San Francisco, CA - Comcast - Page 509 - AVS | Home Theater Discussions And Reviews
post #15241 of 15371 Old 07-28-2014, 08:20 PM
Otto Pylot's Avatar
Quoted: 318 Post(s)
Liked: 291
Originally Posted by maddog510 View Post
Performance should be 25/5, Blast 50/10 & Extreme 105/20. This Wednesday on the 30th, subscribers of the extreme tier will see their speeds increase to 150 mbps but the upload will remain the same.
Yeah, those are the advertised speeds but what about real world, normal use? He's not a gamer. The idea is to get reliable, consistent speeds (not burst rate) so he can stream what he wants and not have to pay for a tv package. As a student, cost is the driving force. TV he can live without, internet access no. He's moving into a condo that we just bought. Thanks.
Otto Pylot is offline
post #15242 of 15371 Old 07-28-2014, 08:39 PM
bobby94928's Avatar
Liked: 147
In Rohnert Park, I was getting 29 down, 6 up with Performance. I recently went to Blast and now get 58 down, 12 up. Vallejo should track the same...
Edit, these are real world numbers... My streams are perfect!
Bobby
bobby94928 is online now
post #15243 of 15371 Old 07-29-2014, 12:54 AM
AVS Club Gold
Keenan's Avatar
Quoted: 559 Post(s)
Liked: 504
Same here, I have similar numbers for Blast, and Netflix streaming is near instantaneous to Super HD quality.
Keenan is offline
post #15244 of 15371 Old 07-29-2014, 12:57 AM
AVS Club Gold
Keenan's Avatar
Quoted: 559 Post(s)
Liked: 504
Blast is supposedly being doubled to 100 as well.
Keenan is offline
post #15245 of 15371 Old 07-29-2014, 02:54 AM
Larry Kenney's Avatar
Quoted: 150 Post(s)
Liked: 34
I have Performance here in San Francisco and usually get 28.5 down / 5.3 up.
Larry
My complete SF Bay Area DTV Station Lists: http://www.choisser.com/sfonair.html
Lots of Broadcasting links and information: http://www.choisser.com/broadcast.html
Check out photos and info on my antennas: http://www. larrykenney.com/tvantennas.html
Larry Kenney is offline
post #15246 of 15371 Old 07-29-2014, 10:31 AM
Otto Pylot's Avatar
Quoted: 318 Post(s)
Liked: 291
Thanks everyone. Seems that Performance will be the way to go for the budget minded if internet only is reasonable without a bundle.
post #15247 of 15371 Old 07-30-2014, 11:36 AM
bobby94928's Avatar
Liked: 147
and, as of this morning, I am getting 95 down, 12 up!
Bobby
post #15248 of 15371 Old 07-30-2014, 11:46 AM
AVS Club Gold
Keenan's Avatar
Quoted: 559 Post(s)
Liked: 504
Yup, same here. I don't really have any use for such speeds but I guess it's nice to have. I'll very likely just drop down to Performance which is now at 50Mb/s and save $10 per month. When my year of free Blast upgrade expires of course!
Keenan is offline
post #15249 of 15371 Old 07-31-2014, 12:20 AM
tranle's Avatar
Quoted: 25 Post(s)
What sort of cable modem do you need to get the ~100MB download speed ?
Can an old SB6120 with 4 download stream works or do you need one that can do 8 download stream ?
tranle is offline
post #15250 of 15371 Old 07-31-2014, 12:26 AM
AVS Club Gold
Keenan's Avatar
Quoted: 559 Post(s)
Liked: 504
I think the 6120 should work, have you power off/on rebooted it? A modem with 8 channel bonding does help but I believe a 4 channel should work also.
Keenan is offline
post #15251 of 15371 Old 07-31-2014, 12:30 AM
tranle's Avatar
Quoted: 25 Post(s)
Yes, I did a reboot but went from 57MB to 75MB that is why I asking it to make sure that my old modem is not a limiting factor.
tranle is offline
post #15252 of 15371 Old 07-31-2014, 12:50 AM
AVS Club Gold
Keenan's Avatar
Quoted: 559 Post(s)
Liked: 504
It's possible, I haven't had one of those in quite some time. Are you using http://speedtest.comcast.net/ ?
You might try asking at http://www.dslreports.com/forum/comcast as they get into all aspects of Comcast HSI and can definitely answer your question about that modem.
Keenan is offline
post #15253 of 15371 Old 07-31-2014, 03:08 AM
Quoted: 150 Post(s)
Liked: 34
Performance didn't change. It's still 28.5/5.9 here in San Francisco.
Larry
post #15254 of 15371 Old 07-31-2014, 03:15 AM
c3
c3's Avatar
Performance about 58/6 in Mountain View.
c3 is offline
post #15255 of 15371 Old 07-31-2014, 06:07 AM
dr1394's Avatar
Quoted: 25 Post(s)
After a modem reset, I'm getting about 35/6 with an old DOCSIS 2.0 SB5101 (up from 30/6). I guess I'll have to swap out for the wireless gateway they've been bugging me about.
Ron
HD MPEG-2 Test Patterns http://www.w6rz.net
dr1394 is offline
post #15256 of 15371 Old 07-31-2014, 08:33 AM
Grandude's Avatar
I just reset my Zoom modem and speed went from 25 or so down to 58 down.
Brian...reporting from the left coast...
Grandude is online now
post #15257 of 15371 Old 07-31-2014, 10:29 AM
AVS Club Gold
Keenan's Avatar
Quoted: 559 Post(s)
Liked: 504
Larry
Did you cold re-boot your modem?
Keenan is offline
post #15258 of 15371 Old 07-31-2014, 10:34 AM
AVS Club Gold
Keenan's Avatar
Quoted: 559 Post(s)
Liked: 504
Ron
If you plan to stay with Comcast you're better off purchasing your own, plus it will very likely perform better than the Comcast-supplied equipment, especially when it comes to wireless. If you do go with the Comcast gateway be sure to check if the public WiFi hotspot feature is enabled as I believe they come that way by default.
P.S. Yes, if you want the faster speed you'll need to go with a DOCSIS 3 modem. If you already have a wireless router a good D3 8x4 modem is the Zoom 5341J
And Asus makes excellently performing and highly configurable wireless routers.
Here's a list of Comcast approved equipment. I'm not sure when that was last updated so there may be more recent equipment available. I would go with something that is DOCSIS 3.0 and IPv6 capable to future proof as much as you can at this point it time.
Keenan is offline
post #15259 of 15371 Old 07-31-2014, 01:09 PM
undecided's Avatar
Quoted: 114 Post(s)
Liked: 77
Agree with Keenan a SB6120 with 4 downstream channels should work at 100 Mbps download - however you would have more headroom with a modem with 8 download channels (SB6141 or Zoom etc). Asking at dslreports is also a good suggestion.
undecided is offline
post #15260 of 15371 Old 07-31-2014, 02:09 PM
Quoted: 150 Post(s)
Liked: 34
No, I hadn't.
I have now, and I'm getting 57.21 down, 5.87 up. Nice!!
Larry
post #15261 of 15371 Old 07-31-2014, 03:07 PM
wco81's Avatar
Quoted: 215 Post(s)
Liked: 103
Yeah I rebooted my SB6121, getting comparable speeds.
Would like the upload doubled more than the download.
Comcast didn't even announce it?
wco81 is offline
post #15262 of 15371 Old 07-31-2014, 03:10 PM
AVS Club Gold
Keenan's Avatar
Quoted: 559 Post(s)
Liked: 504
They've been running commercials on TV for over a month and it's been happening in the mid-west and the east over the last several months, we're one of the last markets to get the increase.
Keenan is offline
post #15263 of 15371 Old 07-31-2014, 08:06 PM
dr1394's Avatar
Quoted: 25 Post(s)
Thanx for the tips. Oddly enough, my old SB5101 works fine on IPv6.
I do have an Asus RT-AC66U that works great, so I don't need another wireless device. We'll see how may times Comcast bugs me about upgrading. They've sent me a letter and called on the phone already.
Ron
dr1394 is offline
post #15264 of 15371 Old 07-31-2014, 09:20 PM
AVS Club Gold
Keenan's Avatar
Quoted: 559 Post(s)
Liked: 504
Ron
It may not be native IPv6, although I know next to nothing about what all that means, but if it works!
Keenan is offline
post #15265 of 15371 Old 07-31-2014, 11:51 PM
undecided's Avatar
Quoted: 114 Post(s)
Liked: 77
Those of you getting 50 or 100 Mbps on Blast are making me jealous
Here in Santa Cruz County Blast is 25 Mbps down.
That said I can do everything I want - multiple Super HD Netflix streams, Vudu HDX, Amazon 1080P
post #15266 of 15371 Old 08-01-2014, 05:00 PM
AVS Club Gold
Keenan's Avatar
Quoted: 559 Post(s)
Liked: 504
Comcast mentions no upgrades for Santa Cruz and elsewhere.
Keenan is offline
post #15267 of 15371 Old 08-01-2014, 06:00 PM
dr1394's Avatar
Quoted: 25 Post(s)
The ASUS router is configured for native IPv6, so I'd have to say it's the real deal.
Ron
dr1394 is offline
post #15268 of 15371 Old 08-01-2014, 06:29 PM
AVS Club Gold
Keenan's Avatar
Quoted: 559 Post(s)
Liked: 504
Ron
Yes, I guess the SB5101 is IPv6 capable but is not DOCSIS 3 so you won't be able to take advantage of the higher speeds that were just implemented, I think the 5101 tops out at about what you said you were getting. If you want the faster speeds you'll have to upgrade the modem, But if it's fast enough already... I have no real need for 100Mb/s myself, in fact, 25/5 worked just fine for me before we got all the speed increases.
Keenan is offline
post #15269 of 15371 Old 08-01-2014, 07:25 PM
undecided's Avatar
Quoted: 114 Post(s)
Liked: 77
Thanks for the link - confirmation of what I expected. We haven't seen the last speed bump never mind this one - hopefully soon.
So my Blast is 25 Mbps while the other side of the hill its now 105 Mbps!
I am happy for those getting the speed increase.
post #15270 of 15371 Old 08-05-2014, 09:48 AM
tdavis's Avatar
I have the Motorola 6120, and it's capable of the 100mbps Blast! speed (which I also have..)
I am not home at the moment, I'll post a speedtest when I do get a chance at home.
Here is my speed, using a Motorola 6120, with a Netgear WND3800 over Giga-bit networking.
tdavis is offline
