Washington, DC / Baltimore, MD - HDTV - Page 461 - AVS Forum | Home Theater Discussions And Reviews
 50Likes
post #13801 of 14516 Old 06-14-2014, 08:30 AM
nottenst's Avatar
Quoted: 68 Post(s)
Liked: 45
I called again this morning and the tech person tried to get the HD channels authorized on my box. He said it could take anywhere up to an hour and a half for it to work. I don't know if what he did actually succeeded because I was called by someone who heard about my problem from writing to We_Can_Help@cable.comcast.com. This was about a 40 minutes after the end of my previous call. After less than 2 minutes after he called the HD channels were now working. I think it was him and not the delayed result from the earlier phone call, but I can't be certain. In any case, I have the channels. Thanks for the help.
TheKrell likes this.
nottenst is offline
post #13802 of 14516 Old 06-14-2014, 11:06 AM
PaulGo's Avatar
Quoted: 175 Post(s)
Liked: 95
I agree it was the call from we can help. For a HD DTA the loading of the channel info is almost instantaneous.
nottenst likes this.
PaulGo is online now
post #13803 of 14516 Old 06-14-2014, 08:22 PM
Frankie20's Avatar
What happened to WZDC 25? Since Friday I can no longer receive the channel.
Is anyone else have problems with WZDC?
Frankie20 is offline
post #13804 of 14516 Old 06-14-2014, 10:07 PM - Thread Starter
AntAltMike's Avatar
Quoted: 138 Post(s)
Liked: 63
I've lost it here in Berwyn Heights, just to the east of College Park. I have a chimney-mounted Winegard directional antenna and it is always reliable here.
AntAltMike is offline
post #13805 of 14516 Old 06-15-2014, 04:07 AM
Trip in VA's Avatar
Quoted: 800 Post(s)
Liked: 239
Send a message via AIM to Trip in VA
Looks like it went out around 1PM on Friday the 13th. http://www.rabbitears.info/tvdx/sign...tuner1/WZDC-CD
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is offline
post #13806 of 14516 Old 06-23-2014, 10:39 PM
dtv_junkie87's Avatar
Quoted: 40 Post(s)
Liked: 25
WNUV, one of the three Sinclair stations in its home market of Baltimore, to get getTV on a subchannel soon:
http://www.tvtechnology.com/news/008...tations/271009
Now the Baltimore/DC area will have TWO getTV affiliates! Who says you can't have too much of a good thing?
dtv_junkie87
dtv_junkie87 is offline
post #13807 of 14516 Old 07-03-2014, 02:50 PM
StevenJB's Avatar
dtv_junkie87
Channel 54-2, WNUV-DT, GET-TV became operational on or about 01 Jul 14.
StevenJB is offline
post #13808 of 14516 Old 07-04-2014, 07:50 PM - Thread Starter
AntAltMike's Avatar
Quoted: 138 Post(s)
Liked: 63
It's schedule information is incorrect at the moment. It indicated that Crash Landing would end at 9:55 PM this evening, when in fact it ended at 10:35, and it said it would be followed by Crime and Punishment, when it in fact was followed by Hellcats of the Navy. WFDC 14.3 has the content and time correct. The mismatch of time and content could be due to the Nancy Davis (Reagan) marathon, if it is superseding the previously scheduled programming.
post #13809 of 14516 Old 07-12-2014, 06:42 PM
mkfs's Avatar
Chan 20's encoder seems to be SOL tonight. No program guide.....
mkfs is offline
post #13810 of 14516 Old 07-17-2014, 05:55 AM
Trip in VA's Avatar
Quoted: 800 Post(s)
Liked: 239
Wow.
So I moved two streets over to a new house which I have bought, and I now have better reception with the temporary indoor antenna than I did with the outdoor antenna/amp at the old place. And I lost elevation in the move. I hadn't seen WMDO-LD for more than a few minutes in the past year, now it's solid. The only stations I lost were WNVT and WUTB, and WUTB wasn't solid at the old location.
Going to stick an antenna in the attic and see if it grabs WWPX, WUTB, and WNVT, and if it stabilizes WJZ. If it does those things, I will just leave it there.
- Trip
N4MJC
RabbitEars
post #13811 of 14516 Old 07-21-2014, 02:24 PM
PaulGo's Avatar
Quoted: 175 Post(s)
Liked: 95
Comcast has not encrypted all channels in Montgomery County, MD.
post #13812 of 14516 Old 08-03-2014, 08:47 AM
StantonGuy's Avatar
I cut the Comcast cord again--the TV service was fine, but the internet was completely unreliable. I plugged the rooftop antenna back into the old tube TV via the digital converter box and wasn't that happy with the number of channels. Then I remembered I had a cheap on-hand splitter on the cable to run one to the bedroom and one to the living room so I removed the splitter. Wow!
My current channel list:
2
4
5
7
9
11
13
14
20
22
23
25
26
30 (only .1-.6, may have been because I scanned late last night)
32
45
47
49 (.1-.4, weird ones when there)
50
54
58
60 & 66 both but the same.
Location http://www.tvfool.com/?option=com_wr...e1c67875a23269
Omnidirectional MS-1000 antenna attached to the chimney on the roof.
Very happy. Now I realize I need to get a better splitter to make the same channels available throughout the house. Channel Master CM3418 or would the 8-way splitter on Denny's site be sufficient. Also considering getting a 16-way splitter to reach all of the runs (or most of them anyway) and just capping the ends at the wall where not being used.
Picking up this conversation that was interrupted with two years of Comcast.
Originally Posted by CLT OTA Nut View Post
Quote:Originally Posted by StantonGuy
I'm running a lot of cables too (two to each room, one each side, or more in the living room and to the basement apartment so maybe 16 locations when all is said and done--though obviously not watching TV in all 16 at one time).
If only DC, I still don't know about a 16 way unamplified splitter, but you should be alright.
You might want to checkout a 2 way splitter off of the antenna going to 2 CM 3418 which are 8 way amplified "splitters" or distribution amps... Depending on how long the runs are this may help, and you may be able to have everything live at once.
You may still overload the RF with any amplification...
Are all 16 feeds going to a central junction?
Yes, if I understand it right, all 16 feeds would be to a central junction: antenna on the roof down to central location then dispersed from there throughout the house.
So should I go with an unamplified 8 or 16-way splitter, a CM3418 (or two) or something else?
Originally Posted by AntAltMike View Post
Digital broadcast frequencies only go up to 698 MHz, and in this market, the highest frequency used is 692 MHz. While many old cable TV systems only carried channels up to 450 MHz, splitters rated to that frequency are very uncommon, as the previous incarnation of splitters were rated to 890 MHz (UHF channel 83). Splitters commonly rated to 806 MHz (UHF channel 69), 864 MHz (cable channel 135) or 890 MHz are all ideal for off-air use.
Mike, do you recommend a specific splitter?
Thanks for all of the help!
StantonGuy is offline
post #13813 of 14516 Old 08-07-2014, 07:28 PM - Thread Starter
AntAltMike's Avatar
Quoted: 138 Post(s)
Liked: 63
I just checked the Redskins/Patriots preseason game on WRC, and at 10:25 PM, just after the game ended but still part of the broadcast, it was being televised in 1080i. I thought that for the last free few years, Comcast cable had the exclusive on the Redskins preseason HDTV distribution.
post #13814 of 14516 Old 08-07-2014, 08:50 PM
carltonrice's Avatar
Quoted: 37 Post(s)
WMAR-DT Flashing Problem
I was watching WMAR-DT during ABC's primetime this evening and there was a problem with almost constant intermittent flashing going on. Seemed to be there whether or not they were doing the ABC feed or the local feed. Didn't see anything like that on any other station, so I don't think it's my reception or HDTV.
Anybody else seeing this problem?
carltonrice is offline
post #13815 of 14516 Old 08-08-2014, 04:48 AM
VARTV's Avatar
Quoted: 76 Post(s)
Liked: 29
I just checked the Redskins/Patriots preseason game on WRC, and at 10:25 PM, just after the game ended but still part of the broadcast, it was being televised in 1080i. I thought that for the last free years, Comcast cable had the exclusive on the Redskins preseason HDTV distribution.
They changed it for this season. Our local station also showed in HD for the first time...
Robert F Corbin
VARTV.com | Virginia Media News & Information
email: editor@VARTV.com
facebook: facebook.com/VARTV
twitter: twitter.com/VARTV
linkedin: linkedin.com/in/VARTV
google+: plus.google.com
pinterest: pinterest.com/VARTV
VARTV is offline
post #13816 of 14516 Old 08-12-2014, 12:25 PM - Thread Starter
AntAltMike's Avatar
Quoted: 138 Post(s)
Liked: 63
The time displayed on my Seki 32" HDTV is 40 minutes fast on WZDC-CD 25-1 and 15 minutes fast on WFDC-DT 14.1, and has been for at least several weeks. Is anyone else experiencing this problem?
post #13817 of 14516 Old 08-12-2014, 12:41 PM - Thread Starter
AntAltMike's Avatar
Quoted: 138 Post(s)
Liked: 63
The WFDC subchannel names now read 14.2 GET-TV, which presently displays a blank screen, and 14.3 now reads GRITtv, but that sub-channel is still carrying GET-TV programming. Grittv has been mentioned recently in other Local HDTV Info and Reception subforums.
post #13818 of 14516 Old 08-12-2014, 02:28 PM
dleedlee's Avatar
Quoted: 49 Post(s)
Yep, 14.1, 14.3 are 15 minutes fast on my iView3500STB, wreaking havoc on my timed recordings if they are the last (off) or current (on) channel.
dleedlee is offline
post #13819 of 14516 Old 08-12-2014, 05:11 PM - Thread Starter
AntAltMike's Avatar
Quoted: 138 Post(s)
Liked: 63
WFDC subchannel 14.4 is now labeled Escape, but it, too, displays just a blank screen. Escape has been referenced in other Local HDTV Info and Reception subforums here in conjunction with the addition of GRITtv.
post #13820 of 14516 Old 08-12-2014, 05:37 PM
dleedlee's Avatar
Quoted: 49 Post(s)
"New national digital networks Escape and Grit will flip the on switch August 18 at 12 Noon Eastern."
http://classictvblog.com/tag/grit-tv-network/
dleedlee is offline
post #13821 of 14516 Old 08-12-2014, 05:47 PM - Thread Starter
AntAltMike's Avatar
Quoted: 138 Post(s)
Liked: 63
From the linked page:
Escape will air female-skewed movies and off-cable true crime series.
Oh, boy! Another Lifetime Movies channel!
Grit will program action and adventure movies skewing to men... Grit kicks things off with the classic Gary Cooper western High Noon.
I haven't seen High Noon since, since... uh, since it aired last week on 20.2 Movies!
post #13822 of 14516 Old 08-12-2014, 11:36 PM
mkfs's Avatar
With gender appropriate ads on each, of course. You gotta know those ZuperBaiterProstrate spiels will be out in farce err force.
mkfs is offline
post #13823 of 14516 Old 08-16-2014, 12:34 AM - Thread Starter
AntAltMike's Avatar
Quoted: 138 Post(s)
Liked: 63
Promos are now up on 14.3 Grittv and 14.4 Escape. Gettv has been renumbered to 14-2.
post #13824 of 14516 Old 08-18-2014, 01:21 PM - Thread Starter
AntAltMike's Avatar
Quoted: 138 Post(s)
Liked: 63
I have Spanish audio on both the English and Spanish audio selections on 45.1's NFL football game last night at 11:00 PM.
14.3 Grittv and 14.4 Escape came on as scheduled, but the clock didn't get reset. it is still at least fifteen minutes fast.
post #13825 of 14516 Old 08-23-2014, 07:09 PM - Thread Starter
AntAltMike's Avatar
Quoted: 138 Post(s)
Liked: 63
Redskins/Ravens were on 4.1 (1080i), 7.1 (720p) and 54.1. How did they come to be carried by two channels in the same DMA?
post #13826 of 14516 Old 08-27-2014, 10:43 AM
CycloneGT's Avatar
Quoted: 69 Post(s)
Liked: 46
Guessing here
I'm going to guess and say that WRC has the rights to Redskins games in the DC market, and WJLA has Ravens game rights in the DC market.
Perfect storm of pre-season scheduling. Likley not worth fighting over so it aired on both channels.
CycloneGT is offline
post #13827 of 14516 Old 08-28-2014, 04:40 AM
nottenst's Avatar
Quoted: 68 Post(s)
Liked: 45
And tonight they are both showing pre-season games of the Redskins and Ravens - only this time it is two different games.
nottenst is offline
post #13828 of 14516 Old 08-31-2014, 10:57 AM
pamajestic's Avatar
I now see Bounce TV on WMAR 2.3 and still on WUTB. The same network on two channels in the same market?
pamajestic is offline
post #13829 of 14516 Old 08-31-2014, 06:52 PM - Thread Starter
AntAltMike's Avatar
Quoted: 138 Post(s)
Liked: 63
I'm seeing it too. FWIW, WMAR has the more powerful transmitter and wider coverage, but since its coverage totally overlaps WUTBs, then I will speculate that WUTB's affiliation will end soon though I have not as yet found either station's immediate sub-channel plans.
post #13830 of 14516 Old 08-31-2014, 07:26 PM - Thread Starter
AntAltMike's Avatar
Quoted: 138 Post(s)
Liked: 63
I just attempted to send a query to WUTB viafeature on their website but got an invalid recipient rejection notice twice. I did successfully send a similar query to WMAR and await their response.
