St. Louis, MO - HDTV - Page 447 - AVS Forum | Home Theater Discussions And Reviews
 22Likes
post #13381 of 13400 Old 10-31-2016, 10:55 AM
moman19's Avatar
Quoted: 21 Post(s)
Originally Posted by JoelWNelson View Post
Is anyone else having more trouble picking up Fox 2 over the last couple days? The signal is always a bit weaker for me than 4,5,11 and 30, but it has been nearly unwatchable during the most recent two WS games. Nothing has changed with my setup other than more leaves have come off the trees.
No problems here today. Bare trees are actually BETTER for signal propagation at higher frequencies (cellular). Not sure it has much impact with blowtorch OTA transmitters unless you live in the fringe.
moman19 is offline
post #13382 of 13400 Old 10-31-2016, 11:16 AM
JoelWNelson's Avatar
That's what I thought too, which is why this is driving me nuts. I am in Hazelwood but in a tree-filled valley so per tvfool, rabbitears, etc. reception of STL stations actually is nearly fringe-grade. But I can usually get 2, 4, 5, 11 and 30 to work. Not this past weekend though. It was at least a little better last night.
JoelWNelson is offline
post #13383 of 13400 Old 10-31-2016, 11:25 AM
Saluki's Avatar
Originally Posted by hockeynut View Post
I have charter and some of my local channels have been breaking up like crazy. Tried to watch Pitch tonight and it was so frustrating with the constant breakups in video and audio. Anyone else experiencing problems?
Yes, having the same issues (mid-county STL)
Saluki is offline
post #13384 of 13400 Old 10-31-2016, 11:56 AM
moman19's Avatar
Quoted: 21 Post(s)
What type antenna are you using? If it's indoors, your best bet is to get a better model, a rooftop antenna or at least move what you have higher or into the attic.
moman19 is offline
post #13385 of 13400 Old 10-31-2016, 12:03 PM
I have the Winegard Freevision, http://www.winegard.com/freevision, roof mounted and aimed at about 172 degrees. I'm near Teson Rd./White Birch Park area part way down the slope toward the river with a tree-lined hill right in front between my location and the towers, and another 25 foot hill immediately behind, opposite the towers, that I believe signals may be refracting off of and causing multipath.
Any tips or recommendations on a different antenna for the location are appreciated.
post #13386 of 13400 Old 10-31-2016, 03:06 PM
moman19's Avatar
Quoted: 21 Post(s)
In my opinion, that antenna may not be sufficient for your area. First, all stations in our market are UHF-only so the VHF component, which is probably more than half the metal you see is of no benefit. Sorry to say, but what's left is not much better than a UHF loop antenna. Look for a directional one that looks something like this: https://www.antennasdirect.com/store...V-Antenna.html
This one may be overkill, but smaller/shorter ones are available and you can aim them where the towers towers are. Stay away from UHF/VHF combo units as they are bigger and VHF buys you nothing.
moman19 is offline
post #13387 of 13400 Old 10-31-2016, 03:09 PM
Thanks, no worries, I bought the antenna when I lived in a market that was half VHF. Will try changing out the antenna when I can!
post #13388 of 13400 Old 11-02-2016, 01:14 PM
As an update, I replaced it today with an Antennas Direct ClearStream 4V. While I still am not getting PBS or Ion reliably, Fox is at least reliable now for hopefully watching the Cubs win tonight. I'll try adding a preamp next but this is good enough for today.
post #13389 of 13400 Old 11-03-2016, 08:03 AM
Dan in St. Louis's Avatar
Quoted: 111 Post(s)
Liked: 38
Be sure to try different antenna directions. Reflection and refraction can perform strange tricks with radio signals, and the "best" direction may not be where you would guess.
Also try tipping the antenna so it aims a bit above horizontally, for the same reason.
PS: Their tower appears to be here.
---- Dan in Saint Louis
Dan in St. Louis is offline
post #13390 of 13400 Old 11-03-2016, 12:54 PM
moman19's Avatar
Quoted: 21 Post(s)
It appears to be a good antenna but it is also omni-directional and cannot really be aimed to any great degree. This is why I prefer the "pointy" looking ones that can be aimed in a general direction. They are also better at rejecting any reflections that might arrive from different locations.
moman19 is offline
post #13391 of 13400 Old 11-03-2016, 01:43 PM
ADTech's Avatar
Quoted: 115 Post(s)
Liked: 63
KTVI's tower is located behind the football field of Lindbergh High. KETC's if along Tesson Ferry (Hwy 21) overlooking the Meramec river. WRBU's tower is a little further out 21, just south of High Ridge.
Not sure what antenna you're referring to, neither the FVHD30 nor the C4(v) is anything close to omni-like on UHF.
Tech support for Antennas Direct
ADTech is offline
post #13392 of 13400 Old 11-03-2016, 03:19 PM
moman19's Avatar
Quoted: 21 Post(s)
The fellow mentioned he purchased an Antennas Direct ClearStream 4V. Not certain but it looks rather non-directional.
moman19 is offline
post #13393 of 13400 Old 11-03-2016, 06:13 PM
ProjectSHO89's Avatar
Quoted: 192 Post(s)
Liked: 105
He purchased both.
Not even close in that judgement. It is QUITE directional. Go here and scroll down to the last section. http://www.hdtvprimer.com/antennas/temporarypage.html
ProjectSHO89 is online now
post #13394 of 13400 Old 11-03-2016, 09:25 PM
Robert Simandl's Avatar
Quoted: 149 Post(s)
Liked: 72
Whenever I get p.o.'d at Charter, I try to tell myself "at least we don't have ComCast."
http://cordcuttersnews.com/comcast-r...aps-28-states/
Bob Simandl ... somewhere near St. Louis
Robert Simandl is offline
post #13395 of 13400 Old 11-04-2016, 07:17 AM
Linxs's Avatar
Originally Posted by Robert Simandl View Post
And will show up on Android phones and tablets next week.
You can also watch on computers now as of yesterday you can go to psvue.com/watch.
Linxs is offline
post #13396 of 13400 Old 11-11-2016, 09:58 AM
The solution was tilting the antenna a little to better receive the signal refracting over the hill, as well as adding Antennas Direct's "Juice" preamplifier. Fox now comes in very reliably, as does PBS at least 95% of the time, and as an added bonus I am even picking up Ion (46) off and on.
post #13397 of 13400 Old 12-02-2016, 12:55 PM
jwb0007's Avatar
Quoted: 20 Post(s)
Question, please, re HD TV antennas: specifically, any thoughts about this one that popped up on my screen?
LAVA HD-2605 ULTRA Outdoor TV Antenna - UHF/VHF/FM/SDTV/HDTV/4K
List Price: $119.95
Our Price: $69.95
Sale Price: $69.95
The link to this is: http://www.tvantennasale.com/Lava-HD...FYGFaQodSj0ILA
I live in the St. Louis, MO area (more precisely, in Weldon Spring, about 1 mile north of the Hwy 40 / I64, MO Hwy 94 area. I am seriously considering "cutting the cord" on Charter Cable (keeping their internet, though). I presently have a good Android box so I can get all the KODI and other types of apps. Am also thinking of PlayStation Vue, too, for the sports that I would like to watch.
Will really appreciate thoughts and insights about the advisability of this. I do seem to be watching less TV, and never seem to watch the vast majority of channels on my basic cable package as it is.
Jim
St. Louis, MO area
My System:
AVRs: Yamaha RX-A2030, RX-V575, Denon AVR-X1100W Amplifier: Yamaha M-65
Speakers: Polk RTi12, Polk RTi6, Polk CSiA6, Polk CS350, Infinity Primus P362, Klipsch KSF-C5
Subs: Outlaw LFM-1 EX, Klipsch Synergy Sub-10
jwb0007 is online now
post #13398 of 13400 Old Today, 10:01 AM
Quoted: 111 Post(s)
Liked: 38
List Price: $119.95
Our Price: $69.95
Sale Price: $69.95
Just be sure you get a money-back guarantee if it fails to perform up to your needs. That is a company I have never heard of so I have no way to judge the truth of their advertising.
Solid Signal will give good advice.
post #13399 of 13400 Old Today, 10:26 AM
Quoted: 192 Post(s)
Liked: 105
The Lavas and their ilk are generally cheaply made imports that are very flimsy. Recommend avoiding them as well as their outrageous performance claims.
How about supporting a local (Ellisville) company - Antennas Direct? One of their tech guys is a regular participant here, screen name "ADTech".
Depending on your specifics, a DB4e would likely work well from the 40/94 area. You'd have to post your TVFool plot link and give a description of what your signal path back towards South County looks like for confirmation or to see if a smaller or a larger antenna would be appropriate.
post #13400 of 13400 Old Today, 01:54 PM
jwb0007's Avatar
Quoted: 20 Post(s)
Dan and Project, thank you for your helpful replies. And had not considered staying local, but seems like a good suggestion.
A few comments and questions?
1. My primary reasons for considering dropping Charter Cable for TV and a telephone line no longer needed, and keeping only Charter internet, are related to both the actual cost, and the fact that outside of some live sports on the ESPN channels and FS Midwest, there is not much that I choose to watch. Or cannot watch on my Amazon stick and Android box.
2. Am thinking that I could get those sports channels, as well as some others that have some value, through PlayStation Vue
Comments welcome on how effective that exchange might/might not be.
Then, as I do have 3 TVs and AV receivers (areas) that I would like to be able to have equal access to the HDTV inputs described above, how do I accomplish that? I have attached my TVFool Plot, as suggested.
As mentioned, I presently use Charter Cable for my TV.
However, I presently have a DirecTV antenna dish (now unused) on my roof (below the top/ridge of the roof). It is pointed approximately at 180 degrees--due South (by my seaman's eye), while it appears from the Plot that the TV stations I would likely want to receive are at about 120-160 degrees. Some, but not huge, trees/leaves in the direction of the broadcasting towers. I assume an 18' height in the TV Plot, but could be a tad higher.
  1. Might I be able to use that short mast to attach the antenna?
  2. Which antenna might you recommend?
  3. Do I understand correctly that I might be able to use the existing cabling from the satellite dish or my present Charter cable installation to get the signal to all 3 TVs?
  4. How "complicated" or "technical" is that for a person of average capabilities?
  5. Would that result in diminishing the signal to any of the three? If so, might I be better off with some kind of splitter at the UHF antenna itself? Any kind of "booster" needed?
May I ask how satisfied, in general, the posters on this forum may be with their similar decisions?
Am sure there are many more things I should be thinking about, and welcome your mention of those!
Thank you all for your various inputs!!!
Jim
St. Louis, MO area
My System:
