Washington, DC / Baltimore, MD - HDTV - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 47Likes
post #271 of 14428 Old 02-06-2007, 08:00 AM
tonyd79's Avatar
Problems with INHD and MHD on Comcast Howard County. All other channels are okay. Big time breakup/meltdown.
tonyd79 is offline
post #272 of 14428 Old 02-06-2007, 09:54 AM
wkearney99's Avatar
Quoted: 327 Post(s)
Liked: 129
Also bear in mind the issues of bandwidth. If you're not on one of their own networks there are a whole host of delays that can disrupt the service. Higher bandwidth applications like video will certainly benefit from being delivered through a controlled network. Both from a performance and a reliability standpoint. Unfortunately that also means getting stuck with Verizon's draconian restrictions against using your IP connection the way you choose.
If having FiosTV requires having Verizon internet we will NOT make the switch. That and several of our friends have left Verizon's DSL services (going to speakeasy) because they're had absolutely HORRIBLE support experiences from Verizon.
Verizon's just not a company worth trusting if you want actual choice, good service and reasonable treatment.
wkearney99 is offline
post #273 of 14428 Old 02-06-2007, 10:12 AM
Newmie's Avatar
I'd have to disagree with that. Before verizon I had no choice in high speed internet or cable TV. It was either COX or Comcast depending on which part of Va I was in. Having been vary disappointed with both C. & C. basic bandwidth speeds and over all Cust. service (COX being the worst) I'm SO thankful for the option to choice Verizon.
The install went Perfect for once. My bandwidth speed is double that of COX for less $$. I also get a HD DVR box for the same price I was paying COX without one.
With all that said its nice just having one bill for the above and phone.
IMHO- Verizon may not be perfect but its better then the other cable options available in Va.
Newmie is offline
post #274 of 14428 Old 02-06-2007, 10:37 AM
rosh400's Avatar
I know this is a TV not an internet thread but I think it is important to respond. FIOS Internet and DSL are completely separate animals. We've had FIOS internet service for 14 months and haven't needed to deal with support because we've never had a single problem. This is completely different from our previous experience with Comcast which varied between bad and acceptable and dialup before that. We have the 15/2 internet service and using the speakeasy speed test we are routinely at 15.2 down and 1.8 up.
I would doubt that VZ requires FIOS internet to have FIOS TV but I think you would be pleased with FIOS internet service.
rosh400 is offline
post #275 of 14428 Old 02-06-2007, 12:32 PM
ashutoshsm's Avatar
wkearney, with FiOS, and ALL that unused bandwidth, VZ seems to have dropped all their draconian restrictions of the past.
I doubt even port 80/21 etc are blocked/disallowed! Run a web server. They don't care. Yet!
*ashu*
ashutoshsm is offline
post #276 of 14428 Old 02-06-2007, 01:10 PM
sgtjim's Avatar
Originally Posted by afiggatt View Post
The Samsung DTB-H260F is a digital only ATSC receiver which can also receive unscrambled digital QAM cable channels. All of those basic channels are either analog or scrambled on the digital simulcast. The H260F has no analog tuning capability. The DTB-H260F is specifically sold as a ATSC OTA receiver which has a throw-in capability for QAM. It is not a cable box.
If you want to get all the basic cable channels, you need a cable ready TV or analog tuner or if you want the digital channels beyond the local broadcast stations, a cable STB or a TV / STB with cable card capability.
C
I believe you previously answered a question of mine wherein I wondered why I was unable to tune in the Comcast Music Channels with the Samsung when several neighbors that have integrated ATSC/QAM/NTSC tuners are able to receive the music channels. I believe you stated it was because the cable Co uses a filter on my cable line.
Could it be because the Samsung does not have an NTSC tuner? The music channels are in the channel 107 range which I guess is for digital channels. As all of the neighbors and myself are on the same cable run[There are several boxes along the route which could indeed have a filter) I just think there is another answer and the only way I could know for sure is to connect an integrated tv with QAM tuning.
Thanks for your thoughts.
sgtjim is offline
post #277 of 14428 Old 02-06-2007, 04:09 PM
SJKurtzke's Avatar
9 is now running a promo advertiesing HDTV...in SD.
I guess they're also adopting more CBS mandates...they're using "We are" before everything ("We are CBS" was the slogan put on the promotional material at the 2006-2007 upfronts)
SJKurtzke is offline
post #278 of 14428 Old 02-06-2007, 08:27 PM
URFloorMatt's Avatar
Compared to Comcast, that loses most of its thrust. At least in my experience anyway, down here in former Adelphia territory. Now, if we're talking in comparison to Cox, you may have a point. I hear nothing but good things about Cox and I have had a few hiccups with Verizon customer support since I switched to FiOS.
Anyway, as has been stated in this thread, Verizon FiOS and Verizon DSL are completely separate services. FiOS Internet is like cable broadband on crack.
URFloorMatt is offline
post #279 of 14428 Old 02-06-2007, 09:05 PM
tonyd79's Avatar
No one else having this problem in Howard County? Or elsewhere?
I an loathe to deal with Comcast because they always assume every problem is at the customer end and don't bother checking for a systemic problem. And their solution is always to send out a repairman.
tonyd79 is offline
post #280 of 14428 Old 02-06-2007, 09:13 PM
cfkillers's Avatar
i get the same problem for comcast in prince georges county. i get it late night early morning. i get it on discovery hd inhd mhd and espn2hd. my screen gets real pixelated and no sound. i called comcast and they reset box and it cleared up but started 5 min later. i think im get a new hd dvr box but i still havent watched all my recordings
cfkillers is offline
post #281 of 14428 Old 02-07-2007, 03:58 AM
GoIrish's Avatar
That's because they usually are at the customer end.
GoIrish
GoIrish is offline
post #282 of 14428 Old 02-07-2007, 06:52 AM
Marcus Carr's Avatar
Quoted: 57 Post(s)
Liked: 100
FiOS Construction Locations Feb 1st thru Feb 28th
Anne Arundel County Schedule:
http://www22.verizon.com/about/commu...acountyfeb.doc
Baltimore County Schedule:
http://www22.verizon.com/about/commu...es/bacofeb.doc
Howard County Schedule:
http://www22.verizon.com/about/commu...les/hcofeb.doc
Montgomery County Schedule:
http://www22.verizon.com/about/commu...es/mocofeb.doc
Prince George's County Schedule:
http://www22.verizon.com/about/commu...es/pgcofeb.doc
YOU ARE READING AVS FORUM
Marcus Carr is offline
post #283 of 14428 Old 02-07-2007, 07:01 AM
UHD Addict
aaronwt's Avatar
Quoted: 5252 Post(s)
Liked: 3161
FIOS construction in VA(FEB2007)
Verizon Virginia Community Page
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is offline
post #284 of 14428 Old 02-07-2007, 07:28 AM
knnirs's Avatar
Originally Posted by sgtjim View Post
C
There is another possible explanation. I know that Channel 107(Music channel) is using QAM (64) while most clear digital channels use QAM (256). It is possible that the Samsung tuner is not capable of decoding QAM (64). I use an LG LST-4200A which provides a good signal from Channel 107, as well as from all the other clear digital channels from Comcast Basic.
knnirs is offline
post #285 of 14428 Old 02-07-2007, 08:19 AM
pablopbb's Avatar
I too am in Elkridge/Howard County, but have never seen TNT HD or Discovery HD in the clear. I only get a PBS, CBS, ABC, NBC and the Comcast Sports Net in HD (I get more digital channels, but they are SD, not HD). Recently, I rescanned, and now the channel assignments are somewhat garbled (PBS is showing up at 13-2 or 13-1, can't remember which one... but it definitely shouldn't be, and now CBS HD is missing. And, I started miraculously getting Fox HD at 45-2 (I only got Fox HD via OTA before)).
Anyways, other than ComcastSportsNet HD, I've never gotten anything other than the local OTAs (and even then, FOX HD hasn't typically been on my Comcast feed as unencrypted).
I have a Vizio VX37L set with NTSC/ ATSC/ QAM tuner built-in.
pablopbb is offline
post #286 of 14428 Old 02-07-2007, 09:25 AM
tonyd79's Avatar
GoIrish
That is a pretty bad generalization. If they research the problem and find no issue, then it is at my end. You don't just ASSUME and cause a customer to sit out work to fix a problem that may or may not have a systemic cause.
But noooooo, Comcast just says, "We'll send out a tech." No checking to see if there is an issue on their end. Just knee-jerk.
Just like your unhelpful answer to my question.
What would cause two stations on MY box to go bad without a general fault?
tonyd79 is offline
post #287 of 14428 Old 02-07-2007, 09:45 AM
Hoopnoop's Avatar
I have a question about getting FIOS channels in the clear. I recently cancelled the FIOS TV service and now only get OTA along with FIOS internet. I tried to see which FIOS channels I could get through QAM but was unable to get any through my old cable line. Can I get the FIOS channels in the clear if I only get their internet service? If so, how do I do this?
thanks in advance for any help
Hoopnoop is offline
post #288 of 14428 Old 02-07-2007, 10:21 AM
wagsgt's Avatar
Originally Posted by HDDAVID View Post
Hello Hoyty..Do you have D* where you live? If so, how has your experience been with them? Currently i live in Columbia, but will be moving to Parkville in a few months,and already purchased the D* HR-20 HD DVR. I'm just waiting to move before I hook everything up.
Right now I have Comcast and get all the DC and Baltimore locals, but only the Baltimore locals in HD
When I lived in Crofton,MD. I also recived both Balt and DC channels. Now in Frederick with crappy Adelphia for now, hoping more HD channels will come soon.
wagsgt is offline
post #289 of 14428 Old 02-07-2007, 11:21 AM
Devin Clancy's Avatar
No, you have to actually pay for them.
Unlike analog cable, Fios can be shut off at the software level without cutting the cable.
Devin Clancy is offline
post #290 of 14428 Old 02-07-2007, 12:03 PM
GoIrish's Avatar
An RF issue in your home, a bad box, ingress from a neighbor, a bad splitter. Those are some examples of what can be wrong.
My qualified generalization is based on experience and information.
You asked the general population of AVSForum if they have a problem such as yours. I didn't see any responses from any other Howard County customers affirming your same issue even though though there are many members from Howard County on this forum regularly. I get the same SA feed in Harford County and I have no problems.
To be a common problem affecting all customers as you want to infer, you don't think they would have repaired it ? Perhaps all the other customers in Howard County that have this issue sought the advice and counsel of people on the internet as well, rather than simply call the cable company. That could explain why they all have a problem and the company doesn't know about it and fixed it.
When I say that these types of issues are usually at the customer end it's because on a vast percentage basis they are. Yours certainly could be the exception to the rule, but we won't know that until you call the company for a service call.
GoIrish
GoIrish is offline
post #291 of 14428 Old 02-07-2007, 12:17 PM
JoeInNVa's Avatar
I kept losing UHD and could not figure out why. I had it fine on one TV but the other it would show up for a few seconds then be gone for a while...I thought about calling Comcast to figure it out, but figured I needed to check something out...Guess what? The connector to the back of my box was a little loose. I tightened it up and BAM guess what I saw? Yup, UHD...
So, yes it can be at your end...And if there was an issue on their end, don't you think there would be more than 1 person calling in?
Arrive
Raise Hell
Leave
JoeInNVa is offline
post #292 of 14428 Old 02-07-2007, 01:26 PM
hoyty's Avatar
First I wanted to post a more general link to Verizon's Maryland Construction page as a follow-up to Marcus Carr's post. Second according to a story in the Sun about the progress Verizon is making in Baltimore County. Lastly, can someone more familiar with the area tell me if the construction plans for Balt Co are anywhere near the Harford Rd / Parkville area? I am hoping to get FIOS sooner than later.
hoyty is offline
post #293 of 14428 Old 02-07-2007, 04:12 PM
bornyank1's Avatar
Hey all, Georgetown OTA HD guy again here...I just got a loop antenna, as many of you suggested. This is the model I got: http://www.amazon.com/RCA-ANT120-Ind...826271-6082209.
My question is, what position should I turn the UHF/VHF knob on the top to get the best reception? Thanks.
bornyank1 is offline
post #294 of 14428 Old 02-07-2007, 07:31 PM
hokiefan's Avatar
I want to burn JP/Raycom sports / wdca to the ground. How the F is the duke unc game blacked out in the DC area? In fact, I'm really in the BALTIMORE market. These media rules are GODDAMN RIDUCLOUS.
hokiefan is offline
post #295 of 14428 Old 02-07-2007, 08:20 PM
Onazuka's Avatar
And don't get me started on JP/Raycom Sports not broadcasting the ACC Basketball Tournament in HD and blacking out ESPN who does show it in HD so I have to watch it in SD from them !
Onazuka is offline
post #296 of 14428 Old 02-07-2007, 09:50 PM
afiggatt's Avatar
Put the antenna in or close to the window with the open face of the loop facing out the window for starters. Set the "fine-tuning" knob to a middle position and don't worry about it too much although you could try a couple of settings for it.
afiggatt is offline
post #297 of 14428 Old 02-08-2007, 08:29 AM
wkearney99's Avatar
Quoted: 327 Post(s)
Liked: 129
I've had great success this past week setting up a Winegard SS-1000 Square Shooter mounted on a tripod inside my attic.
I've noticed the ATSC tuner in the Pioneer Pro-1140HD picks up quite a few stations. The HDHomerun networked tuner feeing a Media Center 2005 PC gets the same ones at just about the same signal strength. The tuners in the DirecTV HR10-250 comes nowhere near as close and just barely gets the same signals. I get 4,5,7,9,14,26 and 50 ATSC stations reasonably well. I'm in zip 20817 and apparently being 'close' to the transmitters is worse than a little farther away.
Once the weather warms up a bit I'm going to try moving the antenna outside of the attic to see if that improves reception. It's a 1950's house with an asphalt shingled roof that's not very steep (about 10yrs old The local stations are between bearings of 130 to 150 degrees. Baltimore stations are closer to about 20 degrees and that's outside the pickup of the SS-1000. I don't expect moving outside the attic will improve that. But hopefully it'll allow picking up 32.
There there's the idea of using two antennae.... anyone done this around here?
post #298 of 14428 Old 02-08-2007, 08:32 AM
Tendril's Avatar
I was so pissed off at that last night.
Does anyone know if the game was available in Howard County? A friend of mine was having trouble finding it and not sure if he ever did.
Tendril is offline
post #299 of 14428 Old 02-08-2007, 09:00 AM
Red Dog's Avatar
If Howard Co. gets Baltimore channels, then it was available on WNUV-54.
Don't get me started about the ESPN-blackout in ACC markets. I'm already dreading the tournament coming up.
Red Dog is offline
post #300 of 14428 Old 02-08-2007, 10:00 AM
inlogan's Avatar
I just posted this about a week ago and apparently no one noticed. I emailed Raycom and asked. Maybe Mark Bulla can shed some light on this since I think WNUV is the Baltimore affiliate, right? I doubt we'll get much info from WDCA.
>Thank you for your feedback. Currently, Raycom Sports and Lincoln
>Financial Sports are testing "non-network" HD delivery of our ACC
>Basketball telecasts with our local stations throughout the ACC
>Territory. If the tests are successful, we have plans in place to
>produce and deliver the entire ACC Basketball Tournament in HD.
>Thank you,
>Raycom Sports & Lincoln Financial Sports
inlogan is offline
