Philadelphia, PA - OTA - Page 136 - AVS Forum | Home Theater Discussions And Reviews
 15Likes
Old 09-10-2016, 01:21 PM
G-star's Avatar
Quoted: 18 Post(s)
Originally Posted by MasterSplinter View Post
Has WCAU reduced their broadcasting power? I haven't watched it for most of the summer but I tried to tune in to watch the Olympics and noticed the signal is significantly worse than before. In fact, this channel used to be the strongest signal out of all of the Philadelphia channels for me (almost 100% signal strength) and now the signal is so weak that I can't even tune to the channel most of the time (it hovers around 50% signal strength, and cannot even get a lock at most times of the day).
I'm 17mi from Roxborough, and have also found WCAU to be very problematic lately. I get the more "difficult" channels just fine (WPVI, WHYY) and about 45 total, and I'm using a relatively cheap $40 GE attic antenna.
Anybody have any info or work-around the reception for WCAU? I was very annoyed when trying to watch the football game on Thursday night.
"That's right Mr. Martini...there is an Easter Bunny".
G-star is offline
Old 09-11-2016, 02:21 PM
wilbur_the_goose's Avatar
Quoted: 291 Post(s)
Liked: 136
Remember, WCAU is Comcast. Perhaps they don't want you to view OTA and purchase their Xfinity service instead?
wilbur_the_goose is offline
Old 09-11-2016, 03:18 PM
LastButNotLeast's Avatar
Quoted: 1541 Post(s)
Liked: 1149
So it's not a bug, it's a feature.
Michael
wilbur_the_goose likes this.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
For most of the time, the here and now is neither now nor here. Graham Swift
LastButNotLeast is offline
Old 09-13-2016, 01:20 PM
John ODonnell's Avatar
I'm having the same issue. I am about 35 miles from the Roxborough towers (actually my home neighborhood) in Douglassville. I always received the 10's @ 100%. About two weeks ago I started to see sever pixelation. Right now (Tuesday 9/13 @ 4:40pm), I can't even get a signal.
John
John ODonnell is offline
Old 09-29-2016, 11:04 AM
cdelena's Avatar
Quoted: 91 Post(s)
Liked: 62
Speaking on Comcast... what DVRs do the use in the Philly area?
Is it SA/Cisco boxes? The reason I ask is that on the west coast Motorola boxes are most of the installed base and I am thinking the most recent Comcast software (dvrmanager) doesn't work here because they ignored the devices here.
I get nothing of use from customer service.
cdelena is offline
Old 10-01-2016, 11:25 AM
Quoted: 291 Post(s)
Liked: 136
No clue here - no way will I submit to Comcast
Old 11-04-2016, 01:24 PM
mvcg66b3r's Avatar
Quoted: 104 Post(s)
WTVE 51.1 switches to SonLife
RabbitEars is saying WTVE Reading PA has switched to SonLife on 51.1, joining Atlantic City's WMGM in carrying the religious network on primary channels. This also gives SonLife FIVE outlets in the Philly market, including WACP 4.3, WPSJ-CD 8.2 and WZPA-LD 33.3.
http://www.rabbitears.info/market.ph...=55305#station
Name:	SonLife Philly 2.png
ID:	1753809   Click image for larger version
Name:	SonLife Philly.png
James Calvin Woods - Son of Verta Jane Holland
mvcg66b3r is offline
Old 11-05-2016, 06:42 AM
Quoted: 291 Post(s)
Liked: 136
Wow - what a waste of spectrum.
Old 11-07-2016, 12:35 PM
gerall's Avatar
Quoted: 50 Post(s)
I'm about 25 miles from roxborough. was using an old legacy antenna for @ 20 years no problem - this summer a bad storm damaged it and I lost reception. Antennas direct recommended replacing it with the DB8E UHF bow tie antenna. I installed it and it receives all uhf and also vhf although 6 is spotty. the problem is the signal at times freezes and cuts out for a few seconds, which rarely if ever happened with the old antenna. Is this due to the fact that this is a multi-directional antenna rather than a directional/yagi? Could it be that the signal is too strong with this antenna? Any help would be appreciated.
gerall is offline
Old 11-07-2016, 03:23 PM
frank70's Avatar
Quoted: 107 Post(s)
Liked: 83
Is it only 6 that freezes and cuts out? The DB8 antennas are indeed directional (the big ground-plane(s) on the back side should be the first clue), but also are virtually useless for LOW VHF. I have a DB8 but need to couple in a simple twin-lead folded dipole tuned for channel 6. If all the stations are freezing and/or cutting out, then I have no clue - that antenna should pull the UHF channels just fine; are you sure you have it aimed correctly? Multipath reflections from blowing trees can also cause dropouts, in which case you might try adjusting the antenna direction by a few degrees either side of Roxborough to try to reject more of the multipath. Also make sure all 8 bowties are pointed in the same direction.
frank70 is online now
Old 11-21-2016, 02:53 PM
gerall's Avatar
Quoted: 50 Post(s)
Thanks, Frank. Tried adjusting and still dropouts. I have 2 tvs - the main tv is a 12 year old mits crt rear projection with a built in tuner and that has dropouts. the other is an old analog crt with a coverter box and with the db8e picks up all uhf AND vhf includingch 6 with minimal drop outs. I think adding a new tuner may solve the problem - do you have any recommendations? Am I correct that I can't use a converter box tuner as a digital tuner with a digital tv? thanks
gerall is offline
Old 11-21-2016, 04:58 PM
frank70's Avatar
Quoted: 107 Post(s)
Liked: 83
I certainly wouldn't recommend using a converter box with a digital TV - though it might work (using composite inputs to the TV), the picture quality would be a big disappointment. Does the 12 year old digital TV have an HDMI input? If so, I'd recommend getting a Channel Master DVR+ 16GB unit to use as a tuner (and DVR if you later want to add an inexpensive 1GB external hard drive). If no HDMI input (i.e.: only component inputs), then I have no suggestion other than getting a new LED/LCD flat screen TV with built in tuner (or, well maybe you could find an old used Dish DTVPal DVR which has component outputs).
Note that the 12 year old TV's tuner probably has poor multipath rejection (as they did back then) and that could be the root cause of your problems.
Old 11-22-2016, 06:08 AM
gerall's Avatar
Quoted: 50 Post(s)
Thanks. The tv has a DVI input. Any tuner recommendations would be welcome.
gerall is offline
Old 11-22-2016, 06:54 AM
frank70's Avatar
Quoted: 107 Post(s)
Liked: 83
Unfortunately, although you can convert HDMI to DVI, audio is not carried on that connector, nor does the Channel Master DVR+ have a separate audio output, so using that as a tuner is out. Maybe now is the right time to upgrade to a new digital TV since they're going to all be on sale this week, instead of trying to continue to nurse the projection set along. You'll be amazed at how much sharper (than projection) LED backlit LCD TVs are these days. Tuners have come a long way too, but just in case, make sure you can take it back in the unlikely event the tuner is still not happy with your signal.
Also, since you're splitting the signal to 2 TVs, perhaps a preamp would help.
Old 11-22-2016, 07:06 AM
Quoted: 291 Post(s)
Liked: 136
@gerall - Might be wise to pick up a cheap new TV on a Black Friday sale...
Old 11-22-2016, 08:07 AM
gerall's Avatar
Quoted: 50 Post(s)
Thanks, great idea. Any recommendations for a 65"? I can join Costco.
gerall is offline
Old 11-22-2016, 09:30 AM
Liked: 1149
That would be here:
http://www.avsforum.com/forum/166-lc...anel-displays/
and elsewhere.
Good luck.
Michael
Old 11-23-2016, 04:52 AM
Quoted: 291 Post(s)
Liked: 136
Anybody can join Costco.
Old Today, 02:29 PM
T-Max's Avatar
Location: Near the Bridgewater Commons Mall, Bridgewater NJ
Long time no post
But I was losing my OTA signal for WHYY (Philly) late at night so I emailed them about it and this is what they said:
Over the next several months, there is technical work being completed at our transmitter site. If you view WHYY-TV using an antenna or listen to WHYY-FM, you can expect major signal interruptions between the hours of midnight to 5:00 am.
So that's what the deal is with my loss of signal late @ night.I wuz thinking maybe it was funding cuts, yada yada yada.
What, me worry?
T-Max is offline
