Washington, DC / Baltimore, MD - HDTV - Page 355 - AVS Forum | Home Theater Discussions And Reviews
 49Likes
post #10621 of 14472 Old 09-14-2009, 11:48 AM
machpost's Avatar
Originally Posted by carltonrice View Post
I was wondering if any of the HD news laggards in the area would be rolling out HD News in time for the fall season.
Heh, I'm almost convinced that WRC will never, EVER roll out HD news.
machpost is offline
post #10622 of 14472 Old 09-14-2009, 01:18 PM
Big J's Avatar
Me too.
J
Big J is offline
post #10623 of 14472 Old 09-14-2009, 01:23 PM
URFloorMatt's Avatar
What normally comes on CBS at 9pm on Mondays? According to my FiOS guide, WUSA will be airing the Dr. Oz premiere tonight at that time. Assuming that's accurate, I guess it's because they couldn't air it this afternoon due to U.S. Open coverage.
URFloorMatt is offline
post #10624 of 14472 Old 09-14-2009, 03:32 PM
Marcus Carr's Avatar
Quoted: 57 Post(s)
Liked: 104
Dr. Oz was in SD on WBAL.
YOU ARE READING AVS FORUM
Marcus Carr is offline
post #10625 of 14472 Old 09-14-2009, 06:03 PM
dexter6's Avatar
Hi Everyone!
I'm new to the DC Area and new to this thread, though I've been on the forums for a little while now. I've been having some problems with my Comcast HD signal and was wondering if anybody else has seen this.
I've got the Motorola HD Box (DCX3200) and I get a pixelated picture when using my AT&T cell phone. It appears to only effect SciHD (217) and FXHD (221) to my knowledge, but it may effect more than that.
Some quick Googling revealed I'm not crazy ( http://www.broadbandreports.com/foru...eless~start=20 ) but I was wondering if I'm the only one in the DC Area with this problem.
Does anyone have a channel list by frequency like what is posted in that link? I'd like to confirm the range of channels affected by my phone.
Does anyone think the Ferrite beads will do anything? My experience with Comcast tells me I'm going to get the SOL response from them, so I figured I'd check with the experts.
Thanks in advance!
dexter6 is offline
post #10626 of 14472 Old 09-14-2009, 07:55 PM
djp952's Avatar
Thanks in advance!
Radio Shack has some ferrite chokes they stock, it can't hurt to try. You can undoubtedly get them WAY cheaper somewhere else, though
I personally don't think it will do much, though. It's probably more likely that the tuner inside the cable box isn't adequately shielded. Do you have the coax grounded? I think cable does it like you would with OTA with a grounding block outside the house hooked to the Earth ground. Also make sure all your connections are good through the entire system. I've heard that loose connectors can cause an increased sensitivity to interference.
Are you using an amplifier anywhere? If so, you might want to try unhooking that to see if perhaps the amp is making things worse.
One easy way to see if maybe your system itself might have a flaw would be to find somebody else with the same box and use your phone over there
djp952 is offline
post #10627 of 14472 Old 09-15-2009, 04:59 AM
VARTV's Avatar
Quoted: 71 Post(s)
Yikes!
Robert F Corbin
VARTV.com | Virginia Media News & Information
email: editor@VARTV.com
facebook: facebook.com/VARTV
twitter: twitter.com/VARTV
linkedin: linkedin.com/in/VARTV
google+: plus.google.com
pinterest: pinterest.com/VARTV
VARTV is offline
post #10628 of 14472 Old 09-15-2009, 05:43 AM
Quoted: 57 Post(s)
Liked: 104
WBAL likes to do things half way. They have two syndicated shows in HD and two that should be. They have HD news but still no DD5.1 at any time.
post #10629 of 14472 Old 09-15-2009, 07:36 AM
howie14's Avatar
Originally Posted by mjones73 View Post
Anyone having glitching issues with WJZ HD via Directv? Been watching the Ravens game and it's been dropping out and glitching the whole game.
I was at the game and recording it OTA through my DISH DVR. The DVR's OTA tuner is pretty flaky and I lost almost the entire game due to whatever problems they were having.
howie14 is offline
post #10630 of 14472 Old 09-15-2009, 12:55 PM
hsweiss's Avatar
Anyone else lose MPT Channel 22? I'm pointed towards Baltimore TV Hill but have been able to get channel 22 with 80%+ signal on the backside of my antenna (only 6 miles away due south). The last couple of weeks I've noticed that their signal strength had degraded a bit but I had no reception problems. Last night (Mon) they were completely gone - 22.1, 22.2, and 22.3. I could still receive 26.[1-4], 14.1, 50.[1-2] all from DC on the backside of the antenna. I rescanned a couple of times too - nothing. Have they jacked around with their xmission pattern?
hsweiss is offline
post #10631 of 14472 Old 09-15-2009, 01:03 PM
Jim Miller's Avatar
My daughter is less than 2 miles from the tower and occasionally loses all signal. I think they've got a screw loose.
jtm
Jim Miller is offline
post #10632 of 14472 Old 09-15-2009, 01:47 PM
Digital Rules's Avatar
Quoted: 112 Post(s)
Liked: 24
Originally Posted by hsweiss View Post
Anyone else lose MPT Channel 22? I'm pointed towards Baltimore TV Hill . . .
You may have been experiencing tropo activity from RF channel 42 in Philadelphia last night. The activity was moderate last night.
Digital Rules is offline
post #10633 of 14472 Old 09-15-2009, 04:11 PM
It was HD on WUSA today. Hard to believe that's the same tiny studio that Late Night with Conan O'Brien used for 16 years. "Oprah money" indeed.
post #10634 of 14472 Old 09-15-2009, 05:46 PM
hokiefan's Avatar
I'm looking for anyone that lives out in haymarket/manassas/leesburg that is picking up baltimore stations. In particular, WJZ. What type of antenna/amp are you using? Thanks!
hokiefan is offline
post #10635 of 14472 Old 09-15-2009, 06:23 PM
Belcherwm's Avatar
Here's a post from a couple months ago.
http://www.avsforum.com/avs-vb/showt...2#post16664202
Belcherwm is offline
post #10636 of 14472 Old 09-15-2009, 07:15 PM
Quoted: 112 Post(s)
Liked: 24
I've put up 2 antenna systems recently in the Manassas, & Leesburg areas. The Baltimore stations come in much better in Leesburg than in Manassas, but neither location provided "reliable" digital reception. The heavy air traffic from Dulles airport is a deal breaker in most of these areas.
WJZ & WBAL are not even 100% in Fairfax or Arlington using a Winegard YA-1713. You'll see an occasional hiccup that you never see on the Baltimore UHF stations. And you can forget watching them with a thunderstorm within 20-30 miles. Unfortunately, the FCC didn't do enough research on this VHF thing.
post #10637 of 14472 Old 09-15-2009, 07:51 PM
hsweiss's Avatar
Seems that might have been it - I rescanned again tonight and Channel 22.[1-3] MPT is back on the air.
hsweiss is offline
post #10638 of 14472 Old 09-16-2009, 06:45 AM
hsweiss's Avatar
jtm
I've never had drop outs from Channel 22 before - they have been rock solid. I wonder if your daughter is suffering from signal overload (I had that problem after WJZ 13 changed to their directional antennas).
hsweiss is offline
post #10639 of 14472 Old 09-16-2009, 05:21 PM
Looks like WUSA is finally doing 16:9 promos for local programming and news. Unfortunately, like WTTG, they're in SD. At least the one I saw for Dr. Oz and the afternoon programming block was. Couldn't tell if the bump for the 11pm weather forecast was or not.
post #10640 of 14472 Old 09-16-2009, 06:15 PM
djp952's Avatar
@Jim Miller:
FWIW, 22 (42) is rediculously powerful from here in Elkridge. It's the only DTV channel I can tune by simply putting my finger on the coax jack (no lie). I would seriously consider overload (as per hsweiss) given her distance from the tower.
Time will probably tell on this one. Tropo comes and goes, but as we move into the winter months, if the issue starts to get worse and worse, overload becomes more and more likely.
You could contact WMPT to see if they would hook you up with a single channel attenuator for 42 given your proximity, but be advised that you'll almost undoubtedly lose 54 (40) and 24 (41) from Baltimore, if those are a concern. I believe Channel Master's JoinTennas have been discontinued, but if in the end you feel that a single channel injector/attenuator is in order, a company named TinLee still makes them. Probably more $$ than it's worth.
$0.02
edit: I didn't even ask ... are you using an amplifier?
djp952 is offline
post #10641 of 14472 Old 09-17-2009, 04:39 AM
Big J's Avatar
Anyone else have Mont. County Comcast play peek-a-boo with some of the locals yesterday? I seem to have lost some of them again. Have they moved them (again)?
J
Big J is offline
post #10642 of 14472 Old 09-17-2009, 05:51 AM
Quoted: 57 Post(s)
Liked: 104
WBAL had shown a promo in at least widescreen. False advertising.
post #10643 of 14472 Old 09-17-2009, 10:32 AM
Knicks_Fan's Avatar
Both Wheel and Jeopardy! were in SD last night on WJLA, but the Leon Harris news special at 8pm (Pre-empting a repeat of Wipeout) was in HD!
Knicks_Fan is offline
post #10644 of 14472 Old 09-17-2009, 10:44 AM
VARTV's Avatar
Quoted: 71 Post(s)
I thought Wipeout was new?
Robert F Corbin
VARTV is offline
post #10645 of 14472 Old 09-17-2009, 11:11 AM
UHD Addict
aaronwt's Avatar
Quoted: 5476 Post(s)
Liked: 3306
I know it ran earlier in the summer. They had ads for it at every movie I saw at the theater.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is online now
post #10646 of 14472 Old 09-17-2009, 01:18 PM
Not for us. Kudos to WJLA for picking the timeslot of ABC's only summer hit to air some time-wasting news special on healthcare reform.
post #10647 of 14472 Old 09-17-2009, 05:48 PM
jgantert's Avatar
They're going to air that episode of Wipeout again, don't worry. It's on at like 2am some evening. Check your Tivo season pass. Probably won't be in HD tho.
jgantert is offline
post #10648 of 14472 Old 09-17-2009, 06:13 PM
lax01's Avatar
Anybody getting Channel Available Shortly on FOX-HD in Montgomery County? First episode of Fringe and I'm watching in SD...so lame
Josh
PSN: lax01
lax01 is offline
post #10649 of 14472 Old 09-17-2009, 07:55 PM
UHD Addict
aaronwt's Avatar
Liked: 3306
Fringe was good tonight!
post #10650 of 14472 Old 09-18-2009, 06:26 AM
robertforsyth's Avatar
Following-up on my earlier posts, WJLA was unable to locate a suitable UHF channel in and around Washington, DC. WJLA is now focused on solving, if at all possible, the myriad of reception problems that have arisen on high-band VHF channels since the DTV transition.
As part of this effort, WJLA recently received temporary authority from the FCC to increase WJLA's ERP. The FCC approved this increase to allow WJLA to conduct testing to determine if the resulting stronger signals overcome any of the reception problems.
We encourage all to conduct their own tests and to share your results on this page. Your work will be instrumental in determining whether the FCC should approve power increases for high-band VHF stations.
- Robert
Robert Forsyth
Director, Digital Media
WJLA-TV
robertforsyth is offline
