia, PA - OTA - Page 135 - AVS Forum | Home Theater Discussions And Reviews
 14Likes
post #4021 of 4047 Old 04-21-2016, 03:59 AM
frank70's Avatar
Quoted: 92 Post(s)
Liked: 76
Originally Posted by Ken.F View Post
When I key in 29.3 it just stays on whatever channel is currently tuned. Samsung LN32D450G1D.
Ok, then it's just my TV being flaky - apparently Sony didn't plan on stations with gaps in their subchannel numbering.
Anybody have any clue where channel 10.3 is coming from?
frank70 is offline
post #4022 of 4047 Old 04-21-2016, 04:19 AM
Trip in VA's Avatar
Quoted: 426 Post(s)
Liked: 118
Send a message via AIM to Trip in VA Send a message via Yahoo to Trip in VA
Originally Posted by frank70 View Post
1. WCAU 10 is coming up with 3 subchannels. The third of these, 10.3 is new, is labeled WCAU-DT in the PSIP, is virtually identical to 10.1. However, it is NOT on RF channel 34 as are 10.1 and 10.2, but rather on RF 49. According to rabbitears, the nearest two stations on RF 49 are WWSI in Atlantic City (which comes in as PSIP channel 62 and is two subchannels of Spanish language programming), and W49BE in Hackettstown (which would come in as PSIP channel 52 if I could receive it, but I can't). So it can't be emanating from either of those stations. So what is this new and mysterious phantom WCAU-DT 10.3???
Sounds like they're doing the same thing they do in San Francisco. In San Francisco, the NBC signal on Mount San Bruno broadcasts 11-1, 11-2, and 48-3, while the Telemundo signal on Mount Allison broadcasts 48-1, 48-2, and 11-3. This allows people who have trouble with one signal or the other, since they're not co-located, to be able to receive the missing programming. Given the loss of WMGM as an NBC affiliate, this doesn't seem unreasonable. Keep an eye out in case a 62-3 pops up on WCAU. I've updated RabbitEars under this assumption.
2. WTXF 29 is coming up with 3 subchannels, 29.1, 29.2 and 29.4. Rabbitears indeed reflects this new gap. However, if I manually tune to 29.3, up pops GetTV. But now, once I do that, 29.1 through 29.4 become identical to WUVP 65, and WTXF (FOX 29) is just GONE! The only way to restore WTXF is to ask the TV to scan for new digital channels, after which it will restore WTXF in the 29.1, 29.2, and 29.4 positions. I need to carefully avoid punching in 29.3 because doing so will once again lose me all of WTXF, replacing it with WUVP's 4 subchannels of programming. It seems that WTXF needs to fill in that gap to prevent this odd behavior. Thoughts?
Definitely flakiness in your receiver, as others have clarified. Sony receivers have always been strange about PSIP, in my experience.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
post #4023 of 4047 Old 05-12-2016, 06:09 PM
mvcg66b3r's Avatar
Quoted: 89 Post(s)
Liked: 9
It just did:
http://www.rabbitears.info/market.ph...=63153#station
Name:	WCAU Telemundo.png
James Calvin Woods - Son of Verta Jane Holland
mvcg66b3r is online now
post #4024 of 4047 Old 05-13-2016, 06:31 AM
frank70's Avatar
Quoted: 92 Post(s)
Liked: 76
Originally Posted by mvcg66b3r View Post
Well this has the unfortunate effect of forcing WCAU to broadcast two HD subchannels simultaneously (as WPVI now does with Live Well), eating into the bit rate for the main-market channel and reducing it's PQ. I think OTA TV is headed down the slippery slope of cable TV... lots and lots of low quality channels, not at all what the HDTV initiative was all about.
frank70 is offline
post #4025 of 4047 Old 05-13-2016, 07:54 AM
Ken.F's Avatar
Quoted: 1265 Post(s)
Liked: 1023
If 10.3 is transmitted on RF 49 there shouldn't be any bit rate loss to 10.1 and 10.2 since they are on RF 34.
Ken.F is offline
post #4026 of 4047 Old 05-13-2016, 10:25 AM
frank70's Avatar
Quoted: 92 Post(s)
Liked: 76
No Ken, I was commenting on 62.3 (an HD channel) being transmitted on RF 34 along with 10.1 (also an HD channel). Not being a Spanish speaker, I don't give a hoot about the picture quality on RF 49.
frank70 is offline
post #4027 of 4047 Old 05-13-2016, 11:24 AM
Ken.F's Avatar
Liked: 1023
No Ken, I was commenting on 62.3...
Sorry, I thought you were still talking about 10.3.
Ken.F is offline
post #4028 of 4047 Old 05-13-2016, 11:37 AM
NoReDist's Avatar
It definitely improves Telemundo's reach out here to Chester county, Berks & MD. Many Spanish communities there.
NoReDist is offline
post #4029 of 4047 Old 05-16-2016, 10:12 PM
Agrajag's Avatar
Quoted: 56 Post(s)
Guys, I just got my home theater set up and, as a cord cutter, I picked up the new TiVo Roamio and a Mohu Sky antenna. However, all attempts to get a signal strength above 45 (of 100) has failed. Spent hours adjusting the antenna with no luck. My backyard is overrun with Oak trees which isn't helping.
Is there a place to call (I'm in South Jersey) to have a pro come out and check signal strength and possibly install the best antenna for our needs? If so, who?
Sent from my SM-P900 using Tapatalk
Agrajag is offline
post #4030 of 4047 Old 05-17-2016, 07:09 AM
LastButNotLeast's Avatar
Quoted: 1145 Post(s)
Liked: 796
Antennas such as that are not particularly good.
Do you have access to an attic? Running the cable is the only pita, for which you might want an electrician.
If you need to mount it outside, you'll probably want expert help.
Make sure the antenna can get both high and low vhf (otherwise you'll never get Ch. 6), and aim it at Roxborough.
Something from here would do the trick:
https://www.antennasdirect.com/store/attic.html
Michael
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
LastButNotLeast is offline
post #4031 of 4047 Old 05-17-2016, 09:26 AM
Agrajag's Avatar
Quoted: 56 Post(s)
Last, thanks for the input. Just a bit before you replied I had found the site you mentioned and actually did order a different antenna. I'll be trying this guy in a few days (with a VHF kit applied):
https://www.antennasdirect.com/store...V-Antenna.html
We'll see if that makes a dent.
Agrajag is offline
post #4032 of 4047 Old 05-19-2016, 12:32 PM
Agrajag's Avatar
Quoted: 56 Post(s)
I will say, I'm not having the best experience with Antennas Direct. I could have ordered on Amazon from them and had the antennas already. Instead, they charged me and all they can tell me is "it processed". They have NO way to tell me where the antenna is and it hasn't yet gotten to FedEx. What the heck is that BS? They claimed they'd ship it on Tuesday and now it's Thursday which means I likely won't have it for the weekend now.
Agrajag is offline
post #4033 of 4047 Old 05-25-2016, 11:44 AM
Liked: 796
You should have it by now. Did it work?
BTW, their shipping information clearly states 5 to 7 working days.
We've all gotten spoiled by next day, haven't we.
post #4034 of 4047 Old 05-25-2016, 12:36 PM
Agrajag's Avatar
Quoted: 56 Post(s)
It arrived two days ago and I assembled it yesterday. It goes up on the roof tomorrow, so we'll know the deal then! I have high hopes.
Agrajag is offline
post #4035 of 4047 Old 05-25-2016, 12:41 PM
Liked: 796
Our collective fingers are crossed.
Michael
post #4036 of 4047 Old 05-25-2016, 03:22 PM
frank70's Avatar
Quoted: 92 Post(s)
Liked: 76
Be very patient when aiming the antenna (perhaps you have a rotator, which will make that MUCH easier). Even though you may have a theoretical magnetic bearing to Roxborough, a few degrees this way and that can make a world of difference if you have multi-path problems. The voice of experience.
Good luck!
NoReDist likes this.
frank70 is offline
post #4037 of 4047 Old 05-26-2016, 09:31 AM
Agrajag's Avatar
Quoted: 56 Post(s)
It's in and with very little need for adjustment it's already way beyond the Mohu Sky antenna. The problematic ABC, which was only getting a 37 is at 67-72. Most everything is in the upper 70s or beyond. Incredible.
Agrajag is offline
post #4038 of 4047 Old 05-26-2016, 09:40 AM
Liked: 796
post #4039 of 4047 Old 06-08-2016, 06:58 PM
gregarious119's Avatar
Can anyone else check WPVI tonight and see if your reception is working? I'm getting 100% Signal Strength, but only 40% Signal Quality and 0% Symbol quality. I can usually receive this channel with no problems. Other channels are coming in as normal (watching Copa America at the moment).
Anyknow know the best way to contact the station engineers at this time of night?
gregarious119 is offline
post #4040 of 4047 Old 07-09-2016, 06:40 AM
G-star's Avatar
Hey guys - About to cut the cord. Wondering if someone can recommend a good attic antenna that will pick up hi/lo band VHF and UHF and won't break the bank? From my cursory research, it seems WPVI is a low band station, and I want to be able to receive it.
"That's right Mr. Martini...there is an Easter Bunny".
G-star is offline
post #4041 of 4047 Old 07-09-2016, 07:36 AM
wilbur_the_goose's Avatar
Quoted: 238 Post(s)
Liked: 113
I get WPVI with a UHF only antenna (Winegard Square Shooter) in zip 19425. At the bottom of a shallow valley.
It's mounted outdoors up high. However, I've never gotten WHYY, which I think is nearly an impossible get in northern Chester County.
wilbur_the_goose is online now
post #4042 of 4047 Old 07-09-2016, 12:32 PM
G-star's Avatar
Thanks for your input. I didn't even know that it was possible to receive a VHF signal on a UHF only antenna. I guess I have lots to learn.
I'm in 19020, about 17 miles from the major station antennas in BC.
G-star is offline
post #4043 of 4047 Old 07-11-2016, 03:32 PM
Liked: 0
I'm in Quakertown and am receiving 56 stations including WPVI on a RCA ANT751R with a RCA TVPRAMP1R Preamplifier. The antenna is installed in the attic. The antenna was around $45 when I bought it and the preamp was $25. I did a little research (TVFOOL) and just bought the minimum equipment hoping it would work. I "cut the cord" about 3 years ago. When I bought the antenna, I wasn't expecting much for a $45 antenna but it worked well.
I added the preamp a couple of weeks after I put the antenna up and was able to watch 2.1 KJWP (METV) from Wilmington.
ems2158 is offline
post #4044 of 4047 Old 07-25-2016, 11:03 AM
jaxstraww's Avatar
Quoted: 12 Post(s)
Since the storms this morning I'm having issues too. Antenna looks to be in teh same spot. Everything else is ok but channel 6 is a mess. Mine reads 40% as well.
Sharp Aquos LC-60EQ
ClearStream 4
Channel Master DVR+
Nvidia Shield
PS3 & PS4
jaxstraww is offline
post #4045 of 4047 Old 07-25-2016, 03:13 PM
frank70's Avatar
Quoted: 92 Post(s)
Liked: 76
WPVI looking normal here in Lower Bucks this evening.
frank70 is offline
post #4046 of 4047 Old Yesterday, 04:19 AM
Liked: 0
Has WCAU reduced their broadcasting power? I haven't watched it for most of the summer but I tried to tune in to watch the Olympics and noticed the signal is significantly worse than before. In fact, this channel used to be the strongest signal out of all of the Philadelphia channels for me (almost 100% signal strength) and now the signal is so weak that I can't even tune to the channel most of the time (it hovers around 50% signal strength, and cannot even get a lock at most times of the day).
I'm in the Allentown, PA area. I haven't made any hardware changes since the time the channel had a strong signal. All of my other channels broadcasting from Philadelphia still have the same signal strength as before.
I know they recently added the WWSI subchannel but I can't imagine that would impact the signal strength. Anybody know what is going on?
MasterSplinter is offline
post #4047 of 4047 Old Today, 07:42 PM
Quoted: 238 Post(s)
Liked: 113
They turned over the WCAU engineering team to Comcast with predictable results
(I'm being facetious)
